G-code
Revision as of 14:33, 22 June 2017 by Chrishamm (talk | contribs) (Added 'R' parameter to M291 and improved formatting)
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications as well. See also on Wikipedia's G-code article.
There are a few different ways to prepare GCode for a printer. One method woull be to use a slicing program such as Slic3r, Skeinforge or Cura. These programs import a CAD model, slice it into layers, and output the GCode required to print each layer. Slicers are the easiest way to go from a 3D model to a printed part, however the user sacrifices some flexibility when using them. Another option for GCode generation is to use a lower level library like mecode. Libraries like mecode give you precise control over the tool path, and thus are useful if you have a complex print that is not suitable for naive slicing. The final option is to just write the GCode yourself. This may be the best choice if you just need to run a few test lines while calibrating your printer.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years. This particular page is the master page for RepRap. Nowhere in here should the same code be used for two different things; there are always more numbers to use... The rule is: add your new code here, then implement it.
Unfortunately human nature being what it is, the best procedures aren't always followed, so some multiple uses of the same code exist. The rule which should be followed is that later appearances of a code on this page (later than the original use of a code), are deprecated and should be changed, unless there is a good technical reason (like the general G-Code standard) why a later instance should be preferred. Note that the key date is appearance here, not date of implementation.
Introduction
N3 T0*57
N4 G92 E0*67
N5 G28*22
N6 G1 F1500.0*82
N7 G1 X2.0 Y2.0 F3000.0*85
N8 G1 X3.0 Y3.0*33
Gcode can also be stored in files on SD cards. A file containing RepRap Gcode usually has the extension .g, .gco or .gcode. Files for BFB/RapMan have the extension .bfb. Gcode stored in file or produced by a slicer might look like this:
G92 E0
G28
G1 F1500
G1 X2.0 Y2.0 F3000
G1 X3.0 Y3.0
Slicers will (optionally?) add GCode scripts to the beginning and end of their output file to perform specified actions before and/or after a print such as z-probing the build-area, heating/cooling the bed and hotend, performing ooze free "nozzle wipe" startup routine, switching system power on/off, and even "ejecting" parts. More info on the Start GCode routines and End GCode routines pages.
Support Marlin RepRapFirmware Klipper Prusa Buddy Repetier Smoothie Druid MK4duo
Partial ??? ??? ??? ??? Experimental deprecated ??? Partial
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa MakerBot
??? No ??? Yes ??? Yes automatic ??? ???
Here means:
{{yes}}
The Gcode is fully supported by the firmware.
{{partial}} or {{experimental}}
There is some support for the Gcode. Often it is required to check out the source code branch for the firmware (usually stored in a different branch) or to flip configuration switches on the mainboard.
automatic
The firmware handles this Gcode automatically, so there's no need to send the command. An example is power supply on/off Gcode (M80/M81) in the Teacup firmware.
It is unknown if the firmware supports this Gcode. You may want to test this yourself before using it in production.
{{no}}
The firmware does not support this Gcode.
deprecated
The firmware deprecated this Gcode. The firmware author(s) should amend the deprecated Gcode on this page with workarounds (if needed) and the last supported firmware version that will accept this Gcode.
Fields
A RepRap Gcode is a list of fields that are separated by white spaces or line breaks. A field can be interpreted as a command, parameter, or for any other special purpose. It consists of one letter directly followed by a number, or can be only a stand-alone letter (Flag). The letter gives information about the meaning of the field (see the list below in this section). Numbers can be integers (128) or fractional numbers (12.42), depending on context. For example, an X coordinate can take integers (X175) or fractionals (X17.62), but selecting extruder number 2.76 would make no sense. In this description, the numbers in the fields are represented by nnn as a placeholder.
In RepRapFirmware, some parameters can be followed by more than one number, with colon used to separate them. Typically this is used to specify extruder parameters, with one value provided per extruder. If only one value is provided where a value is needed for each extruder, then that value is applied to all extruders.
Letter Meaning
Tnnn Select tool nnn. In RepRap, a tool is typically associated with a nozzle, which may be fed by one or more extruders.
U,V,W Additional axis coordinates (RepRapFirmware)
Hnnn Parameter - used for heater number in PID Tuning
Ennn Length of extrudate. This is exactly like X, Y and Z, but for the length of filament to consume.
Comments
Gcode comments begin at a semicolon, and end at the end of the line:
N3 T0*57 ; This is a comment
N4 G92 E0*67
; So is this
N5 G28*22
Special fields
N: Line number
Yes Yes ??? ??? ??? Yes ??? ??? Yes
 ? Yes ??? Yes Yes Yes Yes ??? ???
Example
N123
If checking is supported, the RepRap firmware expects line numbers to increase by 1 each line, and if that doesn't happen it is flagged as an error. But you can reset the count using M110 (see below).
*: Checksum
 ? Yes ??? Yes ??? No Yes ??? ???
Example: *71
The firmware compares the checksum against a locally-computed value. If they differ, it requests a repeat transmission of the line.
Checking
Example
N123 [...G Code in here...] *71
The RepRap firmware checks the line number and the checksum. You can leave both of these out - RepRap will still work, but it won't do checking. You have to have both or neither though. If only one appears, it produces an error.
int cs = 0;
   cs = cs ^ cmd[i];
Buffering
Yes Yes ??? ??? ??? ??? ??? ??? Yes
Yes ??? ??? Yes ??? Yes Yes ??? ???
RepRapFirmware also implements an internal queue to ensure that certain codes (like M106) are executed in the right order and not when the last move has been added to the look-ahead queue. This feature is not available in RepRapFirmware-dc42.
G-commands
G0 & G1: Move
Yes Yes ??? ??? ??? Yes Yes ??? Yes
Yes Yes Yes Yes Yes Yes Yes ??? Yes
  • G0 : Rapid linear Move
  • G1 : Linear Move
Usage
Parameters
Not all parameters need to be used, but at least one has to be used
Snnn Flag to check if an endstop was hit (S1 to check, S0 to ignore, S2 see note, default is S0)1
Examples
G0 X12               ; move to 12mm on the X axis
G0 F1500             ; Set the feedrate to 1500mm/minute
G1 X90.6 Y13.8 E22.4 ; Move to 90.6mm on the X axis and 13.8mm on the Y axis while extruding 22.4mm of material
G1 F1500           ; Set feedrate to 1500mm/m
G1 X50 Y25.3 E22.4 ; Move and extrude
In the above example, we first set the feedrate to 1500mm/m, then move to 50mm on X and 25.3mm on Y while extruding 22.4mm of filament between the two points.
G1 F1500                 ; Feedrate 1500mm/m
G1 X50 Y25.3 E22.4 F3000 ; Accelerate to 3000mm/m
However, in the above example, we set a feedrate of 1500 mm/m, then do the same move, but accelerating to 3000 mm/m. Everything stays synchronized, so extrusion accelerates right along with X and Y movement.
The RepRap spec treats the feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over the acceleration and deceleration of the printer head in a way that ensures everything moves smoothly together and the right volume of material is extruded at all points.3
Notes
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the S parameter in this way, as damage may occur if you assume incorrectly. In RepRapFirmware, using the S1 or S2 parameter on a delta printer causes the XYZ parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1.
4RepRapFirmware provides an additional 'R1' parameter to tell the machine to go back to the coordinates a print was previously paused at. If this parameter is used and the code contains axis letters, an offset will be added to the pause coordinates (e.g. G1 R1 Z5).
G2 & G3: Controlled Arc Move
Yes1 No ??? ??? ??? Yes Yes ??? Yes
Yes Yes No No Yes Experimental No ??? ???
Usage
Parameters
Examples
G2 X90.6 Y13.8 I5 J10 E22.4
(Move in a Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
G3 X90.6 Y13.8 I5 J10 E22.4
(Move in a Counter-Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
Notes
1In Marlin Firmware not implemented for DELTA and SCARA printers.
G4: Dwell
Pause the machine for a period of time.
Parameters
Pnnn Time to wait, in milliseconds
Snnn Time to wait, in seconds (Only on Repetier, Marlin, Smoothieware, and RepRapFirmware 1.16 and later)
Example
G4 P200
On Marlin, Smoothie and RepRapFirmware, the "S" parameter will wait for seconds, while the "P" parameter will wait for milliseconds. "G4 S2" and "G4 P2000" are equivalent.
G6: Direct Stepper Move
No Use G1 S2 ??? ??? ??? No No ??? No
No No No No No No No ??? No
Perform a direct, uninterpolated, and non-kinematic synchronized move of one or more steppers directly. Units may be linear (e.g., mm or inches on DELTA) or specified in degrees (SCARA). This command is useful for initialization, diagnostics, and calibration, and should be disabled on production equipment. This type of move can be potentially dangerous, especially for deltabots, so implementations should do their best to limit movement to prevent twerking and damaging the carriage assembly.
Parameters
Annn Stepper A position or angle
Bnnn Stepper B position or angle
Cnnn Stepper C position or angle
R Relative move flag
SCARA Examples
G6 A45     ; Move SCARA A stepper to the 45° position
G6 B20 R   ; Move SCARA B stepper 20° counter-clockwise
DELTA Example
G6 C10 R   ; Move DELTA C carriage up by 10mm
G10: Tool Offset
No Yes ??? ??? ??? No No ??? No
??? No No No Yes No No ??? ???
Usage
G10 Pnnn Xnnn Ynnn Znnn Rnnn Snnn1
Parameters
Pnnn Tool number
Xnnn X offset
Ynnn Y offset
U,V,Wnnn U, V and W axis offsets5
Znnn Z offset2
Rnnn Standby temperature(s)
Snnn Active temperature(s)
Examples
G10 P2 X17.8 Y-19.3 Z0.0
(sets the offset for tool (or in older implementations extrude head) 2 to the X, Y, and Z values specified)
G10 P1 R140 S205
(set standby and active temperatures3 for tool 1)
The precise meaning of the X, Y (and other offset) values is: with no offset this tool is at this position relative to where a tool with offset (0, 0, 0) would be. So if the tool is 10mm to the left of a zero-offset tool the X value would be -10, and so on.
See also M585.
Notes
1Marlin uses G10/G11 for executing a retraction/unretraction move. The RepRapPro version of Marlin supports G10 for tool offset. Smoothie uses G10 for retract and G10 Ln for setting workspace coordinates.
2It's usually a bad idea to put a non-zero Z value in as well unless the tools are loaded and unloaded by some sort of tool changer or are on indepedent carriages. When all the tools are in the machine at once they should all be set to the same Z height.
4The NIST G-code standard mentions an additional L parameter, which is ignored (except in smoothie). This command is subject to discussion.
5Tool offsets are applied after any X axis mapping has been performed. Therefore if for example you map X to U in your M563 command to create the tool, you should specify a U offset not an X offset. If you map X to both X and U, you can specify both offsets.
G10: Retract
Yes dc42,ch ??? ??? ??? Yes: 0.92 Yes ??? Yes
??? No No No No No No ??? ???
Parameters
Snnn retract length (S1 = long retract, S0 = short retract = default) (Repetier only)
Example
G10
Retracts filament according to settings of M207 (Marlin, RepRapFirmware) or according to the S value (Repetier).
RepRapFirmware recognizes G10 as a command to set tool offsets and/or temperatures if the P parameter is present, and as a retraction command if it is absent.
G11: Unretract
Parameters
Example
G11
Unretracts/recovers filament according to settings of M208 (Marlin, RepRapFirmware) or according to the S value (Repetier).
G17..19: Plane Selection (CNC specific)
No No ??? ??? ??? ??? ??? ??? No
Yes ??? ??? ??? Yes No ??? ??? ???
  • G17 : XY (default)
  • G18 : ZX
  • G19 : YZ
G20: Set Units to Inches
Yes Yes No Yes Yes No Yes ??? ???
Example
G20
G21: Set Units to Millimeters
Yes Yes Yes Yes Yes Yes Yes ??? ???
Example
G21
G22 & G23: Firmware controlled Retract/Precharge
No No ??? ??? ??? No No ??? No
Usage
G22 ; Retract
G23 ; Unretract/Precharge
Relying on machine's firmware to execute extrusion retract/precharge move, instead of having slicer generating to E axis G1 movement. The retract/precharge length, velocity is handled by the machine firmware.
G26: Mesh Validation Pattern
Template:Yes:1.1.0 No ??? ??? ??? No No ??? No
Usage
G26 C P O2.25 ; Do a typical test sequence
The G26 Mesh Validation Pattern is designed to be used in conjunction with various Mesh Bed Leveling systems – those that adjust for an uneven —rather than just tilted— bed. The G26 command prints a single layer pattern over the entire print bed, giving a clear indication of how accurately every mesh point is defined. G26 can be used to determine which areas of the mesh are less-than-perfect and how much to adjust each mesh point.
G26 has large feature list, including a built-in test that extrudes material onto the bed. By default this is configured for PLA temperatures and a nozzle size of 0.4mm. (This will be adjustable in an upcoming version of Marlin.)
See the G26_Mesh_Validation_Tool.cpp file in the Marlin source code for full documentation of the G26 parameter list.
G28: Move to Origin (Home)
Yes Yes ??? ??? ??? Yes Yes ??? Yes1
Parameters
This command can be used without any additional parameters.
Examples
G28     ; Home all axes
G28 X Z ; Home the X and Z axes
When the firmware receives this command, it quickly moves the specified axes (or all axes if none are given) to the endstops, backs away from each endstop by a short distance, and slowly bumps the endstop again to increase positional accuracy. This process, known as "Homing", is required to determine the position of the print carriage(s). Some firmware may even forbid movement away from endstops and other operations until the axes have been homed.
The X, Y, and Z parameters act only as flags. Any coordinates given are ignored. For example, G28 Z10 results in the same behavior as G28 Z. Delta printers cannot home individual axes, but must always home all three towers, so the X Y Z parameters are simply ignored on these machines.
Marlin firmware (version 1.1.0 and up) provides an option called Z_SAFE_HOMING for printers that use a Z probe to home Z instead of an endstop. With this option, the XY axes are homed first, then the carriage moves to a position –usually the middle of the bed– where it can safely probe downward to home Z.
RepRapFirmware uses macro files to home either all axes or individual axes. If all axes are homed, the file homeall.g is processed. For individual axes the homex.g, homey.g, or homez.g file will be used. On Delta printers, G28 command will always home all three towers by processing the homedelta.g file, regardless of any X Y Z parameters.
Because the behavior of G28 is unspecified, it is recommended not to automatically include G28 in your ending GCode. On a Cartesian this will result in damaging the printed object. If you need to move the carriage at the completion of a print, use G0 or G1.
Notes
1 MK4duo has a B parameter that tells the printer to return to the coordinates it was at before homing.
G29: Detailed Z-Probe
Yes Yes, 1.17 and later ??? ??? ??? Yes: 0.91.7 No, see G32 ??? Yes
??? No No No Yes Yes No ??? ???
This command uses a probe to measure the bed height at 3 or more points to determine its tilt and overall flatness. It then enables compensation so that the nozzle will remain parallel to the bed. The printer must be homed with G28 before using this command.
Each firmware behaves differently and depends on the type of bed leveling that's been configured. For example, Marlin 1.0.2 provides 3 different types of automatic bed leveling (probe required) and a manual bed leveling option. See your firmware's documentation for the specific options available.
Usage
G29
G29 Snnn
Parameters
Snnn Firmware-dependent behavior
Pfile.csv Optional file name for bed height map file (RepRapFirmware only)
Examples
G29    ; Probe the bed and enable compensation
G29 S2 ; Special operation - see below
G29 P1 ; UBL automated probe - see below
G29 Auto Bed Leveling (Marlin)
Marlin 1.0.2 and earlier provides three options for automatic bed leveling:
  • The 3-point method probes the bed at three points to produce a matrix, adjusting for a flat but tilted bed.
  • The planar grid method (non-Delta) probes a grid pattern to produce a matrix by the "least-squares" method, adjusting for a flat but tilted bed.
  • The bilinear grid method (Delta only) probes a grid pattern to produce a mesh, using bilinear interpolation to adjust for an uneven bed.
Marlin 1.1.0 and up allows the bilinear grid (i.e., "mesh") method to be used on all types of machines, not just deltas. This is the recommended leveling method going forward.
Also in Marlin 1.1.0 and up, the PROBE_MANUALLY option allows all forms of Auto Bed Leveling to be used without a probe. The procedure is similar to that of MESH_BED_LEVELING (see below). Begin the process with G29 to move the nozzle to the first point. Adjust the Z axis using G1 or your host software. Send G29 again to move to the next point and repeat until all points have been sampled.
Parameters
P Set the size of the grid that will be probed (P x P points). Not supported by non-linear delta printer bed leveling. Example: G29 P4
S Set the XY travel speed between probe points (in units/min)
D Dry-Run mode. Just evaluate the bed Topology - Don't apply or clean the rotation Matrix. Useful to check the topology after a first run of G29.
V Set the verbose level (0-4). Example: G29 V3
T Generate a Bed Topology Report. Example: G29 P5 T for a detailed report. This is useful for manual bed leveling and finding flaws in the bed (to assist with part placement). Not supported by non-linear delta printer bed leveling.
F Set the Front limit of the probing grid
B Set the Back limit of the probing grid
L Set the Left limit of the probing grid
R Set the Right limit of the probing grid
Global Parameters
E By default G29 will engage the Z probe, test the bed, then disengage. Include E or E1 to engage/disengage the Z probe for each sample. (This has no effect for fixed probes.)
G29 Unified Bed Leveling (Marlin)
Marlin firmware (version 1.1.0 and up) includes the AUTO_BED_LEVELING_UBL option for Unified Bed Leveling. UBL combines mesh leveling, tilted plane adjustment, 3-point leveling, and manual editing tools all together in a single package. To accomplish so much, UBL overloads `G29` with several new parameters and provides an additional G26 Mesh Tuning feature.
See the MarlinFW website for a dedicated Unified Bed Leveling page and complete documentation on `G29` for UBL and `G26` Mesh Validation.
G29 UBL Parameters (synopsis)
A     Activate   Activate the Unified Bed Leveling system. (i.e., M420 S1)
D     Disable    Disable the Unified Bed Leveling system. (i.e., M420 S0)
B#    Business   Do Manual Probing in 'Business Card' mode.
H#    Height     Height to raise the nozzle after each Manual Probe of the bed.
C     Continue   Continue, Constant, or Current Location, depending on Phase.
E     Every      Stow the probe after every sampled point.
F#    Fade       Fade leveling compensation gradually, until it ceases at the given height.
I#    Invalidate Invalidate a specified number of Mesh Points (X and Y).
J#    Grid       Do a grid (planar) leveling of the current Mesh using a grid with n points on a side.
K#    Kompare    Compare (diff) current Mesh with stored Mesh #, replacing current Mesh with the result.
L     Load       Load Mesh from the previously activated location in the EEPROM.
L#    Load       Load Mesh from the specified location in the EEPROM.
S     Store      Store the current Mesh in the Activated area of the EEPROM. Also save all settings.
S #   Store      Store the current Mesh at the specified area in EEPROM, set as the Activated area.
S -1  Store      Store the current Mesh as a print-out suitable to be fed back into the system.
O     Map        Display the Mesh Map Topology.
P0    Phase 0    Zero Mesh Data and turn off the Mesh Compensation System.
P1    Phase 1    Invalidate the Mesh and do Automatic Probing to generate new Mesh data.
P2    Phase 2    Probe unpopulated areas of the Mesh (those that couldn't be auto-probed).
P3    Phase 3    Fill unpopulated Mesh points with a fixed value. No 'C' for "smart fill" extrapolation.
P4    Phase 4    Fine tune the Mesh. ** Delta Mesh Compensation requires an LCD panel. **
P5    Phase 5    Find Mean Mesh Height and Standard Deviation.
P6    Phase 6    Shift Mesh height. All Mesh points are adjusted by the amount specified with 'C'.
Q     Test       Load specified Test Pattern to help check system operation.
R #   Repeat     Repeat the command the specified number of times. Default: grid points X * Y.
T     3-Point    Perform a 3-Point Bed Leveling on the current Mesh.
U     Unlevel    Perform a probe of the outer perimeter to assist in physically leveling the bed.
W     What?      Print a report of Unified Bed Leveling stored data.
X #              The X location for the command
Y #              The Y location for the command
Z     Zero       Do a single probe to set the Z Height of the nozzle.
Z #   Zero       Raise/lower the entire Mesh to conform with the specified difference (plus zprobe_zoffset).
G29 Manual Bed Leveling (Marlin)
Marlin firmware (version 1.0.2 and up) also provides a MESH_BED_LEVELING feature that can be used to perform bed leveling on machines lacking a probe. This form of bed leveling compensates for uneven Z height across the surface of the bed using a mesh and bilinear interpolation.
Manual Bed Leveling Usage
G29 S1 ; Move to the first point and wait for a measurement
G29 S2 ; Store the current Z, move to the next point
G29 S3 Xn Yn Zn.nn ; Modify the Z height of a single point
Options for the S parameter
S0 Produces a mesh report
S1 Start probing mesh points
S2 Probe the next mesh point
S3 Xn Yn Zn.nn Manually modify a single point
S4 Zn.nn Set z offset. Positive away from bed, negative closer to bed.
G29 Auto Bed Leveling (Repetier-Firmware)
Repetier firmware since v0.91 supports G29 with the optional Snnn parameter as described below. Useful to simply detect the Z bed angle so you can manually readjust your bed and get it as close to in plane as possible. If you wish to apply automatic software Z plane compensation on Repetier, use G32 instead with firmware 0.92.8 and above.
S0 Default value. Z bed heights are calculated at the measured points, relative to current Z position before issuing G29.
S1 Same as S0, except printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issue G28 Z to home to Z maximum position before issuing G29 Snnn for this to work correctly, or the printer height will be invalid.
S2 Same as S1, except new calculated Z height is also stored to EEPROM.
G29 Auto Bed Leveling (RepRapFirmware)
RepRapFirmware:
S0 (default if no S parameter) Probe the bed, save the height map in a file on the SD card, and activate bed compensation. The default folder for the height map file is /sys and the default file name is heightmap.csv.
S1 Load the height map from file and activate bed compensation. The default folder and filename as for S0.
S2 Clear bed height map
To define the grid, see M557.
G29.1: Set Z probe head offset
Example
G29.1 X30 Y20 Z0.5
G29.2: Set Z probe head offset calculated from toolhead position
Example
G29.2 Z0.0
The user would typically place the toolhead at the zero point of the axis and issue the G29.2 command.
G30: Single Z-Probe
??? No No No Yes Yes use G28 & G92 ??? ???
Usage
Parameters
Pnnn Probe point number
Xnnn X coordinate
Ynnn Y coordinate
Znnn Z coordinate
Hnnn Height correction
Snnn Set parameter
Example
G30
Examples (RepRapFirmware)
G30                          ; Probe the bed at the current XY position. When the probe is triggered, set the Z coordinate to the probe trigger height.
G30 S-1                      ; Probe the bed at the current XY position. When the probe is triggered, do not adjust the Z coordinate.
G30 P0 X20 Y50 Z-99999       ; Probe the bed at X20 Y50 and save the XY coordinates and the height error as point 0
G30 P3 X180 Y180 Z-99999 S4  ; Probe the bed at X180 Y180, save the XY coordinates and the height error as point 3 and calculate 4-point compensation or calibration
G30 P3 X180 Y180 Z-99999 S-1 ; As previous example but just report the height errors
RepRapFirmware supports additional behaviour: if a Pn field is specified the probed X, Y, and Z values are saved as point n on the bed for calculating the offset plane or for performing delta printer calibration. If X, Y, or Z values are specified (e.g. G30 P1 X20 Y50 Z0.3) then those values are used instead of the machine's current coordinates. A silly Z value (less than -9999.0) causes the machine to probe at the current point to get Z, rather than using the given value. If an S field is specified (e.g. G30 P1 Z0.3 S) the bed plane is computed for compensation and stored. The combination of these options allows for the machine to be moved to points using G1 commands, and then probe the bed, or for the user to position the nozzle interactively and use those coordinates. The user can also record those values and place them in a setup GCode file for automatic execution.
RepRapFirmware uses the value of the S parameter to specify what computation to perform. If the value is -1 then the Z offsets of all the points probed are printed, but no calibration is done. If the value is zero or not present, then this specifies that the number of factors to be calibrated is the same as the number of points probed. Otherwise, the value indicates the number of factors to be calibrated, which must be no greater than the number of points probed. In version 1.09, the number of factors may be 3, 4 or 5 when doing auto bed compensation on a Cartesian or CoreXY printer, and 3, 4, 6 or 7 when doing auto calibration of a Delta printer.
RepRapFirmware supports an optional H parameter, which is a height correction for that probe point. It allows for the Z probe having a trigger height that varies with XY position. The nominal trigger height of the Z probe (e.g. at bed centre) is declared in the Z parameter of the G31 command in the config.g file. When you probe using G30 and the probe triggers, the firmware will assume that the nozzle is at the nominal trigger height plus the value you have in the H parameter.
1MK4duo Firmware support an optional parameter for Autocalibration Delta.
Usage
G30 Xnnn Ynnn Znnn Annn E R I D T S U
Parameters
Xnnn X coordinate
Ynnn Y coordinate
Znnn Z coordinate
Annn A Autocalibration width nnn precision
E Adjust Endstop
R Adjust Endstop & Delta Radius
I Adjust Tower
D Adjust Diagonal Rod
T Adjust Tower Radius
Sn Stows the probe if 1 (default=1)
Un <bool> with a non-zero value will apply the result to current zprobe_zoffset
G31: Set or Report Current Probe status
No Yes ??? ??? ??? Yes: 0.91.7 Yes ??? No
Usage
Parameters
Pnnn Trigger value
Xnnn Probe X offset1
Ynnn Probe Y offset1
Znnn Trigger Z height
Cnnn Temperature coefficient2
Snnn Calibration temperature2
Tnnn (RepRapFirmware 1.17 and later) Z probe type to which these parameters apply, defaults to the current Z probe type as defined by M558 P parameter
Examples
G31 P500 Z2.6
G31 X16.0 Y1.5
In RepRapFirmware, separate G31 parameters may be defined for different probe types (i.e. 0+4 for switches, 1+2 for IR probes and 3 for alternative sensors). To specify which probe you are setting parameters for, send a M558 command to select the probe type before sending the G31 command, or use the T parameter.
In Repetier, G31 supports no parameters and simply prints the high/low status of the Z probe.
Notes
1X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) can be specified in RepRapFirmware. This allows you to calculate your probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset.
2In RepRapFirmware, additional parameters 'S' (bed temperature in oC at which the specified Z parameter is correct, default is current bed temperature) and 'C' (temperature coefficient of Z parameter in mm/oC, default zero) can be set for the alternative (ultrasonic) sensor. This is useful for probes that are affected by temperature. This facility is deprecated and likely to be removed in a future version of RepRapFirmware.
G31: Dock Z Probe sled
Yes No ??? ??? ??? ??? No ??? Yes
??? No No No No Yes No ??? ???
No: See G29 Yes ??? ??? ??? Yes: 0.92.8 Yes ??? No
Usage
G32           ; Probe and calculate
G32 Snnn      ; Each firmware has its own parameters
G32 Snnn Pnnn ; Refer to their specific documentation
This command is implemented as a more sophisticated form of bed leveling (which uses a transformation matrix or motorized correction. Smoothieware uses this code instead of `G29`.
Each firmware behaves differently. For example, Repetier firmware allows for motorized rotation of the bed whilst ReprapFirmware probes the bed with a transformation matrix.
Probe and calculate in Reprapfirmware
This command probes the bed at 3 or more pre-defined points (see M557) and updates transformation matrix for bed leveling compensation.
Parameters
Snnn Store transformation matrix after probing1
Examples
G32
G32 S2
RepRapFirmware executes macro file bed.g if present instead of using the M557 coordinates.
Notes
1Currently only Repetier firmware v0.92.8 and higher have working support for an optional Snnn parameter. The numeric value sets the behavior that occurs immediately after point probe and transformation matrix calculation. These are the values for Reprapfirmware:
S0 Default value. Transformation matrix is updated in RAM but is not stored to EEPROM. Z bed height not calculated.
S1 Transformation matrix is updated in RAM but is not stored to EEPROM. Printer immediately moves to Z maximum position (Z max endstop required!), and calculates new Z maximum height. You must first issue G28 to home to Z maximum position before issuing G32 Snnn for this to work correctly, or the printer height will be invalid.
S2 Same as S1, except transformation matrix and Z max heights are also stored to EEPROM.
S3 Transformation matrix is stored to EEPROM. Z bed height not calculated.
Probe and calculate in Repetier firmware
This command probes the bed at 3 or more pre-defined points and implements bed leveling compensation by either moving the A axis during printing (as with regular bed leveling, G29) or by tilting the bed with motors.
Parameters
Snnn Bed leveling method
Pnnn Bed correction method
The values for Snnn and Pnnn are as follows:
S0 This method measures at the 3 probe points and creates a plane through these points. If you have a really planar bed this gives the optimum result. The 3 points must not be in one line and have a long distance to increase numerical stability.
S1 This measures a grid. Probe point 1 is the origin and points 2 and 3 span a grid. We measure BED_LEVELING_GRID_SIZE points in each direction and compute a regression plane through all points. This gives a good overall plane if you have small bumps measuring inaccuracies.
S2 Bending correcting 4 point measurement. This is for cantilevered beds that have the rotation axis not at the side but inside the bed. Here we can assume no bending on the axis and a symmetric bending to both sides of the axis. So probe points 2 and 3 build the symmetric axis and point 1 is mirrored to 1m across the axis. Using the symmetry we then remove the bending from 1 and use that as plane.
P0 Use a rotation matrix. This will make z axis go up/down while moving in x/y direction to compensate the tilt. For multiple extruders make sure the height match the tilt of the bed or one will scratch. This is the default.
P1 Motorized correction. This method needs a bed that is fixed on 3 points from which 2 have a motor to change the height. The positions are defined in firmware by BED_MOTOR_1_X, BED_MOTOR_1_Y, BED_MOTOR_2_X, BED_MOTOR_2_Y, BED_MOTOR_3_X, BED_MOTOR_3_Y Motor 2 and 3 are the one driven by motor driver 0 and 1. These can be extra motors like Felix Pro 1 uses them or a system with 3 z axis where motors can be controlled individually like the Sparkcube does. This method requires a Z max endstop.
G32: Undock Z Probe sled
G33: Firmware dependent
G33: Measure/List/Adjust Distortion Matrix (Repetier - Redeem)
No No ??? ??? ??? Yes: v0.92.8 No ??? No
Usage
G33
G33 Lnnn
G33 Rnnn
G33 Xnnn Ynnn Znnn
Parameters
L0 List distortion matrix in a report
R0 Reset distortion matrix
X[pos] Y[pos] Z[zCorrection] Set correction for nearest point
Examples
G33
G33 R0
When used with no parameters, G33 will measure a grid of points and store the distortion dips and valleys in the bed surface, and then enable software distortion correction for the first few or several layers. The values will be stored in EEPROM if enabled in firmware. You must previously have G28 homed, and your Z minimum/maximum height must be set correctly for this to work. Use the optional parameters to list, reset or modify the distortion settings. Distortion correction behavior can be later turned on or off by code M323.
G33: Delta Auto Calibration (Marlin 1.1.x)
Yes No ??? ??? ??? No No ??? No
Performs a 1-4-7 point calibration of delta height (P1), endstops, delta radius (P2) and tower angle corrections (P>=3) by an iteration process based on the least squares method.
Usage
G33
G33 Pn Cx.xx T Vn E
Parameters
Pn Number of probe points: n*n (n=1-7), when P is omitted the default set in Configuration.h is used
Cn.nn Forces the iterations to stop when a standard deviation from the zero plane less then x.xx mm is achieved; when C is omitted the iterations go on until the best possible standard deviation is reached.
T Do not calibrate tower angle corrections (if used with P>=3); do not use the probe points near the towers, but the probe points opposite to the towers (if used with P=2)
Vn Verbose level: (n=0-2) 0 = dry run without calibration; 1(default) = settings ; 2 = settings and probe results
E Engage the probe for each point
Examples
G33 : calibrates with the default settings.
G33 Auto Calibrate
Checking... AC
.Height:297.77    Ex:+0.00  Ey:+0.00  Ez:+0.00    Radius:100.00
.Tower angle :    Tx:+0.00  Ty:+0.00  Tz:+0.00
Iteration : 01                                    std dev:0.306
.Height:297.65    Ex:-0.15  Ey:-0.14  Ez:+0.00    Radius:100.77
.Tower angle :    Tx:-0.02  Ty:+0.11  Tz:+0.00
Iteration : 02                                    std dev:0.049
.Height:297.67    Ex:-0.12  Ey:-0.12  Ez:+0.00    Radius:100.87
.Tower angle :    Tx:-0.03  Ty:+0.20  Tz:+0.00
Iteration : 03                                    std dev:0.033
.Height:297.69    Ex:-0.10  Ey:-0.12  Ez:+0.00    Radius:100.91
.Tower angle :    Tx:-0.03  Ty:+0.25  Tz:+0.00
Iteration : 04                                    std dev:0.031
.Height:297.69    Ex:-0.07  Ey:-0.11  Ez:+0.00    Radius:100.92
.Tower angle :    Tx:-0.03  Ty:+0.30  Tz:+0.00
Calibration OK                                    rolling back.
Save with M500 and/or copy to Configuration.h
G33 P6 V0 : probes 36 points in dry run mode.
G33 Auto Calibrate
Checking... AC (DRY-RUN)
.      c:+0.03     x:+0.32   y:+0.34   z:+0.41
.                 yz:+0.37  zx:+0.32  xy:+0.17
End DRY-RUN                                       std dev:0.306
G33 P4 C0.05 T : probes 16 points and
                 stops when a standard deviation of 0.05mm is reached;
                 calibrates delta height, endstops and delta radius,
                 leaves the tower angle corrections unaltered.
G33 Auto Calibrate
Checking... AC
.Height:297.78    Ex:+0.00  Ey:+0.00  Ez:+0.00    Radius:100.00
Iteration : 01                                    std dev:0.317
.Height:297.65    Ex:-0.15  Ey:-0.16  Ez:+0.00    Radius:100.80
Iteration : 02                                    std dev:0.059
.Height:297.66    Ex:-0.17  Ey:-0.13  Ez:+0.00    Radius:100.91
Calibration OK                                    std dev:0.042
G33 P2 : probes center and tower positions and
         calibrates delta height, endstops and delta radius.
G33 Auto Calibrate
Checking... AC
Iteration : 01                                    std dev:0.374
.Height:297.68    Ex:-0.14  Ey:-0.15  Ez:+0.00    Radius:101.09
Iteration : 02                                    std dev:0.054
.Height:297.68    Ex:-0.14  Ey:-0.14  Ez:+0.00    Radius:101.23
Iteration : 03                                    std dev:0.007
.Height:297.69    Ex:-0.13  Ey:-0.14  Ez:+0.00    Radius:100.92
G33 P1 : probes the center and sets the delta height only.
G33 Auto Calibrate
Checking... AC
.Height:295.00
Calibration OK
.Height:297.78
note: Height = delta height; Ex, Ey, Ez = end-stop corrections; Radius = delta radius; Tx, Ty, Tz = tower angular corrections; c, x, y, z, yz, zx, xy = probe results at center, towers and opposite to towers; std dev = standard deviation of the probe results towards the zero plane.
Yes: 1.1.0 No ??? ??? ??? ??? Yes ??? No
Yes ??? ??? ??? ??? No ??? ??? ???
??? No ??? ??? ??? ??? ??? ??? No
No No ??? ??? ??? ??? No ??? No
G40 turns off cutter compensation. If tool compensation was on the next move must be a linear move and longer than the tool diameter. It is OK to turn compensation off when it is already off.
G42: Move to Grid Point
Yes: 1.1.2 No ??? ??? ??? No No ??? No
G42 does a fast move in XY to any of the intersection points in the bed calibration grid. This is useful during calibration to align the nozzle or probe.
Parameters
Inn Grid X index (zero-based). If omitted, the nearest latitude.
Jnn Grid Y index (zero-based). If omitted, the nearest longitude.
P Probe flag. Moves the probe to the grid point (instead of the nozzle).
Fnnn Feedrate (mm/m)
Example
G42 I3 J4 P F3000 ; Move the probe to grid coordinate 3, 4
G54..59: Coordinate System Select (CNC specific)
No No ??? ??? ??? ??? Yes ??? No
G60: save current position to slot
??? ??? ??? ??? ??? ??? ??? ??? Yes
Usage
G60 Snn
Parameters
Snn <nn> specifies memory slot # (0-based) to save into (default 0)
G61: Apply/restore saved coordinates to the active extruder.
Usage
G61 Xnnn Ynnn Znnn Ennn Fnnn Snn
Parameters
Xnnn X coordinate
Ynnn Y coordinate
Znnn Z coordinate
Ennn E coordinate
Fnnn F Set Feedrate
Snn S specifies memory slot # (0-based)
Example
G90
Yes Yes No Yes Yes Yes Yes ??? Yes
Example
G91
All coordinates from now on are relative to the last position. Note: RepRapFirmware latest revision firmware uses M83 to set the extruder to relative mode: extrusion is NOT set to relative by ReprapFirmware on G91: only X,Y and Z are set to relative. By contrast, Marlin (for example) DOES also set extrusion to relative on a G91 command, as well as setting X, Y and Z.
G92: Set Position
Parameters
Xnnn new X axis position
Ynnn new Y axis position
Znnn new Z axis position
Ennn new extruder position
Example
G92 X10 E90
G92.x: Reset Coordinate System Offsets (CNC specific)
??? No ??? ??? ??? ??? Yes ??? No
  • G92.1 - reset axis offsets to zero and set parameters 5211 - 5219 to zero. (X Y Z A B C U V W)
  • G92.2 - reset axis offsets to zero.
G93 is Inverse Time Mode. In inverse time feed rate mode, an F word means the move should be completed in (one divided by the F number) minutes. For example, if the F number is 2.0, the move should be completed in half a minute.
When the inverse time feed rate mode is active, an F word must appear on every line which has a G1, G2, or G3 motion, and an F word on a line that does not have G1, G2, or G3 is ignored. Being in inverse time feed rate mode does not affect G0 (rapid move) motions.
No No ??? ??? ??? Yes: 0.92 No ??? No
Parameters
X Flag to set floor for X axis
Y Flag to set floor for Y axis
Z Flag to set floor for Z axis
Rnnn Radius to add
Examples
G100 X Y Z ; set floor for argument passed in. Number ignored and may be absent.
G100 R5    ; Add 5 to radius. Adjust to be above floor if necessary
G100 R0    ; Set radius based on current z measurement. Moves all axes to zero
??? No No No No No No ??? Yes
Example
G130 X10 Y18 Z15 A20 B12
G131: Remove offset
No No ??? ??? ??? Yes: 0.91 No ??? No
G133: Measure steps to top
G161: Home axes to minimum
??? No No No No No Yes ??? Yes
Parameters
Example
G161 X Y Z F1800
Instruct the machine to home the specified axes to their minimum position. Similar to G28, which decides on its own in which direction to search endstops.
G162: Home axes to maximum
Parameters
Example
G162 X Y Z F1800
M-commands
Yes Yes ??? ??? ??? No No ??? Yes
Yes No No Yes Yes No Yes ??? ???
Parameters
Pnnn Time to wait, in milliseconds1
Snnn Time to wait, in seconds2
Example
M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller, although this step is not mandatory on RepRapFirmware. See also M1, M112.
RepRapFirmware executes macro file stop.g before everything is turned off. Apart from that, RepRapFirmware (v1.09n-ch) accepts an extra 'H' parameter, whose value must be non-zero, to keep all heaters active. This is what Duet Web Control v1.07 sends to cancel a paused print.
Notes
1Not available in RepRapFirmware, but as a work-around G4 can be run before M0.
2Only available on Marlin.
M1: Sleep or Conditional stop
Yes No No No No No ??? ??? ???
Example
M1
If Marlin is emulated in RepRapFirmware, this does the same as M25 if the code was read from a serial or Telnet connection, else the macro file sleep.g is run before all heaters and drives are turned off.
M2: Program End
No No ??? ??? ??? No ??? ??? No
Yes No No No No No Yes ??? Yes
Example
M2
No Yes ??? ??? ??? Yes Yes ??? No
Yes No No No No No Yes ??? ???
Parameters
Snnn Spindle RPM
Example
M3 S4000
RepRapFirmware interprets this code only if a Roland mill has been configured.
In Repetier-Firmware in laser mode you need S0..S255 to set laser intensity. Normally you use S255 to turn it on full power for moves. Laser will only fire during G1/G2/G3 moves and in laser mode (M452).
No No ??? ??? ??? Yes No ??? No
Yes No No No No No No ??? ???
Example
M4 S4000
No No ??? ??? ??? Yes Yes ??? No
Example
M5
The spindle is turned off.
M6: Tool change
??? No No No No No Yes ??? ???
Example
M6
Yes No No No No No use M106 ??? ???
Example
M7
Example
M8
Example
M9
M10: Vacuum On (CNC specific)
??? No No No No No use M106 ??? ???
Example
M10
Example
M11
Yes No ??? ??? ??? No Yes ??? Yes
??? No No No No Yes (automatic) ??? ???
Example
M17
call M84 Yes ??? ??? ??? No Yes ??? call M84
??? No No No No Yes use M2 ??? Yes
Parameters
This command can be used without any additional parameters.1
X X axis
Y Y axis
Z Z axis
E Extruder drive(s)2
Examples
M18
M18 X E0
Notes
2RepRapFirmware allows stepper motors to be disabled selectively. For example, M18 X E0:2 will disable the X, extruder 0 and extruder 2 motors.
M20: List SD card
??? Yes No No No No Yes ??? ???
Parameters
Snnn Output style1
Pnnn Directory to list2
Examples
M20
M20 S2 P/gcodes/subdir
ok
SQUARE.G
SQCOM.G
ZCARRI~2.GCO
CARRIA~1.GCO
On Marlin, a file list response is usually encapsulated. Standard configurations of RepRapFirmware mimic this style in emulation mode:
Begin file list:
SQUARE.G
ZCARRI~2.GCO
End file list
ok
GCode files:
"Traffic cone.g","frog.gcode","calibration piece.g"
Note that some firmwares list file names in upper case, but - when sent to the M23 command (below) they must be in lower case. Teacup and RepRapFirmware have no such trouble and accept both. RepRapFirmware always returns long filenames in the case in which they are stored.
Notes
1If the S2 parameter is used on RepRapFirmware, then the file list is returned in JSON format as a single array called "files" with each name that corresponds to a subdirectory preceded by an asterisk, and the directory is returned in variable "dir".
Example
M20 S2 P/gcodes
{"dir":"\/gcodes","files":["4-piece-1-2-3-4.gcode","Hinged_Box.gcode","Hollow_Dodecahedron_190.gcode","*Calibration pieces"]}
2This parameter is only supported by RepRapFirmware and defaults to the 0:/gcodes directory, which is the directory that printable gcode files are normally stored in.
M21: Initialize SD card
Parameters
Pnnn SD card number (RepRapFirmware only, default 0)
Examples
M21
M21 P1
The specified SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
M22: Release SD card
Yes Yes ??? ??? ??? Yes No ??? Yes
Parameters
Examples
M22
M22 P1
The specified SD card is released, so further (accidental) attempts to read from it are guaranteed to fail. Helpful, but not mandatory before removing the card physically.
M23: Select SD file
Example
M23 filename.gco
M24: Start/resume SD print
??? Yes No No No Yes Yes ??? ???
Example
M24
The machine prints from the file selected with the M23 command. If the print was previously paused with M25, printing is resumed from that point. To restart a file from the beginning, use M23 to reset it, then M24.
When this command is used to resume a print that was paused, RepRapFirmware runs macro file resume.g prior to resuming the print.
M25: Pause SD print
Example
M25
The machine pauses printing at the current position within the file. To resume printing, use M24. Do not use this code to pause the print in a G-code file, use M226 instead.
Prior to pausing, RepRapFirmware runs macro file pause.g. This allows the head to be moved away from the print, filament to be retracted, etc.
M26: Set SD position
Yes Yes ??? ??? ??? Yes aborts ??? Yes
??? Yes No No No No No ??? ???
Parameters
Snnn File position in bytes
Example
M26
M27: Report SD print status
Example
M27
Report SD print status.
Marlin and recent forks of RepRapFirmware report the number of bytes processed in this format, which can be processed by Pronterface:
SD printing byte 2134/235422
Not SD printing.
M28: Begin write to SD card
Example
M28 filename.gco
M29: Stop writing to SD card
Example
M29 filename.gco
Yes Yes No No No No No ??? ???
Example
> M30 filename.gco
> filename.gco is deleted.
M30 in grbl
M30 exchange pallet shuttles and end the program. Pressing cycle start will start the program at the beginning of the file.
Yes No ??? ??? ??? No No ??? Yes
Example
M31
The response looks like:
 echo:54 min, 38 sec
Yes Yes ??? ??? ??? No Yes ??? No
Example
M32 filename.gco
It can be used when printing from SD card and does the same as M23 and M24.
M33: Stop and Close File and save restart.gcode
Stop the printing from SD and save all position in restart.gcode for restart printing in future
M35: Upload firmware NEXTION from SD
M36: Return file information
??? No No No No No No ??? No
Example
M36 filename.gco
If the file name parameter is not supplied and a file on the SD card is currently being printed, then information for that file is returned including additional field "fileName". This feature is used by the web interface and by PanelDue, so that if a connection is made when a file is already being printed, the name and other information about that file can be shown.
M37: Simulation mode
M37 S1 enters simulation mode. All G and M codes will not be acted on, but the time they take to execute will be calculated.
M37 S0 leaves simulation mode.
M38 Compute SHA1 hash of target file
Used to compute a hash of a file on the SD card. Examples:
> M38 gcodes/myfile.g
> Cannot find file
> M38 www/reprap.htm
> 91199139dbfadac15a18cfb962dfd4853db83999
Returns a hexadecimal string which is the SHA1 of the file. If the file cannot be found, then the string "Cannot find file" is returned instead.
M40: Eject
See also M240 and M241 below.
M41: Loop
Example
M41
M42: Switch I/O pin
??? Yes No No No No No ??? No
Parameters
Pnnn Pin number
Snnn Pin value
Example
M42 P7 S255
In RepRapFirmware, the S field may be in the range 0..1 or 0..255. The pin reference is an internal firmware reference named "digital pin", see Duet pinout. It maps on different connector pins depending the hardware. On Duet 0.6 and 0.8.5 hardware using pre-1.16 firmware, the supported pin numbers and their names on the expansion connector are:
Duet M42 P value to Expansion Port Pin Mapping
P Name Expansion Port Pin
16 TXD1 11
17 RXD1 12
18 TXD0 13
19 RXD0 14
20 TWD1 35
21 TWCK1 36
23 PA14 10
36 PC4 18
52 AD14 41
67 PB16 32
In firmware 1.16, the pin numbering has changed.
Duet 0.6 and 0.8.5 v1.16+ M42 P value to Expansion Port Pin Mapping
60 PA10/RXD0 14
61 PA11/TXD0 13
62 PA12/RXD1 12
63 PA13/TXD1 11
64 PA14/RTS1 10
65 PB12/TWD1 35
66 PB13/TWCK1 36
67 PB16/DAC1* 32
68 PB21/AD14 41
69 PC4 18
  • Also used as CS signal on external SD card socket
Duet WiFi v1.16+ M42 P value to Expansion Port Pin Mapping
P Signal Name Expansion Connector Label Expansion Pin
60 CS5 CS5 50
61 CS6 E3_STOP 9
62 CS7 E4_STOP 14
63 CS8 E5_STOP 19
See Using servos and controlling unused I/O pins for all pin definitions.
Pre-1.16 example:
M42 P20 S1 ;set the connector pin 35 to high.
See also M583.
Support Marlin RepRapFirmware Klipper Prusa Buddy Repetier Smoothie Druid MK4duo
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa MakerBot
Example
M43
M43: Pin report and debug
Usage
M43 En Pnnn Wn In
Parameters
En Enable / disable background endstop monitoring
Pnnn Pin to read or watch. If omitted, read/watch all pins
Wn bool watch pins -reporting changes- until reset, click, or M108
In bool Flag to ignore pin protection
Parameters
Pnnn number of points
Xnnn position on the X axis
Ynnn position on the Y axis
Vnnn verbosity
E engage
Lnnn legs of travel
S schizoid
As with G29, the E flag causes the probe to stow after each probe.
The S flag will result is a random sized, 5 pointed star, being traced (X and Y axis) between each sample. Usually a user will get worse repeat-ability numbers with S specified because the X axis and Y axis movements will add to the machine's positioning errors.
M70: Display message
see M117 see M117 ??? ??? ??? No ??? ??? see M117
??? No No No No see M117 No ??? Yes
Example
M70 P200 Message
Instruct the machine to display a message on its interface LCD. P is the time to display message for.
M72: Play a tone or song
see M300 see M300 ??? ??? ??? No No ??? see M300
Example
M72 P2
M73: Set build percentage
Example
M73 P50
Instruct the machine that the build has progressed to the specified percentage. The machine is expected to display this on it's interface board. If the percentage is exactly 0, then a Build Start Notification is sent. If the percentage is exactly 100, then a Build End notification is sent.
M80: ATX Power On
??? Yes No No No No automatic ??? ???
Examples
M80    ; Turn on the power supply
M80 S  ; Report power supply state (Marlin 1.1.1)
Notes
  • Marlin requires the POWER_SUPPLY configuration option to be set to a non-zero value to enable M80.
  • Some firmwares (e.g., Teacup) handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off.
M81: ATX Power Off
??? Yes No No No Yes automatic ??? ???
Example
M81
For redeem, adding 'P' will quit the daemon (redeem). Adding parameter 'R' will restart the daemon.
Example
M82
Example
M83
M84: Stop idle hold
Parameters
Innn Reset flags1
Example
M84
On Marlin, Repetier and RepRapFirmware, M84 can also be used to configure or disable the idle timeout. For example, "M84 S10" will idle the stepper motors after 10 seconds of inactivity. "M84 S0" will disable idle timeout; steppers will remain powered up regardless of activity.
Notes
1RepRapFirmware-dc42 and other firmware may not support this parameter.
M85: Set inactivity shutdown timer
Yes No ??? ??? ??? Yes No ??? Yes
Example
M85 S30
M92: Set axis_steps_per_unit
??? Yes No No No Yes No ??? ???
Parameters
Xnnn Steps per unit for the X drive
Ynnn Steps per unit for the Y drive
Znnn Steps per unit for the Z drive
Ennn Steps per unit for the extruder drive(s)
Examples
M92 X87.489 Y87.489 Z87.489
M92 E420:420
Allows programming of steps per unit (usually mm) for motor drives. These values are reset to firmware defaults on power on, unless saved to EEPROM if available (M500 in Marlin) or in the configuration file (config.g in RepRapFirmware). Very useful for calibration.
RepRapFirmware will report the current steps/mm if you send M92 without any parameters.
M93: Send axis_steps_per_unit
No Use M92 ??? ??? ??? ??? No ??? No
M98: Call Macro/Subprogram
Parameters
Pnnn Macro filename
Example
M98 Pmymacro.g
Runs the macro in the file mymacro.g. In conventional G Codes for CNC machines the P parameter normally refers to a line number in the program itself (P2000 would run the Macro starting at line O2000, say). For RepRap, which almost always has some sort of mass storage device inbuilt, it simply refers to the name of a GCode file that is executed by the G98 call. That GCode file does not need to end with an M99 (return) as the end-of-file automatically causes a return. Macro calls cannot usually be nested or be recursive; i.e. you can't call a macro from a macro, although RepRapFirmware explicitly supports this.
RepRapFirmware also allows the filename to include a path to a subdirectory. For relative paths, the default folder is /sys, but some implementations may check the /macros directory too. Absolute file paths are supported on RepRapFirmware as well.
Example
M99
Returns from an M98 call.
M98: Get axis_hysteresis_mm
Example
M98
Proposed for Marlin
M99: Set axis_hysteresis_mm
Example
M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
No 1.17c and later ??? ??? ??? No No ??? No
??? No Yes No No No Yes ??? ???
in Teacup firmware: If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103.
in BFB/RapMan: Turn extruder on (forward/filament in).
in RepRapFirmware: undo filament retraction. The length and speed are set by the M207 command. RepRapFirmware supports this command for compatibility with Simplify3D.
in other firmwares: Deprecated. Regarding filament retraction, see G10, G11, M207, M208, M227, M228, M229.
??? No Yes No No No No ??? ???
In other firmwares: Deprecated.
In Teacup firmware: If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101.
In RepRapFirmware: retract filament. The length and speed are set by the M207 command. RepRapFirmware supports this command for compatibility with Simplify3D.
??? Yes Yes Yes Yes Yes Yes ??? Yes
Parameters
Snnn Target temperature
Example
M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). Duet-dc42 and other firmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command applies to. See also M109.
M104 in Teacup Firmware
Example
M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100°C.
??? Yes No Yes No Yes Yes ??? Yes
Parameters
Rnnn Response sequence number1
Snnn Response type1
Examples
M105
M105 S2
ok T:201 B:117
M105 X0
Notes
1These parameters are only supported by RepRapFirmware, which returns a JSON-formatted response if parameter S2 or S3 is specified. Additionally, parameter Rnn may be provided, where nn is the sequence number of the most recent G-code response that the client has already received. M105 S2 is equivalent to M408 S0, and M105 S3 is equivalent to M408 S2. Usage of these forms of M105 is deprecated, please use M408 instead.
M106: Fan On
??? Yes Yes Yes Yes Yes Yes ??? ???
Parameters
Pnnn Fan number (optional, defaults to 0)2
Snnn Fan speed (0 to 255; RepRapFirmware also accepts 0.0 to 1.0))
Extra Parameters
Innn Invert signal, or disable fan1
Fnnn Set fan PWM frequency, in Hz1
Lnnn Set minimum fan speed (0 to 255 or 0.0 to 1.0)1
Bnnn Blip time - fan will be run at full PWM for this number of seconds when started from standstill1
Hnn:nn:nn... Select heaters monitored when in thermostatic mode1
Rnnn Restore fan speed to the value it has when the print was paused1
Tnnn Set thermostatic mode trigger temperature1
Example
M106 S127
M106 P1 I1 S87
M106 P1 T45 H1:2
M106 P2 B0.1 L0.05
The first example turns on the default cooling fan at half speed. The second one inverts the cooling fan signal of the second fan and sets its value to 1/3 of its maximum. The third one sets the second fan to a thermostatic fan for heaters 1 and 2 (e.g. the extruder heaters in a dual-nozzle machine) such that the fan will be on when either hot end is at or above 45C.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0 turns the fan off. In some implementations like RepRapFirmware the PWM value may alternatively be specified as a real fraction: M106 S0.7.
Notes
2Marlin only supports fan 0, all values above 0 will be interpreted as 0
M106 in RepRapFirmware
If an S parameter is provided but no other parameter is present, then the speeds of the print cooling fans associated with the current tool will be set (see the F parameter in the M563 command). If no tool is active then the speed of Fan 0 will be set. Either way, the speed is remembered so that it can be recalled using the R2 parameter (see below).
If no S parameter is given but the R1 parameter is used, the fan speed when the print was last paused will be set. If the R2 parameter is used, then the speeds of the print cooling fans associated with the current tool will be set to the remembered value (see above).
The T and H parameters allow a fan to be configured to operate in thermostatic mode, for example to use one of the fan channels to control the hot end fan. In this mode the fan will be fully on when the temperature of any of the heaters listed in the H parameter is at or above the trigger temperature set by the T parameter, and off otherwise. Thermostatic mode can be disabled using parameter H-1.
The B parameter sets the time for which the fan will be operated at full PWM when started from cold, to allow low fan speeds t be used. A value of 0.1 seconds is usually sufficient.
The L parameter defines the minimum PWM value that is usable with this fan. If a lower value is commanded that is not zero, it will be rounded up to this value.
The I parameter causes the fan output signal to be inverted if its value is greater than zero. This makes the cooling fan output suitable for feeding the PWM input of a 4-wire fan via a diode. If the parameter is present and zero, the output is not inverted. If the I parameter is negative then in RRF 1.16 and later the fan is disabled, which frees up the pin for use as a general purpose I/O pin that can be controlled using M42.
M106 in Teacup Firmware
Example
M106 P2 S255
Note well: The ambiguous text in the note above needs to be reworded by someone who knows the actual functioning. Below is my interpretation based on language use, not practical experience or code inspection.
Note: If M104 is (or becomes) active on a heater (or other device) with a feedback sensor it will correct any M106 initiated control output value change in the time it takes for the PID (of other feedback) loop to adjust it back to minimum error. It may not be easy to observe a change in the temperature (process value) due to this brief change in the control value
M107: Fan Off
??? Yes Yes Yes Yes Yes No ??? ???
Deprecated in Teacup firmware and in RepRapFirmware. Use M106 S0 instead.
M108: Cancel Heating (Marlin)
Breaks out of an M109 or M190 wait-for-temperature loop, continuing the print job. Use this command with caution! If cold extrusion prevention is enabled (see M302) and the temperature is too low, this will start "printing" without extrusion. If cold extrusion prevention is disabled and the hot-end temperature is too low, the extruder may jam.
This command was introduced in Marlin 1.1.0. As with other emergency commands [e.g., M112] this requires the host to leave space in the command buffer, or the command won't be executed until later.
M108: Set Extruder Speed (BFB)
Sets speed of extruder motor. (Deprecated in FiveD firmware, see M113)
??? Yes No Yes Yes Yes not needed ??? Yes
Parameters
Example
M109 S215
M109 in Teacup
M109 in Marlin, Sprinter (ATmega port), RepRapFirmware
Example
M109 S185
RepRapFirmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command refers to (see below).
M109 in Sprinter (4pi port)
Example
M109 S185 R240 ; set extruder temperature to 185 and wait for the temperature to be between 185 - 240.
M109 in MakerBot
Example
M109 S70 T0
M110: Set Current Line Number
??? No No Yes No Yes not needed ??? ???
Parameters
Nnnn Line number
Example
M110 N123
M111: Set Debug Level
??? No No Yes No Yes Debug ??? ???
Parameters
Pnnn Debug module1
Snnn Debug on/off
Examples
M111 S6
M111 P1 S1
Notes
M111 in RepRapFirmware
RepRapFirmware allows debugging to be set for each module. If the optional 'P' parameter is not specified, debugging will be enabled for all modules. For a list of modules, send M111 S1 P15.
M111 in Repetier
#define DEBUG_ECHO (1<<0)
#define DEBUG_INFO (1<<1)
#define DEBUG_ERRORS (1<<2)
M112: Emergency Stop
Yes Yes ??? ??? ??? Yes Yes ??? Yes
??? No No Yes No Yes Yes ??? ???
Example
M112
M113: Set Extruder PWM
No No ??? ??? ??? No No ??? No
??? No No Yes No No No ??? ???
Example
M113
M113 S0.7
M114: Get Current Position
Example
M114
??? Yes No Yes No Yes Yes ??? No
Parameters
Pnnn Electronics type1
Examples
M115
M115 P2
sample data from firmware:
Notes
1This parameter is supported only in RepRapFirmware and can be used tell the firmware about the hardware on which it is running. If the P parameter is present then the integer argument specifies the hardware being used. The following are currently supported:
M115 P0   Automatic board type selection if supported, or default if not
M115 P1   Duet 0.6
M115 P2   Duet 0.7
M115 P3   Duet 0.85
M116: Wait
No Yes ??? ??? ??? Yes No ??? No
??? No No Yes No Yes Yes ??? Yes
Parameters
Pnnn Tool number
Hnnn Heater number
Cnnn Chamber number
Examples
M116
M116 P1
Wait for all temperatures and other slowly-changing variables to arrive at their set values if no parameters are specified. See also M109.
Notes
M117: Get Zero Position
??? No No Yes No No No ??? see M70
Example
M117
M117: Display Message
??? No No No No Yes No ??? No
Example
M117 Hello World
M118: Negotiate Features
??? No No No No No No ??? ???
Example
M118 P42
M119: Get Endstop Status
Example
M119
In redeem, M119 can also be used to invert end stops.
Example
M119 X1 1
This will invert end stop X1 (Inverted means switch is connected in Normally Open state (NO))
M120: Push
No Yes ??? ??? ??? No Yes ??? No
Example
M120
  1. Current feedrate, and
  1. Current feedrate
  2. Extruder positions
M121: Pop
Example
M121
M122: Diagnose
No Yes ??? ??? ??? No No ??? No
Example
M122
M123: Tachometer value
M124: Immediate motor stop
Immediately stops all motors.
M126: Open Valve
??? No No Yes No No No ??? Yes
Example
M126 P500
M126 in MakerBot
Example
M126 T0
M127: Close Valve
Example
M127 P400
M127 in MakerBot
Example
M127 T0
M128: Extruder Pressure PWM
Example
M128 S255
M129: Extruder pressure off
Example
M129 P100
M130: Set PID P value
see M301 No ??? ??? ??? No see M301 ??? see M301
??? No No No No see M301 Yes ??? ???
Parameters
Pnnn heater number
Snnn proportional (Kp)
Example
M130 P0 S8.0  ; Sets heater 0 P factor to 8.0
M131: Set PID I value
Parameters
Pnnn heater number
Snnn integral (Ki)
Example
M131 P1 S0.5  ; Sets heater 1 I factor to 0.5
M132: Set PID D value
see M301 see M301 ??? ??? ??? No See M301 ??? see M301
??? No No No No see M301 Yes ??? Yes
Parameters
Pnnn heater number
Snnn derivative (Kd)
Example
M132 P0 S24  ; Sets heater 0 D factor to 24.0
M132 in MakerBot
Example
M132 X Y Z A B
M133: Set PID I limit value
see M301 No ??? ??? ??? No No ??? see M301
Parameters
Pnnn heater number
Snnn integral limit (Ki)
Example
M133 P1 S264  ; Sets heater 1 I limit value to 264
M133 in MakerBot
Example
M133 T0 P500
Instruct the machine to wait for the toolhead to reach its target temperature. T is the extruder to wait for. P if present, sets the time limit.
No see M500 ??? ??? ??? No See M504 ??? No
Example
M134
M134 in MakerBot
Example
M134 T0 P500
M135: Set PID sample interval
Parameters
Snnn Heat sample time in seconds
Example
M135 S300
M135 in MakerBot
Example
M135 T0
No see M301 ??? ??? ??? No No ??? No
??? No No No No No Debug ??? ???
Example
M136 P1  ; print heater 0 PID parameters to host
??? Yes No Yes Yes Yes Yes ??? Yes
Parameters
Hnnn Heater number1
Example
M140 S55
RepRapFirmware allows the bed heater to be switched off if the absolute negative temperature (-273.15) is passed as target temperature. In this case the current bed temperature is not affected1:
M140 S-273.15
No Yes ??? ??? ??? No No ??? Yes
??? No No No Yes No uses M104 ??? ???
Parameters
Hnnn Heater number1
Examples
M141 S30
M141 H0
Notes
M142: Holding Pressure
Example
M142 S1
M143: Maximum heater temperature
Parameters
H Heater number (RepRapFirmware 1.17 and later, default 1 which is normally the first hot end)
S Maximum temperature
Examples
M143 S275      ; set the maximum temperature of the hot-end to 275°C
M143 H0 S125   ; set the maximum bed temperature to 125C
The default maximum temperature for all heaters was 300°C prior to RepRapFirmware version 1.13, and 262°C from 1.13 onwards. From RepRapFirmware 1.17 onwards, the default maximum temperatures are 262C for extruders and 125C for the bed.
When the temperature of the heater exceeds this value, countermeasures will be taken.
M144: Bed Standby
Example
M144
M146: Set Chamber Humidity
Parameters
Example
M146 R60
M149: Set temperature units
Parameters
Example
M149 K
M150: Set display color
Parameters
Rnnn red
Unnn green
Bnnn blue
Example
M150 R255 U128 B192
Set BlinkM Color via I2C. Range for values: 0-255
M155: Automatically send temperatures
Yes: 1.1.0 No ??? ??? ??? Yes No ??? Yes
Parameters
Snnn enable sending temperatures = 1, disable = 0
Example
M155 S1
Hosts normally monitor printer temperatures by sending M105 every x seconds. This not only adds traffic, but also only works while printer is not blocked by waiting commands. So frequency more depends on frequency you can send new commands and creates extra traffic. As a solution, firmware can be told to automatically send temperatures every second. This function is disabled by default for best compatibility with existing hosts. To indicate the availability of this function, M115 will add an extra line:
Cap:AUTOREPORT_TEMP:1
so hosts know about the presence of the function.
Example
M160 S4
M160 S4
G1 X70.6 E0:0:0:42.4
G1 E42.4:0:0:0
Yes: RC7 Use M567 ??? ??? ??? Yes: 0.92 No ??? No
Parameters
Snnn extruder number
Pnnn weight
M164: Store weights
Yes: RC7 No ??? ??? ??? Yes: 0.92 No ??? No
Parameters
Snnn virtual extruder number
M165: Set multiple mix weights
Yes: RC7 No ??? ??? ??? No: No ??? No
Parameters A B C D H I
A[factor] Mix factor for extruder stepper 1
B[factor] Mix factor for extruder stepper 2
C[factor] Mix factor for extruder stepper 3
D[factor] Mix factor for extruder stepper 4
H[factor] Mix factor for extruder stepper 5
I[factor] Mix factor for extruder stepper 6
  • Set multiple mix factors for a mixing extruder.
  • Factors that are left out will be set to 0.
  • All factors together must add up to 1.0.
??? Yes No No Yes Yes See M116 ??? ???
Parameters
Example
M190 S60
No 1.17 and later ??? ??? ??? No No ??? Yes
??? No No No Yes No No ??? ???
Example
M191 P60
In MK4duo:
Parameters
Example
M191 S60
M200: Set filament diameter
Yes see M404 ??? ??? ??? Yes Yes ??? Yes
M200 D0<code> or <code>M200 D1.128 ; reset E multiplier to 1, since sqrt(1 / pi) * 2 = 1.128
Parameters
Xnnn Acceleration for X axis
Ynnn Acceleration for Y axis
Znnn Acceleration for Z axis
Ennn Acceleration for extruder drives
Example
M201 X1000 Y1000 Z100 E2000
RepRapFirmware expects these values to be in mm/s².
??? ??? No No No ??? No ??? ???
Set max travel acceleration in units/s^2 for travel moves (M202 X1000 Y1000). Unused in Marlin!!
M203: Set maximum feedrate
Parameters
Xnnn Maximum feedrate for X axis
Ynnn Maximum feedrate for Y axis
Znnn Maximum feedrate for Z axis
Ennn Maximum feedrate for extruder drives
Example
M203 X6000 Y6000 Z300 E10000
Sets the maximum feedrates that your machine can do in mm/min (Marlin uses mm/sec).
M203 Repetier
Set temperature monitor to Sx.
Yes 1.18 and later ??? ??? ??? Yes Yes ??? Yes
??? Yes No No No ??? No ??? ???
Parameters (RepRapFimware)
Pnnn Acceleration for printing moves
Tnnn Acceleration for travel moves
Example
M204 P500 T2000
Use M201 to set per-axis accelerations and extruder accelerations. RepRapFirmware applies the M204 accelerations to the move as a whole, and also applies the limits set by M201 to each axis and extruder.
Other firmwares:
P = Printing moves
The command M204 P800 T3000 R9000 sets the acceleration for printing movements to 800mm/s^2, for travels to 3000mm/s^2 and for retracts to 9000mm/s^2.
M204 Repetier
Usage
M204 X[Kp] Y[Ki] Z[Kd]
M205: Advanced settings
Yes Use M566 ??? ??? ??? Yes Yes ??? Yes
Sprinter / Marlin
Minimum travel speed = S[printing] T[travel]
B[min segment time] X[max XY jerk] Z[max Z jerk] E[max E jerk]
Sprinter / Marlin Example
M205 X30 Z5 ; Set X/Y Jerk to 30mm/s, Z jerk to 5mm/s
Smoothieware uses a different algorithm: [1]
X[xy junction deviation] Z[z junction deviation] S[minimum planner speed].
Z junction deviation only applies to z only moves
0 disables junction deviation for Z
-1 uses global junction deviation
Smoothie example
M205 X0.05  ; set X/Y Junction Deviation
M205 Repetier
Output EEPROM settings.
M206: Offset axes
Yes Yes ??? ??? ??? No Yes ??? Yes
Parameters
Xnnn X axis offset
Ynnn Y axis offset
Znnn Z axis offset
Example
M206 X10.0 Y10.0 Z-0.4
M206 in Repetier: Set eeprom value
Example
M206 T3 P39 X19.9
Set Jerk to 19.9
Example
M207
M207: Set retract length
Parameters
Rnnn positive or negative additional length to un-retract, in mm (RepRapFirmware only)
Fnnn retraction feedrate, in mm/min
Tnnn feedrate for un-retraction if different from retraction, mm/min (RepRapFirmware 1.16 and later only)
Znnn additional zlift/hop
Example
M207 S4.0 F2400 Z0.075
Sets the retract length used by the G10 and G11 commands, stays in mm regardless of M200 setting
M208: Set axis max travel
Parameters
Snnn Whether to set the axis minimum1
Xnnn X axis limit
Ynnn Y axis limit
Znnn Z axis limit
Example
M208 X250 Y210 Z180
RepRapPro's version of Marlin uses M208 this way. Send M503 to see the current values. On Marlin, the value can be saved to EEPROM using the M500 command.
Notes
1With RepRapFirmware on a Cartesian printer, you can also use this command to specify software limits for axis travel in the negative direction, by adding parameter S1. The axis limits you set are also the positions assumed when an endstop is triggered.
M208 X200 Y200 Z90; set axis maxima
M208 X-5 Y0 Z0 S1 ; set axis minimum
M208: Set unretract length
Yes See M207 ??? ??? ??? No Yes ??? Yes
Parameters
Fnnn feedrate, in mm/sec
Example
M209 S1
This boolean value S 1=true or 0=false enables automatic retract detect if the slicer did not support G10/G11: every normal extrude-only move will be classified as retract depending on the direction.
M210: Set homing feedrates
Example
M210 X1000 Y1500
No Use M564 ??? ??? ??? No No ??? No
Example
M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
Example
M211 X0 S1
Enables X min endstop
Example
M211
Yes* Use G31 ??? ??? ??? No No ??? Yes
Example
M212 Z-0.2
M218: Set Hotend Offset
Yes Use G10 ??? ??? ??? No No ??? Yes
Example
M218 T1 X50 Y0.5
Parameters
Snnn Speed factor override percentage (0..100 or higher)
Example
M220 S80
Parameters
Snnn Extrude factor override percentage (0..100 or higher), default 100%
Dnnn Extruder drive number (RepRapFirmware only), default 0
Example
M221 S70
M221 S95 D1
Sets extrude factor override percentage. In the case of RepRapFirmware, sets the extrusion factor percentage for the specified extruder drive only.
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: Gcode Initiated Pause
??? No Yes No Yes No No ??? ???
Example
M226
M226: Wait for pin state
Yes see M577 ??? ??? ??? Yes No ??? Yes
Parameters
Pnnn pin number
Snnn pin state
Example
M226 P2 S1
Example
M227 P1600 S1600
P and S are steps.
Example
M228
See also M227.
Example
M229 P1.0 S1.0
Example
M230 S1
M231: Set OPS parameter
M231 S[OPS_MODE] X[Min_Distance] Y[Retract] Z[Backslash] F[RetractMove]
M240: Trigger camera
Example
M240
Triggers a camera to take a photograph. (Add to your per-layer GCode.)
??? No No No No No Debug: Echo off ??? ???
Example
M240
Echoing may be controlled in some firmwares with M111.
??? No No No No No Debug: Echo on ??? ???
Example
M241
M245: Start cooler
Example
M245
M246: Stop cooler
Example
M246
M250: Set LCD contrast
Example
M250 C20
Examples
M251 S0 ; Reset
M251 S1 ; Print
M251 S2 ; Store to Z length (also EEPROM if enabled)
(This is a Repetier-Firmware only feature.)
M260: i2c Send Data
Yes: 1.1.0 No ??? ??? ??? No No ??? Yes
Buffer and send data over the i2c bus. Use A to set the address from 0-127. Add up to 32 bytes to the buffer with each B. Send and reset the buffer with S.
Examples
M260 A5 B65 S ; Send 'A' to Address 5 now
M260 A0       ; Set address to 0 (broadcast)
M260 B77  ; M
M260 B97  ; a
M260 B114 ; r
M260 B108 ; l
M260 B105 ; i
M260 B110 ; n
M260 S1   ; Send the current buffer
M261: i2c Request Data
Request data from an i2c slave device. This command simply relays the received data to the host.
Example
M261 A99 B5 ; Request 5 bytes from Address 99
Both M260 and M261 are commands demonstrating use of the i2c bus (TWIBus class) in Marlin Firmware. Developers and vendors can make Marlin an i2c master device by enabling EXPERIMENTAL_I2CBUS, and Marlin can act as a slave device by setting I2C_SLAVE_ADDRESS from 8-127. This class can be used to divide up processing responsibilities between multiple instances of Marlin running on multiple boards. For example, one board might control a Z axis with 4 independent steppers to create a self-leveling system, or a second board could drive the graphical display while the first board handles printing.
M280: Set servo position
Yes 1.16 and later ??? ??? ??? Use M340 No ??? Yes
??? No No No Yes Yes No ??? ???
Set servo position absolute.
Parameters
Pnnn Servo index
Snnn Angle or microseconds
I1 Invert polarity (RepRapFirmware only)
Example
M280 P1 S50
Marlin and RepRapFirmware treat S values below 200 as angles, and 200 or greater as the pulse width in microseconds.
In RepRapFirmware, the servo index is the same as the pin number for the M42 command. See https://duet3d.com/wiki/Using_servos_and_controlling_unused_I/O_pins for details.
RepRapFirmware supports the optional I1 parameter, which if present causes the polarity of the servo pulses to be inverted compared to normal for that output pin. The I parameter is not remembered between M280 commands (unlike the I parameter in M106 commands), so if you need inverted polarity then you must include I1 in every M280 command you send.
Duet 0.8.5 M280 P value to Expansion Port Pin Mapping
Use M307 H# A-1 C-1 D-1 before using these pins
3 PC23_PWML6 21
4 PC22_PWML5 22
5 PC21_PWML4 23
On the Duet 0.6, pin 18 is controlled by heater 2. On the 0.8.5, pin 18 is controlled by heater 6, but is also shared with fan1. In order to use this pin, the fan must be disabled (M106 P1 I-1). See Using servos and controlling unused I/O pins
M290: Baby stepping
No 1.18 and later ??? ??? ??? No No ??? No
Parameters
Snnn Amount to baby step in mm. Positive values raise the head, negative values lower it.
Example
M290 S0.05
This command tells the printer to apply the specified additional offset to the Z coordinate for all future moves, and to apply the offset to moves that have already been queued if this case be done. Baby stepping is cumulative, for example after M290 S0.1 followed by M290 S-0.02, an offset of 0.08mm is used.
M290 with no parameters reports the accumulated baby stepping offset.
The baby stepping offset is reset to zero when the printer is homed or the bed is probed.
M291: Display message and optionally wait for response
No 1.19 and later ??? ??? ??? No No ??? No
Parameters
P"message" The message to display, which must be enclosed in double quotation marks. If the message itself contains a double quotation mark, use two double quotation marks to represent it.
R"message" Optional title for the message box. Must be enclosed in double quotation marks too.
Sn 0 = no acknowledgement needed (default), 1 = display an OK button and wait for it to be pressed (the user interface then sends M292 to indicate that is has been acknowledged)
Tn Timeout in seconds, ignored if S=1. The message will be cancelled after this amount of time, if the user does not cancel it before then. A zero or negative value means that the message does not time out (it may still be cancelled by the user). In RepRapFirmware, the default timeout for messages that do not require acknowledgement is 10 seconds.
Zn 0 = no special action, 1 = display Z jog buttons alongside the message to allow the user to adjust the height of the print head
Examples
M291 P"Please do something and press OK when done" S1
M291 P"This message will be closed after 10 seconds" T10
This command provides a more flexible alternative to M117, in particular messages that time out, messages that suspend execution until the user acknowledges them, and messages that allow the user to adjust the height of the print head before acknowledging them.
M292: Acknowledge message
This command is sent by the user interface when the user acknowledges a message that was displayed because of a M291 command with parameter S=1.
M300: Play beep sound
??? No No No Yes No No ??? Yes
Parameters
Snnn frequency in Hz
Pnnn duration in milliseconds
Example
M300 S300 P1000
If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound.
M301: Set PID parameters
??? Yes No No No Yes See M130-M133 ??? ???
Parameters
Hnnn heater number (Smoothie uses 'S', Redeem uses 'E')
Pnnn proportional (Kp)
Innn integral (Ki)
Dnnn derivative (Kd)
Examples
M301 H1 P1 I2 D3 ; Marlin
M301 H1 P1 I2 D3 T0.2 B20 W127 S0.8 ; RepRapFirmware (v1.09 onwards), Duet-dc42
M301 S0 P30 I10 D10 ; Smoothie
M301 E0 P30 I10 D10 ; Redeem (E = Extruder, -1=Bed, 0=E, 1=H, 2=A, 3=B, 4=C, default = 0)
Marlin
Hot end only; see M304 for bed PID. H is the heater number, default 1 (i.e. first extruder heater).
  • H Is the heater number, and is compulsory. H0 is the bed, H1 is the first hot end, H2 the second etc.
  • P Interprets a negative P term as indicating that bang-bang control should be used instead of PID (not recommended for the hot end, but OK for the bed heater).
  • I Integral value
  • D Derivative value
  • T Is the approximate additional PWM (on a scale of 0 to 255) needed to maintain temperature, per degree C above room temperature. Used to preset the I-accumulator when switching from heater fully on/off to PID.
  • S PWM scaling factor, to allow for variation in heater power and supply voltage. Is designed to allow a correction to be made for a change in heater power and/or power supply voltage without having to change all the other parameters. For example, an S factor of 0.8 means that the final output of the PID controller should be scaled to 0.8 times the standard value, which would compensate for a heater that is 25% more powerful than the standard one or a supply voltage that is 12.5% higher than standard.
  • W Wind-up. Sets the maximum value of I-term, must be high enough to reach 245C for ABS printing.
  • B PID Band. Errors larger than this cause heater to be on or off.
An example using all of these would be:
M301 H1 P20 I0.5 D100 T0.4 S1 W180 B30
Smoothie
S0<code> is 0 for the hotend, and 1 for the bed, other numbers may apply to your configuration, depending on the order in which you declare temperature control modules.
Other implementations
W: Wind-up. Sets the maximum value of I-term, so it does not overwhelm other PID values, and the heater stays on. (Check firmware support - Sprinter, Marlin?)
Example
M301 W125
Teacup
See <code>M130, M131, M132, M133 for Teacup's codes for setting the PID parameters.
M302: Allow cold extrudes
Yes Yes1 ??? ??? ??? Yes: 0.92 No ??? Yes
Parameters
Snnn Cold extrude minimum temperature
Pnnn Cold extrude allow state (RepRapFirmware)
Examples (RepRapFirmwre)
M302       ; Report current state
M302 P1    ; Allow cold extrusion
Examples (Others)
M302 S0    ; Allow extrusion at any temperature
M302 S170  ; Allow extrusion above 170
This tells the printer to allow movement of the extruder motor above a certain temperature, or if disabled, to allow extruder movement when the hotend is below a safe printing temperature.
Notes
1RepRapFirmware uses the P[0|1] parameter instead of S[temperature], and for M302 with no parameters it will report the current cold extrusion state.
M303: Run PID tuning
Yes 1.15 and later ??? ??? ??? Yes Yes ??? Yes
Hot end usage:
M303 S<temperature> C<cycles>
Bed usage (repetier, not sure whether cycles work here):
M303 P1 S<temperature>
Bed usage (others):
Example
M303 C8 S175
M303 E0 S190
In RepRapFirmware, this command computes the process model parameters (see M307), which are in turn used to calculate the PID constants. H is the heater number, P is the PWM to use (default 0.5), and S is the maximum allowable temperature (default 225). Tuning is performed asynchronously. Run M303 with no parameters to see the current tuning state or the last tuning result.
Example
M303 H1 P0.4 S240 ; tune heater 1 using 40% PWM, quit if temperature exceeds 240C
Notes
In Marlin Firmware you can add the U1 parameter to apply the PID results to current settings upon completion.
Yes Yes ??? ??? ??? ??? see M301 ??? Yes
Parameters
Innn integral (Ki)
Examples
M304 P1 I2 D3 ; set kP=3, kI=2, kD=3
M304 P1 I2 D3 T0.7 B20 W127 ; RepRapFirmware
M304          ; Report parameters
Sets Proportional, Integral and Derivative values for bed. RepRapFirmware interprets a negative P term as indicating that bang-bang control should be used instead of PID. In RepRapFirmware, this command is identical to M301 except that the H parameter (heater number) defaults to zero.
Example
M304 H1 B4200 R4800 T100000
No Yes ??? ??? ??? ??? Yes ??? No
Parameters
Pnnn Heater number
Tnnn Thermistor resistance at 25oC
Bnnn Beta value, or the reciprocal of the Steinhart-Hart thermistor model B coefficient
Cnnn Steinhart-Hart C coefficient (RepRapFirmware 1.17 and later), default 0
Rnnn Series resistor value
Lnnn ADC low offset
Hnnn ADC high offset
Xnnn Heater ADC channel, or thermocouple or PT100 adapter channel, defaults to the same value as the P parameter
Example
M305 P1 T100000 R1000 B4200
Sets the parameters for temperature measurement. The example above tells the firmware that for heater 1 (P parameter: 0 = heated bed, 1 = first extruder) the thermistor 25C resistance (T parameter) is 100Kohms, the thermistor series resistance (R parameter) is 1Kohms, the thermistor beta (B parameter) is 4200. All parameters other than P are optional. If only the P parameter is given, the existing values are displayed.
RepRapFirmware also supports ADC gain and offset correction and a thermistor selection facility.
Example
M305 P1 T100000 R1000 B4200 H14 L-11 X2
The H correction affects the reading at high ADC input voltages, so it has the greatest effect at low temperatures. The L correction affects the reading at low input voltages, which correspond to high temperatures.
The X parameter tells the firmware to use the thermistor input corresponding to a different heating channel. RepRapFirmware also allow an external SPI thermocouple interface (such as the MAX31855) or PT100 interface (MAX31865) to be configured. Thermocouple channels are numbered from 100 and PT100 channels from 200.
In the above example, the ADC high end correction (H parameter) is 14, the ADC low end correction (L parameter) is -11, and thermistor input #2 is used to measure the temperature of heater #1.
M306: Set home offset calculated from toolhead position
No No ??? ??? ??? ??? Yes ??? No
Example
M306 Z0
Implemented in Smoothieware
M307: Set or report heating process parameters
No 1.15 and later ??? ??? ??? No No ??? No
Parameters
Hn Heater number (0 is usually the bed heater)
Annn gAin, expressed as ultimate temperature rise obtained in degC divided by the PWM fraction. For example, if G=180 then at 50% PWM the ultimate temperature rise would be 90C.
Cnnn dominant time Constant of the heating process in seconds
Dnnn Dead time in seconds
Two additional parameters help control the heating process
Bn selects Bang-bang control instead of PID if non-zero. Default at power-up is 0 for extruder heaters, 1 for the bed heater.
Snnn maximum PWM to be used used with this heater on a scale of 0 to 1. Default 1.0.
Examples
M307 H0 ; report the process parameters for heater 0
M307 H1 A346.2 C140 D5.3 B0 S0.8 ; set process parameters for heater 1, use PID, and limit heater 1 PWM to 80%
Each heater and its corresponding load may be approximated as a first order process with dead time, which is characterised by the gain, time constant and dead time parameters. The model can used to calculate optimum PID parameters (including using different values for the heating or cooling phase and the steady state phase), to better detect heater faults, and to calculate feed-forward terms to better respond to changes in the load. Normally these model parameters are found by auto tuning - see M303.
RepRapFirmware 1.16 and later allow the PID controller for a heater to be disabled by setting the A, C, and D parameters to -1. This frees up the corresponding heater control pin for use as a general purpose I/O pin.
M320: Activate autolevel (Repetier)
No No ??? ??? ??? Yes No ??? No
Usage
M320
M320 S1
Parameters
Snnn if greater than 0, activate and store persistently in EEPROM
Examples
M320    ; temporarily activate auto leveling
M320 S1 ; permanently activate auto leveling
Parameter Snnn is optional.
(Repetier only)
M321: Deactivate autolevel (Repetier)
Usage
M321
M321 S1
Parameters
Snnn if greater than 0, deactivate and store persistently in EEPROM
Examples
M321    ; temporarily deactivate auto leveling
M321 S1 ; permanently deactivate auto leveling
(Repetier only)
M322: Reset autolevel matrix (Repetier)
Usage
M322
M322 S1
Parameters
Snnn if greater than 0, also reset the matrix values saved EEPROM
Examples
M322    ; temporarily reset auto level matrix
M322 S1 ; permanently reset auto level matrix
(Repetier only)
M323: Distortion correction on/off (Repetier)
Usage
M323
M323 Snnn
M323 Snnn Pnnn
Parameters
Snnn 0 (disable correction) or 1 (enable correction)
Pnnn 1 (store correction state persistently in EEPROM)
Examples
M323       ; Show if distortion correction is enabled
M323 S0    ; Disable distortion correction temporarily
M323 S1 P1 ; Enable distortion correction permanently
(Repetier only) Controls distortion correction feature after having set it up using G33.
M340: Control the servos
Support Marlin RepRapFirmware Klipper Prusa Buddy Repetier Smoothie Druid MK4duo
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa MakerBot
M350: Set microstepping mode
Yes Yes ??? ??? ??? Yes No ??? Yes
??? No No No No Yes No ??? ???
Sets microstepping mode.
Warning: Steps per unit remains unchanged; except that in RepRapFirmware the steps/mm will be adjusted automatically.
Usage
M350 Snn Xnn Ynn Znn Enn Bnn
Parameters
Not all parameters need to be used, but at least one should be used. As with other commands, RepRapFirmware reports the current settings if no parameters are used.
Snn Set stepping mode for all drivers (not supported by RepRapFirmware)
Xnn Set stepping mode for the X axis
Ynn Set stepping mode for the Y axis
Znn Set stepping mode for the Z axis
Enn Set stepping mode for Extruder 0 (for RepRapFirmware use Enn:nn:nn etc. for multiple extruders)
Bnn Set stepping mode for Extruder 1 (not supported by RepRapFirmware, see above)
Inn Enable (nn=1) or disable (nn=0) microstep interpolation mode for the specified drivers, if they support it (RepRapFirmware only)
Modes (nn)
1 = full step
2 = half step
4 = quarter step
8 = 1/8 step
16 = 1/16 step
64 = 1/64 step
128 = 1/128 step
256 = 1/256 step
Examples
M350 S16    ; reset all drivers to the default 1/16 micro-stepping - not supported by RepRapFirmware
M350 Z1     ; set the Z-axis' driver to use full steps
M350 E4 B4  ; set both extruders to use quarter steps - Marlin/Repetier
M350 E4:4:4 ; set extruders 0-2 to use quarter steps - RepRapFirmware
Yes No ??? ??? ??? No No ??? Yes
Example
M351
M355: Turn case lights on/off
Yes: 1.1.0 No ??? ??? ??? Yes: 0.92.2 No ??? No
??? No No No No No use M106 ??? ???
Examples
M355 S1 ; Enable lights
M355 S0 ; Disable lights
M355    ; Report status
Every call or change over LCD menu sends a state change for connected hosting software like:
Case lights on
Case lights off
No case lights
No No ??? ??? ??? Yes: 0.92.2 No ??? No
Target
Example
M360
Response
Config:Baudrate:250000
Config:InputBuffer:127
Config:NumExtruder:2
Config:MixingExtruder:0
Config:HeatedBed:0
Config:SDCard:1
Config:Fan:1
Config:LCD:1
Config:SoftwarePowerSwitch:1
Config:XHomeDir:-1
Config:YHomeDir:-1
Config:ZHomeDir:-1
Config:SupportG10G11:1
Config:CaseLights:0
Config:ZProbe:1
Config:Autolevel:0
Config:EEPROM:1
Config:PrintlineCache:24
Config:JerkXY:30.00
Config:JerkZ:0.30
Config:RetractionLength:3.00
Config:RetractionSpeed:40.00
Config:RetractionZLift:0.00
Config:XMin:0.00
Config:YMin:0.00
Config:ZMin:0.00
Config:XMax:250.00
Config:YMax:150.00
Config:ZMax:90.00
Config:XSize:250.00
Config:YSize:150.00
Config:ZSize:90.00
Config:XPrintAccel:250.00
Config:YPrintAccel:250.00
Config:ZPrintAccel:100.00
Config:XTravelAccel:250.00
Config:YTravelAccel:250.00
Config:ZTravelAccel:100.00
Config:PrinterType:Cartesian
Config:MaxBedTemp:120
Config:Extr.1:Jerk:50.00
Config:Extr.1:MaxSpeed:100.00
Config:Extr.1:Diameter:0.00
Config:Extr.1:MaxTemp:220
Config:Extr.2:Jerk:50.00
Config:Extr.2:MaxSpeed:100.00
Config:Extr.2:Diameter:0.00
Config:Extr.2:MaxTemp:220
Partial No ??? ??? ??? No Yes ??? Partial
??? No No No No ??? No ??? ???
Experimental No ??? ??? ??? No Yes ??? Experimental
Smoothieware: M364 P0 will accept the current position as 90deg between arms. The offset is stored as a trim offset (M666) and no further user interaction is required except to save all changes via M500.
M365: SCARA scaling factor
M366: SCARA convert trim
No No ??? ??? ??? No Yes ??? No
No Use M557 ??? ??? ??? No Yes ??? No
Usage
M370
M370 X[divisions] Y[divisions]
M374: Save calibration grid
No 1.17 and later ??? ??? ??? No Yes ??? No
Saves the calibration grid.
Parameters
extension (Smoothieware only) Extension of the grid file
Pfilename (RepRapFirmware only) Name of the file to save to
Z (Smoothieware only) Also save the M206 Z homing offset into the grid file
Usage (Smoothieware)
M374
M374 <file extension> Z
Usage (RepRapFirmware)
M374
M374 PMyAlternateHeightMap.csv
In Smoothieware, without parameters this saves the grid into the default grid file that gets loaded at boot. The optional parameter specifies the extension of the grid file - useful for special grid files such as for a special print surface like a removable print plate. Addition of Z will additionally save the M206 Z homing offset into the grid file.
In RepRapFirmware, this saves the grid parameters and height map into the specified file, or the default file heightmap.csv if no filename was specified. To load the height map automatically at startup, use command M375 in the config.g file.
Displays the bed level calibration matrix (Marlin), or loads the grid matrix file (Smoothieware and RepRapFirmware)
Parameters
Usage
M375
M375 [file extension] ; (Smoothieware only)
M375 PMyAlternateHeightMap.csv ; (RepRapFirmware only)
Without parameters loads default grid, and with specified extension or specified filename attempts to load the specified grid. If not available will not modify the current grid. In Smoothieware, if Z was saved with the grid file, it will load the saved Z with the grid.
M376: Set bed compensation taper
Parameters
Hnnn Height (mm) over which to taper off the bed compensation
Example
M376 H10
This command specifies that bed compensation should be tapered off over the specified height, so that no bed compensation is applied at and above that height. If H is zero or negative then no tapering is applied, so compensation is performed throughout the entire print.
If the firmware does not adjust the extrusion amount to compensate for the changing layer height while tapering is being applied, you will get under- or over-extrusion. Using a large taper height will reduce this effect. For example, if the taper height is 50 times the largest bed height error, then under- or over-extrusion will be limited to 2%.
M380: Activate solenoid
Yes No ??? ??? ??? ??? No ??? Yes
Example
M380
M381: Disable all solenoids
Example
M381
??? Yes No No Yes ??? use G4 ??? ???
Example
M400
M401: Lower z-probe
Yes 1.17 and later ??? ??? ??? ??? No ??? Yes
Example
M401
Lower z-probe if present. In RepRapFirmware this runs macro file sys/deployprobe.g.
M402: Raise z-probe
Example
M402
Raise z-probe if present. In RepRapFirmware this runs macro file sys/retractprobe.g.
Yes Yes ??? ??? ??? No No ??? Yes
Parameters
Nnnn Filament width (in mm)
Dnnn Nozzle diameter (in mm)1
Examples
M404 N1.75
M404 N3.0 D1.0
Enter the nominal filament width (3mm, 1.75mm) or will display nominal filament width without parameters.
Notes
1While Marlin only accepts the 'N' parameter, RepRapFirmware further allows to specify the nozzle diameter (in mm) via the 'D 'parameter. This value is used to properly detect the first layer height when files are parsed or a new print is being started.
M405: Filament Sensor on
Example
M405
M406: Filament Sensor off
Example
M406
Example
M407
Displays measured filament diameter. In RepRapFirmware, M407 does the same as M404.
Parameters
Snnn Response type
Rnnn Response sequence number
Example
M408 S0
Report a JSON-style response by specifying the desired type using the 'S' parameter.
The following response types are supported:
  • Type 0 is a short-form response, similar to the response used by older versions of the web interface.
  • Type 1 is like type 0 except that static values are also included.
  • Type 2 is similar to the response provided by the web server for Duet Web Control.
  • Type 3 is an extended version of type 2 which includes some additional parameters that aren't expected to change very frequently.
  • Type 4 is an extended version of type 2 which may be used to poll for current printer statistics.
  • Type 5 reports the current machine configuration.
Here is an example of a typical type 0 response:
{"status":"I","heaters":[25.0,29.0,28.3],"active":[-273.1,0.0,0.0],"standby":[-273.1,0.0,0.0],"hstat":[0,2,1],"pos":[-11.00,0.00,0.00],"extr":[0.0,0.0],
 "sfactor":100.00, "efactor":[100.00,100.00],"tool":1,"probe":"535","fanPercent":[75.0,0.0],"fanRPM":0,"homed":[0,0,0],"fraction_printed":0.572}
The response is set as a single line with a newline character at the end. The meaning of the fields is:
status:  I=idle, P=printing from SD card, S=stopped (i.e. needs a reset), C=running config file (i.e starting up), A=paused, D=pausing, R=resuming from a pause, B=busy (e.g. running a macro), F=performing firmware update
hstat:   status of the heaters, 0=off, 1=standby, 2=active, 3=heater fault. Heater 0 is normally the bed heater, heaters 1, 2.. are the extruder heaters.
pos:     the X, Y and Z (and U, V, W if present) axis positions of the current tool (if a tool is selected), or of the print head reference point if no tool is selected
efactor: the current extrusion factors (see M221 command), one value per extruder
tool:    the selected tool number. A negative number typically means no tool selected.
probe:   the Z-probe reading
fanPercent: the speeds of the controllable fans, in percent of maximum
fanRPM:  the print cooling fan RPM
homed:   the homed status of the X, Y and Z axes (and U, V, W if they exist), or towers on a delta. 0=axis has not been homed so position is not reliable, 1=axis has been homed so position is reliable.
timesLeft: an array of the estimated remaining print times (in seconds) calculated by different methods. These are currently based on the proportion of the file read,
           the proportion of the total filament consumed, and the proportion of the total layers already printed. Only present if a print from SD card is in progress.
seq:     the sequence number of the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater than that.
resp:    the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater.
The type 1 response comprises these fields plus some additional ones that do not generally change and therefore do not need to be fetched as often. The extra fields include:
firmwareName: the name of the firmware, e.g. "RepRapFirmware", "Smoothieware" or "Repetier"
axes:    the number of axes
volumes: the number of SD card slots available
numTools:   the number of available tools numbered contiguously starting from 0
For a more detailed comparison of type 2 - 5, see RepRap_Firmware_Status_responses.
PanelDue currently uses only M408 S0 and M408 S1.
M420: Set RGB Colors as PWM (MachineKit)
??? No No No Yes ??? No ??? ???
Usage: M420 R[Red PWM (0-255)] E[Green PWM (0-255)] B[Blue PWM (0-255)]
Example
M420 R255 E255 B255
Set the color of your RGB LEDs that are connected to PWM-enabled pins. Note, the Green color is controlled by the <code>E value instead of the G value due to the G code being a primary code that cannot be overridden.
In Marlin M420 is Enable/Disable Mesh Leveling (with current values) S1=enable S0=disable
M420: Leveling On/Off/Fade (Marlin)
Enable/Disable Bed Leveling (using the current stored grid or mesh).
Usage
M420 S[bool] Z[float]
Examples
M420 S1  ; Enable compensation using current grid/mesh
M420 Z10 ; Gradually reduce compensation until Z=10
Marlin 1.1.0 adds the Z parameter to set the "fade" height. This requires the ENABLE_LEVELING_FADE_HEIGHT option.
When the Z fade height value is set non-zero, bed compensation will gradually reduce up to the given height, and cease completely above that height.
M421: Set a Mesh Bed Leveling Z coordinate
Yes No ??? ??? ??? No No ??? No
No No No No No No No ??? No
Set a single Z coordinate in the Mesh, Bilinear or UBL Leveling grid. Requires MESH_BED_LEVELING or AUTO_BED_LEVELING_BILINEAR or AUTO_BED_LEVELING_UBL.
I & J are the index for the X and Y axis respectively.
Usage
M421 I[index] J[index] Z[float] to set an absolute value to a mesh point
or
M421 I[index] J[index] Q[float] to offset a mesh point by a specified value
M450: Report Printer Mode
Usage
M450
Example
> M450
> PrinterMode:FFF
Printers can be used for different task by exchanging the toolhead. Depending on the tool, a different behavior of some commands can be expected. This command reports the current working mode. Possible answers are:
PrinterMode:FFF
PrinterMode:Laser
PrinterMode:CNC
M451: Select FFF Printer Mode
Usage
M451
Example
> M451
> PrinterMode:FFF
Switches to FFF mode for filament printing.
M452: Select Laser Printer Mode
Usage
M452
Example
> M452
> PrinterMode:Laser
Switches to laser mode. This mode enables handling of a laser pin and makes sure that the laser is only activated during G1 moves if laser was enabled or E is increasing. G0 moves should never enable the laser. M3/M5 can be used to enable/disable the laser for moves.
M453: Select CNC Printer Mode
Usage
M453
Example
> M453
> PrinterMode:CNC
Switches to CNC mode. In this mode M3/M4/M5 control the pins defined for the milling device.
M460: Define temperature range for thermistor-controlled fan
No Use M106 ??? ??? ??? Yes No ??? No
Usage
M460 X[minTemp] Y[maxTemp]
Example
M460 X50 Y60
If the firmware has a thermistor controlled fan defined, you can set at which temperature the fan starts and from which temperature on it should run with maximum speed.
M500: Store parameters in EEPROM
Yes Yes ??? ??? ??? Yes Yes ??? Yes
Example
M500
Save current parameters to EEPROM.
M501: Read parameters from EEPROM
Yes Yes ??? ??? ??? Yes ??? ??? Yes
Parameters
Snnn Enable auto-save (only RepRapFirmware)
Example
M501
Set the active parameters to those stored in the EEPROM. This is useful to revert parameters after experimenting with them.
RepRapFirmware versions prior to 1.17 allows "S1" to be passed, which forces parameters to be automatically saved to EEPROM when they are changed.
In RepRapFirmware 1.17 and later, the parameters are saved in file sys/config-override.g on the SD card.
M502: Revert to the default "factory settings."
Example
M502
This command resets all tunable parameters to their default values, as set in the firmware. This doesn't reset any parameters stored in the EEPROM, so it must be followed with M500 if you want to do that.
M503: Print settings
Yes Yes ??? ??? ??? ??? ??? ??? Yes
Example
M503
This command asks the firmware to reply with the current print settings stored in EEPROM. The reply output includes the G-Code commands to produce each setting. For example, the Steps Per Unit values are displayed as an M92 command.
RepRapFirmware outputs the content of the configuration file, but note that it may be truncated if it is too long.
M530: Enable printing mode
No No ??? ??? ??? Yes ??? ??? Yes
Example
M530 S1 L270
This command tells the firmware that a print has started (S1) or ended (S0). The L parameter sets the number of layers. L0 denotes unknown layer count. This enables the firmware to switch into a special print display mode to show print progress. Firmware should indicate the presence of this feature by responding to M115 with an additional line:
Cap:PROGRESS:1
M531: Set print name
Example
M531 Demo Model
Sets the name of the currently printed object. Should follow M530 S1 for correct display.
M532: Set print progress
Example
M532 X23.7 L56
Sets the print progress (X = 0..100) and currently printed layer (L). Should be send every 0.1% progress change on every layer change.
M540: Enable/Disable "Stop SD Print on Endstop Hit"
Parameters
Snnn state, S1=enable, S0=disable
Example
M540 S1
M540: Set MAC address
Parameters
Pnnn The MAC address
Examples
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED
M540 PDE:AD:BE:EF:CA:FE
All devices running on the same network shall all have different MAC addresses. For your printers, changing the last digit is sufficient.
M550: Set Name
Parameters
Pnnn Machine name
Example
M550 PGodzilla
M551: Set Password
Parameters
Pnnn Password
Example
M551 Pmy-very-secret-word
Note for RepRapFirmware: If the specified password differs from the default one (i.e. reprap), the user will be asked to enter it when a connection is established via HTTP or Telnet. For FTP, the password must always be passed explicitly.
M552: Set IP address, enable/disable network interface
Parameters
Pnnn IP address, 0.0.0.0 means acquire an IP address using DHCP
Snnn (optional) 0 = disable networking, 1 = enable networking as a client, 2 = enable networking as an access point (WiFi-enabled electronics only)
Rnnn (optional, RepRapFirmware 1.17 and earlier only) HTTP port, default 80
Example
M552 P192.168.1.14
Sets the IP address of the machine to (in this case) 192.168.1.14. If the S parameter is not present then the enable/disable state of the network interface is not changed.
In RepRapFirmware 1.18 and later the HTTP port address is set using the M586 command, so the R parameter of this command is no longer supported.
M552 with no parameters reports the current network state and IP address.
M553: Set Netmask
Parameters
Pnnn Net mask
Example
M553 P255.255.255.0
Sets the network mask of the RepRap machine to (in this case) 255.255.255.0. A restart may be required before the new network mask is used. If no 'P' field is specified, this echoes the existing network mask configured.
Recent RepRapFirmware versions allow the IP configuration to be changed without a restart.
M554: Set Gateway
Parameters
Pnnn Gateway
Example
M554 P192.168.1.1
Sets the Gateway IP address of the RepRap machine to (in this case) 192.168.1.1. A restart may be required before the new gateway IP address is used. If no 'P' field is specified, this echoes the existing Gateway IP address configured.
M555: Set compatibility
Parameters
Pnnn Emulation type
Example
M555 P1
For firmware that can do it, the firmware is set to a mode where its input and (especially) output behaves exactly like other established firmware. The value of the 'P' argument is:
P value Firmware
1 RepRap_Firmware
2 Marlin
3 Teacup
4 Sprinter
5 Repetier
M556: Axis compensation
No Yes ??? ??? ??? No No ??? No
Parameters
Snnn Height of the measured distances
Xnnn Deviation in X direction
Ynnn Deviation in Y direction
Znnn Deviation in Z direction
Example
M556 S100 X0.7 Y-0.2 Z0.6
Image denoting how to determine the S parameter for Gcode M556
M557: Set Z probe point or define probing grid
No Yes ??? ??? ??? No Yes ??? No
Parameters to define G32 probe points (Cartesian/CoreXY printers only, deprecated in RepRapFirmware)
Pnnn Probe point number
Xnnn X coordinate
Ynnn Y coordinate
Example
M557 P1 X30 Y40.5
Parameters to define G29 probe grid (all values in mm)
Xaaa:bbb Minimum and maximum X coordinates to probe
Yaaa:bbb Minimum and maximum Y coordinates to probe
R Radius to probe
S Probe point spacing
Examples
M557 X0:200 Y0:220 S20
M557 R150 S15
Set the points at which the bed will be probed to compensate for its plane being slightly out of horizontal.
The first form defines the points for for G32 bed probing. The P value is the index of the point (indices start at 0) and the X and Y values are the position to move extruder 0 to to probe the bed. An implementation should allow a minimum of three points (P0, P1 and P2). This just records the point coordinates; it does not actually do the probing. See G32. Defining the probe points in this way is deprecated in RepRapFirmware, you should define them in a bed.g file instead.
The second form defines the grid for G29 bed probing. For Cartesian printers, specify minimum and maximum X and Y values to probe and the probing interval. For Delta printers, specify the probing radius. If you define both, the probing area will be the intersection of the rectangular area and the circle. There is a firmware-dependent maximum number of probe points supported, which may be as low as 100.
M558: Set Z probe type
Parameters
Pnnn Z probe type
Xnnn If nonzero, use probe for homing X axis
Ynnn If nonzero, use probe for homing Y axis
Znnn If nonzero, use probe for homing Z axis
Fnnn Feed rate (i.e. probing speed, mm/min)
Hnnn Dive height (mm)
Innn Invert (I1) or do not invert (I0) the Z probe reading (RepRapFirmware 1.16 and later)
Rnnn Z probe recovery time after triggering, default zero (seconds) (RepRapFirmware 1.17 and later)1
Tnnn Travel speed to and between probe points (mm/min)
Snnn Extra parameter for experimentation
Example
M558 P1 X0 Y0 Z1 F500 T5000 H3
A Z probe may be a switch, an IR proximity sensor, or some other device. This selects which to use. P0 indicates that no Z probe is present. P1 gives an unmodulated IR probe, or any other probe type that emulates an unmodulated IR probe (probe output is an analog signal that rises with decreasing nozzle height above the bed). If there is a control signal to the probe, it is driven high when the probe type is P1. P2 specifies a modulated IR probe, where the modulation is commanded directly by the main board firmware using the control signal to the probe. P3 selects an alternative Z probe by driving the control signal to the probe low. P4 selects a switch for bed probing (on the Duet, this must be connected to the E0 endstop pins). P5 (from RepRapFirmware 1.14) selects a switch (normally closed) for bed probing between In and Gnd pins of the Z-probe connector (Duet 0.8.5 and Duet WiFi). P6 is as P4 but the switch is connected to and alternative connector (on the Duet series, the E1 endstop connector).
The X, Y and Z parameters specify whether each axis uses the Z probe for homing or not. If the parameter is nonzero, the Z probe is used for homing that axis. If the parameter is zero, the endstop switch for that axis is used for homing instead. See also G31 and G32.
Notes
1This parameter used to specify the Z probe channel in RepRapFirmware, but it has been superceded by the functionality of "M115 Px". With older firmware versions and a Duet 0.7/0.85, this parameter should be 1.
Example
M559
M560: Upload web page file
Example
M560
<!-- **EoF** -->
M561: Set Identity Transform
Example
M561
M562: Reset temperature fault
Parameters
Pnnn Heater number
Example
M562 P2
M563: Define or remove a tool
Parameters
Pnnn Tool number
Dnnn Extruder drive(s)
Hnnn Heater(s)
Fnnn Fan(s) to map fan 0 to (RepRapFirmware 1.16 and later)
Xnnn Axis or axes to map X movement to (RepRapFirmware 1.16 and later)
Examples
M563 P0 D0:2:3 H1:3         ; create a tool using extruder drives 0, 2 and 3 and heaters 1 and 3
M563 P1 D1 H2 X3            ; create a tool using extruder drive 1 and heater 2 with X movement mapped to the U axis
M563 P2 D0:1 H1:2 X0:3 F0:2 ; create a tool using extruder drives 0 and 1, heaters 1 and 2,
                            ; with X movement mapped to both X and U axes and fan 0 mapped to fan 0 and fan 2
Tools are usually (though not necessarily) extruders. The 'P' field specifies the tool number. Tool numbers can have any positive integer value and 0. The 'D' field specifies the drive(s) used by the tool - in the first example drives 0, 2 and 3. Drive 0 is the first drive in the machine after the movement drives (usually X, Y and Z). If there is no 'D' field the tool has no drives. The 'H' field specifies the tool's heaters - in the first example heaters 1 and 3. Heater 0 is usually the hot bed (if any) so the first extruder heater is usually 1. If there is no H field the tool has no heaters.
Tools are driven using multiple values in the 'E' field of G1 commands, each controlling the corresponding drive in the 'D' field above, as follows:
G1 X90.6 Y13.8 E2.24:2.24:15.89
G1 X70.6 E0:0:42.4
The first line moves straight to the point (90.6, 13.8) extruding a total of 2.24mm of filament from both drives 0 and 2 and 15.98mm of filament from drive 3. The second line moves back 20mm in X extruding 42.4mm of filament from drive 3.
Alternatively, if the slicer does not support generating G1 commands with multiple values for the extrusion amount, the M567 command can be used to define a tool mix ratio.
The X mapping option is used to create tools on machines with multiple independent X carriages. The additional carriages are set up as axes U, V etc. (see M584) and the X mapping option in M563 defines which carriage or carriages are used.
RepRapFirmware supports an additional form of the M563 command. The command:
M563 S1
means add 1 (the value of the S parameter) to all tool numbers found in the remainder of the current input stream (e.g. the current file if the command is read from a file on the SD card), or until a new M563 command of this form is executed. The purpose of this is to provide compatibility between systems in which tool numbers start at 1, and programs such as slic3r that assume tools are numbered from zero.
Recent versions of RepRapFirmware allow the deletion of existing tools if M563 is called in this way:
M563 P1 D-1 H-1
M564: Limit axes
Parameters
Snnn Limit movement within axis boundaries
Example
M564 S0
Allow moves outside the print volume, or not. If the S parameter is 0, then you can send G codes to drive the RepRap outside its normal working volume, and it will attempt to do so. User beware... If you set the S parameter to 1 then the RepRap will not think outside the box. The default behaviour is S = 1.
M565: Set Z probe offset
No see G31 ??? ??? ??? No Yes ??? No
Example
M565 X3 Y4.5 Z-2.37
Set the offset from the extruder tip to the probe position. The X, Y, and Z values are the delta between the extruder and the actual trigger position of the probe. If the probe trigger point is below the extruder (typical) the Z offset will be negative. This just records the point offset; it does not actually do the probing. See G32.
Parameters
Xnnn Maximum instantaneous speed change of the X axis (mm/min)
Ynnn Maximum instantaneous speed change of the Y axis
Znnn Maximum instantaneous speed change of the Z axis
Ennn Maximum instantaneous speed change of the extruder drives
Example
M566 X20 Y20 Z2 E10
Sets the maximum allowable speed change (sometimes called 'jerk speed') of each motor when changing direction.
The model files and gcode files used by repraps generally render circles and other curves shapes as a sequence of straight line segments. If the motors were not allowed any instantaneous speed change, they would have to come to a stop at the junction between each pair of line segments. By allowing a certain amount of instantaneous speed change, printing speed can be maintained when the angle between the two line segments is small enough.
If you set these X and Y values too low, then the printer will be slow at printing curves. If they are too high then the printer may be noisy when cornering and you may suffer ringing and other print artefacts, or even missed steps.
On very old versions of RepRapFirmware (prior to 1.09), these were also the minimum speeds of each axis.
M567: Set tool mix ratios
Parameters
Pnnn Tool number
Ennn Mix ratios
Example
M567 P2 E0.1:0.2:0.1:0.6
This example sets the mix ratio for tool 2 (the P value). When mixing is then turned on (see M568), only single E values need to be sent on a G1 command (any extra E values will be ignored, but are not illegal):
G1 X20 E1.3
See also M568.
Parameters
Pnnn Tool number
Snnn Whether mix ratios should be activated
Example
M568 P2 S0
G1 X20 E0.2:0.4:0.166:0.3
The off state is the default.
M569: Set axis direction and enable values
Parameters
Pnnn Motor driver number
Snnn Direction of movement of the motor(s) attached to this driver: 0 = backwards, 1 = forwards
Rnnn Driver enable polarity: 0 = active low, 1 = active high (default 0)
Tnnn Minimum driver step pulse width and interval in microseconds1
Example
M569 P0 S1
Set the control value for the drive specified by P that sends it forwards to the given value in the S field. After sending the example, sending a 1 to X (drive 0) will make it go forwards, sending a 0 will make it go backwards. Obviously to be used with extreme caution...
Notes
1RepRapFirmware 1.14 and later support the T parameter, to allow the step pulse width and interval to be lengthened for those drivers that need it. If no T parameter is given, then the step pulse width and interval are guaranteed to be suitable for the on-board drivers. Currently, RepRapFirmware only remembers the highest T parameter seen in any M569 command, and applies that value to all drivers for which any nonzero T parameter was specified.
Some versions of RepRapFirmware prior to 1.14 also provide X, Y, Z and E parameters to allow the mapping from axes and extruders to stepper driver numbers to be changed. From 1.14 onward, this functionality is provided by M584 instead.
M570: Configure heater fault detection
Parameters for RepRapFirmware 1.14 and earlier
Snnn Heater timeout (in seconds)
Example
M570 S120
After a heater has been switched on, wait 120 seconds for it to get close to the set temperature. If it takes longer than this, raise a heater fault.
Parameters for RepRapFirmware 1.15e and later
Hnnn Heater number
Pnnn Time in seconds for which a temperature anomaly must persist on this heater before raising a heater fault (default 5 seconds)
Tnnn Permitted temperature excursion from the setpoint for this heater (default 10C)
Example
M570 H1 P4 T15
Warning! Heating fault detection is provided to reduce the risk of starting a fire if a dangerous fault occurs, for example if the heater cartridge or thermistor falls out of the heater block. You should not increase the detection time or permitted temperature excursion without good reason, because doing so will reduce the protection.
M571: Set output on extrude
Parameters
Snnn Output value
Fnnn Output PWM frequency (RepRapFirmware 1.17 and later)
Pnnn Logical pin number (RepRapFirmware 1.17 and later), defaults to the FAN0 output until M571 with a P parameter has been seen
Example
M571 P3 F200
M571 S0.5
This turns the controlled pin output on whenever extrusion is being done, and turns it off when the extrusion is finished. The output could control a fan or a stirrer or anything else that needs to work just when extrusion is happening. It also can be used to control a laser beam. The S parameter sets the value of the PWM to the output. 0.0 is off; 1.0 is fully on.
In RepRapFirmware 1.17 and later you can use the P parameter to change the pin used and you can also set the PWM frequency. Pin numbers are the same as in the M42 and M280 commands. The pin you specify must not be in use for anything else, so if it is normally used as a heater you must disable the heater first using M307, or if it is used for a fan you must disable the fan using M106 with the I-1 parameter.
M572: Set or report extruder pressure advance
No dc42, ch, dn ??? ??? ??? No No ??? No
Parameters
Dnnn Extruder number
Snnn Pressure advance amount (in seconds)
Example
M572 D0 S0.1
This sets the pressure advance coefficient (S parameter) for the specified extruder (D parameter). Supported by RepRapFirmware-dc42, -ch and -dn.
Pressure advance causes the extruder drive position to be advanced or retarded during printing moves by an additional amount proportional to the rate of extrusion. At the end of a move when the extrusion rate is decreasing, this may result in the extruder drive moving backwards (i.e. retracting). Therefore, if you enable this feature, you may need to reduce the amount of retraction you use in your slicing program to avoid over-retraction.
With Bowden extruders, an S value between 0.1 and 0.2 usually gives the best print quality.
Older versions of RepRapFirmware used the P parameter to specify the drive number, instead of using D to specify the extruder number.
M573: Report heater PWM
Parameters
Pnnn Heater number
Example
M573 P1
This gives a running average (usually taken over about five seconds) of the PWM to the heater specified by the P field. If you know the voltage of the supply and the resistance of the heater this allows you to work out the power going to the heater. Scale: 0 to 1.
Parameters
Xnnn Switch type for X axis
Ynnn Switch type for Y axis
Znnn Switch type for Z axis
E Select extruder endstops to define active high or low (RepRapFirmware 1.16 and earlier only)
Snnn Logic level
Example
M574 X1 Y2 Z0 S1  ; X endstop at low end, Y endstop at high end, no Z endstop, all active high
This defines the type of endstop switch or opto sensor that the printer has for each axis: 0 = none, 1 = low end, 2 = high end. The optional S parameter defines whether the endstop input is active high (S1, the default) or low (S0). A normally-closed endstop switch wired in the usual way produces an active high output (S1).
This is intended for use with boards that provide a single endstop input for each axis that may be used for either a high or a low end endstop, such as the Duet. On delta printers, the XYZ parameters refer to the towers and the endstops should normally all be high end (i.e. at the top of the towers).
In RepRapFirmware 1.16 and earlier, the M574 command with E parameter is used to specify whether a Z probe connected to the E0 endstop input produces an active high (S1) or active low (S0) output. In RepRapFirmware 1.17 and later, use the I parameter of the M558 command instead.
Parameters
Pnnn Serial channel number
Bnnn Baud rate
Snnn Whether checksums should be used
Example
M575 P1 B57600 S1
This sets the communications parameters of the serial comms channel specified by the P parameter. P0 specifies the main serial interface (typically a USB port, or serial-over-USB), while P1 specifies an auxiliary serial port (for example, the port used to connect a PanelDue). The B parameter is the required baud rate (this parameter is typically ignored if the port is a true USB port). The S parameter is a bitmap of features. The lowest bit, if set, specifies that only commands that include a valid checksum should be accepted from this comms channel.
M577: Wait until endstop is triggered
??? No No No No ??? No ??? No
Parameters
Snnn Desired endstop level
Xnnn Select X axis endstop
Ynnn Select Y axis endstop
Znnn Select Z axis endstop
Ennn Select extruder drive endstop
Example
M577 E0 S1
Wait for an endstop switch to be pressed. The example above will wait until the first extruder endstop is triggered.
The following trigger types may be used using the 'S' parameter:
0: Endstop not hit 1: Low endstop hit 2: High endstop hit 3: Near endstop (only Z probe)
M578: Fire inkjet bits
Parameters
Pnnn Inkjet head number
Snnn Bit pattern
Example
M578 P3 S5
This fires inkjet head 3 (the P field) using the bit pattern specified by the S field. The example shown would fire bits 101. If the P parameter is ommitted inkjet 0 is assumed.
This is a version of the M700 command used by the Inkshield, but unfortunately M700 is already taken so cannot be used for that in the standard.
M579: Scale Cartesian axes
Parameters
Xnnn Scale factor for X axis
Ynnn Scale factor for Y axis
Znnn Scale factor for Z axis
Example
M579 X1.0127 Y0.998
On a Cartesian RepRap you can get prints exactly the right size by tweaking the axis steps/mm using the M92 G Code above. But this does not work so easily for Delta and other RepRaps for which there is cross-talk between the axes. This command allows you to adjust the X, Y, and Z axis scales directly. So, if you print a part for which the Y length should be 100mm and measure it and find that it is 100.3mm long then you set Y0.997 (= 100/100.3).
M580: Select Roland
Parameters
Rnnn Whether Roland mode should be activated
Pnnn Initial text to send to the Roland controller
Example
M580 R1 PVS4;!VZ2;!MC1;
This is not really anything to do with RepRap, but it is convenient. The little Roland mills are very widely available in hackerspaces and maker groups, but annoyingly they don't speak G Codes. As all RepRap firmware includes a G-Code interpreter, it is often easy to add functions to convert G Codes to Roland RML language. M580 selects a Roland device for output if the R field is 1, and returns to native mode if the R field is 0. The optional P string is sent to the Roland if R is 1. It is permissible to call this repeatedly with R set to 1 and different strings in the P field to communicate directly with a Roland.
M581: Configure external trigger
Parameters
Tnn Logical trigger number to associate the endstop input(s) with, from zero up to a firmware-specific maximum (e.g. 9 for RepRapFirmware)
X, Y, Z, E Selects endstop input(s) to monitor
P Reserved, may be used in future to allow general I/O pins to cause triggers
S Whether trigger occurs on a rising edge of that input (S1, default), falling edge (S0), or ignores that input (S-1). By default, all triggers ignore all inputs.
C Condition: whether to trigger at any time (C0, default) or only when printing a file from SD card (C1)
Example
M581 E1:2 S1 T2 C1   ; invoke trigger 2 when a rising edge is detected on the E1 or E2 endstop input and a file is being printed from SD card
When M581 is executed, if the T parameter is present but the other parameters are omitted, the trigger inputs and edge polarities for that trigger number are reported. Otherwise, the specified inputs and their polarities are added to the conditions that cause that trigger. Using S-1 with no X, Y, Z or E parameters sets the trigger back to ignoring all inputs.
In RepRapFirmware, trigger number 0 causes an emergency stop as if M112 had been received. Trigger number 1 causes the print to be paused as if M25 had been received. Any trigger number # greater then 1 causes the macro file sys/trigger#.g to be executed. Polling for further trigger conditions is suspended until the trigger macro file has been completed. RepRapFirmware does not wait for all queued moves to be completed before executing the macro, so you may wish to use the M400 command at the start of your macro file. If several triggers are pending, the one with the lowest trigger number takes priority.
M582: Check external trigger
Parameters
T Trigger number to poll
Example
M582 T2 ; check levels of inputs that give rise to trigger #2
Triggers set up by the M581 command are normally activated only when the specified inputs change state. This command provides a way of causing the trigger to be executed if the input is at a certain level. For each of the inputs associated with the trigger, the trigger condition will be checked as if the input had just changed from the opposite state to the current state.
For example, if you use M581 to support an out-of-filament sensor, then M582 allows you to check for out-of-filament just before starting a print.
M583: Wait for pin
No {soon} ??? ??? ??? No No ??? No
Parameters
Pnnn Pin number
Sn State to wait for (0 or 1) or analog tolerance
Rnnn Analog value to wait for (between 0.0 and 1.0)
Example
M583 P5 S0 ; Wait for Pin 5 to become 0
This allows you, for example, to turn on a DC motor (see the M42 command) then wait until a switch connected to Pin Pnnn gives the value Sn.
If the R field is present, then the system waits until the value on analog Pnnn is reached. In this case the S value is used as a tolerance, so M583 P8 R0.7 S0.01 would wait until the analog value on Pin 8 was between 0.69 and 0.71.
M584: Set drive mapping
No Version 1.14 and later ??? ??? ??? No No ??? No
Parameters
Xnnn Driver number(s) for X motor(s)
Ynnn Driver number(s) for Y motor(s)
Znnn Driver number(s) for Z motor(s)
U,V,Wnnn Driver number(s) for additional axes U, V, and W (RepRapFirmware 1.16 and later)
Ennn Driver number(s) for E motor(s)
Snnn Special functions (to be defined)
Example
M584 X0 Y1 Z2:3 E4:5:6 ; Driver 0 controls the X motor, 1 controls Y, 2 and 3 control Z motors, 4 and 5 control E motors
Assigning a drive using M584 does not remove its old assignment. Therefore, if you assign a drive that defaults to being an extruder drive, you should also assign the extruder drives explicitly as in the above example. Failure to do so may result in unexpected behaviour.
You can use M584 to create additional axes - for example, to represent additional carriages on a machine with multiple independent X carriages. You should not create axis W unless you also create axis V, and you should not create axis V unless you also create axis U.
On the Duet WiFi and Duet Ethernet, if you configure multiple drivers for an axis, either all of them must be TMC2660 drivers on the Duet or a Duet expansion board, or none of them must be. This is to facilitate dynamic microstepping and other features of the TMC2660.
M585: Probe Tool
No Template:Soon ??? ??? ??? No No ??? No
In machines with a tool probe this probes the currently selected tool against it and corrects the offsets set by the G10 command (q.v.).
Parameter must be only one of
Xnnn
Y-nnn
Znnn
Where the absolute value of nnn is the radius of the tool plus the radius of the probe in that direction. So M585 X1.5 will set the X offset of a 1mm diameter tool against a 2mm diameter probe, etc. If the value of nnn is positive the tool is moved in the positive direction towards the probe until it touches. If it is negative, the tool moves the other way.
So the process should be:
Set the values as closely as known in the G10 command.
Move to a position slightly offset from the probe then execute M585s in X, Y and Z in the tool selection macro to set them precisely.
After this, the G10 command on its own can be used to report the values.
M586: Configure network protocols
No 1.18 and later ??? ??? ??? No No ??? No
Parameters
Pnn Protocol: 0 = HTTP or HTTPS, 1 = FTP or SFTP, 2 = Telnet or SSH (which of the two choices depends on the T parameter)
Snn 0 = disable this protocol, 1 = enable this protocol
Rnn TCP port number to use for the specified protocol. Ignored unless S = 1. If this parameter is not provided then the default port for that protocol and TLS setting is used.
Tnn 0 = don't use TLS, 1 = use TLS. Ignored unless S = 1. If this parameter is not provided, then TLS will be used if the firmware supports it and a security certificate has been configured. If T1 is given but the firmware does not support TLS or no certificate is available, then the protocol will not be enabled and an error message will be returned.
M586 with no S parameter reports the current support for the available protocols.
RepRapFirmware 1.18 and later enable only HTTP (or HTTPS if supported) protocol by default. If you wish to enable FTP and/or Telnet, enable them using this command once or twice in config.g.
M587: Store WiFi host network in list, or list stored networks
No 1.19 and later ??? ??? ??? No No ??? No
Parameters
Sccc Network SSID
Pccc Network password
Inn.nn.nn.nn (optional) IP address to use when connected to this network. If zero or not specified then an IP address will be acquired via DHCP.
Jnn.nn.nn.nn (optional) Gateway IP address to use when connected to this network.
Knn.nn.nn.nn (optional) Netmask to use when connected to this network
If a password or SSID includes space or semicolon characters then it must be enclosed in double quotation marks. For security, do not use this command in the config.g file, or if you do then remove it after running it once so that the network password is not visible in the file.
M587 with no parameters lists all stored SSIDs, but not the stored passwords.
M588: Forget WiFi host network
Parameters
Sccc SSID to remove from the networks list
The specified SSID will be removed from the networks list and the associated password cleared out of EEPROM. If the SSID is given as * then all stored networks will be forgotten.
M589: Configure access point parameters
Parameters
Sccc The SSID that the WiFi interface should use when it is commanded to run as an access point
Pccc The WiFi password
Inn.nn.nn.nn The IP address to use
Note: WPA2 security will be used by default.
M590: Report current tool type and index
No No ??? ??? ??? No No ??? No
Report the current tool type, which may be "Extruder," "Picker," "Laser," "Foam Cutter," "Milling," or any others implemented by the machine. Also report the tool index, such as "0x01" for the second extruder.
Example
> M590
> echo: Extruder 0x00
M600: Set line cross section
No No ??? ??? ??? ??? ??? ??? No
Example
M600 P0.061
Sets the cross section for a line to extrude in velocity extrusion mode. When the extruder is enabled and movement is executed the amount of extruded filament will be calculated to match the specified line cross section.
M600: Filament change pause
Yes Not needed, use macro files ??? ??? ??? ??? Yes ??? Yes
Pause for filament change.
Parameters
X[pos]
Y[pos]
Z[relative lift]
E[initial retract
L[later retract distance for removal]
Example
M600
In SmoothieWare:
The variable "after_suspend_gcode" is run after M600.
For example:
after_suspend_gcode G91_G0E-5_G0Z10_G90_G0X-50Y-50 # gcode to run after suspend, retract then get head out of way
Yes Use M563 ??? ??? ??? ??? No ??? Yes
Set Dual X-Carriage movement mode.
Parameters
S[mode] Mode (see below)
X[duplication x-offset] Optional X offset for Mode 2
R[duplication temp offset] Optional temperature difference for Mode 2
Example
M605 S1 ; Set mode to auto-park
M605 S0: Full control mode. The slicer has full control over x-carriage movement M605 S1: Auto-park mode. The inactive head will auto park/unpark without slicer involvement M605 S2 [Xnnn] [Rmmm]: Duplication mode. The second extruder will duplicate the first with nnn millimeters x-offset and an optional differential hotend temperature of mmm degrees. E.g., with "M605 S2 X100 R2" the second extruder will duplicate the first with a spacing of 100mm in the x direction and 2 degrees hotter.
M665: Set delta configuration
Yes Yes ??? ??? ??? No Yes ??? Yes
Parameters
Lnnn Diagonal rod length
Rnnn Delta radius
Snnn Segments per second1
Bnnn Safe probing radius2,3
Hnnn Delta height defined as nozzle height above the bed when homed after allowing for endstop corrections 2
Xnnn X tower position correction2,4
Ynnn Y tower position correction2,4
Znnn Z tower position correction2,4
Examples
M665 L250 R160 S200 ; (Marlin)
M665 L250 R160 B80 H240 X0 Y0 Z0 ; (RepRapFirmware and Marlin 1.1.0)
Set the delta calibration variables. (See the discussion page for notes on this implementation.)
Notes
1Only supported on Marlin.
2Only supported in RepRapFirmware and Marlin 1.1.0.
3 In Marlin 1.1.0 sets the radius on which the probe points are taken for the delta auto calibration routine G33 as well as for the manual LCD calibration menu.
4X, Y and Z tower angular offsets from the ideal (i.e. equilateral triangle) positions, in degrees, measured anti-clockwise looking down on the printer. In Marlin 1.1.0 X,Y and Z tower angular offsets will be rotated so the Z tower angular offset is zero.
Parameters
Xnnn X axis endstop adjustment
Ynnn Y axis endstop adjustment
Znnn Z axis endstop adjustment
Annn X bed tilt in percent1
Bnnn Y bed tilt in percent1
Example
M666 X-0.1 Y+0.2 Z0
In RepRapFirmware and Repetier, positive endstop adjustments move the head closer to the bed when it is near the corresponding tower. In Marlin and Smoothieware, negative endstop corrections move the head closer to the bed when it is near the corresponding tower.
In Marlin, only negative endstop corrections are allowed. From version 1.1.0 onward positive endstops are allowed to be entered but the endstops will be normalized to zero or negative and the residue will be subtracted from the delta height defined in M665.
In Repetier the endstop corrections are expressed in motor steps. In other firmwares they are expressed in mm.
1RepRapFirmware 1.16 and later.
M667: Select CoreXY mode
Parameters
Snnn CoreXY mode
Xnnn X axis scale factor
Ynnn Y axis scale factor
Znnn Z axis scale factor
Example
M667 S1
M667 S0 selects Cartesian mode (unless the printer is configured as a delta using the M665 command). Forward motion of the X motor moves the head in the +X direction. Similarly for the Y motor and Y axis, and the Z motor and Z axis. This is the default state of the firmware on power up.
M667 S1 selects CoreXY mode. Forward movement of the X motor moves the head in the +X and +Y directions. Forward movement of the Y motor moves the head in the -X and +Y directions.
M667 S2 selects CoreXZ mode. Forward movement of the X motor moves the head in the +X and +Z directions. Forward movement of the Z motor moves the head in the -X and +Z directions.
M667 S3 selects CoreYZ mode. Forward movement of the Y motor moves the head in the +Y and +Z directions. Forward movement of the Z motor moves the head in the -Y and +Z directions.
Additional parameters X, Y and Z may be given to specify factors to scale the motor movements by for the corresponding axes. For example, to specify a CoreXZ machine in which the Z axis moves 1/3 of the distance of the X axis for the same motor movement, use M667 S2 Z3. The default scaling factor after power up is 1.0 for all axes.
To change the motor directions, see the M569 command.
M668: Set Z-offset compensations polynomial
No dc42-cmm ??? ??? ??? No No ??? No
Polynomial compensation is an experimental method to compensate for geometric distortion of a delta machine Z-plane. After the bed is compensated with the set of G30 points, there remains error. This method fits a 6th degree polynomial with independent origins for each order to the residual error data (using a simulated annealing technique on the host). The polynomial is communicated and controlled through M668. Because the polynomial takes many floating point operations to compute each point, the firmware builds a grid of values, and used bi-linear interpolation to adjust the actual Z-axis offset error estimate.
For the polynomial used, 40 parameters are specified. The I parameter allows the coefficients to be loaded a few at a time, which limits the size of the G-code string. The index starts with 1, not with 0.
M668 Ix S[list of values] sets the polynomial parameters starting at index x, if index present and != 0.
M668 R recomputes the grid based on the current parameters.
M668 P[0|1] turns off or on the polynomial compensation.
Typical usage
M668 I1 S4.882E-17:0.0
M668 I3 ...
M668 R P1
Which sets the list, computes the interpolation grid, and then enables compensation.
M669: Set kinematics type and kinematics parameters
Parameters
Knnn Kinematics type: 0 = Cartesian, 1 = CoreXY, 2 = CoreXZ, 3 = linear delta, 4 = SCARA
Selects the specified kinematics, then uses the other parameters to configure it. If the K parameter is missing then the other parameters are used to update the configuration data for the current kinematics. If no parameters are given then the current kinematics and configuration parameters are reported
Parameters for SCARA kinematics
Pnnn Proximal arm length (mm)
Dnnn Distal arm length (mm)
Annn:nnn Proximal arm joint movement minimum and maximum angles, in degrees anticlockwise seen from above relative to the X axis
Bnnn:nnn Proximal-to-distal arm joint movement minimum and maximum angles, in degrees anticlockwise seen from above relative to both arms in line
Cnnn:nnn:nnn Crosstalk factors. The first component is the proximal motor steps to equivalent distal steps factor, the second is the proximal motor steps to equivalent Z motor steps factor, and the third component is the distal motor steps to equivalent Z motor steps factor.
Snnn Segments per second if smooth XY motion is approximated by means of segmentation
Tnnn Minimum segment length (mm) if smooth XY motion is approximated by means of segmentation
Examples
M669 K4 P300 D250 A-90:90 B-135:135 C0:0:0 S200
The minimum and maximum arm angles are also the arm angles assumed by the firmware when the homing switches are triggered. The P, D, A and B parameters are mandatory. The C and F parameters default to zero, and the segmentation parameters default to firmware-dependent values.
M670: Set IO port bit mapping
Support Marlin RepRapFirmware Klipper Prusa Buddy Repetier Smoothie Druid MK4duo
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa MakerBot
Parameters
Pnn:nn:nn... List of logical port numbers that bits 0, 1, 2... control
Tnnn port switching time advance in milliseconds
RepRapFirmware 1.19 and later provides an optional P parameter on the G1 command to allow I/O ports to be set to specified states for the duration of the move. The argument to the P parameter is a bitmap giving the required state of each port. The M669 command specifies the mapping between the bits of that argument and logical port numbers. Optionally, the T parameter can be used to advance the I/O port switching a short time before the corresponding move begins.
M700: Level plate
bq No ??? ??? ??? No No ??? bq
Example
M700
M701: Load filament
bq v1.19 and later ??? ??? ??? No No ??? bq
Parameters
This command can be used without any additional parameters.
Snn Filament to load1
Examples
M5912
M591 S"PLA"
RepRapFirmware 1.19 and later implement a filament management mechanism to load and unload different materials. This code may be used to load a material for the active tool, however be aware that this code will work only for tools that have exactly one extruder assigned. When called the firmware does the following:
1) Run the macro file "load.g" in the subdirectory of the given material (e.g. /filaments/PLA/load.g)
2) Change the filament name of the associated tool, so it can be reported back to Duet Web Control
If this code is called without any parameters, RepRapFirmware will report the name of the loaded filament (if any).
1 only supported in RepRapFirmware
2 standard call for bq-Marlin Firmware
M702: Unload filament
Parameters
Example
M702
In contrast to M701 this code is intended to unload the previously loaded filament from the selected tool. RepRapFirmware will do the following when called:
1) Run the macro file "unload.g" in the subdirectory of the given material (e.g. /filaments/PLA/unload.g)
2) Change the filament name of the current tool, so it can be reported back to Duet Web Control
M703: Get Board Type
bq see M115 ??? ??? ??? No No ??? bq
1 only in bq-Marlin Firmware
Example
M703
M710: Erase the EEPROM and reset the board
bq see M999 ??? ??? ??? No No ??? bq
Example
M710
M750: Enable 3D scanner extension
No v1.18 and later ??? ??? ??? No No ??? No
Example
M750
This code may be used as an OEM extension to enable scanner functionality in the firmware. After a regular start of RepRapFirmware, the 3D scan extension is disabled by default, but if additional scanner components are attached, this code may be used to enable certain OEM functions.
M751: Register 3D scanner extension over USB
Example
M751
When a 3D scanner board is attached to the USB port, this code is used to turn on communication between the 3D printing and the scanner board. If the USB connection is removed while the 3D scanner configuration is active, the firmware will disable it again and restore the default communication parameters.
M752: Start 3D scan
Parameters
Snnn: Length/degrees of the scan
Pnnn: Filename for the scan
Example
M752 S300 Pmyscan
Instruct the attached 3D scanner to initiate a new 3D scan and to upload it to the board's SD card (i.e. in the "scans" directory). Before the SCAN command is sent to the scanner, the macro file "scan_pre.g" is executed and when the scan has finished, the macro file "scan_post.g" is run. Be aware that both files must exist to avoid error messages.
M753: Cancel current 3D scanner action
Example
M753
Instruct the attached 3D scanner to cancel the current operation. Cancelling uploads is not supported.
M754: Calibrate 3D scanner
Example
M754
Calibrates the attached 3D scanner. Before the calibration is performed by the external scanner, "calibrate_pre.g" is run and when it is complete, "calibrate_post.g" is executed.
M755: Set alignment mode for 3D scanner
Parameters
Pnnn Whether to turn on (> 0) or off (<= 0) the alignment feature
Examples
M755 P1
M755 P0
Sends the ALIGN ON/OFF command the attached 3D scanner. Some devices turn on a laser when this command is received. If the 'P' parameter is missing, equal to, or less than 0, the alignment feature is turned off. Depending on whether the alignment is turned on or off, either align_on.g or align_off.g is executed before the ALIGN command is sent to the scanner.
M756: Shutdown 3D scanner
Example
M756
Sends the SHUTDOWN command the attached 3D scanner.
M800: Fire start print procedure
Example
M800
M801: Fire end print procedure
Example
M801
M851: Set Z-Probe Offset
Yes Use G31 ??? ??? ??? ??? ??? ??? Use M666 P
Sets the Z-probe Z offset. This offset is used to determine the actual Z position of the nozzle when using a probe to home Z with G28. This value may also be used by G29 to apply correction to the Z position.
This value represents the distance from nozzle to the bed surface at the point where the probe is triggered. This value will be negative for typical switch probes, inductive probes, and setups where the nozzle makes a circuit with a raised metal contact. This setting will be greater than zero on machines where the nozzle itself is used as the probe, pressing down on the bed to press a switch. (This is a common setup on delta machines.)
This setting is saved in the EEPROM by M500 and restored by M501. The default (as reset by M502) is set by the Z_PROBE_OFFSET_FROM_EXTRUDER setting in Configuration.h.
Note that in Marlin 1.1.0 and up M851 sets the value literally as given, while Marlin 1.0.2 negates the absolute value.
The examples below will set the Z-probe Z offset to -4mm (below the nozzle):
M851 in Marlin 1.0.2
M851 Z4 ; Set the Z probe offset to -4
M851 in Marlin 1.1.0
M851 Z-4 ; Set the Z probe offset to -4
M900 Set Linear Advance Scaling Factors
1.1.0 No ??? ??? ??? No No ??? No
Sets the advance extrusion factors for Linear Advance. If any of the R, W, H, or D parameters are set to zero the ratio will be computed dynamically during printing.
Parameters
K[factor] Advance K factor
R[ratio] Set ratio directly (overrides WH/D)
W[width] H[height] D[diam] Set ratio from WH/D
Examples
M900 K0.7 W0.4 H0.1 D1.75 ; Set K and WH/D ratio
M900 R0.025   ; Set the WH/D ratio directly
M900 R0 ; Set to "auto ratio"
Requires enabling the LIN_ADVANCE feature in Marlin 1.1.
M905: Set local date and time
No 1.16 and later ??? ??? ??? No No ??? No
Parameters
Pnnn Current date in the format YYYY-MM-DD
Snnn Current time in the format HH:MM:SS
Example
M905 P2016-10-26 S00:23:12
Updates the machine's local date and time or reports them if no parameters are specified. The time should be specified in 24-hours format as in "13:45" instead of 1:45PM.
M906: Set motor currents
No Yes ??? ??? ??? No M907? ??? No
??? No No No No Yes No ??? ???
Parameters
Xnnn X drive motor current
Ynnn Y drive motor current
Znnn Z drive motor current
Ennn E drive(s) motor current(s)
Innn Motor current idle factor (0..100)1
H1 Set/Get Motor currents used for the downward Z-probe homing movement 2
Example
M906 X300 Y500 Z200 E350:350
Notes
1RepRapFirmware supports an additional I parameter. This is the percentage of normal that the motor currents should be reduced to when the printer becomes idle but the motors have not been switched off. The default value is 30%.
2RepRapFirmware, DC42 version, cmm sub-version supports "H1", which sets the XYZ motor currents used during Z-probing temporarily to different (typically lower) value. If "H1" is specified, the homing current is set, otherwise it operates normally. The homing current should be specified after the main current is set. The actual motor current is not changed until the next Z-probe operation. Lower motor currents reduce vibration during Z-probe motions.
Yes Use M906 ??? ??? ??? Yes Yes ??? Yes
Set digital trimpot motor current using axis codes (X, Y, Z, E, B, S). In Repetier, it sets the current in Percent. In Redeem, it sets the current in Amps (whereas M906 uses milliamps).
Yes No ??? ??? ??? Yes: 0.92 No ??? Yes
??? No No No No ??? No ??? ???
M908 P<pin> S<current>
M909: Set microstepping
Use M350 Use M350 ??? ??? ??? Use M350 No ??? Use M350
Example
M909 X3 Y5 Z2 E3
Set the microstepping value for each of the steppers. In Redeem this is implemented as powers of 2 so…
M909 X2 ; set microstepping on X-axis to 2^2 = 4
M909 Y3 ; set microstepping on Y-axis to 2^3 = 8 etc.
M910: Set decay mode
Example
M910 X3 Y5 Z2 E3
Set the decay mode for each stepper controller The decay mode controls how the current is reduced and recycled by the H-bridge in the stepper motor controller. It varies how the implementations are done in silicone between controllers. Typically you have an on phase where the current flows in the target current, then an off phase where the current is reversed and then a slow decay phase where the current is recycled.
M911: Set power monitor threshold voltages
??? No No No No No No ??? ???
Parameters
Pnnn Power monitor channel, default 0
Snnn Undervoltage threshold
Tnnn Overvoltage threshold
Example
M911 P0 S20 T27.5
Set the minimum supply voltage for which correct operation of the printer mechanics is guaranteed and stepper motor positions are guaranteed to be held for all enabled drivers, and/or the maximum safe voltage above which sensitive parts of the machine should be shut down. M911 with no parameters or with just the P parameter reports the current thresholds.
M912: Set electronics temperature monitor adjustment
Parameters
Pnnn Temperature monitor channel, default 0
Snnn Value to be added to the temperature reading in degC
Example
M912 P0 S10.5
Many microcontrollers used to control 3D printers have built-in temperature monitors, but they normally need to be calibrated for temperature reading offset. The S parameter specifies the value that should be added to the raw temperature reading to provide a more accurate result.
M913: Set motor percentage of normal current
Parameters
X, Y, Z, E Percentage of normal current to use for the specified axis or extruder motor(s)
Example
M913 X50 Y50 Z50 ; set X Y Z motors to 50% of their normal current
M913 E30:30 ; set extruders 0 and 1 to 30% of their normal current
This allows motor currents to be set to a specified percentage of their normal values as set by M906. It can be used (for example) to reduce motor current during course homing, to make homing quieter or to reduce the risk of damage to endstops, and to reduce current while loading filament to guard against the possibility of feeding too much filament. Use M913 again with the appropriate parameters set to 100 to restore the normal currents.
M914: Set/Get Expansion Voltage Level Translator
No Alligator build only ??? ??? ??? No No ??? No
Parameters
S Expansion voltage signal level, must be 3 or 5
Example
M914 S5 ; set expansion signal level to 5V
M913 ; report expansion signal voltage level
M928: Start SD logging
Yes No ??? ??? ??? No No ??? Yes
Example
M928 filename.g
Stop SD logging with M29.
M997: Perform in-application firmware update
??? No No No No No No ??? No
Parameters
Snnn Firmware module number(s), default 0
Example
M997 S0:1 - update firmware modules 0 and 1
This command triggers a firmware update if the necessary files are present on the SD card. In RepRapFirmware on the Duet series, module numbers are as follows:
0 - main firmware, filename sys/RepRapFirmware.bin (Duet) or sys/DuetWiFiFirmware (Duet WiFi). File sys/iap.bin (Duet) or sys/iap4e.bin (Duet WiFi) must also be present.
1 - web server firmware, filename sys/DuetWiFiServer.bin
2 - web server file system, filename sys/DuetWebControl.bin
3 - put the WiFi module into bootloader mode, so that firmware can be uploaded directly via its serial port
M998: Request resend of line
No Yes ??? ??? ??? No No ??? ???
Parameters
Pnnn Line number
Example
M998 P34
Request a resend of line 34. In some implementations the input-handling code overwrites the incoming G Code with this when it detects, for example, a checksum error. Then it leaves it up to the GCode interpreter to request the resend.
Parameters
Pnnn Reset flags1
Example
M999
Restarts the firmware using a software reset.
Notes
1The dc42 fork of RepRapFirmware not only resets the board but also puts the board into firmware upload mode if parameter PERASE is present.
Other commands
G: List all G-codes
??? ??? ??? ??? ??? Yes ??? ??? ???
Example
G
This lists all implemeted G-codes in the firmware with description and sends it back to the host.
(Note: this has been implemented in Redeem, and so is only a proposal.)
M: List all M-codes
Example
M
This lists all implemeted M-codes in the firmware with description and sends it back to the host.
T: Select Tool
??? No ??? Yes ??? Yes Yes ??? ???
Parameters
Pnnn: Bitmap of all the macros to be run (only RRF 1.17b or later)
Tool number
Example
T1
The sequence followed is:
  4. Use the new tool.
Selecting a non-existent tool (100, say) just does Step 1 above1. That is to say it leaves all tools in their standby state. You can, of course, use the G10 command beforehand to set that standby temperature to anything you like.
Some implementations (e.g. RepRapFirmware) allow you to specify tool-change G Code macros2. There are normally three specified (any of which can contain no commands if desired) that execute in this order:
  2. (Old tool is released);
With such implementations there is no wait for temperature stabilisation. That can be achieved by an M116 in any of the macros, of course. However be aware that recent RepRapFirmware versions does NOT run any tool change macros if the axes are not homed.
After a reset tools will not start heating until they are selected. You can either put them all at their standby temperature by selecting them in turn, or leave them off so they only come on if/when you first use them. The M0, M1, and M112 commands turn them all off. You can, of course, turn them all off with the M1 command, then turn some back on again. Don't forget also to turn on the heated bed (if any) if you use that trick.
Notes
1 For RepRapFirmware, selecting a non-existent tool also removes any X/Y/Z offset applied for the old tool.
2 Under special circumstances, the execution of those macro files may not be desired. RepRapFirmware 1.17b or later supports an optional P parameter to specify which macros shall be run. If it is abscent then all of the macros above will be run, else you can pass a bitmap of all the macros to be executed. The bitmap of this value consists of tfree=1, tpre=2 and tpost=4.
Marlin uses codes M500-M503 to manipulate EEPROM values.
xx can be one of:
ok
rs
On the latest version of Pronterface and Octoprint (1.2.0+) a special comment of the form:
// action:command
is allowed to be sent from the firmware, the command can currently be pause, resume or disconnect which will execute those commands on the host. As this is also a comment other hosts will just ignore these commands.
ok
start
Exceptions:
1. Marlin 1.0.0 Gen6 Firmware does not follow the two character rule. 'rs' is actually 'Resend' and '!!' is 'Error'. Example Lines:
  • Error: Line Number is not current line + 1. Last Line: 7
  • Resend: 8
  • Writing to File: print.gco
  • Done saving file.
  • File selected
2. The dc42 fork of RepRapFirmware responds to some commands with a reply string in JSON format, terminated by a newline. This allows later firmware revisions to include additional information without confusing clients (e.g. PanelDue) that do not expect it, and to make responses self-describing so that the client will not be confused if responses are delayed or lost. The commands affected are:
  • M105 S2
  • M105 S3
  • M20 S2
  • M36
  • M408
Problem to solve
When using Marlin firmware or emulating Marlin, each line of G-code sent from the host to the controller is answered with an ok before the next line can be sent without locking communications up. This slows down communication and limits the number of commands that can be sent per second to the printer controller, as the USB stack on the host and the serial interface driver on the Arduino add their own latencies (up to 10 milliseconds). This is not a problem for other controller electronics using native USB such as the Duet, because the standard serial-over-USB drivers provide flow control, so the host software can be configured so as not to wait for the ok.
Alternatives to G-code
