G-code
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications as well. See also on Wikipedia's G-code article.
There are a few different ways to prepare G-code for a printer. One method would be to use a slicing program such as Slic3r, Skeinforge or Cura. These programs import a CAD model, slice it into layers, and output the G-code required to print each layer. Slicers are the easiest way to go from a 3D model to a printed part, however the user sacrifices some flexibility when using them. Another option for G-code generation is to use a lower level library like mecode. Libraries like mecode give you precise control over the tool path, and thus are useful if you have a complex print that is not suitable for naive slicing. The final option is to just write the G-code yourself. This may be the best choice if you just need to run a few test lines while calibrating your printer.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years. This particular page is the master page for RepRap. Nowhere in here should the same code be used for two different things; there are always more numbers to use... The rule is: add your new code here, then implement it.
Unfortunately human nature being what it is, the best procedures aren't always followed, so some multiple uses of the same code exist. The rule which should be followed is that later appearances of a code on this page (later than the original use of a code), are deprecated and should be changed, unless there is a good technical reason (like the general G-Code standard) why a later instance should be preferred. Note that the key date is appearance here, not date of implementation.
- 1 Introduction
- 2 Fields
- 3 Case sensitivity
- 4 Quoted strings
- 5 Using expressions in parameters
- 6 Comments
- 7 Special fields
- 8 Checking
- 9 Conditional Execution and Loops
- 10 Buffering
- 11 G-commands
- 11.1 G0 & G1: Move
- 11.2 G2 & G3: Controlled Arc Move
- 11.3 G4: Dwell
- 11.4 G6: Direct Stepper Move
- 11.5 G10: Set tool Offset and/or workplace coordinates and/or tool temperatures
- 11.6 G10: Retract
- 11.7 G11: Unretract
- 11.8 G12: Clean Tool
- 11.9 G17..19: Plane Selection (CNC specific)
- 11.10 G20: Set Units to Inches
- 11.11 G21: Set Units to Millimeters
- 11.12 G22: Firmware Retract
- 11.13 G23: Firmware Recover
- 11.14 G26: Mesh Validation Pattern
- 11.15 G27: Park toolhead
- 11.16 G28: Move to Origin (Home)
- 11.17 G29: Detailed Z-Probe
- 11.18 G29.1: Set Z probe head offset
- 11.19 G29.2: Set Z probe head offset calculated from toolhead position
- 11.20 G30: Single Z-Probe
- 11.21 G31: Set or Report Current Probe status
- 11.22 G31: Dock Z Probe sled
- 11.23 G32: Probe Z and calculate Z plane
- 11.24 G32: Undock Z Probe sled
- 11.25 G33: Firmware dependent
- 11.26 G34: Z Stepper Auto-Align
- 11.27 G34: Calculate Delta Height from toolhead position (DELTA)
- 11.28 G38.x Straight Probe (CNC specific)
- 11.29 G40: Compensation Off (CNC specific)
- 11.30 G42: Move to Grid Point
- 11.31 G53..59: Coordinate System Select (CNC specific)
- 11.32 G60: save current position to slot
- 11.33 G61: Apply/restore saved coordinates to the active extruder.
- 11.34 G75: Print temperature interpolation
- 11.35 G76: PINDA probe temperature calibration
- 11.36 G80: Cancel Canned Cycle (CNC specific)
- 11.37 G80: Mesh-based Z probe
- 11.38 G81: Mesh bed leveling status
- 11.39 G82: Single Z probe at current location
- 11.40 G83: Babystep in Z and store to EEPROM
- 11.41 G84: UNDO Babystep Z (move Z axis back)
- 11.42 G85: Pick best babystep
- 11.43 G86: Disable babystep correction after home
- 11.44 G87: Enable babystep correction after home
- 11.45 G88: Reserved
- 11.46 G90: Set to Absolute Positioning
- 11.47 G91: Set to Relative Positioning
- 11.48 G92: Set Position
- 11.49 G93: Feed Rate Mode (Inverse Time Mode) (CNC specific)
- 11.50 G94: Feed Rate Mode (Units per Minute) (CNC specific)
- 11.51 G98: Activate farm mode
- 11.52 G99: Deactivate farm mode
- 11.53 G100: Calibrate floor or rod radius
- 11.54 G130: Set digital potentiometer value
- 11.55 G131: Remove offset
- 11.56 G132: Calibrate endstop offsets
- 11.57 G133: Measure steps to top
- 11.58 G161: Home axes to minimum
- 11.59 G162: Home axes to maximum
- 11.60 G425: Perform auto-calibration with calibration cube
- 12 M-commands
- 12.1 M0: Stop or Unconditional stop
- 12.2 M1: Sleep or Conditional stop
- 12.3 M2: Program End
- 12.4 M3: Spindle On, Clockwise (CNC specific)
- 12.5 M4: Spindle On, Counter-Clockwise (CNC specific)
- 12.6 M5: Spindle Off (CNC specific)
- 12.7 M6: Tool change
- 12.8 M7: Mist Coolant On (CNC specific)
- 12.9 M8: Flood Coolant On (CNC specific)
- 12.10 M9: Coolant Off (CNC specific)
- 12.11 M10: Vacuum On (CNC specific)
- 12.12 M11: Vacuum Off (CNC specific)
- 12.13 M13: Spindle on (clockwise rotation) and coolant on (flood)
- 12.14 M16: Expected Printer Check
- 12.15 M17: Enable/Power all stepper motors
- 12.16 M18: Disable all stepper motors
- 12.17 M20: List SD card
- 12.18 M21: Initialize SD card
- 12.19 M22: Release SD card
- 12.20 M23: Select SD file
- 12.21 M24: Start/resume SD print
- 12.22 M25: Pause SD print
- 12.23 M26: Set SD position
- 12.24 M27: Report SD print status
- 12.25 M28: Begin write to SD card
- 12.26 M29: Stop writing to SD card
- 12.27 M30: Delete a file on the SD card
- 12.28 M31: Output time since last M109 or SD card start to serial
- 12.29 M32: Select file and start SD print
- 12.30 M33: Get the long name for an SD card file or folder
- 12.31 M33: Stop and Close File and save restart.gcode
- 12.32 M34: Set SD file sorting options
- 12.33 M35: Upload firmware NEXTION from SD
- 12.34 M36: Return file information
- 12.35 M37: Simulation mode
- 12.36 M38 Compute SHA1 hash of target file
- 12.37 M39 Report SD card information
- 12.38 M40: Eject
- 12.39 M41: Loop
- 12.40 M42: Switch I/O pin
- 12.41 M43: Stand by on material exhausted
- 12.42 M43: Pin report and debug
- 12.43 M44: Codes debug - report codes available
- 12.44 M44: Reset the bed skew and offset calibration
- 12.45 M45: Bed skew and offset with manual Z up
- 12.46 M46: Show the assigned IP address
- 12.47 M47: Show end stops dialog on the display
- 12.48 M48: Measure Z-Probe repeatability
- 12.49 M49: Set G26 debug flag
- 12.50 M70: Display message
- 12.51 M72: Play a tone or song
- 12.52 M73: Set/Get build percentage
- 12.53 M75: Start the print job timer
- 12.54 M76: Pause the print job timer
- 12.55 M77: Stop the print job timer
- 12.56 M78: Show statistical information about the print jobs
- 12.57 M80: ATX Power On
- 12.58 M81: ATX Power Off
- 12.59 M82: Set extruder to absolute mode
- 12.60 M83: Set extruder to relative mode
- 12.61 M84: Stop idle hold
- 12.62 M85: Set Inactivity Shutdown Timer
- 12.63 M86: Set Safety Timer expiration time
- 12.64 M87: Cancel Safety Timer
- 12.65 M92: Set axis_steps_per_unit
- 12.66 M93: Send axis_steps_per_unit
- 12.67 M98: Call Macro/Subprogram
- 12.68 M99: Return from Macro/Subprogram
- 12.69 M101: Turn extruder 1 on (Forward), Undo Retraction
- 12.70 M102: Turn extruder 1 on (Reverse)
- 12.71 M103: Turn all extruders off, Extruder Retraction
- 12.72 M104: Set Extruder Temperature
- 12.73 M105: Get Extruder Temperature
- 12.74 M106: Fan On
- 12.75 M107: Fan Off
- 12.76 M108: Cancel Heating
- 12.77 M108: Set Extruder Speed (BFB)
- 12.78 M109: Set Extruder Temperature and Wait
- 12.79 M110: Set Current Line Number
- 12.80 M111: Set Debug Level
- 12.81 M112: Full (Emergency) Stop
- 12.82 M113: Set Extruder PWM
- 12.83 M113: Host Keepalive
- 12.84 M114: Get Current Position
- 12.85 M115: Get Firmware Version and Capabilities
- 12.86 M116: Wait
- 12.87 M117: Get Zero Position
- 12.88 M117: Display Message
- 12.89 M118: Echo message on host
- 12.90 M118: Negotiate Features
- 12.91 M119: Get Endstop Status
- 12.92 M120: Push
- 12.93 M121: Pop
- 12.94 M120: Enable endstop detection
- 12.95 M121: Disable endstop detection
- 12.96 M122: Firmware dependent
- 12.97 M123: Firmware dependent
- 12.98 M124: Firmware dependent
- 12.99 M126: Open Valve
- 12.100 M127: Close Valve
- 12.101 M128: Extruder Pressure PWM
- 12.102 M129: Extruder pressure off
- 12.103 M130: Set PID P value
- 12.104 M131: Set PID I value
- 12.105 M132: Set PID D value
- 12.106 M133: Set PID I limit value
- 12.107 M134: Write PID values to EEPROM
- 12.108 M135: Set PID sample interval
- 12.109 M136: Print PID settings to host
- 12.110 M140: Set Bed Temperature (Fast)
- 12.111 M141: Set Chamber Temperature (Fast)
- 12.112 M142: Firmware dependent
- 12.113 M143: Maximum heater temperature
- 12.114 M144: Bed Standby
- 12.115 M146: Set Chamber Humidity
- 12.116 M149: Set temperature units
- 12.117 M150: Set LED color
- 12.118 M154: Auto Report Position
- 12.119 M155: Automatically send temperatures
- 12.120 M160: Number of mixed materials
- 12.121 M163: Set weight of mixed material
- 12.122 M164: Store weights
- 12.123 M165: Set multiple mix weights
- 12.124 M190: Wait for bed temperature to reach target temp
- 12.125 M191: Wait for chamber temperature to reach target temp
- 12.126 M192: Wait for Probe Temperature
- 12.127 M200: Set filament diameter
- 12.128 M201: Set max acceleration
- 12.129 M202: Set max travel acceleration
- 12.130 M203: Firmware dependent
- 12.131 M204: Firmware dependent
- 12.132 M205: Firmware dependent
- 12.133 M206: Firmware dependent
- 12.134 M207: Firmware dependent
- 12.135 M208: Firmware dependent
- 12.136 M209: Enable automatic retract
- 12.137 M210: Set homing feedrates
- 12.138 M211: Disable/Enable software endstops
- 12.139 M212: Set Bed Level Sensor Offset
- 12.140 M217: Toolchange Parameters
- 12.141 M218: Set Hotend Offset
- 12.142 M220: Set speed factor override percentage
- 12.143 M221: Set extrude factor override percentage
- 12.144 M220: Turn off AUX V1.0.5
- 12.145 M221: Turn on AUX V1.0.5
- 12.146 M222: Set speed of fast XY moves
- 12.147 M223: Set speed of fast Z moves
- 12.148 M224: Enable extruder during fast moves
- 12.149 M225: Disable on extruder during fast moves
- 12.150 M226: G-code Initiated Pause
- 12.151 M226: Wait for pin state
- 12.152 M227: Enable Automatic Reverse and Prime
- 12.153 M228: Disable Automatic Reverse and Prime
- 12.154 M229: Enable Automatic Reverse and Prime
- 12.155 M230: Disable / Enable Wait for Temperature Change
- 12.156 M231: Set OPS parameter
- 12.157 M232: Read and reset max. advance values
- 12.158 M240: Trigger camera
- 12.159 M240: Start conveyor belt motor / Echo off
- 12.160 M241: Stop conveyor belt motor / echo on
- 12.161 M245: Start cooler
- 12.162 M246: Stop cooler
- 12.163 M250: Set LCD contrast
- 12.164 M256: Set LCD brightness
- 12.165 M251: Measure Z steps from homing stop (Delta printers)
- 12.166 M260: i2c Send Data
- 12.167 M261: i2c Request Data
- 12.168 M280: Set servo position
- 12.169 M281: Set Servo Angles
- 12.170 M282: Detach Servo
- 12.171 M290: Babystepping
- 12.172 M291: Display message and optionally wait for response
- 12.173 M292: Acknowledge message
- 12.174 M300: Play beep sound
- 12.175 M301: Set PID parameters
- 12.176 M302: Allow cold extrudes
- 12.177 M303: Run PID tuning
- 12.178 M304: Set PID parameters - Bed
- 12.179 M305: Set thermistor and ADC parameters
- 12.180 M306: Set home offset calculated from toolhead position
- 12.181 M307: Set or report heating process parameters
- 12.182 M308: Set or report sensor parameters
- 12.183 M309: Set or report heater feedforward
- 12.184 M320: Activate autolevel (Repetier)
- 12.185 M321: Deactivate autolevel (Repetier)
- 12.186 M322: Reset autolevel matrix (Repetier)
- 12.187 M323: Distortion correction on/off (Repetier)
- 12.188 M340: Control the servos
- 12.189 M350: Set microstepping mode
- 12.190 M351: Toggle MS1 MS2 pins directly
- 12.191 M355: Turn case lights on/off
- 12.192 M360: Report firmware configuration
- 12.193 SCARA calibration codes (Morgan)
- 12.194 M360: Move to Theta 0 degree position
- 12.195 M361: Move to Theta 90 degree position
- 12.196 M362: Move to Psi 0 degree position
- 12.197 M363: Move to Psi 90 degree position
- 12.198 M364: Move to Psi + Theta 90 degree position
- 12.199 M365: SCARA scaling factor
- 12.200 M366: SCARA convert trim
- 12.201 M370: Morgan manual bed level - clear map
- 12.202 M371: Move to next calibration position
- 12.203 M372: Record calibration value, and move to next position
- 12.204 M373: End bed level calibration mode
- 12.205 M374: Save calibration grid
- 12.206 M375: Display matrix / Load Matrix
- 12.207 M376: Set bed compensation taper
- 12.208 M380: Activate solenoid
- 12.209 M381: Disable all solenoids
- 12.210 M400: Wait for current moves to finish
- 12.211 M401: Lower z-probe
- 12.212 M402: Raise z-probe
- 12.213 M403: Set filament type (material) for particular extruder and notify the MMU
- 12.214 M404: Filament width and nozzle diameter
- 12.215 M405: Filament Sensor on
- 12.216 M406: Filament Sensor off
- 12.217 M407: Display filament diameter
- 12.218 M408: Report JSON-style response
- 12.219 M409: Query object model
- 12.220 M410: Quick-Stop
- 12.221 M412: Disable Filament Runout Detection
- 12.222 M413: Power-Loss Recovery
- 12.223 M415: Host Rescue
- 12.224 M416: Power loss
- 12.225 M420: Set RGB Colors as PWM (MachineKit)
- 12.226 M420: Leveling On/Off/Fade (Marlin)
- 12.227 M421: Set a Mesh Bed Leveling Z coordinate
- 12.228 M425: Backlash Correction
- 12.229 M450: Report Printer Mode
- 12.230 M451: Select FFF Printer Mode
- 12.231 M452: Select Laser Printer Mode
- 12.232 M453: Select CNC Printer Mode
- 12.233 M460: Define temperature range for thermistor-controlled fan
- 12.234 M470: Create Directory on SD-Card
- 12.235 M471: Rename File/Directory on SD-Card
- 12.236 M486: Cancel Object
- 12.237 M500: Store parameters in non-volatile storage
- 12.238 M501: Read parameters from EEPROM
- 12.239 M502: Restore Default Settings
- 12.240 M503: Report Current Settings
- 12.241 M504: Validate EEPROM
- 12.242 M505: Firmware dependent
- 12.243 M509: Force language selection
- 12.244 M510: Lock Machine
- 12.245 M511: Unlock Machine with Passcode
- 12.246 M512: Set Passcode
- 12.247 M524: Abort SD Printing
- 12.248 M530: Enable printing mode
- 12.249 M531: Set print name
- 12.250 M532: Set print progress
- 12.251 M540: Set MAC address
- 12.252 M540 in Marlin: Enable/Disable "Stop SD Print on Endstop Hit"
- 12.253 M550: Set Name
- 12.254 M551: Set Password
- 12.255 M552: Set IP address, enable/disable network interface
- 12.256 M553: Set Netmask
- 12.257 M554: Set Gateway and/or DNS server
- 12.258 M555: Set compatibility
- 12.259 M556: Axis compensation
- 12.260 M557: Set Z probe point or define probing grid
- 12.261 M558: Set Z probe type
- 12.262 M559: Upload configuration file
- 12.263 M560: Upload web page file
- 12.264 M561: Set Identity Transform
- 12.265 M562: Reset temperature fault
- 12.266 M563: Define or remove a tool
- 12.267 M564: Limit axes
- 12.268 M565: Set Z probe offset
- 12.269 M566: Set allowable instantaneous speed change
- 12.270 M567: Set tool mix ratios
- 12.271 M568: Tool settings
- 12.272 M568: Turn off/on tool mix ratios (obsolete meaning in old RepRapFirmware versions)
- 12.273 M569: Stepper driver control
- 12.274 M569.1: Stepper driver closed loop control
- 12.275 M569.2: Read or write any stepper driver register
- 12.276 M569.3: Read Motor Driver Encoder
- 12.277 M569.4: Set Motor Driver Torque Mode
- 12.278 M569.5: Collect Data from Closed-loop Driver
- 12.279 M569.6: Execute Closed-loop Driver Tuning Move
- 12.280 M569.7: Configure motor brake port
- 12.281 M570: Configure heater fault detection
- 12.282 M571: Set output on extrude
- 12.283 M572: Set or report extruder pressure advance
- 12.284 M573: Report heater PWM
- 12.285 M574: Set endstop configuration
- 12.286 M575: Set serial comms parameters
- 12.287 M576: Set SPI comms parameters
- 12.288 M577: Wait until endstop is triggered
- 12.289 M578: Fire inkjet bits
- 12.290 M579: Scale Cartesian axes
- 12.291 M580: Select Roland
- 12.292 M581: Configure external trigger
- 12.293 M582: Check external trigger
- 12.294 M584: Set drive mapping
- 12.295 M585: Probe Tool
- 12.296 M586: Configure network protocols
- 12.297 M587: Store WiFi host network in list, or list stored networks
- 12.298 M588: Forget WiFi host network
- 12.299 M589: Configure access point parameters
- 12.300 M590: Report current tool type and index
- 12.301 M591: Configure filament monitoring
- 12.302 M592: Configure nonlinear extrusion
- 12.303 M593: Configure Dynamic Acceleration Adjustment
- 12.304 M594: Enter/Leave Height Following mode
- 12.305 M595: Set movement queue length
- 12.306 M600: Set line cross section
- 12.307 M600: Filament change pause
- 12.308 M601: Pause print
- 12.309 M602: Resume print
- 12.310 M603: Stop print (Prusa i3)
- 12.311 M603: Configure Filament Change
- 12.312 M605: Set dual x-carriage movement mode
- 12.313 M650: Set peel move parameters
- 12.314 M651: Execute peel move
- 12.315 M665: Set delta configuration
- 12.316 M666: Set delta endstop adjustment
- 12.317 M667: Select CoreXY mode
- 12.318 M668: Set Z-offset compensations polynomial
- 12.319 M669: Set kinematics type and kinematics parameters
- 12.320 M670: Set IO port bit mapping
- 12.321 M671: Define positions of Z leadscrews or bed leveling screws
- 12.322 M672: Program Z probe
- 12.323 M673: Align plane on rotary axis
- 12.324 M674: Set Z to center point
- 12.325 M675: Find center of cavity
- 12.326 M700: Level plate
- 12.327 M701: Load filament
- 12.328 M702: Unload filament
- 12.329 M703: Configure Filament
- 12.330 M710: Firmware dependent
- 12.331 M750: Enable 3D scanner extension
- 12.332 M751: Register 3D scanner extension over USB
- 12.333 M752: Start 3D scan
- 12.334 M753: Cancel current 3D scanner action
- 12.335 M754: Calibrate 3D scanner
- 12.336 M755: Set alignment mode for 3D scanner
- 12.337 M756: Shutdown 3D scanner
- 12.338 M800: Fire start print procedure
- 12.339 M801: Fire end print procedure
- 12.340 M808: Set or Goto Repeat Marker
- 12.341 M851: Set Z-Probe Offset
- 12.342 M860 Wait for Probe Temperature
- 12.343 M861 Set Probe Thermal Compensation
- 12.344 M862: Print checking
- 12.345 M871: PTC Configuration
- 12.346 M876: Dialog handling
- 12.347 M890 Run User Gcode
- 12.348 M900 Set Linear Advance Scaling Factors
- 12.349 M905: Set local date and time
- 12.350 M906: Set motor currents
- 12.351 M907: Set digital trimpot motor
- 12.352 M908: Control digital trimpot directly
- 12.353 M909: Set microstepping
- 12.354 M910: Set decay mode
- 12.355 M910: TMC2130 init
- 12.356 M911: Configure auto save on loss of power ("power panic")
- 12.357 M911: Set TMC2130 holding currents
- 12.358 M912: Set electronics temperature monitor adjustment
- 12.359 M912: Set TMC2130 running currents
- 12.360 M913: Set motor percentage of normal current
- 12.361 M913: Print TMC2130 currents
- 12.362 M914: Set/Get Expansion Voltage Level Translator
- 12.363 M914: Set TMC2130 normal mode
- 12.364 M915: Configure motor stall detection
- 12.365 M915: Set TMC2130 silent mode
- 12.366 M916: Resume print after power failure
- 12.367 M916: Set TMC2130 Stallguard sensitivity threshold
- 12.368 M917: Set motor standstill current reduction
- 12.369 M917: Set TMC2130 PWM amplitude offset (pwm_ampl)
- 12.370 M918: Configure direct-connect display
- 12.371 M918: Set TMC2130 PWM amplitude gradient (pwm_grad)
- 12.372 M928: Start SD logging
- 12.373 M929: Start/stop event logging to SD card
- 12.374 M950: Create heater, fan or GPIO/servo device
- 12.375 M951: Set height following mode parameters
- 12.376 M952: Set CAN expansion board address and/or normal data rate
- 12.377 M953: Set CAN-FD bus fast data rate
- 12.378 M954: Configure as CAN expansion board
- 12.379 M955: Configure Accelerometer
- 12.380 M956: Collect accelerometer data and write to file
- 12.381 M995: Calibrate Touch Screen
- 12.382 M997: Perform in-application firmware update
- 12.383 M998: Request resend of line
- 12.384 M999: Restart after being stopped by error
- 13 Other commands
- 13.1 G: List all G-codes
- 13.2 M: List all M-codes
- 13.3 T: Select Tool
- 13.4 D: Debug codes
- 13.4.1 D-1: Endless Loop
- 13.4.2 D0: Reset
- 13.4.3 D1: Clear EEPROM and RESET
- 13.4.4 D2: Read/Write RAM
- 13.4.5 D3: Read/Write EEPROM
- 13.4.6 D4: Read/Write PIN
- 13.4.7 D5: Read/Write FLASH
- 13.4.8 D6: Read/Write external FLASH
- 13.4.9 D7: Read/Write Bootloader
- 13.4.10 D8: Read/Write PINDA
- 13.4.11 D9: Read/Write ADC
- 13.4.12 D10: Set XYZ calibration = OK
- 13.4.13 D12: Time
- 13.4.14 D80: Bed check
- 13.4.15 D81: Bed analysis
- 13.4.16 D106: Print measured fan speed for different pwm values
- 13.4.17 D2130: Trinamic stepper controller
- 13.4.18 D9125: PAT9125 filament sensor
- 14 Proposed EEPROM configuration codes
- 15 Replies from the RepRap machine to the host computer
- 16 Proposal for sending multiple lines of G-code
- 17 Alternatives to G-code
Introduction
A typical piece of G-code as sent to a RepRap machine might look like this:
N3 T0*57 N4 G92 E0*67 N5 G28*22 N6 G1 F1500.0*82 N7 G1 X2.0 Y2.0 F3000.0*85 N8 G1 X3.0 Y3.0*33
G-code can also be stored in files on SD cards. A file containing RepRap G-code usually has the extension .g
, .gco
or .gcode
Files for BFB/RapMan have the extension .bfb
G-code stored in file or produced by a slicer might look like this:
G92 E0 G28 G1 F1500 G1 X2.0 Y2.0 F3000 G1 X3.0 Y3.0
Slicers will (optionally?) add G-code scripts to the beginning and end of their output file to perform specified actions before and/or after a print such as z-probing the build-area, heating/cooling the bed and hotend, performing ooze free "nozzle wipe" startup routine, switching system power on/off, and even "ejecting" parts. More info on the Start GCode routines and End GCode routines pages.
To find out which specific G-code(s) are implemented in any given firmware, there are little tables attached to the command descriptions, like this one:
Support | Marlin | RepRapFirmware | Repetier | Smoothie | Klipper | Prusa | MK4duo | MakerBot |
Partial | ??? | Experimental | ??? | ??? | ??? | Partial | ??? | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | |
??? | No | ??? | Yes | ??? | Yes | Automatic | Yes |
Here means:
- {{yes}}
- The G-code is fully supported by the firmware.
- {{partial}} or {{experimental}}
- There is some support for the G-code. Often it is required to check out the source code branch for the firmware (usually stored in a different branch) or to flip configuration switches on the mainboard.
- {{automatic}}
- The firmware handles this G-code automatically, so there's no need to send the command. An example is power supply on/off G-code (M80/M81) in the Teacup firmware.
- It is unknown if the firmware supports this G-code. You may want to test this yourself before using it in production.
- {{no}}
- The firmware does not support this G-code.
For the technically-minded, G-code line endings are Unix Line Endings (\n
), but will accept Windows Line Endings (\r\n
), so you should not need to worry about converting between the two, but it is best practice to use Unix Line Endings where possible.
Fields
A RepRap G-code is a list of fields that are separated by white spaces or line breaks. A field can be interpreted as a command, parameter, or for any other special purpose. It consists of one letter directly followed by a number, or can be only a stand-alone letter (Flag). The letter gives information about the meaning of the field (see the list below in this section). Numbers can be integers (128) or fractional numbers (12.42), depending on context. For example, an X coordinate can take integers (X175
) or fractionals (X17.62
), but selecting extruder number 2.76 would make no sense. In this description, the numbers in the fields are represented by nnn
as a placeholder.
In RepRapFirmware, some parameters can be followed by more than one number, with colon used to separate them. Typically this is used to specify extruder parameters, with one value provided per extruder. If only one value is provided where a value is needed for each extruder, then that value is applied to all extruders.
Letter | Meaning |
Gnnn | Standard G-code command, such as move to a point |
Mnnn | RepRap-defined command, such as turn on a cooling fan |
Tnnn | Select tool nnn. In RepRap, a tool is typically associated with a nozzle, which may be fed by one or more extruders. |
Snnn | Command parameter, such as time in seconds; temperatures; voltage to send to a motor |
Pnnn | Command parameter, such as time in milliseconds; proportional (Kp) in PID Tuning |
Xnnn | A X coordinate, usually to move to. This can be an Integer or Fractional number. |
Ynnn | A Y coordinate, usually to move to. This can be an Integer or Fractional number. |
Znnn | A Z coordinate, usually to move to. This can be an Integer or Fractional number. |
U,V,W | Additional axis coordinates (RepRapFirmware) |
Innn | Parameter - X-offset in arc move; integral (Ki) in PID Tuning |
Jnnn | Parameter - Y-offset in arc move |
Dnnn | Parameter - used for diameter; derivative (Kd) in PID Tuning |
Hnnn | Parameter - used for heater number in PID Tuning |
Fnnn | Feedrate in mm per minute. (Speed of print head movement) |
Rnnn | Parameter - used for temperatures |
Qnnn | Parameter - not currently used |
Ennn | Length of extrudate. This is exactly like X, Y and Z, but for the length of filament to consume. |
Nnnn | Line number. Used to request repeat transmission in the case of communications errors. |
*nnn | Checksum. Used to check for communications errors. |
Case sensitivity
The original NIST G-code standard requires gcode interpreters to be case-insensitive, except for characters in comments. However, not all 3D printer firmwares conform to this and some recognise uppercase command letters and parameters only.
- Firmwares that are known to be case-insensitive
- RepRapFirmware version 1.19 and later (except within quoted strings)
- Firmwares that are known to be case-sensitive
- RepRapFirmware version 1.18 and earlier
Quoted strings
In RepRapFirmware, some commands support quoted strings when providing file names and other string parameters. This allows file names, WiFi passwords etc. to contain spaces, semicolons and other characters that would otherwise not be permitted. Double-quote characters are used to delimit the string, and any double-quote character within the string must be repeated.
Unfortunately, some gcode sender programs convert all characters to uppercase and don't provide any means to disable this feature. Therefore, within a quoted-string, the single-quote character is used as a flag to force the following character to lowercase. If you want to include a single quote character in the string, use two single quote characters to represent one single quote character.
Example: to add SSID MYROUTER with password ABCxyz;" 123
to the WiFi network list, use command:
M587 S"MYROUTER" P"ABCxyz;"" 123"
or if you can't send lowercase characters:
M587 S"MYROUTER" P"ABC'X'Y'Z;"" 123"
No | Yes | No | ??? | ??? | No | No | ??? | |
??? | No | ??? | No | ??? | No | No | No |
RepRapFirmware 3.1 and later allow parameter values to be computed from an expression enclosed in { }. Such an expression may include constants, values from the machine object model, operators and functions. Example:
G1 X{move.axes[0].max-5} Y{move.axes[1].min+5} F6000 ; move to 5mm short of the X and Y axis limits
See https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Use_of_expressions_within_GCode_commands for more details.
Comments
G-code comments begin at a semicolon, and end at the end of the line:
N3 T0*57 ; This is a comment N4 G92 E0*67 ; So is this N5 G28*22
Some firmwares also obey the CNC G-code standard, which is to enclose comments in round brackets. Comments of this form must start and end on the same line:
(Home some axes) G28 (here come the axes to be homed) X Y
Comments and white space will be ignored by your RepRap Printer. It's better to strip these out on the host computer before sending the G-code to your printer, as this saves bandwidth.
Special fields
N: Line number
Yes | Yes | Yes | ??? | ??? | Yes | Yes | ??? | |
??? | Yes | ??? | Yes | Yes | Yes | Yes | Yes |
- Example
N123
If checking is supported, the RepRap firmware expects line numbers to increase by 1 each line, and if that doesn't happen it is flagged as an error. But you can reset the count using M110
(see below).
*: Checksum
??? | Yes | ??? | Yes | ??? | No | Yes | No |
Example: *71
The firmware compares the checksum against a locally-computed value. If they differ, it requests a repeat transmission of the line.
Checking
- Example
N123 [...G Code in here...] *71
The RepRap firmware checks the line number and the checksum. You can leave both of these out - RepRap will still work, but it won't do checking. You have to have both or neither though. If only one appears, it produces an error.
The checksum "cs" for a G-code string "cmd" (including its line number) is computed by exor-ing the bytes in the string up to and not including the * character as follows:
int cs = 0; for(i = 0; cmd[i] != '*' && cmd[i] != NULL; i++) cs = cs ^ cmd[i]; cs &= 0xff; // Defensive programming...
RepRapFirmware 3.01 and later supports conditions and loops in GCode. Properties from the firmware object model (e.g. current position, current tool) can be included in controlling expressions. See https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands for details.
Buffering
Yes | Yes | ??? | ??? | ??? | ??? | Yes | ??? | |
Yes | ??? | ??? | Yes | ??? | Yes | Yes | Yes |
Typically, the following moving commands are buffered: G0
-G3
and G28
-G32
. The Teacup Firmware buffers also some setting commands: G20
, G21
, G90
and G91
. All other G
, M
or T
commands are not buffered.
RepRapFirmware also implements an internal queue to ensure that certain codes (like M106) are executed in the right order and not when the last move has been added to the look-ahead queue.
G-commands
G0 & G1: Move
Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | |
G0
: Rapid Move -
G1
: Linear Move
- Usage
- Parameters
- Not all parameters need to be used, but at least one has to be used
Xnnn
The position to move to on the X axisYnnn
The position to move to on the Y axisZnnn
The position to move to on the Z axisEnnn
The amount to extrude between the starting point and ending pointFnnn
The feedrate per minute of the move between the starting point and ending point (if supplied)Hnnn
(RepRapFirmware) Flag to check if an endstop was hit (H1
to check,H0
to ignore, otherHnnn
see note, default isH0
)1Rnnn
(RepRapFirmware) Restore point number 4Snnn
Laser cutter/engraver power. In RepRapFirmware, when not in laser mode S in interpreted the same as H.- Examples
G0 X12 ; move to 12mm on the X axis G0 F1500 ; Set the feedrate to 1500mm/minute G1 X90.6 Y13.8 E22.4 ; Move to 90.6mm on the X axis and 13.8mm on the Y axis while extruding 22.4mm of material
The RepRap firmware spec treats G0
and G1
as the same command, since it's just as efficient as not doing so.2
G1 F1500 ; Set feedrate to 1500mm/m G1 X50 Y25.3 E22.4 ; Move and extrude
In the above example, we first set the feedrate to 1500mm/m, then move to 50mm on X and 25.3mm on Y while extruding 22.4mm of filament between the two points.
G1 F1500 ; Feedrate 1500mm/m G1 X50 Y25.3 E22.4 F3000 ; Accelerate to 3000mm/m
However, in the above example, we set a feedrate of 1500 mm/m, then do the same move, but accelerating to 3000 mm/m. Everything stays synchronized, so extrusion accelerates right along with X and Y movement.
The RepRap spec treats the feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over the acceleration and deceleration of the printer head in a way that ensures everything moves smoothly together and the right volume of material is extruded at all points.3
To reverse the extruder by a given amount (for example to reduce its internal pressure while it does an in-air movement so that it doesn't dribble) simply use G0
or G1
to send an E
value that is less than the currently extruded length.
- Notes
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the H
parameter in this way, as damage may occur if you assume incorrectly. In RepRapFirmware, using the H1
or H2
parameter on a delta printer causes the XYZ
parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is H1. H3 may be used to measure axis lengths and H4 can be used to stop when an endstop is hit while updating the position only (H4 is supported in 3.2-b4 and later).
2In the RS274NGC Spec, G0
is Rapid Move, which was used to move between the current point in space and the new point as quickly and efficiently as possible, and G1
is Controlled Move, which was used to move between the current point in space and the new point as precise as possible. In RepRapFirmware, G1 is always a linear move but G0 may not be linear (e.g. on a SCARA machine); however a G0 move will never go below the lower of the initial and final Z height of the move.
4RepRapFirmware provides an additional 'R' parameter to tell the machine to add the coordinates of the specified restore point to all axis coordinates mentioned in the G0 or G1 command. Axes that are not mentioned in the G0 or G1 command are not moved. When a print is paused, the coordinates are saved in restore point #1. When a tool change is commenced, the coordinates are saved in restore point #2. Coordinates can also be saved in restore points explicity using the G60 command.
Yes1 | Yes | Yes | Yes | Yes3 | Yes2 | Yes | No | |
Yes | Yes | No | No | Yes | Experimental | No | Yes |
- Usage
G2 Xnnn Ynnn Innn Jnnn Ennn Fnnn
(Clockwise Arc)G3 Xnnn Ynnn Innn Jnnn Ennn Fnnn
(Counter-Clockwise Arc)- Parameters
Xnnn
The position to move to on the Y axisInnn
The point in X space from the current X position to maintain a constant distance fromJnnn
The point in Y space from the current Y position to maintain a constant distance fromEnnn
The feedrate per minute of the move between the starting point and ending point (if supplied)- Examples
G2 X90.6 Y13.8 I5 J10 E22.4
(Move in a Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
G3 X90.6 Y13.8 I5 J10 E22.4
(Move in a Counter-Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
- Notes
1In Marlin Firmware not implemented for DELTA printers.
2Prusa Firmware implements arcs only in Cartesian XY.
3On Klipper, a gcode_arcs
section must be enabled in the configuration file.
G4: Dwell
Pause the machine for a period of time.
- Parameters
Pnnn
Time to wait, in milliseconds (In Teacup, P0, wait until all previous moves are finished)Snnn
Time to wait, in seconds (Only on Repetier, Marlin, Prusa, Smoothieware, and RepRapFirmware 1.16 and later)- Example
G4 P200
On Marlin, Smoothie and RepRapFirmware, the "S" parameter will wait for seconds, while the "P" parameter will wait for milliseconds. "G4 S2" and "G4 P2000" are equivalent.
No | Use G1 S2 or G1 H2 instead | No | No | ??? | No | No | No | |
No | No | No | No | No | No | No | No |
Perform a direct, uninterpolated, and non-kinematic synchronized move of one or more steppers directly. Units may be linear (e.g., mm or inches on DELTA
) or specified in degrees (SCARA). This command is useful for initialization, diagnostics, and calibration, and should be disabled on production equipment. This type of move can be potentially dangerous, especially for deltabots, so implementations should do their best to limit movement to prevent twerking and damaging the carriage assembly.
- Parameters
Annn
Stepper A position or angleBnnn
Stepper B position or angleCnnn
Stepper C position or angleR
Relative move flag- SCARA Examples
G6 A45 ; Move SCARA A stepper to the 45° position G6 B20 R ; Move SCARA B stepper 20° counter-clockwise
- DELTA Example
G6 C10 R ; Move DELTA C carriage up by 10mm
No | Yes | No | Yes | ??? | No | No | ??? | |
??? | No | No | No | Yes | No | No | Yes |
- Usage
G10 Lnnn Pnnn Xnnn Ynnn Znnn Rnnn Snnn
1- Parameters
Pnnn
Tool numberLnnn
Offset mode 5Xnnn
X offsetYnnn
Y offsetZnnn
Z offset2U,V,W,A,B,Cnnn
other axis offsets4Rnnn
Standby temperature(s) (RepRapFirmware)Snnn
Active temperature(s) (RepRapFirmware)- Examples
G10 L1 P2 X17.8 Y-19.3 Z0.0
(sets the offset for tool 2 to the X, Y, and Z values specified)
G10 P1 R140 S205
(RepRapFirmware only - set standby and active temperatures3 for tool 1)
The precise meaning of the X, Y (and other offset) values is: with no offset this tool is at this position relative to where a tool with offset (0, 0, 0) would be. So if the tool is 10mm to the left of a zero-offset tool the X value would be -10, and so on.
The R
value is the standby temperature in oC that will be used for the tool, and the S
value is its operating temperature. If you don't want the tool to be at a different temperature when not in use, set both values the same. See the T code (select tool) below. In tools with multiple heaters the temperatures for them all are specified thus: R100.0:90.0:20.0 S185.0:200.0:150.0 .
See also M585
- Notes
1Marlin uses G10/G11 for executing a retraction/unretraction move. Smoothie uses G10
for retract and G10 Ln
for setting workspace coordinates. RepRapFirmware interprets a G10 command with no P or L parameter as a retraction command.
2It's usually a bad idea to put a non-zero Z
value in as well unless the tools are loaded and unloaded by some sort of tool changer or are on indepedent carriages. When all the tools are in the machine at once they should all be set to the same Z height.
4Tool offsets are applied after any X axis mapping has been performed. Therefore if for example you map X to U in your M563
command to create the tool, you should specify a U offset not an X offset. If you map X to both X and U, you can specify both offsets. (Not supported on all firmwares).
5L1 sets the offsets of the specified tool relative to the head reference point to the specified values. L2 sets the current workplace coordinate offsets to the specified values. L20 adjusts the current workplace coordinate offsets so that the current tool head position has the specified coordinates. NOTE on some firmwares L is required (and is required by NIST standard). P is also required to specify either the tool to update or the WCS to update.
G10: Retract
Yes | Yes | Yes: 0.92 | Yes | Yes | Yes | Yes | ??? | |
??? | No | No | No | No | No | No | No |
- Parameters
Snnn
retract length (S1 = long retract, S0 = short retract = default) (Repetier only)- Example
G10
Retracts filament according to settings of M207
(Marlin, RepRapFirmware) or according to the S
value (Repetier).
RepRapFirmware recognizes G10
as a command to set tool offsets and/or temperatures if the P
parameter is present, and as a retraction command if it is absent.
G11: Unretract
- Parameters
Snnn
G11
Unretracts/recovers filament according to settings of M208
value (Repetier).
G12: Clean Tool
Yes: 1.1.0 | Use a macro instead | No | No | ??? | No | Yes | No | |
- Usage
[P<0|1>] [S<count>] [T<count>]
G12 Pnnn Snnn Tnnn
- Parameters
Pnnn
1 Pattern style selectionSnnn
Number of strokes (i.e. back-and-forth movements)Tnnn
Number of repetitionsEnnn
0=Never 1=Always apply software endstops (Marlin 2.0.6+)- Examples
G12 ; stroke pattern (default)
To generate a three triangle zig-zag pattern which will be stroked three times time use the following command. G12 P1 S3 T2 ; zig-zag pattern with 2 triangles
- Notes
1In Marlin firmware and Derivatives Mk4duo this is implemented by hard-coded firmware behaviours As defined for variables NOZZLE_CLEAN_STROKES, NOZZLE_CLEAN_START_POINT, NOZZLE_CLEAN_END_POINT and NOZZLE_CLEAN_PARK.
With NOZZLE_CLEAN_PARK enabled, the nozzle will automatically return to the XYZ position after G12 is run.
More on this behaviour is documented inside of the code base.
The use of G12 for tool cleaning clashes with the established use of G12 for circular pocket milling on CNC machines. For this reason, RepRapFirmware does not support G12.
Yes:1.1.4 | G18 and G19 need RRF 3.3 or later | ??? | ??? | ??? | No | No | ??? | |
Yes | ??? | ??? | ??? | Yes | No | ??? | Yes |
G17
: XY (default) -
G18
: ZX -
G19
: YZ
This mode applies to G2
/G3
arc moves. Normal arc moves are in the XY plane, and for most applications that's all you need. For CNC routing it can be useful to do small "digging" moves while making cuts, so to keep the G-code compact it uses G2
/G3
arcs involving the Z plane.
These commands are supported in Marlin 1.1.4 and later with ARC_SUPPORT
and CNC_WORKSPACE_PLANES
enabled.
Yes | Yes | Yes | Yes | ??? | No | Yes | No | |
Yes | Yes | No | Yes | Yes | No | Yes | Yes |
- Example
G20
Units from now on are in inches. In RepRapFirmware, the inches/mm setting applies to regular printing and travel moves (G0, G1, G2 etc.) but not to configuration commands. Therefore configuration should be done in mm.
When executing a macro file, RepRapFirmware remembers the initial inches/mm setting and restores it after execution of the macro has completed.
Yes | Yes | Yes | Yes | ??? | No | Yes | ??? | |
- Example
G21
When executing a macro file, RepRapFirmware remembers the initial inches/mm setting and restores it after execution of the macro has completed. So a macro file such as pause.g (executed when a pause command is received) can safely use G21 at the start to switch the units to mm without affecting the job after the macro completes, regardless of whether the job was using inches or mm.
G10 | Use G10 | No | No | ??? | No | No | No | |
No | No | No | No | Yes | No | No | No |
- Usage
G22 ; Do a retract move
Use this command (along with G23
) to have the firmware to do retraction moves (in contrast to generating an E axis G1
move). The retract length and speed are set in the firmware.
G11 | Use G11 | No | No | ??? | No | No | No | |
- Usage
G23 ; Do a recover move
Use this command (along with G22
) to have the firmware to do a recover move. The recover length and speed are set in the firmware.
Yes: 1.1.0 | No | No | No | No | No | Yes | No | |
- Usage
G26 C P O2.25 ; Do a typical test sequence
The G26
Mesh Validation Pattern is designed to be used in conjunction with various Mesh Bed Leveling systems – those that adjust for an uneven —rather than just tilted— bed. The G26
command prints a single layer pattern over the entire print bed, giving a clear indication of how accurately every mesh point is defined. G26
can be used to determine which areas of the mesh are less-than-perfect and how much to adjust each mesh point.
G26
has large feature list, including a built-in test that extrudes material onto the bed. By default this is configured for PLA temperatures and a nozzle size of 0.4mm. (This will be adjustable in an upcoming version of Marlin.)
See the G26_Mesh_Validation_Tool.cpp
file in the Marlin source code for full documentation of the G26
parameter list.
G27: Park toolhead
Park the toolhead (i.e., nozzle) at a predefined XY position, with a Z raise value that applies over 0 or over the current position depending on the P
parameter.
In Marlin this G-code is enabled by NOZZLE_PARK_FEATURE
and the park position is defined by NOZZLE_PARK_POINT
. See G27 Park Toolhead for details.
- Usage
G27 P0 ; Park, raising Z by NOZZLE_PARK_Z_RAISE_MIN, using NOZZLE_PARK_POINT.z as a safe height over 0 G27 P1 ; Park, raising Z to at least NOZZLE_PARK_POINT.z over 0 G27 P2 ; Park, raising Z by NOZZLE_PARK_POINT.z over the current Z
Yes | Yes | Yes | Yes | Yes | Yes2 | Yes | Yes | |
Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes1 |
- Parameters
- This command can be used without any additional parameters.
X
Flag to go back to the X axis originY
Flag to go back to the Y axis originZ
Flag to go back to the Z axis origin- Examples
G28 ; Home all axes (On Prusa i3 MK2/s,MK2.5/s,MK3/s it will also perform mesh bed leveling)2 G28 X Z ; Home the X and Z axes
When the firmware receives this command, it quickly moves the specified axes (or all axes if none are given) to the endstops, backs away from each endstop by a short distance, and slowly bumps the endstop again to increase positional accuracy. This process, known as "Homing", is required to determine the position of the print carriage(s). Some firmware may even forbid movement away from endstops and other operations until the axes have been homed.
The X
, Y
, and Z
parameters act only as flags. Any coordinates given are ignored. For example, G28 Z10
results in the same behavior as G28 Z
. Delta printers cannot home individual axes, but must always home all three towers, so the X Y Z
parameters are simply ignored on these machines.
Marlin firmware (version 1.1.0 and later) provides an option called Z_SAFE_HOMING
for printers that use a Z probe to home Z instead of an endstop. With this option, the XY axes are homed first, then the carriage moves to a position –usually the middle of the bed– where it can safely probe downward to home Z.
RepRapFirmware uses macro files to home either all axes or individual axes. If all axes are homed, the file homeall.g
is processed. For individual axes the homex.g
, homey.g
, or homez.g
file will be used. On Delta printers, G28
command will always home all three towers by processing the homedelta.g
file, regardless of any X
Y
Z
parameters.
Because the behavior of G28
is unspecified, it is recommended not to automatically include G28
in your ending G-code. On a Cartesian this will result in damaging the printed object. If you need to move the carriage at the completion of a print, use G0
or G1
- Notes
1 MK4duo has a B
parameter that tells the printer to return to the coordinates it was at before homing.
2 Original Prusa i3 MK2/s, MK2.5/s, MK3/s supports a W
parameter to suppress mesh bed leveling. If W
is omitted, G28 will home only and NOT perform mesh bed leveling.
Original Prusa i3 MK3/s (TMC2130 drivers) supports a C
parameter to calibrate the X and Y home position.
W
Suppress mesh bed leveling (Prusa MK2/s, MK2.5/s and MK3/s only)2C
Calibrate X and Y home position (Prusa MK3/s only)2
Yes | 1.17+ | Yes: 0.91.7 | No: see G32 | ??? | G811 | Yes | ??? | |
No | No | No | No | Yes | Yes | No | No |
This command uses a probe to measure the bed height at 3 or more points to determine its tilt and overall flatness. It then enables compensation so that the nozzle will remain parallel to the bed. The printer must be homed with G28
before using this command.
Each firmware behaves differently and depends on the type of bed leveling that's been configured. For example, Marlin 1.0.2 provides 3 different types of automatic bed leveling (probe required) and a manual bed leveling option. See your firmware's documentation for the specific options available.
- Usage
G29
G29 Snnn
- Parameters
Snnn
Firmware-dependent behaviorPfile.csv
Optional file name for bed height map file (RepRapFirmware only)- Examples
G29 ; Probe the bed and enable compensation G29 S2 ; Special operation - see below G29 P1 ; UBL automated probe - see below
G29 Auto Bed Leveling (Marlin - MK4duo)
Marlin 1.0.2 and earlier provides three options for automatic bed leveling:
- The 3-point method probes the bed at three points to produce a matrix, adjusting for a flat but tilted bed.
- The planar grid method (non-Delta) probes a grid pattern to produce a matrix by the "least-squares" method, adjusting for a flat but tilted bed.
- The bilinear grid method (Delta only) probes a grid pattern to produce a mesh, using bilinear interpolation to adjust for an uneven bed.
Marlin 1.1.0 and later allows the bilinear grid (i.e., "mesh") method to be used on all types of machines, not just deltas. This is the recommended leveling method going forward.
Also in Marlin 1.1.0 and later, the PROBE_MANUALLY
option allows all forms of Auto Bed Leveling to be used without a probe. The procedure is similar to that of MESH_BED_LEVELING
(see below). Begin the process with G29
to move the nozzle to the first point. Adjust the Z axis using G1
or your host software. Send G29
again to move to the next point and repeat until all points have been sampled.
- Parameters
P
Set the size of the grid that will be probed (P x P points). Not supported by non-linear delta printer bed leveling. Example:G29 P4
S
Set the XY travel speed between probe points (in units/min)D
Dry-Run mode. Just evaluate the bed Topology - Don't apply or clean the rotation Matrix. Useful to check the topology after a first run of G29.V
Set the verbose level (0-4). Example:G29 V3
T
Generate a Bed Topology Report. Example:G29 P5 T
for a detailed report. This is useful for manual bed leveling and finding flaws in the bed (to assist with part placement). Not supported by non-linear delta printer bed leveling.F
Set the Front limit of the probing gridB
Set the Back limit of the probing gridL
Set the Left limit of the probing gridR
Set the Right limit of the probing grid
- Global Parameters
E
By defaultG29
will engage the Z probe, test the bed, then disengage. IncludeE
orE1
to engage/disengage the Z probe for each sample. (This has no effect for fixed probes.)
G29 Unified Bed Leveling (Marlin - MK4duo)
Marlin firmware (version 1.1.0 and later) includes the AUTO_BED_LEVELING_UBL
option for Unified Bed Leveling. UBL combines mesh leveling, tilted plane adjustment, 3-point leveling, and manual editing tools all together in a single package. To accomplish so much, UBL overloads `G29` with several new parameters and provides an additional G26
Mesh Tuning feature.
See the MarlinFW website for a dedicated Unified Bed Leveling page and complete documentation on `G29` for UBL and `G26` Mesh Validation.
- G29 UBL Parameters (synopsis)
A Activate Activate the Unified Bed Leveling system. (i.e., M420 S1) D Disable Disable the Unified Bed Leveling system. (i.e., M420 S0) B# Business Do Manual Probing in 'Business Card' mode. H# Height Height to raise the nozzle after each Manual Probe of the bed. C Continue Continue, Constant, or Current Location, depending on Phase. E Every Stow the probe after every sampled point. F# Fade Fade leveling compensation gradually, until it ceases at the given height. I# Invalidate Invalidate a specified number of Mesh Points (X and Y). J# Grid Do a grid (planar) leveling of the current Mesh using a grid with n points on a side. K# Kompare Compare (diff) current Mesh with stored Mesh #, replacing current Mesh with the result. L Load Load Mesh from the previously activated location in the EEPROM. L# Load Load Mesh from the specified location in the EEPROM. S Store Store the current Mesh in the Activated area of the EEPROM. Also save all settings. S # Store Store the current Mesh at the specified area in EEPROM, set as the Activated area. S -1 Store Store the current Mesh as a print-out suitable to be fed back into the system. O Map Display the Mesh Map Topology. P0 Phase 0 Zero Mesh Data and turn off the Mesh Compensation System. P1 Phase 1 Invalidate the Mesh and do Automatic Probing to generate new Mesh data. P2 Phase 2 Probe unpopulated areas of the Mesh (those that couldn't be auto-probed). P3 Phase 3 Fill unpopulated Mesh points with a fixed value. No 'C' for "smart fill" extrapolation. P4 Phase 4 Fine tune the Mesh. ** Delta Mesh Compensation requires an LCD panel. ** P5 Phase 5 Find Mean Mesh Height and Standard Deviation. P6 Phase 6 Shift Mesh height. All Mesh points are adjusted by the amount specified with 'C'. Q Test Load specified Test Pattern to help check system operation. R # Repeat Repeat the command the specified number of times. Default: grid points X * Y. T 3-Point Perform a 3-Point Bed Leveling on the current Mesh. U Unlevel Perform a probe of the outer perimeter to assist in physically leveling the bed. W What? Print a report of Unified Bed Leveling stored data. X # The X location for the command Y # The Y location for the command Z Zero Do a single probe to set the Z Height of the nozzle. Z # Zero Raise/lower the entire Mesh to conform with the specified difference (plus zprobe_zoffset).
G29 Manual Bed Leveling (Marlin - MK4duo)
Marlin firmware (version 1.0.2 and later) also provides a MESH_BED_LEVELING
feature that can be used to perform bed leveling on machines lacking a probe. This form of bed leveling compensates for uneven Z height across the surface of the bed using a mesh and bilinear interpolation.
- Manual Bed Leveling Usage
G29 S1 ; Move to the first point and wait for a measurement G29 S2 ; Store the current Z, move to the next point G29 S3 Xn Yn Zn.nn ; Modify the Z height of a single point
- Options for the
S
parameter S0
Produces a mesh reportS1
Start probing mesh pointsS2
Probe the next mesh pointS3 Xn Yn Zn.nn
Manually modify a single pointS4 Zn.nn
Set z offset. Positive away from bed, negative closer to bed.
G29 Auto Bed Leveling (Repetier-Firmware)
Repetier firmware since v0.91 supports G29
with the optional Snnn parameter as described below. Useful to simply detect the Z bed angle so you can manually readjust your bed and get it as close to in plane as possible. If you wish to apply automatic software Z plane compensation on Repetier, use G32
instead with firmware 0.92.8 and above.
S0
Default value. Z bed heights are calculated at the measured points, relative to current Z position before issuingG29
.S1
Same asS0
, except printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issueG28 Z
to home to Z maximum position before issuingG29 Snnn
for this to work correctly, or the printer height will be invalid.S2
Same asS1
, except new calculated Z height is also stored to EEPROM.
G29 Mesh Bed Compensation (RepRapFirmware)
RepRapFirmware:
S0
(default if noS
parameter) Probe the bed, save the height map in a file on the SD card, and activate the height map. The default folder for the height map file is/sys
and the default file name isheightmap.csv
.S1
Load the height map from file and activate bed compensation. The default folder and filename as forS0
.S2
Clear the currently-loaded bed height map
To define the grid, see M557.
In RepRapFirmware 3.2 and later, G29 runs macro file mesh.g if it exists, otherwise it behaves like G29 S0. The mesh.g file can perform other actions (e.g. homing or tool selection) and then use G29 S0 to do the probing.
- Notes
In Prusa Firmware G29
is not active by default, instead G81 is used.1
M851 | No | No | No | ??? | M851 | M851 | No | |
- Example
G29.1 X30 Y20 Z0.5
No | No | No | No | No | No | No | No | |
- Example
G29.2 Z0.0
The user would typically place the toolhead at the zero point of the axis and issue the G29.2
command.
G30: Single Z-Probe
Yes | Yes | Yes | Yes | ??? | No2 | Yes | No | |
No | No | No | No | Yes | Yes | G28,G92 | No1 |
- Usage
- Parameters
Pnnn
Probe point numberXnnn
X coordinateYnnn
Y coordinateZnnn
Z coordinateHnnn
Height correctionSnnn
Set parameter- Example
G30
- Examples (RepRapFirmware)
G30 ; Probe the bed at the current XY position. When the probe is triggered, set the Z coordinate to the probe trigger height. G30 S-1 ; Probe the bed at the current XY position. When the probe is triggered, do not adjust the Z coordinate. G30 P0 X20 Y50 Z-99999 ; Probe the bed at X20 Y50 and save the XY coordinates and the height error as point 0 G30 P3 X180 Y180 Z-99999 S4 ; Probe the bed at X180 Y180, save the XY coordinates and the height error as point 3 and calculate 4-point compensation or calibration G30 P3 X180 Y180 Z-99999 S-1 ; As previous example but just report the height errors
RepRapFirmware supports additional behaviour: if a Pn
field is specified the probed X
, Y
, and Z
values are saved as point n on the bed for calculating the offset plane or for performing delta printer calibration. If X
, Y
, or Z
values are specified (e.g. G30 P1 X20 Y50 Z0.3
) then those values are used instead of the machine's current coordinates. A silly Z
value (less than -9999.0) causes the machine to probe at the current point to get Z, rather than using the given value. If an S field is specified (e.g. G30 P1 Z0.3 S
) the bed plane is computed for compensation and stored. The combination of these options allows for the machine to be moved to points using G1
commands, and then probe the bed, or for the user to position the nozzle interactively and use those coordinates. The user can also record those values and place them in a setup G-code file for automatic execution.
RepRapFirmware uses the value of the S
parameter to specify what computation to perform. If the value is -1 then the Z offsets of all the points probed are printed, but no calibration is done. If the value is zero or not present, then this specifies that the number of factors to be calibrated is the same as the number of points probed. Otherwise, the value indicates the number of factors to be calibrated, which must be no greater than the number of points probed. In version 1.09, the number of factors may be 3, 4 or 5 when doing auto bed compensation on a Cartesian or CoreXY printer, and 3, 4, 6 or 7 when doing auto calibration of a Delta printer.
RepRapFirmware supports an optional H
parameter, which is a height correction for that probe point. It allows for the Z probe having a trigger height that varies with XY position. The nominal trigger height of the Z probe (e.g. at bed centre) is declared in the Z
parameter of the G31
command in the config.g file. When you probe using G30
and the probe triggers, the firmware will assume that the nozzle is at the nominal trigger height plus the value you have in the H
parameter.
1MK4duo Firmware support an optional parameter for Delta.
- Usage
G30 Xnnn Ynnn S Z P
- Parameters
Xnnn
X coordinateYnnn
Y coordinateSn
Stows the probe if 1 (default=1)Zn
<bool> with a non-zero value will apply the result to current delta_heightPn
<bool> with a non-zero value will apply the result to current zprobe_zoffset
- Notes
In Prusa Firmware this G-code is deactivated by default, must be turned on in the source code.2
No | Yes | Yes: 0.91.7 | Yes | ??? | No | No | ??? | |
- Usage
- Parameters
Pnnn
Trigger valueXnnn
Probe X offset1Ynnn
Probe Y offset1Znnn
Trigger Z heightCnnn
Temperature coefficient(s) of trigger height2Snnn
Calibration temperature2Tnnn
(RepRapFirmware 1.17 and later) Z probe type to which these parameters apply, defaults to the current Z probe type as defined byM558 P
parameter- Examples
G31 P500 Z2.6 G31 X16.0 Y1.5
When used on its own this reports whether the Z probe is triggered, or gives the Z probe value in some units if the probe generates height values. If combined with a Z and P field (example: G31 P312 Z0.7
) this will set the Z height to 0.7mm when the Z-probe value reaches 312 when a G28 Z0
(zero Z axis) command is sent. The machine will then move a further -0.7mm in Z to place itself at Z = 0. This allows non-contact measuring probes to approach but not touch the bed, and for the gap left to be allowed for. If the probe is a touch probe and generates a simple 0/1 off/on signal, then G31 Z0.7
will tell the RepRap machine that it is at a height of 0.7mm when the probe is triggered.
In RepRapFirmware, separate G31
parameters may be defined for different probe types (i.e. 0+4 for switches, 1+2 for IR probes and 3 for alternative sensors). To specify which probe you are setting parameters for, send a M558 command to select the probe type before sending the G31
command, or use the T
parameter.
In Repetier, G31
supports no parameters and simply prints the high/low status of the Z probe.
- Notes
1X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) can be specified in RepRapFirmware. This allows you to calculate your probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset.
2In RepRapFirmware, additional parameters 'S' (bed temperature in oC at which the specified Z
parameter is correct, default is current bed temperature) and 'C' (temperature coefficient of Z
parameter in mm/oC, default zero) can be set for the alternative (ultrasonic) sensor. This is useful for probes that are affected by temperature such as PINDA. RepRapFirmware 3.1 and later allow both first and second order temperature coefficients to be specified, e.g. C0.015:0.001.
G31: Dock Z Probe sled
Yes | No | No | No | No | No1 | Yes | No | |
No | No | No | No | No | Yes | No | No |
- Notes
In Prusa Firmware this G-code is deactivated by default, must be turned on in the source code.1
G29 | Yes | 0.92.8+ | Yes | No | G29 | No | No | |
- Usage
G32 ; Probe and calculate G32 Snnn ; Each firmware has its own parameters G32 Snnn Pnnn ; Refer to their specific documentation
This command is implemented as a more sophisticated form of bed leveling (which uses a transformation matrix or motorized correction. Smoothieware uses this code instead of `G29`.
Each firmware behaves differently. For example, Repetier firmware allows for motorized rotation of the bed whilst ReprapFirmware probes the bed with a transformation matrix.
Probe and calculate in Reprapfirmware
RepRapFirmware executes macro file bed.g
in response to the G31 command. The bed.g
file is typically used to probe the bed and then perform delta calibration if the printer is a delta, or to perform individual leadscrew adjustment to level the bed if the printer has multiple independently-controlled Z motors, or to advise the user on how much to adjust each bed levelling adjustment screw.
Probe and calculate in Repetier firmware
This command probes the bed at 3 or more pre-defined points and implements bed leveling compensation by either moving the A axis during printing (as with regular bed leveling, G29
) or by tilting the bed with motors.
- Parameters
Snnn
Bed leveling methodPnnn
Bed correction method
The values for Snnn and Pnnn are as follows:
S0
This method measures at the 3 probe points and creates a plane through these points. If you have a really planar bed this gives the optimum result. The 3 points must not be in one line and have a long distance to increase numerical stability.S1
This measures a grid. Probe point 1 is the origin and points 2 and 3 span a grid. We measure BED_LEVELING_GRID_SIZE points in each direction and compute a regression plane through all points. This gives a good overall plane if you have small bumps measuring inaccuracies.S2
Bending correcting 4 point measurement. This is for cantilevered beds that have the rotation axis not at the side but inside the bed. Here we can assume no bending on the axis and a symmetric bending to both sides of the axis. So probe points 2 and 3 build the symmetric axis and point 1 is mirrored to 1m across the axis. Using the symmetry we then remove the bending from 1 and use that as plane.P0
Use a rotation matrix. This will make z axis go up/down while moving in x/y direction to compensate the tilt. For multiple extruders make sure the height match the tilt of the bed or one will scratch. This is the default.P1
Motorized correction. This method needs a bed that is fixed on 3 points from which 2 have a motor to change the height. The positions are defined in firmware by BED_MOTOR_1_X, BED_MOTOR_1_Y, BED_MOTOR_2_X, BED_MOTOR_2_Y, BED_MOTOR_3_X, BED_MOTOR_3_Y Motor 2 and 3 are the one driven by motor driver 0 and 1. These can be extra motors like Felix Pro 1 uses them or a system with 3 z axis where motors can be controlled individually like the Sparkcube does. This method requires a Z max endstop.
G32: Undock Z Probe sled
- Notes
G33: Firmware dependent
G33: Measure/List/Adjust Distortion Matrix (Repetier - Redeem)
No | No | 0.92.8+ | No | No | No | No | No | |
- Usage
G33
G33 Lnnn
G33 Rnnn
G33 Xnnn Ynnn Znnn
- Parameters
L0
List distortion matrix in a reportR0
Reset distortion matrixX[pos] Y[pos] Z[zCorrection]
Set correction for nearest point- Examples
G33 G33 R0
When used with no parameters, G33
will measure a grid of points and store the distortion dips and valleys in the bed surface, and then enable software distortion correction for the first few or several layers. The values will be stored in EEPROM if enabled in firmware. You must previously have G28
homed, and your Z minimum/maximum height must be set correctly for this to work. Use the optional parameters to list, reset or modify the distortion settings. Distortion correction behavior can be later turned on or off by code M323
G33: Delta Auto Calibration (Marlin 1.1.x - MK4duo)
Yes | Use G32 | No | No | ??? | No | Yes | No | |
End-stops and tower angle corrections are normalized (P0);
Performs a 1-4-7 point calibration of delta height (P1), end-stops, delta radius (P2) and tower angle corrections (P>=3) by a least squares iteration process based on the displacement method.
- Usage
G33
G33 Pn T Cx.xx Fn Vn E O Rx.xx
- Parameters
Pn
Number of probe points: n*n (n= 0-10), when P is omitted the default set in Configuration.h is used.T
Do not calibrate tower angle corrections (if used with P>=3); do not use the probe points near the towers, but the probe points opposite to the towers (if used with P=2)Cx.xx
Force the iterations to stop when a standard deviation from the zero plane less then x.xx mm is achieved; when C is omitted the iterations go on until the best possible standard deviation is reached.Fn
Force to run at least n iterations (n=1-30) and take the best resultVn
Verbose level: (n=0-3) 0 = dry run without calibration; 1(default) = settings at start and end; 2 = settings at all iterations; 3 = settings and probe resultsE
Engage the probe for each pointO
Do not probe at the required kinematic points but at positions offseted to the probe-offsets 1R
Temporary reduce the size of the probe grid by the specified amount (mm) 1
- Notes
1 since 2.0.9.2
- Examples
G33 : calibrates with the default settings. G33 Auto Calibrate Checking... AC .Height:297.77 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 .Tower angle : Tx:+0.00 Ty:+0.00 Tz:+0.00 Iteration : 01 std dev:0.306 Iteration : 02 std dev:0.049 Iteration : 03 std dev:0.033 Iteration : 04 std dev:0.031 Calibration OK rolling back. .Height:297.69 Ex:-0.10 Ey:-0.12 Ez:+0.00 Radius:100.91 .Tower angle : Tx:-0.03 Ty:+0.25 Tz:+0.00 Save with M500 and/or copy to Configuration.h
G33 P6 V0 : probes 36 points in dry run mode. G33 Auto Calibrate Checking... AC (DRY-RUN) .Height:297.77 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 .Tower angle : Tx:+0.00 Ty:+0.00 Tz:+0.00 . c:+0.03 x:+0.32 y:+0.34 z:+0.41 . yz:+0.37 zx:+0.32 xy:+0.17 End DRY-RUN std dev:0.306
G33 P4 C0.05 T : probes 16 points and stops when a standard deviation of 0.05mm is reached; calibrates delta height, endstops and delta radius, leaves the tower angle corrections unaltered. G33 Auto Calibrate Checking... AC .Height:297.78 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 Iteration : 01 std dev:0.317 Iteration : 02 std dev:0.059 Calibration OK std dev:0.042 .Height:297.66 Ex:-0.17 Ey:-0.13 Ez:+0.00 Radius:100.91 Save with M500 and/or copy to Configuration.h
G33 P2 : probes center and tower positions and calibrates delta height, endstops and delta radius. G33 Auto Calibrate Checking... AC .Height:297.78 Ex:+0.00 Ey:+0.00 Ez:+0.00 Radius:100.00 Iteration : 01 std dev:0.374 Iteration : 02 std dev:0.054 Iteration : 03 std dev:0.007 Calibration OK rolling back. .Height:297.68 Ex:-0.14 Ey:-0.14 Ez:+0.00 Radius:101.23 Save with M500 and/or copy to Configuration.h
G33 P1 : probes the center and calibrates the delta height only. G33 Auto Calibrate Checking... AC .Height:261.40 Offset:+0.30 Calibration OK std dev:0.000 .Height:261.58 Offset:+0.10 Save with M500 and/or copy to Configuration.h
note: Height = delta height; Ex, Ey, Ez = end-stop corrections; Radius = delta radius; Tx, Ty, Tz = tower angular corrections; c, x, y, z, yz, zx, xy = probe results at center, towers and opposite to towers; std dev = standard deviation of the probe results towards the zero plane.
G34: Z Stepper Auto-Align
Yes | Use M671 and G32 | No | No | No | No | No | No | |
Use multiple Z steppers and a probe to align Z axis connection points. See M422
for other options.
- Example
G34 I3 T0.8 A1.5 ; 3 iterations, Target Accuracy 0.8, Amplification 1.5
G34: Calculate Delta Height from toolhead position (DELTA)
No | No | No | No | No | No | Yes | No | |
- Example
G34
The user would typically place the toolhead at the zero point of the axis and issue the G34
command.
This value can be saved to EEPROM using the M500
command.
1.1.0+ | 3.0+ | ??? | Yes | ??? | No | Yes | No | |
Yes | No | No | No | No | No | No | No |
Monitors probe input while moving linearly towards the specified coordinates, stopping upon detecting contact or reaching specified coordinates.
- Usage
G38.2 Xnnn Ynnn Znnn Fnnn
- Parameters
Xnnn
target X coordinateYnnn
target Y coordinateZnnn
target Z coordinateFnnn
Feedrate in mm/min- Example
G38.2 Z0 G38.2 X50 G38.2 Z10 Y10
2.0.0+ | 3.0+ | ??? | ??? | ??? | No | No | No | |
Yes | No | No | No | Yes | No | No | Yes |
G40
turns off cutter compensation. If tool compensation was on the next move must be a linear move and longer than the tool diameter. It is OK to turn compensation off when it is already off.
http://www.linuxcnc.org/docs/2.5/html/gcode/tool_compensation.html
G42: Move to Grid Point
1.1.2+ | No | No | No | No | No | Yes | No | |
G42
does a fast move in XY to any of the intersection points in the bed calibration grid. This is useful during calibration to align the nozzle or probe.
- Parameters
Inn
Grid X index (zero-based). If omitted, the nearest latitude.Jnn
Grid Y index (zero-based). If omitted, the nearest longitude.P
Probe flag. Moves the probe to the grid point (instead of the nozzle).Fnnn
Feedrate (mm/m)- Example
G42 I3 J4 P F3000 ; Move the probe to grid coordinate 3, 4
G53..59: Coordinate System Select (CNC specific)
2.0.0+ | 1.21+ | No | Yes | No | No | No | No | |
Not all builds of RepRapFirmware support these commands. For those that do (e.g. Duet WiFi/Ethernet and Duet 3), from firmware version 2.02 the workplace coordinate offsets are included in the data saved to config-override.g by the M500 command.
G60: save current position to slot
No | 1.21+ | No | No | No | No | Yes | No | |
- Usage
G60 Snn
- Parameters
Snn
<nn> specifies memory slot # (0-based) to save into (default 0)
Implementation in RepRapFirmware:
- Slots 0, 1 and 2 are available from RepRapFirmware 1.21, also slots 4 and 5 in RRF 2.02. When a print is paused the coordinates are saved to slot 1 automatically, and at the start of a tool change the coordinates are saved to slot 2 automatically. Use G0 or G1 with the R0, R1 or R2 parameter to move the current tool to a saved position.
G61: Apply/restore saved coordinates to the active extruder.
No | Use G0 or G1 with R parameter | ??? | ??? | ??? | No | Yes | ??? | |
??? | ??? | ??? | ??? | ??? | ??? | ??? | Yes |
- Usage
G61 Xnnn Ynnn Znnn Ennn Fnnn Snn
- Parameters
Xnnn
X coordinateYnnn
Y coordinateZnnn
Z coordinateEnnn
E coordinateFnnn
F Set FeedrateSnn
S specifies memory slot # (0-based)
G75: Print temperature interpolation
No | No | No | No | No | Yes | No | No | |
Show/print PINDA temperature interpolating.
- Usage
G75
G76: PINDA probe temperature calibration
Yes1 | Use G31 | No | No | No | Yes | No | No | |
This G-code is used to calibrate the temperature drift of the PINDA (inductive Sensor).
The PINDAv2 sensor has a built-in thermistor which has the advantage that the calibration can be done once for all materials.
The Original i3 Prusa MK2/s uses PINDAv1 and this calibration improves the temperature drift, but not as good as the PINDAv2.
- Usage
G76
G76 B
1G76 P
1
- Parameters
B
Calibrate bed only 1P
Calibrate probe only 1
- Example
G76 echo PINDA probe calibration start echo start temperature: 35.0° echo ... echo PINDA temperature -- Z shift (mm): 0.---
- Notes1
Marlin requires PROBE_TEMP_COMPENSATION
This process can take a very long time. The timeout is currently set to 15min to allow the parts to fully heat up and cool down.
Use M500
to save the result to EEPROM.
At this moment it is only supported in Marlin bugfix-2.0.x branch.
No | No | ??? | ??? | ??? | No | No | ??? | |
Yes | ??? | ??? | ??? | ??? | No | ??? | No |
G80: Mesh-based Z probe
G29 | No | No | No | No | Yes | G29 | No | |
Default 3x3 grid can be changed on MK2.5/s and MK3/s to 7x7 grid.
- Parameters
N
Number of mesh points on x axis. Default is 3. Valid values are 3 and 7.R
Probe retries. Default 3 max. 10V
Verbosity level 1=low, 10=mid, 20=high.It can be only used if firmware has been compiled with SUPPORT_VERBOSITY active.
Using the following parameters enables additional "manual" bed leveling correction. Valid values are -100 microns to 100 microns.
L
Left Bed Level correct value in um.R
Right Bed Level correct value in um.F
Front Bed Level correct value in um.B
Back Bed Level correct value in um.
G81: Mesh bed leveling status
M420 | No | No | No | No | Yes | No | No | |
Prints mesh bed leveling status and bed profile if activated.
- Usage
G81
- Notes
Equivalent to M420 V
in Marlin Firmware (and possibly G29 T depending on leveling system).
G82: Single Z probe at current location
G30 | No | No | No | No | Yes1 | No | No | |
WARNING! USE WITH CAUTION! If you'll try to probe where is no leveling pad, nasty things can happen!
- Usage
G82
- Notes
G83: Babystep in Z and store to EEPROM
No | No | No | No | No | Yes1 | No | No | |
- Usage
G83
- Notes
G84: UNDO Babystep Z (move Z axis back)
No | No | No | No | No | Yes 1 | No | No | |
- Usage
G84
- Notes
G85: Pick best babystep
- Usage
G85
- Notes
G86: Disable babystep correction after home
This G-code will be performed at the start of a calibration script.
- Usage
G86
G87: Enable babystep correction after home
This G-code will be performed at the end of a calibration script.
- Usage
G87
G88: Reserved
- Usage
G88
- Notes
This G-code currently does not do anything.
- Example
G90
Yes | Yes | No | Yes | Yes | Yes | Yes | Yes |
- Example
G91
All coordinates from now on are relative to the last position. Note: RepRapFirmware latest revision firmware uses M83
to set the extruder to relative mode: extrusion is NOT set to relative by ReprapFirmware on G91
: only X,Y and Z are set to relative. By contrast, Marlin (for example) DOES also set extrusion to relative on a G91
command, as well as setting X, Y and Z.
G92: Set Position
- Parameters
Xnnn
new X axis positionYnnn
new Y axis positionZnnn
new Z axis positionEnnn
new extruder position- Example
G92 X10 E90
A G92
without coordinates will reset all axes to zero on some firmware. This does not apply to RepRapFirmware.
G92.x: Reset Coordinate System Offsets (CNC specific)
1.1.6+ | No | No | Yes | No | No | No | No | |
- Usage
G92.1
- Reset axis offsets (and parameters 5211-5219) to zero. (X Y Z A B C U V W
)G92.2
- Reset axis offsets to zero
Yes | No | No | No | No | No | No | Yes |
G93
is Inverse Time Mode. In inverse time feed rate mode, an F
word means the move should be completed in (one divided by the F
number) minutes.
For example, F2.0
means the move should be completed in a half a minute.
When the inverse time feed rate mode is active, an F
word must appear on every line which has a G1
, G2
, or G3
motion, and an F
word on a line that does not have G1
, G2
, or G3
is ignored. Being in inverse time feed rate mode does not affect G0
(rapid move) motions.
??? | No | ??? | ??? | ??? | ??? | No | ??? | |
Yes | ??? | ??? | ??? | ??? | No | ??? | Yes |
G98: Activate farm mode
Enable Prusa-specific Farm functions and g-code.
- Usage
G98
- Notes
Set of internal Prusa commands
PRUSA [ Ping | PRN | FAN | fn | thx | uvlo | fsensor_recover | MMURES | RESET | fv | M28 | SN | Fir | Rev | Lang | Lz | Beat | FR ]
- Parameters
Ping
PRN
Prints revision of the printer.FAN
Prints fan details.fn
Prints farm number.thx
uvlo
Resets UVLO aka Power Panic and continues SD print.fsensor_recover
Filament sensor recover - restore print and continue.MMURES
Reset MMU.Reset
Resets Printer.fv
??? get file version. ???M28
M28 write to SD.SN
Get serial number from 32U2 processor. Typical format of S/N is:CZPX0917X003XC13518Fir
Prints firmware version.Rev
Prints filament size, elelectronics, nozzle type.Lang
Reset the language.Lz
??? maybe resets Live Z values to 0 ???Beat
Kick farm link timer.FR
Full factory reset.nozzle set 'diameter'
Set nozzle diameter.nozzle D'diameter'
Check nozzle diameter.nozzle
Print nozzle diameter
G99: Deactivate farm mode
- Usage
G99
No | No | 0.92+ | No | No | No | No | No | |
- Parameters
X
Flag to set floor for X axisY
Flag to set floor for Y axisZ
Flag to set floor for Z axisRnnn
Radius to add- Examples
G100 X Y Z ; set floor for argument passed in. Number ignored and may be absent. G100 R5 ; Add 5 to radius. Adjust to be above floor if necessary G100 R0 ; Set radius based on current z measurement. Moves all axes to zero
No | No | No | No | No | No | No | Yes | |
- Example
G130 X10 Y18 Z15 A20 B12
G131: Remove offset
Support | Marlin | RepRapFirmware | Repetier | Smoothie | Klipper | Prusa | MK4duo | MakerBot |
No | No | 0.91+ | No | No | No | No | No | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | |
G133: Measure steps to top
G161: Home axes to minimum
- Parameters
X
Flag to home the X axis to its minimum positionY
Flag to home the Y axis to its minimum positionZ
Flag to home the Z axis to its minimum positionFnnn
Desired feedrate for this command- Example
G161 X Y Z F1800
Instruct the machine to home the specified axes to their minimum position. Similar to G28
, which decides on its own in which direction to search endstops.
G162: Home axes to maximum
- Parameters
X
Flag to home the X axis to its maximum positionY
Flag to home the Y axis to its maximum positionZ
Flag to home the Z axis to its maximum positionFnnn
G162 X Y Z F1800
G425: Perform auto-calibration with calibration cube
2.0.0+ | No | No | No | No | No | No | No | |
This performs an automatic calibration of backlash, positional errors and nozzle offset by touching the nozzle on the sides of a bed mounted, electrically conductive cube, washer or bolt.
- Parameters
B
Perform calibration of backlash only.Tnnn
Perform calibration of toolhead only.V
Probe cube and print position, error, backlash and hotend offset.Unnn
Uncertainty, how far to start probe away from the cube (mm)
- Examples (Marlin)
G425 ; Perform full calibration sequence T1 ; Switch to second nozzle G425 V ; Validate by showing report for T1 T0 ; Switch to second nozzle G425 V ; Validate by showing report for T0
M-commands
Yes | Yes | No | No | No | Yes3 | Yes | No | |
Yes | No | No | Yes | Yes | No | Yes | Yes |
- Parameters
Pnnn
Time to wait, in milliseconds1Snnn
Time to wait, in seconds2- Example
M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller, although this step is not mandatory on RepRapFirmware. See also M1
, M112
RepRapFirmware executes cancel.g if this file is present, if the print is paused and if the axes are homed. Otherwise stop.g is run and the drives are put into idle mode. Also the heaters are turned off if no 'H1' parameter is specified.
- Notes
1Not available in RepRapFirmware, but as a work-around G4
can be run before M0
2Only available on Marlin and Prusa Firmware.
3"Wait for user ..." is shown on LCD in Prusa Firmware.
M1: Sleep or Conditional stop
Yes | Yes | No | No | Yes | Yes1 | Yes | No | |
- Example
M1 M1 Hello world 1
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can still be sent G and M codes, the first of which will wake it up again. See also M0
, M112
The Marlin does the same as M0
In Prusa 8-bit Firmware 1 the M1
needs at least a space behind the command to be executed correctly. It can be used the same as M0 P<ms>
or M0 S<seconds>
but will ignore the following "message".
- Pursa Firmware 8-bit example
M1 S5
will wait for 5 seconds and show in the LCD status line "Waiting for user..." the same asM0 S5
M1 Hello world
will show in the LCD status line "Hello world" and wait until the user press the LCD knob.
If Marlin is emulated in RepRapFirmware, this does the same as M25 if the code was read from a serial or Telnet connection, else the macro file sleep.g
is run before all heaters and drives are turned off.
M2: Program End
Yes | No | No | No | No | No | Yes | Yes |
- Example
M2
Teacup firmware does the same as M84
Yes | Yes | Yes | Yes | No | No | No | No | |
- Parameters
Snnn
Spindle RPM- Example
M3 S4000
Teacup firmware turn extruder on (same as M101
RepRapFirmware interprets this code only if in CNC mode (M453
), in laser mode (M452
) or if a Roland mill has been configured. You must always provide an S parameter with this command to specify the required spindle speed pr laser power. In RepRapFirmware 2.05RC2 and later, and RepRapFirmware 3.0beta13 and later, in laser mode (M452) the laser will only fire during G1/G2/G2 moves.
In Repetier-Firmware in laser mode you need S0
..S255
to set laser intensity. Normally you use S255
to turn it on full power for moves. Laser will only fire during G1
/G2
/G3
moves and in laser mode (M452
Yes | No | Yes | No | No | No | No | No | |
- Example
M4 S4000
Yes | Yes | Yes | Yes | ??? | No | No | ??? | |
- Example
M5
The spindle is turned off.
Teacup firmware turn extruder off (same as M103
M6: Tool change
No | No | No | ??? | ??? | No | No | ??? | |
??? | No | No | No | No | No | Yes | Yes |
- Example
M6
No | No | No | No | ??? | No | No | ??? | |
Yes | No | No | No | No | No | Yes: Use M106 | Yes |
- Example
M7
Teacup firmware turn on the fan, and set fan speed (same as M106
- Example
M8
- Example
M9
M10: Vacuum On (CNC specific)
??? | No | No | No | No | No | Yes: Use M106 | Yes |
- Example
M10
- Example
M11
M13: Spindle on (clockwise rotation) and coolant on (flood)
No | ??? | ??? | ??? | ??? | No | ??? | ??? | |
This one M-code does the work of both M03 and M08. It is not unusual for specific machine models to have such combined commands, which make for shorter, more quickly written programs.
- Example
M13
M16: Expected Printer Check
(2.0+) | No | No | No | ??? | No | Yes | ??? | |
Do a case-sensitive comparison between the string argument and the configured MACHINE_NAME
. If the machine name doesn't match, halt the printer so that a reset is required. This safety feature is meant to prevent G-code sliced for a specific machine from being used on any other machine. In Marlin this feature is enabled with EXPECTED_PRINTER_CHECK
- Example
M16 Cookie Monster
Yes | 3.3 and later | No | Yes | ??? | Yes | Yes | ??? | |
??? | No | No | No | No | Yes | (automatic) | No |
- Parameters
- This command can be used without any additional parameters.1
X
X axisY
Y axisZ
Z axisE
All extruders
- Example
M17 M17 X E0
Powers on stepper motors.
- Notes
1Ability to specify axes was added to Marlin 2.0 and may not be available on other firmware implementations.
M84 | Yes | No | Yes | Yes | M843 | Yes | Yes | |
??? | No | No | No | No | Yes | Yes: Use M2 | No |
- Parameters
- This command can be used without any additional parameters.13
X
X axisY
Y axisZ
Z axisE
Extruder drive(s)2S
Seconds3- Examples
M18 M18 X E0
On Marlin, M18
is a synonym of M84
, so it can also be used to configure or disable the idle timeout.
- Examples
M18 S10 ; Idle steppers after 10 seconds of inactivity M18 S0 ; Disable idle timeout
- Notes
2RepRapFirmware allows stepper motors to be disabled selectively. For example, M18 X E0:2
will disable the X, extruder 0 and extruder 2 motors.
3In Prusa Firmware this command can be used to set the stepper inactivity timeout (`S`) or to disable steppers (`X`,`Y`,`Z`,`E`)
M20: List SD card
Yes | Yes1,2 | Yes | Yes | Yes3 | Yes4 | Yes | ??? | |
??? | Yes | No | No | No | No | Yes | No |
- Parameters
Snnn
Output style1Rnnn
File number to start at1P"ddd"
Directory to list2L
Reports long filenames instead of just short filenames. Requires host software parsing (Cap:EXTENDED_M20).4T
Report timestamps as well. The value is one uint32_t encoded as hex. Requires host software parsing (Cap:EXTENDED_M20).4
- Examples
M20 M20 S2 P"/gcodes/subdir" M20 L 4 M20 T 4
SQUARE.G SQCOM.G ZCARRI~2.GCO CARRIA~1.GCO
Please note that a file list response is usually encapsulated. Standard configurations of RepRapFirmware mimic this style in emulation mode:
Begin file list: SQUARE.G ZCARRI~2.GCO End file list ok
The file size may be appended as an integer representing the size in bytes:
Begin file list: SQUARE.G 1234 ZCARRI~2.GCO 234 End file list ok
At least OctoPrint also supports an additional format showing the file's long name (see also M33) after the size:
Begin file list: SQUARE.G 1234 SQUARE.G ZCARRI~2.GCO 234 ZCARRIAGE_V2.GCO End file list ok
G-code files: "Traffic cone.g","frog.gcode","calibration piece.g"
Note that some firmwares list file names in upper case, but - when sent to the M23
command (below) they must be in lower case. Teacup and RepRapFirmware have no such trouble and accept both. RepRapFirmware always returns long filenames in the case in which they are stored.
- Notes
1If the S2 parameter is used on RepRapFirmware, then the file list (or as much as can be fitted in the output buffer) is returned in JSON format as a single array called "files" with each name that corresponds to a subdirectory preceded by an asterisk, and the directory is returned in variable "dir". The optional R parameter is the file number to start at, default 0. The JSON response also returns value "next" which is the number of the first file that wasn't returned, or 0 if all files were returned. The caller can enumerate all files even if there are very many by making successive M20 S2 calls with each call using R from the "next" value in the previous response, util "next" is zero.
- Example
M20 S2 P/gcodes {"dir":"\/gcodes","first":0,"files":["4-piece-1-2-3-4.gcode","Hinged_Box.gcode","Hollow_Dodecahedron_190.gcode","*Calibration pieces"],"next":0}
- Example for
M20 L
4
Begin file list TEST1.GCO 1234 "TEST1.GCO" DIR_ENTER: /TESTFO~1/ "test folder" DIR_EXIT LFNFIL~1.GCO 56789 "LFN file.gcode" End file list
- Example for
M20 L T
4
Begin file list TEST1.GCO 1234 0x52936b00 "TEST1.GCO" DIR_ENTER: /TESTFO~1/ "test folder" DIR_EXIT LFNFIL~1.GCO 56789 0x52936b08 "LFN file.gcode" End file list
- Example for
M20 T
4
Begin file list TEST1.GCO 1234 0x52936b00 DIR_ENTER: /TESTFO~1/ "test folder" DIR_EXIT LFNFIL~1.GCO 56789 0x52936b08 End file list
2This parameter is only supported by RepRapFirmware and defaults to the 0:/gcodes directory, which is the directory that printable gcode files are normally stored in.
3On Klipper, a virtual SD card is required for this to work.
4The timestamp is a combination of both the date and time into a single integer and printed as a hex.
M21: Initialize SD card
Yes | Yes | Yes | Yes | Yes1 | Yes | Yes | ??? | |
- Parameters
Pnnn
SD card number (RepRapFirmware only, default 0)- Examples
M21 M21 P1
The specified SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
- Notes
1On Klipper, a virtual SD card is required for this to work.
M22: Release SD card
Yes | Yes | Yes | No | ??? | Yes | Yes | ??? | |
- Parameters
Pnnn
M22 M22 P1
The specified SD card is released, so further (accidental) attempts to read from it are guaranteed to fail. Helpful, but not mandatory before removing the card physically.
M23: Select SD file
- Example
M23 filename.gco
- Notes
M24: Start/resume SD print
Yes | Yes | Yes | Yes | Yes1 | Yes | Yes | No | |
No | Yes | No | No | No | Yes | Yes | No |
- Example
M24
The machine prints from the file selected with the M23
command. If the print was previously paused with M25
, printing is resumed from that point. To restart a file from the beginning, use M23
to reset it, then M24
When this command is used to resume a print that was paused, RepRapFirmware runs macro file resume.g
prior to resuming the print.
- Notes
M25: Pause SD print
- Example
M25
The machine pauses printing at the current position within the file. To resume printing, use M24. Do not use this code within a GCode file to pause the print at that point, use M226 instead.
Prior to pausing, RepRapFirmware runs macro file pause.g
. This allows the head to be moved away from the print, filament to be retracted, etc.
RepRapFirmware 1.20 and later also save the current state of the print to file /sys/resurrect.g. This is so that if the printer is turned off after pausing, the print can subsequently be resumed.
- Notes
M26: Set SD position
Yes | Yes | Yes | aborts | Yes1 | Yes | Yes | ??? | |
??? | Yes | No | No | No | No | No | No |
- Parameters
Snnn
File position from start of file in bytesPnnn
(Optional, RepRapFirmware only) Proportion of the first move to be skipped, default 0.0, must be less than 1.0- Example
- M26 S49315
Set the file offset in bytes from the start of the SD card file selected by M23. The offset must correspond to the start of a G-code command.
- Notes
M27: Report SD print status
- Parameters
- C Report the open file's name and long name (Marlin 1.1.9 and up)
- Sn Set the auto-report interval (Marlin 1.1.9 and up)
- Example
M27
Report SD print status.
Marlin and RepRapFirmware report the number of bytes processed in this format, which can be processed by Pronterface:
SD printing byte 2134/235422
Not SD printing.
In Marlin 1.1.9 and up M27 C
reports the open file's DOS 8.3 name and long filename, if any.
- Example
M27 C
Current file: filena~1.gco Filenagotcha.gcode
In Marlin 1.1.9 and up M27 Sn
sets the auto-report interval. This requires the AUTO_REPORT_SD_STATUS
configuration option to be enabled. Marlin reports this capability in M115
as Cap: AUTO_REPORT_SD_STATUS 1
when this option is available.
- Example
M27 S2 ; Report the SD card status every 2 seconds
- Notes
M28: Begin write to SD card
Yes | Yes | Yes | Yes | ??? | Yes | Yes | ??? | |
- Example
M28 filename.gco
M29: Stop writing to SD card
- Example
M29 filename.gco
File opened by M28
command is closed, and all subsequent commands sent to the machine are executed as normal.
Yes | Yes | No | No | No | No | No | No |
- Example
> M30 filename.gco > filename.gco is deleted.
M30: Program Stop
- For Yaskawa and in grbl - Same as M2 in Yaskawa G-code
- Example
M30 ; Exchange pallet shuttles and end the program. Pressing cycle start will start the program at the beginning of the file.
M31: Output time since last M109
or SD card start to serial
Yes | No | No | No | ??? | Yes | Yes | ??? | |
- Example
M31
The response looks like:
echo:54 min, 38 sec
Yes | Yes | No | Yes | ??? | Yes | Yes | ??? | |
- Example
M32 filename.gco
It can be used when printing from SD card and does the same as M23
and M24
Yes | Not required | No | No | ??? | No | No | ??? | |
Example input:
M33 miscel~1/armchair/armcha~1.gco
Example output:
/Miscellaneous/Armchair/Armchair.gcode
M33: Stop and Close File and save restart.gcode
No | No: Use M25 | ??? | ??? | ??? | No | Yes | ??? | |
??? | ??? | ??? | ??? | ??? | ??? | ??? | No |
Stop the printing from SD and save all position in restart.gcode for restart printing in future
Yes | No | No | No | ??? | No | Yes | ??? | |
M35: Upload firmware NEXTION from SD
No | ??? | ??? | ??? | ??? | No | Yes | ??? | |
M36: Return file information
No | Yes | No | No | ??? | No | No | No | |
- Example
M36 filename.gco
{"err":0,"size":436831,"lastModified":"2017-09-21T16:58:07","height":5.20,"firstLayerHeight":0.20,"layerHeight":0.20,"printTime":660,"simulatedTime":1586,"filament":[1280.7],"generatedBy":"Simplify3D(R) Version 4.0.0"}
The "err" field is zero if successful, nonzero if the file was not found or an error occurred while processing it. The "size" field should always be present if the operation was successful. The presence or absence of other fields depends on whether the corresponding values could be found by reading the file. The "filament" field is an array of the filament lengths required from each spool. The size is in bytes, the times are in seconds, all other values are in mm. 'printTime' is the printing time estimated by the slicer, 'simulationTime' is the time measured when the print was simulated by the firmware. The fields may appear in any order, and additional fields may be present.
If the file name parameter is not supplied and a file on the SD card is currently being printed, then information for that file is returned including additional field "fileName". This feature is used by the web interface and by PanelDue, so that if a connection is made when a file is already being printed, the name and other information about that file can be shown.
M37: Simulation mode
No | Yes | No | No | ??? | No | No | ??? | |
- Parameters
- S1 Enter simulation mode
- S0 Leave simulation mode
- P"filename" (optional) Simulate printing a file from SD card
- Examples
- M37 S1
- M37 P"MyModel.g"
M37 S1 enters simulation mode. All G and M codes will not be acted on, but the time they would take to execute will be calculated.
M37 S0 leaves simulation mode and prints the total time taken by simulated moves since entering simulation mode.
M37 P"filename" enters simulation mode, prints the specified file, exits simulation mode, reports the print time, and appends it to the G-code file as a comment for later retrieval.
M38 Compute SHA1 hash of target file
??? | No | No | No | No | No | No | No |
Used to compute a hash of a file on the SD card. Examples:
> M38 gcodes/myfile.g > Cannot find file > M38 www/reprap.htm > 91199139dbfadac15a18cfb962dfd4853db83999
Returns a hexadecimal string which is the SHA1 of the file. If the file cannot be found, then the string "Cannot find file" is returned instead.
M39 Report SD card information
No | Yes: 1.20.1 and later | No | No | ??? | No | Yes | ??? | |
- Parameters
- Pn SD slot number, default 0
- Sn Response format. S0 returns a plain text response, S2 returns a response in JSON format.
- Examples
- M39 ; report information for SD card 0 in plain text format
- M39 P1 S2 ; report information for SD card 1 in JSON format
This command returns information about the SD card in the specified slot in the requested format. At least the following is returned:
- Whether or not a usable card is present in the slot
- The capacity of the card in bytes (if a card is present)
- The amount of free space on the card in bytes (if a card is present)
The JSON response has the following format (more fields may be added in future):
{"SDinfo":{"slot":0,"present":1,"capacity":4294967296,"free":2147485184,"speed":20971520,"clsize":32768}}
The capacity, free space and cluster size are in bytes, and the interface speed is in bytes/second.
M40: Eject
No | Use macro file M40.g | No | No | ??? | No | No | ??? | |
If your RepRap machine can eject the parts it has built off the bed, this command executes the eject cycle. This usually involves cooling the bed and then performing a sequence of movements that remove the printed parts from it. The X, Y and Z position of the machine at the end of this cycle are undefined (though they can be found out using the M114
command, q.v.).
See also M240
and M241
below.
M41: Loop
No | No, use 'while' command | No | No | ??? | No | No | ??? | |
- Example
M41
- When you press the reset button,
- When the build material runs out (if your RepRap is set up to detect this), and
- When there's an error (such as a heater failure).
M42: Switch I/O pin
Yes | Yes | Yes | No | ??? | Yes | Yes | No | |
- Parameters
Pnnn
Pin numberSnnn
Pin value- Example
M42 P7 S255
M42
switches a general purpose I/O pin. Use M42 Px Sy
to set pin x to value y, when omitting Px the LEDPIN will be used.
In Marlin Firmware, pin numbers for 32-bit processors are in the form PORT * 100 + PIN. So pin P1_02 on LPC1768 can be set with M42 P102 S1
Marlin 1.x includes an I
parameter to permit setting "volatile" pins that Marlin is using.
Marlin 2.0.5.2 and up include the M
parameter to set the pin mode: 0=INPUT, 1=OUTPUT, 2=INPUT_PULLUP, 3=INPUT_PULLDOWN.
In RepRapFirmware, the S field may be in the range 0..1 or 0..255. The pin reference is an internal firmware reference named "digital pin", see Duet pinout. It maps on different connector pins depending the hardware. On Duet 0.6 and 0.8.5 hardware using pre-1.16 firmware, the supported pin numbers and their names on the expansion connector are:
P | Name | Expansion Port Pin |
16 | TXD1 | 11 |
17 | RXD1 | 12 |
18 | TXD0 | 13 |
19 | RXD0 | 14 |
20 | TWD1 | 35 |
21 | TWCK1 | 36 |
23 | PA14 | 10 |
36 | PC4 | 18 |
52 | AD14 | 41 |
67 | PB16 | 32 |
In firmware 1.16, the pin numbering has changed.
60 | PA10/RXD0 | 14 |
61 | PA11/TXD0 | 13 |
62 | PA12/RXD1 | 12 |
63 | PA13/TXD1 | 11 |
64 | PA14/RTS1 | 10 |
65 | PB12/TWD1 | 35 |
66 | PB13/TWCK1 | 36 |
67 | PB16/DAC1* | 32 |
68 | PB21/AD14 | 41 |
69 | PC4 | 18 |
- Also used as CS signal on external SD card socket
P | Signal Name | Expansion Connector Label | Expansion Pin |
60 | CS5 | CS5 | 50 |
61 | CS6 | E3_STOP | 9 |
62 | CS7 | E4_STOP | 14 |
63 | CS8 | E5_STOP | 19 |
See Using servos and controlling unused I/O pins for all pin definitions.
Pre-1.16 example:
M42 P20 S1 ;set the connector pin 35 to high.
See also M583
M600 | No | No | No | No | No | No | No | |
- Example
M43
M43: Pin report and debug
Yes | No | No | No | No | No | Yes | No | |
- Usage
M43 En Pnnn Wn In
- Parameters
En
Enable / disable background endstop monitoringPnnn
Pin to read or watch. If omitted, read/watch all pinsWn
bool watch pins -reporting changes- until reset, click, orM108
In
bool Flag to ignore pin protection
- Note
- You must have
PINS_DEBUGGING
uncommented in yourConfiguration_adv.h
file for M43 to work.
M44: Codes debug - report codes available
In MK4duo you must enable FASTER_GCODE_EXECUTE
to get this G-code.
- Parameters
In
G-code listJn
M-code list
M44: Reset the bed skew and offset calibration
??? | ??? | ??? | ??? | ??? | Yes | ??? | ??? | |
Resets the bed skew and offset calibration on Prusa i3 MK2/s,MK2.5/s,MK3/s.
M45: Bed skew and offset with manual Z up
Runs the xyz calibration on Prusa i3 MK2/s,MK2.5/s,MK3/s.
- Parameters
Vnn
Verbosity level 1, 10 and 20 (low, mid, high). Only when SUPPORT_VERBOSITY is defined. This parameter is optional.
M46: Show the assigned IP address
??? | Use M552 | ??? | ??? | ??? | Yes | ??? | ??? | |
Reports the assigned IP address of a Toshiba FlashAir on Prusa i3 MK2/s,MK2.5/s,MK3/s. At this moment it is deactivated.
M47: Show end stops dialog on the display
Show end stops dialog on the display on Prusa i3 MK2/s,MK2.5/s,MK3/s.
Yes | Use macro M48.g | No | Yes | ??? | Yes1 | Yes | No | |
- Parameters
Pnnn
number of pointsXnnn
position on the X axisYnnn
position on the Y axisVnnn
verbosityE
engageLnnn
legs of travelS
schizoid
As with G29
, the E flag causes the probe to stow after each probe.
The S flag will result is a random sized, 5 pointed star, being traced (X and Y axis) between each sample. Usually a user will get worse repeat-ability numbers with S specified because the X axis and Y axis movements will add to the machine's positioning errors.
- Prusa specific 1
This function assumes the bed has been homed. Specifically, that a G28 command as been issued prior to invoking the M48 Z-Probe repeatability measurement function. Any information generated by a prior G29 Bed leveling command will be lost and need to be regenerated.
The number of samples will default to 10 if not specified. You can use upper or lower case letters for any of the options EXCEPT n. n must be in lower case because Marlin uses a capital N for its communication protocol and will get horribly confused if you send it a capital N.
- Usage
M48 nAA Xnnnn Ynnnn Vn Lnn
- Parameters
nAA
number(AA) of samples, default=10 (valid values between 4 and 50)Xnnn
X position for samplesYnnn
Y position for samplesVn
Verbosity level 1-4 (low to highest)Lnn
Legs of travel 1-15
M49: Set G26 debug flag
- Usage
- M49 S1 ; Enable G26 verbose debug output
M70: Display message
M117 | M117 | M117 | M117 | M117 | No | No | Yes | |
No | No | No | No | No | M117 | No | M117 |
- Example
M70 P200 Message
Display a message on the LCD. P
is the time to display message for.
M72: Play a tone or song
M300 | M300 | No | No | No | M300 | No | Yes | |
No | No | No | No | No | No | No | No: See M300 |
- Example
M72 P2
M73: Set/Get build percentage
Yes | 3.3 and later | No | No | ??? | Yes1 | Yes | Yes | |
- Example
M73 P50
Tell the firmware the current build progress percentage. The machine is expected to display this on its display. If the percentage is exactly 0 a "Build Start" notification is sent to the host. If the percentage is exactly 100 a "Build End" notification is sent to the host.
Use "M73" by itself to get a report of the current print progress.
- Prusa specific1
Prusa firmware shows percent done, time remaining and time to change/pause/user interaction.
- Usage
M73 P R Q S C1 D1
- Parameters
P
Percent in normal modeR
Time remaining in normal mode (minutes)Q
Percent in silent modeS
Time remaining in silent mode (minutes)C
Time to change/pause/user interaction in normal mode (minutes)1D
Time to change/pause/user interaction in silent mode (minutes)1- Examples
M73 echo NORMAL MODE: Percent done: ---%; print time remaining in mins: -----" echo SILENT MODE: Percent done: ---%; print time remaining in mins: -----" Prusa Firmware 3.10.0+1 echo NORMAL MODE: Percent done: ---%; print time remaining in mins: -----; Change in mins: -----"1 echo SILENT MODE: Percent done: ---%; print time remaining in mins: -----; Change in mins: -----"1
M75: Start the print job timer
M76: Pause the print job timer
M77: Stop the print job timer
M78: Show statistical information about the print jobs
M80: ATX Power On
Yes | Yes | Yes | No | ??? | Yes1 | Yes | ??? | |
No | Yes | No | No | No | No | automatic | No |
- Parameters
C"port_name"
(RepRapFirmware 3.4 and later only) Name of the pin used to control the power supply, default "pson"
- Examples
M80 ; Turn on the power supply M80 S ; Report power supply state (Marlin 1.1.1) M80 C"!pson" ; invert the PS_ON output for Meanwell power supplies
- Notes
- Marlin requires the
POWER_SUPPLY
configuration option to be set to a non-zero value to enableM80
. - Some firmwares (e.g., Teacup) handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off.
- Prusa requires
defined (PS_ON_PIN)
andPS_ON_PIN
must be set.1
M81: ATX Power Off
No | Yes | No | No | No | Yes | automatic | No |
- Parameters
- P quit the daemon (redeem only)
- R restart the daemon (redeem only)
- Sn n=0 turn power off immediately (default), n=1 turn power off when all thermostatic fans have turned off (RepRapFirmware 1.20 and later only)
- Examples
- M81 ; turn power off immediately
- M81 S1 ; turn power off when everything has cooled down (RepRapFirmware)
Turns off the ATX power supply. Counterpart to M80
- Notes
- Prusa requires
defined (PS_ON_PIN)
andPS_ON_PIN
must be set to Power off.1
Yes | Yes | Yes | Yes | Yes | Yes | Yes | ??? | |
??? | Yes | No | No | No | No | Yes | Yes |
- Example
M82
This is the default in repetier and for Yaskawa controllers.
- Example
M83
Note that the Ultimaker 3 will revert back to absolute extrusion after each tool change.
M84: Stop idle hold
Yes | Yes | Yes | Yes | Yes3 | Yes2 | Yes | ??? | |
??? | Yes | No | No | No | Yes | Yes | No |
- Parameters
Innn
Reset flags1- Example
M84
On Marlin, Repetier and RepRapFirmware, M84
can also be used to configure or disable the idle timeout. For example, "M84 S10" will idle the stepper motors after 10 seconds of inactivity. "M84 S0" will disable idle timeout; steppers will remain powered up regardless of activity.
For Yaskawa systems M84 is not applicable due to servo motors not producing the annoying noises.
- Notes
1RepRapFirmware-dc42 and other firmware may not support this parameter.
2Prusa firmware uses M84
similar to G-code#M18:_Disable_all_stepper_motors
3On Klipper M84
is equivalent to G-code#M18:_Disable_all_stepper_motors
- Prusa Usage
M84 E S X Y Z
- Prusa Parameters
- This command can be used without any additional parameters.2
E
Extruder drive(s)2S
SecondsX
X axisY
Y axisZ
Z axis
M85: Set Inactivity Shutdown Timer
Yes | No | Yes | No | ??? | Yes | Yes | ??? | |
- Example
M85 S30
Set Inactivity Shutdown Timer with parameter S<seconds>. "M85 S0" will disable the inactivity shutdown time (default)
M86: Set Safety Timer expiration time
No | No | No | No | ??? | Yes | No | No | |
- Usage
M86 Snnnn
- Parameters
S
Seconds
Similar to M85
but applies to the "safety timer" in Prusa Firmware.
Sets the safety timer expiration time in seconds. M86 S0 will disable safety timer.
When safety timer expires, heatbed and nozzle target temperatures are set to zero.
M87: Cancel Safety Timer
- Usage
M87
Cancels the safety timer. Equivalent to M86 S0
M92: Set axis_steps_per_unit
??? | Yes | No | No | No | Yes | No | No |
- Parameters
Xnnn
Steps per unit for the X driveYnnn
Steps per unit for the Y driveZnnn
Steps per unit for the Z driveEnnn
Steps per unit for the extruder drive(s)Snnn
Defines in which microstepping the above steps per unit are given. If omitted it will use the microstepping currently set by M350.1- Examples
M92 X87.489 Y87.489 Z87.489 M92 E420:420
Allows programming of steps per unit (usually mm) for motor drives. These values are reset to firmware defaults on power on, unless saved to EEPROM if available (M500
in Marlin) or in the configuration file (config.g in RepRapFirmware). Very useful for calibration.
RepRapFirmware will report the current steps/mm if you send M92
without any parameters.
For Yaskawa systems M92/M93 is not applicable due to use of servo motors.
- Notes
1 Only available in RepRapFirmware >=2.03
M93: Send axis_steps_per_unit
No | Use M92 | ??? | No | ??? | ??? | No | ??? | |
M98: Call Macro/Subprogram
??? | No | No | No | No | No | No | Yes |
- Parameters
Pnnn
Macro filename. In RepRapFirmware 3 this must be enclosed in double-quote characters. In RepRapFirmware 2 the double-quote characters are optional.- Example
M98 Pmymacro.g M98 P"mymacro.g"
Runs the macro in the file mymacro.g. In conventional G Codes for CNC machines the P
parameter normally refers to a line number in the program itself (P2000 would run the Macro starting at line O2000, say). For RepRap, which almost always has some sort of mass storage device inbuilt, it simply refers to the name of a G-code file that is executed by the G98
call. That G-code file does not need to end with an M99
(return) as the end-of-file automatically causes a return. RepRapFirmware supports nested macro calls up to a depth of 5.
Certain machine parameters are saved at the start of the macro call and restored at the end. For RepRapFirmware these are: axis movement relative/absolute mode, extruder movement absolute/relative mode, feed rate, inches/mm setting, and whether or not volumetric extrusion is selected. This allows the macro to change these settings without affecting the subsequent behaviour of the calling file.
RepRapFirmware also allows the filename to include a path to a subdirectory. For relative paths, the default folder is /sys, but some implementations may check the /macros directory too. Absolute file paths are supported by RepRapFirmware too.
- Example
M99
Returns from an M98
call.
No | Yes: 1.17c and later | No | No | ??? | No | No | ??? | |
??? | No | Yes | No | No | No | Yes | No |
In Teacup firmware:
If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103
In BFB/RapMan: Turn extruder on (forward/filament in).
In RepRapFirmware: undo filament retraction. The length and speed are set by the M207
command. RepRapFirmware supports this command for compatibility with Simplify3D.
In other firmwares:
Deprecated. Regarding filament retraction, see G10
, G11
, M207
, M208
, M227
, M228
, M229
??? | No | Yes | No | No | No | No | No |
In other firmwares: Deprecated.
In Teacup firmware:
If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101
In RepRapFirmware: retract filament. The length and speed are set by the M207
In other firmwares: Deprecated. Regarding filament retraction, see G10
, G11
, M207
, M208
, M227
, M228
, M229
Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | |
??? | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
- Parameters
Dnnn
Display temperature (Only Prusa)Snnn
Target temperatureRnnn
Idle temperature (Only MK4duo)
- Example
M104 S190 M104 S190 R170
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). See also M109.
See also using G10. Deprecation of M104
is subject to discussion. --Traumflug 11:33, 19 July 2012 (UTC)
M104 in Marlin Firmware
See Marlin Wiki. In Marlin Firmware, using M104
with no parameters will turn off the heater for the current extruder. This is also the case for M104 S
without a number after the S
parameter.
M104 in Teacup Firmware
In Teacup Firmware, M104
can be additionally used to handle all devices using a temperature sensor. It supports the additional P
parameter, which is a zero-based index into the list of sensors in config.h. For devices without a temp sensor, see M106.
- Example
M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100°C.
M104 in RepRapFirmware and Klipper
RepRapFirmware and some other firmwares support the optional T
parameter (as generated by slic3r) to specify which tool the command applies to.
Yes | Yes | Yes | Yes | Yes | Yes1 | Yes | Yes | |
??? | Yes | No | Yes | No | Yes | Yes | No |
- Parameters
- Examples
M105
Request the temperature of the current extruder, the build base and the build chamber in degrees Celsius. The temperatures are returned to the host computer. For example, the line sent to the host in response to this command can look like:
ok T:201 B:117 ok T:201 /202 B:117 /120 ok T:201 /202 B:117 /120 C:49.3 /50 ok T:201 /202 T0:110 /110 T1:23 /0 B:117 /120 C:49.3 /50 ok T0:110 /110 T1:23 /0 B:117 /120 ok T:20.2 /0.0 B:19.1 /0.0 T0:20.2 /0.0 @:0 [email protected]:0 P:19.8 A:26.4
The parameters mean the following:
- T, T0, ..., Tn - extruder temperature. In a single extruder setup, only T will be reported. Some firmware variants will report no T0 in multi extruder setups - in that case T is to be considered the temperature of the first tool. Otherwise, T should be considered the temperature of the currently selected tool (which will be repeated in one of the Tn entries)
- B - bed temperature
- C - chamber temperature
- @ - Hotend power
- [email protected] - Bed power
- P - PINDAv2 actual (Prusa MK2.5/s MK3/s only)1
- A - Ambient actual (Prusa MK3/s only)1
A temperature report will usually include actual and target temperature for all available heaters, with the format being "actual/target" or - for some firmware variants - "actual /target". During a blocking heatup some firmware variants only report the temperature tuple for the heater that is currently in blocking heatup state.
Note that temperatures can be reported as integers or floats. There sadly are a lot of interpretations of how an M105 response should look like across firmware variants, making parsing them potentially tricky.
Expansion/generalization of M105
to be considered using S1 parameter as noted in Pronterface I/O Monitor
In Repetier and MK4duo you can add X0 (X1 MK4duo) to get raw values as well:
M105 X0 ==> 11:05:48.910 : T:23.61 /0 @:0 T0:23.61 /0 @0:0 RAW0:3922 T1:23.89 /0 @1:0 RAW1:3920
M106: Fan On
- Parameters
Pnnn
Fan number (optional, defaults to 0)2Snnn
Fan speed (0 to 255; RepRapFirmware also accepts 0.0 to 1.0))- Extra Parameters
Innn
Invert signal, or disable fan1 3Fnnn
Set fan PWM frequency, in Hz1 3Lnnn
Set minimum fan speed (0 to 255 or 0.0 to 1.0)1 3Xnnn
Set maximum fan speed (0 to 255 or 0.0 to 1.0)1 3Bnnn
Blip time - fan will be run at full PWM for this number of seconds when started from standstill1Hnn:nn:nn...
Select heaters monitored when in thermostatic mode1 3Rnnn
Restore fan speed to the value it has when the print was paused1Tnnn
Set thermostatic mode trigger temperatureCnnn
Set custom name (RRF > 2.01 only)1- Example
M106 S127
- Examples (RepRapFirmware)
M106 P1 I1 S87 M106 P1 T45 H1:2 M106 P2 B0.1 L0.05
The first example turns on the default cooling fan at half speed. The second one inverts the cooling fan signal of the second fan and sets its value to 1/3 of its maximum. The third one sets the second fan to a thermostatic fan for heaters 1 and 2 (e.g. the extruder heaters in a dual-nozzle machine) such that the fan will be on when either hot end is at or above 45C.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0
turns the fan off. In some implementations like RepRapFirmware the PWM value may alternatively be specified as a real fraction: M106 S0.7
- Notes
2Marlin 1.0 to 1.1.6 only supports a single fan. Marlin 1.1.7 and up supports up to 3 fans.
3These parameters are only available in MK4duo.
M106 in RepRapFirmware
If an S
parameter is provided but no other parameter is present, then the speeds of the print cooling fans associated with the current tool will be set (see the F
parameter in the M563
command). If no tool is active then the speed of Fan 0 will be set. Either way, the speed is remembered so that it can be recalled using the R2
parameter (see below).
If no S
parameter is given but the R1 parameter is used, the fan speed when the print was last paused will be set. If the R2
parameter is used, then the speeds of the print cooling fans associated with the current tool will be set to the remembered value (see above).
The T
and H
parameters allow a fan to be configured to operate in thermostatic mode, for example to use one of the fan channels to control the hot end fan. In this mode the fan will be fully on when the temperature of any of the heaters listed in the H
parameter is at or above the trigger temperature set by the T
parameter, and off otherwise. Thermostatic mode can be disabled using parameter H-1.
The B
parameter sets the time for which the fan will be operated at full PWM when started from cold, to allow low fan speeds t be used. A value of 0.1 seconds is usually sufficient.
The L
parameter defines the minimum PWM value that is usable with this fan. If a lower value is commanded that is not zero, it will be rounded up to this value.
The X
parameter defines the maximum PWM value that is allowed for this fan. If a higher value is commanded, it will be rounded down to this value.
The I
parameter causes the fan output signal to be inverted if its value is greater than zero. This makes the cooling fan output suitable for feeding the PWM input of a 4-wire fan via a diode. If the parameter is present and zero, the output is not inverted. If the I
parameter is negative then in RRF 1.16 and later the fan is disabled, which frees up the pin for use as a general purpose I/O pin that can be controlled using M42
M106 in Teacup Firmware
Additionally to the above, Teacup Firmware uses M106
to control general devices. It supports the additional P
parameter, which is an zero-based index into the list of heaters/devices in config.h.
- Example
M106 P2 S255
Note: When turning on a temperature sensor equipped heater with M106
and M104
at the same time, temperature control will override the value given in M106
quickly.
Note well: The ambiguous text in the note above needs to be reworded by someone who knows the actual functioning. Below is my interpretation based on language use, not practical experience or code inspection.
Note: If M104
is (or becomes) active on a heater (or other device) with a feedback sensor it will correct any M106
initiated control output value change in the time it takes for the PID (of other feedback) loop to adjust it back to minimum error. It may not be easy to observe a change in the temperature (process value) due to this brief change in the control value
M107: Fan Off
??? | Yes | Yes | Yes | Yes | Yes | No | Yes |
Deprecated in Teacup firmware and in RepRapFirmware. Use M106 S0
instead.
M108: Cancel Heating
Yes | Yes | No | No | ??? | No | Yes | ??? | |
??? | No | Yes | No | No | Yes | No | No |
Breaks out of an M109
or M190
wait-for-temperature loop, continuing the print job. Use this command with caution! If cold extrusion prevention is enabled (see M302
) and the temperature is too low, this will start "printing" without extrusion. If cold extrusion prevention is disabled and the hot-end temperature is too low, the extruder may jam.
This command was introduced in Marlin 1.1.0. As with other emergency commands [e.g., M112
] this requires the host to leave space in the command buffer, or the command won't be executed until later.
Recent versions of Marlin introduce EMERGENCY_PARSER
, which overcomes the buffer limitation by watching the incoming serial stream. Commands M108, M112, M410, and M876 can all be intercepted by the emergency parser, so it is recommended to enable this feature.
M108: Set Extruder Speed (BFB)
Sets speed of extruder motor.
(Deprecated in FiveD firmware, see M113
??? | Yes | No | Yes | Yes | Yes | not needed | Yes |
- Parameters
Snnn
minimum target temperature, waits until heatingRnnn
maximum target temperature, waits until cooling (Sprinter)Rnnn
accurate target temperature, waits until heating and cooling (Marlin and MK4duo)Tn
tool number (RepRapFirmware and Klipper), optional- Example
M109 S215
M109 in Teacup
M109 in Marlin, MK4duo, Sprinter (ATmega port), RepRapFirmware, Prusa
- Example
M109 S185
RepRapFirmware also supports the optional T
parameter (as generated by slic3r) to specify which tool the command refers to (see below).
M109 in Sprinter (4pi port)
Parameters: S
(optional), set target temperature value. If not specified, waits for the temperature set by M104. R
(optional), sets target temperature range maximum value.
- Example
M109 S185 R240 ; set extruder temperature to 185 and wait for the temperature to be between 185 - 240.
If you have multiple extruders, use T
or P
parameter to specify which extruder you want to set/wait.
M109 in MakerBot
- Example
M109 S70 T0
M109 in Klipper
According to the documentation, Klipper will wait for the specified temperature to settle, i.e. it will wait until it goes back down in case it overshoots. Klipper also supports the optional T
parameter to specify which tool the command refers to (see above).
M110: Set Current Line Number
??? | No | No | Yes | No | Yes | not needed | No |
- Parameters
Nnnn
Line number- Example
M110 N123
M111: Set Debug Level
Yes | Yes | Yes | No | ??? | No2 | Yes | ??? | |
??? | No | No | Yes | No | Yes | Debug | No |
- Parameters
Pnnn
Debug module1Snnn
Debug on/off- Examples
M111 S6 M111 P1 S1
- Notes
2Prusa fimrware use D-codes/commands for debugging.
M111 in RepRapFirmware
RepRapFirmware allows debugging to be set for each module. If the optional 'P' parameter is not specified, debugging will be enabled for all modules. For a list of modules, send M111 S1 P15
M111 in Repetier
#define DEBUG_ECHO (1<<0) #define DEBUG_INFO (1<<1) #define DEBUG_ERRORS (1<<2) #define DEBUG_DRYRUN (1<<3) // repetier-firmware #define DEBUG_COMMUNICATION (1<<4) // repetier-firmware
For firmware that supports ethernet and web interfaces M111 S9
will turn web debug information on without changing any other debug settings, and M111 S8
will turn it off. Web debugging usually means that HTTP requests will be echoed to the USB interface, as will the responses.
M112: Full (Emergency) Stop
??? | No | No | Yes | No | Yes | Yes | No |
- Example
M112
Any moves in progress are immediately terminated, then RepRap shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M0
and M1
Please note while many systems termed this an Emergency Stop, this terminology is regulated in many regions with specific requirements behind its use. Marlin 2.0.x has renamed this to Full Stop. RepRapFirmware has indicated an intention to make a similar change as well. This stop function is NOT implemented in a Category 0 or 1 stop fashion or with fail-safe hardware compliying with PLd or better. The function as implemented is a category 2 software stop with no redundancies.
M113: Set Extruder PWM
??? | No | No | Yes | No | No | No | No |
- Example
M113
M113 S0.7
it causes the PWM to be set to the S
value (70% in this instance). M113 S0
turns the extruder off, until an M113
command other than M113 S0
is sent.
M113: Host Keepalive
1.1.9+ | No | No | No | ??? | Yes | Yes | ??? | |
During some lengthy processes, such as G29, Marlin may appear to the host to have “gone away.” The “host keepalive” feature will send messages to the host when Marlin is busy or waiting for user response so the host won’t try to reconnect.
- Usage
M113 Snnn
- Parameters
Snnn
keepalive interval to set- Examples
M113 S2
M114: Get Current Position
- Example
M114
Yes | Yes | Yes | Yes | Yes | Yes2 | Yes | No | |
- Parameters
Bnnn
(RepRapFirmware 3 only) Expansion board number (typically the CAN address) for which the firmware version is requested, default 0 (i.e. main board)Pnnn
Electronics type1V
Report the Prusa version number2Unnnnnn
Check the firmware version provided2- Examples
M115 M115 P2
sample data from firmware:
This M115
code is inconsistently implemented, and should not be relied upon to exist, or output correctly in all cases. An initial implementation was committed to svn for the FiveD Reprap firmware on 11 Oct 2010. Work to more formally define protocol versions is currently (October 2010) being discussed. See M115_Keywords for one draft set of keywords and their meanings. See the M408
command for a more comprehensive report on machine capabilities supported by RepRapFirmware.
- Notes
1This parameter is supported only in RepRapFirmware and can be used tell the firmware about the hardware on which it is running. If the P
parameter is present then the integer argument specifies the hardware being used. The following are currently supported:
M115 P0 Automatic board type selection if supported, or default if not M115 P1 Duet 0.6 M115 P2 Duet 0.7 M115 P3 Duet 0.85
2These parameters are only supported in Prusa Firmware. Parameter Unnnnnn
will check the firmware version provided. If the firmware version provided by the U code is higher than the currently running firmware, it will pause the print for 30s and ask the user to upgrade the firmware.
sample data M115
FIRMWARE_NAME:Prusa-Firmware 3.8.1 based on Marlin FIRMWARE_URL:https://github.com/prusa3d/Prusa-Firmware PROTOCOL_VERSION:1.0 MACHINE_TYPE:Prusa i3 MK3S EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
sample data M115 V
3.8.1
sample data on display for 30s or user interactionM115 U3.8.2-RC1
New firmware version availible: 3.8.2-RC1 Please upgrade.
M116: Wait
No | Yes | Yes | No | ??? | No | Yes | Yes | |
- Parameters
Pnnn
Tool numberHnnn
Heater numberCnnn
Chamber number- Examples
M116 M116 P1
Wait for all temperatures and other slowly-changing variables to arrive at their set values if no parameters are specified. See also M109
- Notes
M117: Get Zero Position
No | No | No | No | ??? | No | No | No: See M70 | |
- Example
M117
M117: Display Message
Yes | Yes | Yes | Yes | Yes | Yes1 | Yes | No | |
??? | No | No | No | No | Yes | No | No |
- Example
M117 Hello World
- Notes
In Prusa Firmware it is also used to display internal messages on LCD.1
M118: Echo message on host
1.1.4+ | Yes | No | No | Yes | ??? | Yes | ??? | |
Use this code to print a visible message to the host console, preceded by 'echo:'.
- Parameters
Pn
(RepRapFirmware only) Message targets(s): 0 = generic [default], 1 = USB, 2 = LCD, 3 = HTTP, 4 = TelnetS"msg"
(RepRepFirmware only) Message to send- Example (Marlin)
M118 Color changing to blue
- Example (RepRapFirmware)
M118 P2 S"Color changing to blue"
M118: Negotiate Features
- Example
M118 P42
This M-code is for future proofing. NO firmware or hostware supports this at the moment. It is used in conjunction with M115
's FEATURES keyword.
M119: Get Endstop Status
- Example
M119
In redeem, M119
can also be used to invert end stops.
- Example
M119 X1 1
This will invert end stop X1 (Inverted means switch is connected in Normally Open state (NO))
M120: Push
No | Yes | No | Yes | ??? | No | No | ??? | |
- Example
M120
- Current feedrate
- Whether moves are relative or absolute
- Whether extrusion is relative or absolute
- Whether the units are inches or mm
- Whether or not volumetric extrusion is in use
M121: Pop
- Example
M121
Yes | No | No | No | ??? | M121 | Yes | ??? | |
Yes | No | No | No | ??? | M120 | Yes | ??? | |
M122: Firmware dependent
M122: Diagnose (RepRapFirmware)
- Parameters
- Bmmm Expansion board number for which diagnostics are requested, default 0 which means main board
- Pnnn Optional parameter to specify what diagnostics are required. Caution: some values of P will crash the firmware deliberately to test error handling! See the Duet3D wiki for more details.
- "DSF" Immediate DSF diagnostics (RRF3/Duet3 only with attached SBC)
- Example
- M122
Sending an M122
causes the RepRap to transmit diagnostic information, for example via a USB serial link.
M122: Set Software Endstop (MK4duo)
No | No | No | No | ??? | No | Yes | ??? | |
Disabled or Enabled Software Endstop M122 S<0/1>
M122: Debug Stepper drivers (Marlin)
Yes | No | No | No | ??? | No | No | No | |
No | No | No | No | No | No | No | No |
Get diagnostic info about L6470 or Trinamic stepper drivers having a UART or SPI interface.
With Trinamic drivers there are some extra parameters, and depending on the configuration either basic or detailed information will be reported. Use parameters X
, Y
, Z
, etc. to limit the report only to the specified steppers, otherwise all steppers are reported. Pass I
to re-initialize the drivers. Use parameter S
to sample at regular intervals. The P
parameter can be used to set the sample interval in milliseconds.
- Example
M122
M123: Firmware dependent
M123: Tachometer value (RepRap & Prusa)
No | No | No | No | ??? | Yes1 | No | ??? | |
Sending an M123
causes the RepRap to transmit filament tachometer values from all extruders.
Sending a M123
is used in Prusa firmware to report fan speeds and fan pwm values.1
- Usage
M123
- Prusa firmware output1
E0: - Hotend fan speed in RPM
PRN1: - Part cooling fans speed in RPM
[email protected]: - Hotend fan PWM value
[email protected]: -Part cooling fan PWM value
- Examples1
echo E0:3240 RPM PRN1:4560 RPM [email protected]:255 [email protected]:255
M123: Endstop Logic (MK4duo)
- Parameters
Xn
X LogicYn
Y LogicZn
Z LogicIn
X2 LogicJn
Y2 LogicKn
Z2 LogicPn
Probe LogicDn
Door Logic
- Examples
M123 ; Print Status M123 X1 Y1 Z0 P0
M124: Firmware dependent
M124: Immediate motor stop
Immediately stops all motors.
M124: Set Endstop Pullup
- Parameters
Xn
X Pullup on/offYn
Y Pullup on/offZn
Z Pullup on/offIn
X2 Pullup on/offJn
Y2 Pullup on/offKn
Z2 Pullup on/offPn
Probe Pullup on/offDn
Door Pullup on/off
- Examples
M124 ; Print Status M124 X1 Y1 Z0 P0
M126: Open Valve
Yes | No | No | No | ??? | ??? | Yes | Yes | |
- Example
M126 P500
M126 in MakerBot
- Example
M126 T0
M127: Close Valve
- Example
M127 P400
M127 in MakerBot
- Example
M127 T0
M128: Extruder Pressure PWM
Support | Marlin | RepRapFirmware | Repetier | Smoothie | Klipper | Prusa | MK4duo | MakerBot |
Yes | No | No | No | ??? | ??? | Yes | ??? | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | |
- Example
M128 S255
PWM value to control internal extruder pressure. S255
is full pressure.
M129: Extruder pressure off
- Example
M129 P100
M130: Set PID P value
M301 | M301 | No | M301 | ??? | M301 | No | No | |
No | No | No | No | No | M301 | Yes | M301 |
- Parameters
Pnnn
heater numberSnnn
proportional (Kp)- Example
M130 P0 S8.0 ; Sets heater 0 P factor to 8.0
M131: Set PID I value
- Parameters
Pnnn
heater numberSnnn
integral (Ki)- Example
M131 P1 S0.5 ; Sets heater 1 I factor to 0.5
M132: Set PID D value
M301 | M301 | No | M301 | ??? | M301 | No | Yes | |
- Parameters
Pnnn
heater numberSnnn
derivative (Kd)- Example
M132 P0 S24 ; Sets heater 0 D factor to 24.0
M132 in MakerBot
- Example
M132 X Y Z A B
M133: Set PID I limit value
M301 | M301 | No | No | ??? | M301 | No | Yes | |
- Parameters
Pnnn
heater numberSnnn
integral limit (Ki)- Example
M133 P1 S264 ; Sets heater 1 I limit value to 264
M133 in MakerBot
Wait for the toolhead to reach its target temperature.
- Parameters
Tnn
: Extruder to wait forPnn
: Time limit, in seconds
- Example
M133 T0 P500 ; Wait for Tool 0 to reach target. Fail after 8:20.
No | No: See M500 | No | No: See M504 | ??? | No | No | Yes | |
??? | No | No | No | No | No | Yes | No |
- Example
M134
M134 in MakerBot
- Example
M134 T0 P500
M135: Set PID sample interval
No | Yes | No | No | ??? | No | No | Yes | |
- Parameters
Snnn
Heat sample time in seconds- Example
M135 S300
M135 in MakerBot
- Example
M135 T0
No | M301 | No | No | ??? | No | No | ??? | |
No | No | No | No | No | No | Debug | No |
- Example
M136 P1 ; print heater 0 PID parameters to host
??? | Yes | No | Yes | Yes | Yes | Yes | Yes |
- Parameters
Pnnn
Bed heater index1Hnnn
Heater number1Tnnn
Tool number2Snnn
Active/Target temperatureRnnn
Standby temperature1 2- Example
M140 S55
Set the temperature of the build bed to 55oC and return control to the host immediately (i.e. before that temperature has been reached by the bed).
- Notes
1 These parameters are only supported in RepRapFirmware. RepRapFirmware allows the bed heater to be switched off if the absolute negative temperature (-273.15) is passed as target temperature. In this case the current bed temperature is not affected:
M140 S-273.15
2 These parameters are only supported in MK4duo for Idle temperature
M140 S60 R30 M140 T1 S60 R30
There is an optional R field that sets the bed standby temperature:
M140 S65 R40
??? | No | No | No | Yes | No | uses M104 | No |
- Parameters
Pnnn
Chamber index1Hnnn
Heater number1Tnnn
Tool number2Snnn
Standby temperature1 2- Examples
M141 S30 M141 H0
- Notes
1 These parameters are only supported in RepRapFirmware and work just like in M140.
2 These parameters are only supported in MK4duo and work just like in M140.
M142: Firmware dependent
M142: Holding Pressure
No | No | No | No | ??? | No | No | ??? | |
- Example
M142 S1
M142: Set Cooler Temperature (Fast)
No | No | No | No | ??? | No | Yes | No | |
- Parameters
Tnnn
Tool numberSnnn
Standby temperature- Examples
M142 S60 M142 S60 R30 M141 T1 S60 R30
Set the temperature of the cooler
M143: Maximum heater temperature
- Parameters
H
Heater number (RepRapFirmware 1.17 and later, default 1 which is normally the first hot end)S
Maximum temperature- Examples
M143 S275 ; set the maximum temperature of the hot-end to 275°C M143 H0 S125 ; set the maximum bed temperature to 125C
The default maximum temperature for all heaters was 300°C prior to RepRapFirmware version 1.13, and 262°C from 1.13 onwards. From RepRapFirmware 1.17 onwards, the default maximum temperatures are 262C for extruders and 125C for the bed.
When the temperature of the heater exceeds this value, countermeasures will be taken.
M144: Bed Standby
- Parameters
- Pnn Bed heater number, default 0
- Sn 0 = set bed heater to standby (default), 1 = set bad heater active
- Example
M144
Switch the bed heater to its standby temperature. M140 S1
turns it back to its active temperature.
M146: Set Chamber Humidity
No | No | No | No | ??? | No | No | No | |
- Parameters
Rnnn
Relative humidity in percent- Example
M146 R60
M149: Set temperature units
- Parameters
C
Flag to treat temperature as degrees CelsiusK
Flag to treat temperature as Kelvin- Example
M149 K
It affects the S
or R
values in the codes M104
, M109
, M140
, M141
, M143
, M190
and G10.
The default is M149 C
M150: Set LED color
Yes | See below | No | No | ??? | No1 | Yes | No | |
- Parameters
Rnnn
Red componentUnnn
Green componentBnnn
Blue componentWnnn
White component (Marlin)Pnnn
Brightness (0-255) (Marlin, also RepRapFirmware 2.03 and later)P
Set full brightness (Marlin)Snnn
(RepRapFirmware) Number of individual LEDs to set to these coloursFn
(RepRapFirmware) Following command action. F0 (default) means this is the last command for the LED strip, so the next M150 command starts at the beginning of the strip. F1 means further M150 commands for the remainder of the strip follow this one.Xn
(RepRapFirmware) LED type: X0 (default) = DotStar, X1 = NeoPixel. This parameter is remembered from one call to the next, so it only needs to be given once.Ynn
(RepRapFirmware) Brightness, 0-31 (alternative to P 0-255)Qnnn
(RepRapFirmware) Use specified SPI frequency (in Hz) instead of default frequency. This parameter is only processed if X parameter also present. When using NeoPixels, only frequencies between about 2.5MHz and 4MHz will work.- Example
M150 R255 U128 B192
M150 X1 F3000000 ; set LED type to NeoPixel and set SPI frequency to 3MHz M150 R255 P128 S20 F1 ; set first 20 LEDs to red, half brightness, more commands for the strip follow M150 U255 B255 P255 S20 ; set next 20 LEDs to cyan, full brightness, finished programming LED strip
Set BlinkM, Neopixel, and/or other LED light color and intensity with RGBW component values from 0 to 255. Some LCD controllers use this interface for a backlight. Firmware may override the set color to indicate the current printer status.
RepRapFirmware uses this command to control DotStar or NeoPixel LED strips on controllers that provide a connector for this purpose. When using NeoPixel strips there is a firmware-dependent maximum number of LEDs in the strip supported determined by the size of the DMA buffer.
- Notes
In Prusa Firmware this G-code is deactivated by default, must be turned on in the source code.1
M154: Auto Report Position
2.0.8.1 | No | No | No | No | No | No | No | |
Hosts normally monitor printer position by sending M114
every couple of seconds. This adds more serial traffic and fails if the command queue is full. M154
reduces traffic by setting the firmware to report the 'projected' position at regular intervals. This behavior is disabled by default for best compatibility with existing hosts. If the firmware supports M154
the output of M115
will report the AUTOREPORT_POS
capability.
- Usage
M154 Snnn
: Set the auto-report interval in seconds. Set the interval to 0 to disable.
M155: Automatically send temperatures
1.1.0+ | No | Yes | No | ??? | Yes1 | Yes | No | |
- Parameters
Snnn
enable sending temperatures = 1, disable = 0Snnn
Interval in seconds between auto-reports. S0 to disable. (Marlin) Prusa has a Maximum: 2551Cnn
Activate auto-report function (bit mask). Default is temperature.1
- C bitmap1
bit 0 = Auto-report temperatures
bit 1 = Auto-report fans
bit 2 = Auto-report position
bit 3 = free
bit 4 = free
bit 5 = free
bit 6 = free
bit 7 = free
- Examples
M155 S1 ; Enable temperature report (Marlin: every 1 second) M155 S0 ; Stop reporting temperatures M155 S4 ; Report temperatures every 4 seconds (Marlin) M155 S4 C7; Reports temperatures, fans and position every 4 seconds (Prusa)1
Hosts normally monitor printer temperatures by sending M105
every couple of seconds. This not only adds serial traffic but it will fail whenever the command queue is full. M155
addresses these problems by telling the firmware to automatically report temperatures at regular intervals. This behavior is disabled by default for best compatibility with existing hosts. If the firmware supports M155
the output of M115
will report the AUTOREPORT_TEMP
capability:
Cap:AUTOREPORT_TEMP:1
Prusa Firmware 3.10.0+ also adds capabilities:
Cap:AUTOREPORT_FANS:1 Cap:AUTOREPORT_POSITION:1 Cap:EXTENDED_M20:1
- Example
M160 S4
This command has been superseded by the tool definition command M563
(see below).
M160 S4 G1 X90.6 Y13.8 E2.24:2.24:2.24:15.89 G1 X70.6 E0:0:0:42.4 G1 E42.4:0:0:0
1.1.0+ | M567 | 0.92+ | No | ??? | No | Yes | No | |
- Parameters
Snnn
extruder numberPnnn
weight
See Repetier Color Mixing for more informations.
M164: Store weights
1.1.0+ | No | 0.92 | No | ??? | No | Yes | No | |
- Parameters
Snnn
virtual extruder numberPnnn
store to eeprom (P0 = no, P1 = yes)
M165: Set multiple mix weights
1.1.0+ | M567 | No: | No | ??? | No | Yes | No | |
- Parameters
A B C D H I
A[factor]
Mix factor for extruder stepper 1B[factor]
Mix factor for extruder stepper 2C[factor]
Mix factor for extruder stepper 3D[factor]
Mix factor for extruder stepper 4H[factor]
Mix factor for extruder stepper 5I[factor]
Mix factor for extruder stepper 6
- Set multiple mix factors for a mixing extruder.
- Factors that are left out will be set to 0.
- All factors together must add up to 1.0.
??? | Yes | No | No | Yes | Yes | M116 | Yes |
- Parameters
Snnn
accurate target temperature, waits until heating and cooling (Marlin and Prusa)- Example
M190 S60
Wait for the bed temperature to reach 60 degrees, printing out the temperatures once per second.
2.0.0+ | 1.17+ | No | No | ??? | No | Yes | No | |
No | No | No | No | Yes | No | No | No |
- Example
M191 S60
- Parameters
Snnn
accurate target temperature, waits until heating and cooling (Marlin)
M192: Wait for Probe Temperature
Use M192
to dwell until the probe is at or above a given temperature.
M200: Set filament diameter
Yes | 1.19+ | Yes | Yes | ??? | Yes | Yes | No | |
Volumetric Extrusion is a firmware mode (and an option you can set in some slicers) wherein all extrusion amounts are specified as a volume —using cubic millimeters or inches (i.e., mm3 or in3)— instead of a linear distance. This makes it possible to use the same G-code with any filament diameter.
M200
tells the firmware what the filament diameter is, and (if non-zero) to enable Volumetric Extrusion.
Send M200
without parameters to get the current Volumetric Extrusion state and filament diameters.
Note that slicer-commanded retraction amounts must also be specified in mm3 since the E axis is interpreted as a volume. However, when using Firmware Retraction (G10
/ G11
) the retractions specified by M207
are still set in linear units.
- Parameters (Marlin)
D[linear]
Set the filament diameter in current units. If non-zero, enable Volumetric Extrusion.T[index]
Select the target extruder. If omitted, the active extruder.S[bool]
Enable or Disable Volumetric Extrusion (without modifying the filament diameter).L[limit]
Set the Maximum Extrusion Volume in mm3 per second. (Ignores units set byG20
.) UseL0
for no limit.- Examples (Marlin)
M200 D0 ; Disable Volumetric Extrusion on all extruders M200 D1.75 ; Set filament diameter for the current extruder to 1.75mm M200 T1 D2.85 ; Set filament diameter for E2 to 1.75mm M200 T1 L12 ; Set Maximum Extrusion Volume for E2 to 12mm3 M200 S1 ; Enable Volumetric Extrusion using the last-set diameters
- Parameters (RepRapFirmware)
Daaa:bbb:ccc...
Set filament diameter to aaa for extruder 1, bbb for extruder 2, etc. If any of aaa, bbb etc. are zero then Volumetric Extrusion is disabled for that extruder.Daaa
Set filament diameter (or disable Volumetric Extrusion) for all extruders.- Examples (RepRapFirmware)
M200 D0 ; Disable Volumetric Extrusion on all extruders M200 D1.75 ; Set all extruder filament diameters to 1.75mm M200 D1.75:3.0:1.75 ; Set extruder 0 to 1.75mm, E1 to 3.0mm and the rest to 1.75mm
M201: Set max acceleration
Yes | Yes | Yes | No | No | Yes | Yes | No | |
No | Yes | No | No | No | Yes | No | No |
- Parameters
Xnnn
Acceleration for X axis in units/s2Ynnn
Acceleration for Y axis in units/s2Znnn
Acceleration for Z axis in units/s2Ennn
Acceleration for the active or specified extruder in units/s2- Example
M201 X1000 Y1000 Z100 E2000
Set the acceleration that axes can do in units/s2 for print moves.
The M201
command is intended to define the machine's physical limits. Slicers should use the M204
command to define accelerations for a job and leave M201
settings to the user.
Yes | No | Yes | No | ??? | Yes | Yes | No | |
No | Yes | No | No | No | No | No | No |
Set max travel acceleration in units/s^2 for travel moves (M202 X1000 Y1000
). Unused in Marlin!!
M203: Firmware dependent
M203: Set maximum feedrate
Yes | Yes | Yes | Yes | No | Yes | Yes | No | |
- Parameters
Xnnn
Maximum feedrate for X axisYnnn
Maximum feedrate for Y axisZnnn
Maximum feedrate for Z axisEnnn
Maximum feedrate for extruder drivesInnn
(RepRapFirmware) Minimum feed rate (optional)- Example
M203 X6000 Y6000 Z300 E10000
Sets the maximum feedrates that your machine can do in mm/min. (Marlin uses mm/sec).
This command is intended to define the machine limits. Slicers should not generate M203 commands, instead they should use the F parameter on G0, G1 etc. command to specify the requested speeds.
M203 (Repetier): Set temperature monitor
No | No | Yes | No | ??? | No | No | No | |
Set temperature monitor to Sx
. Repetier Firmware only.
M204: Firmware dependent
Yes | 1.18+ | Yes | Yes | Yes | Yes | Yes | No | |
- Parameters (RepRapFimware)
Pnnn
Acceleration for printing movesTnnn
Acceleration for travel moves- Example
M204 P500 T2000
Accelerations set with M204
apply to the move as a whole based on the type of move. Use M201
to set limits for each axis individually. Both of these limits will be applied during printing.
- Parameters (MK4duo)
Pnnn
Acceleration for printing movesVnnn
Acceleration for travel movesRnnn
Acceleration for Retraction for Tools with T code- Example
M204 P500 V2000 T0 R5000
Other firmwares:
S[accel]
Set Acceleration for normal moves in units/s2T[accel]
Set Acceleration for retract/recover moves in units/s2B[ms]
Set Minimum Segment Time to prevent planner starvation.
Marlin notes: Since version 1.0.2-1 the M204
options are:
P[accel]
Set Acceleration for Printing moves. (i.e., Any XYZ motion plus E.)R[accel]
Set Acceleration for Retract moves. (i.e., E-axis only moves.)T[accel]
Set Acceleration for Travel moves. (i.e., without E movement)
- Example
Set the acceleration for printing movements to 800mm/s^2, for travels to 3000mm/s^2 and for retracts to 9000mm/s^2.
M204 P800 T3000 R9000
M204 (Repetier): Set PID values
- Usage
M204 X[Kp] Y[Ki] Z[Kd]
Set one or more PID parameters. Values are 100 * real value.
M205: Firmware dependent
M205: Advanced settings
Yes | M566 | Yes | Yes | No | Yes | Yes | No | |
- Sprinter / Marlin
- Minimum travel speed =
S[printing]
T[travel]
B[min segment time] X[max XY jerk] Z[max Z jerk] E[max E jerk]
- Sprinter / Marlin Example
M205 X30 Z5 ; Set X/Y Jerk to 30mm/s, Z jerk to 5mm/s
Smoothieware uses a different algorithm: [1]
- X[xy junction deviation] Z[z junction deviation] S[minimum planner speed].
- Z junction deviation only applies to z only moves
- 0 disables junction deviation for Z
- -1 uses global junction deviation
- Smoothie example
M205 X0.05 ; set X/Y Junction Deviation
M205 (Repetier): EEPROM Report
No | No | Yes | No | No | No | No | No | |
Output EEPROM settings. Repetier Firmware only.
M206: Firmware dependent
M206: Offset axes
Yes | Yes | No | Yes | ??? | Yes | Yes | No | |
- Parameters
Xnnn
X axis offsetYnnn
Y axis offsetZnnn
Z axis offset- Example
M206 X10.0 Y10.0 Z-0.4
The values specified are added to the endstop position when the axes are referenced. The same can be achieved with a G92
right after homing (G28
, G161
With Marlin firmware, this value can be saved to EEPROM using the M500
command.
A similar command is G10
, aligning these two is subject to discussion.
In builds of RepRapFirmware that support CNC workplace coordinates, using this command is equivalent to using G10 L2 P1 to set the coordinate offsets for workplace 1.
M206 (Repetier): Set EEPROM value
Set a Repetier Firmware EEPROM value.
- Parameters
T[type]
Value typeP[pos]
Value position[S(long)]
An integer value[X(float)]
A float value
- Example
M206 T3 P39 X19.9 ; Set Jerk to 19.9
M207: Firmware dependent
M207: Set retract length
Yes | Yes | No | Yes | ??? | Yes | Yes | ??? | |
No | No | No | No | Yes | No | No | Yes |
- Parameters
Snnn
positive length to retract, in mmRnnn
positive or negative additional length to un-retract, in mm (RepRapFirmware only)Fnnn
retraction feedrate, in mm/minTnnn
feedrate for un-retraction if different from retraction, mm/min (RepRapFirmware 1.16 and later only)Znnn
additional zlift/hop- Example
M207 S4.0 F2400 Z0.075
Set the retract length used by the G10
and G11
commands. Units are in mm regardless of M200
setting.
Machinekit uses different parameters and speed units for M207
. Use P
to set retract length in mm. Use Q
to set retract velocity in mm/s. For firmware retraction Machinekit uses G22
and G23
in place of G10
and G11
M207 Calibrate Z axis with Z max endstop
No | Use G1 S3 ... | No | No | ??? | No | No | ??? | |
??? | No | No | No | No | No | No | No |
- Example
M207
M207 (Repetier): Set jerk without saving to EEPROM
No | M566 | Yes | No | ??? | No | No | No | |
No | ??? | No | ??? | No | No | ??? | No |
Repetier Firmware only. Change the maximum instantaneous speed change ("jerk") values, but don't store the change in EEPROM.
Since Repetier 0.91 December 2013 [2] (if not earlier)
- Parameters
Xnnn
Temporarily set XY jerk in mm/sZnnn
Temporarily set Z jerk in mm/sEnnn
Temporarily set Extruder jerk in mm/s
- Example
M207 X10 ; Change the X/Y Jerk to 10mm/s
M208: Firmware dependent
M208: Set unretract length
Yes | Use M207 | No | Yes | ??? | Yes | Yes | ??? | |
- Parameters
Snnn
positive length surplus to theM207 Snnn
, in mmFnnn
feedrate, in mm/sec
Sets the "recover" (aka "unretract") length.
M208 (RepRapFirmware): Set axis max travel
No | Yes | No | No | ??? | No | No | ??? | |
- Parameters
Snnn
0 = set axis maximum (default), 1 = set axis minimumXnnn
X axis limitYnnn
Y axis limitZnnn
Z axis limit- Example
- M208 X200 Y200 Z90 ; set axis maxima
- M208 X-5 Y0 Z0 S1 ; set axis minima
The values specified set the software limits for axis travel in the specified direction. The axis limits you set are also the positions assumed when an endstop is triggered.
With automatic retract detection, G-code generated by slicers without G10
/G11
support can take advantage of Firmware Retraction. The firmware converts E-only moves into retract/recover moves, using the firmware's tuned lengths and feedrates in place of the original E moves.
- Example
M209 S1
The S
parameter turns Automatic Retract Detection on (1) or off (0).
M210: Set homing feedrates
- Example
M210 X1000 Y1500
Yes | Use M564 | No | No | ??? | No | No | ??? | |
- Example
M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
- Example
M211 X0 S1
Enables X min endstop
- Example
M211
Partial* | Use G31 | No | No | ??? | No | No | ??? | |
- Example
M212 Z-0.2
PrintrBot suggests that the user make minor (0.1-0.2) adjustments between attempts and immediately executes M500
& M501
after setting this.
M217: Toolchange Parameters
Yes | Use tool change files | No | No | ??? | No | No | ??? | |
If arguments are given, sets tool-change retract and prime length (mm), prime feedrate (mm/m), retract feedrate (mm/m), and park position/raise (mm) or Z raise (mm): S<length> P<prime_speed> R<retract_speed> X<xpos> Y<ypos> Z<zraise>. XY arguments require SINGLENOZZLE_SWAP_PARK. If no arguments are given, reports current values. Currently used to set the SINGLENOZZLE
tool-change options in Marlin 2.0 and up. May be extended for other tool-changing systems in the future.
M218: Set Hotend Offset
Yes | Use G10 | No | No | ??? | Yes1 | Yes | ??? | |
- Example
M218 T1 X50 Y0.5
- Notes
In Prusa Firmware this G-code is only active if EXTRUDERS
is higher then 1 in the source code. On Original i3 Prusa MK2/s MK2.5/s MK3/s it is not active.1
- Parameters
Snnn
Speed factor override percentage (0..100 or higher)- Example
M220 S80
Yes | Yes | Yes | Yes | ??? | Yes1 | Yes | ??? | |
- Parameters
Snnn
Extrude factor override percentage (0..100 or higher), default 100%Dnnn
Extruder drive number (RepRapFirmware only), default 0Tnnn
Extruder drive number (Prusa Firmware only), default 0 if not set.1- Example
M221 S70 M221 S95 D1 M221 S85 T1
Sets extrude factor override percentage. In the case of RepRapFirmware and Prusa Firmware, sets the extrusion factor percentage for the specified extruder drive only.
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: G-code Initiated Pause
??? | No | Yes | No | Yes | No | No | No |
- Example
M226
Initiates a synchronous pause (pauses after all previous commands from the same stream have been completed). That is, program execution is stopped and the printer waits for user interaction. This matches the behaviour of M1
in the NIST RS274NGC G-code standard and M0
in Marlin firmware.
M226: Wait for pin state
Yes | see M577 | Yes | No | ??? | Yes | Yes | ??? | |
- Parameters
Pnnn
pin numberSnnn
pin state- Example
M226 P2 S1
- Example
M227 P1600 S1600
P and S are steps.
"Reverse and Prime" means, the extruder filament is retracted some distance when not in use and pushed forward the same amount before going into use again. This shall help to prevent drooling of the extruder nozzle. Teacup firmware implements this with M101
/M103
- Example
M228
See also M227
- Example
M229 P1.0 S1.0
P
and S
are extruder screw rotations. See also M227
- Example
M230 S1
S1
Disable wait for temperature change
S0
Enable wait for temperature change
M231: Set OPS parameter
No | No | Yes | No | ??? | No | No | ??? | |
M231 S[OPS_MODE] X[Min_Distance] Y[Retract] Z[Backslash] F[RetractMove]
M240: Trigger camera
Yes | No | No | No | ??? | No1 | Yes | ??? | |
- Example
M240
Triggers a camera to take a photograph. (Add to your per-layer G-code.)
- Notes
??? | No | No | No | No | No | Debug: Echo off | No |
- Example
M240
??? | No | No | No | No | No | Debug: Echo on | No |
- Example
M241
M245: Start cooler
No | Use M106 | No | No | ??? | No | No | ??? | |
- Example
M245
M246: Stop cooler
- Example
M246
M250: Set LCD contrast
Yes | Use M918 | No | No | ??? | Yes | Yes | No | |
- Example
M250 C20
M256: Set LCD brightness
2.0.9.3 | No | No | No | No | No | No | No | |
- Example
M256 B128
Set the LCD brightness B<brightness value> (value 0..255), if available.
- Examples
M251 S0 ; Reset M251 S1 ; Print M251 S2 ; Store to Z length (also EEPROM if enabled)
(This is a Repetier-Firmware only feature.)
M260: i2c Send Data
1.1.0+ | 1.21+ | No | No | ??? | No | Yes | No | |
Buffer and send data over the i2c bus. Use A
to set the address from 0-127. Add up to 32 bytes to the buffer with each B
. Send and reset the buffer with S
- Parameters (Marlin, MK4duo)
- Ann I2C address
- Bnn Byte to buffer or send
- S If present, sends the bytes that have been buffered
- Examples
M260 A5 B65 S ; Send 'A' to Address 5 now M260 A0 ; Set address to 0 (broadcast) M260 B77 ; M M260 B97 ; a M260 B114 ; r M260 B108 ; l M260 B105 ; i M260 B110 ; n M260 S1 ; Send the current buffer
- Ann I2C address
- Bnn:nn:nn... Bytes to send
- Snn Number of bytes to receive (optional, RepRapFirmware 2.02 and later)
- Examples
M260 A5 B65 ; Send 'A' to address 5 M260 A"0x7F" B65 ; Send 'A' to address 7F (hex) M260 A0
