G-code
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications, too. See also on Wikipedia's G-code article.
There are a few different ways to prepare GCode for a printer. One is to use a slicer like Slic3r, Skeinforge or Cura. These programs take a CAD model, slice it into layers, and output the GCode required for each layer. Slicers are the easiest way to go from a 3D model to a printed part, but the user sacrifices some flexibility when using them. Another option for GCode generation is to use a lower level library like mecode. Libraries like mecode give you precise control over the tool path, and thus are useful if you have a complex print that is not suitable for naive slicing. The final option is to just write the GCode yourself. This may be the best choice if you just need to run a few test lines while calibrating your printer.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years. But this is the master page for RepRap. Nowhere in here should the same code be used for two different things; there are always more numbers to use... The rule is: add your new code here, then implement it.
But human nature being what it is, things aren't always done that way, so some multiple uses of the same code exist. The rule is that later appearances by them on this page than the original use of a code are deprecated and should be changed, unless there is a good technical reason (like the general G-Code standard) why a later instance should be prefered. Note that the key date is appearance here, not date of implementation.
- 1 Introduction
- 2 Fields
- 3 Comments
- 4 Special fields
- 5 Checking
- 6 Buffering
- 7 G-commands
- 7.1 G0 & G1: Move
- 7.2 G2 & G3: Controlled Arc Move
- 7.3 G4: Dwell
- 7.4 G10: Tool Offset
- 7.5 G10: Retract
- 7.6 G11: Unretract
- 7.7 G17..19: Plane Selection (CNC specific)
- 7.8 G20: Set Units to Inches
- 7.9 G21: Set Units to Millimeters
- 7.10 G22 & G23: Firmware controlled Retract/Precharge
- 7.11 G28: Move to Origin (Home)
- 7.12 G29: Detailed Z-Probe
- 7.13 G29.1: Set Z probe head offset
- 7.14 G29.2: Set Z probe head offset calculated from toolhead position
- 7.15 G30: Single Z-Probe
- 7.16 G31: Set or Report Current Probe status
- 7.17 G32: Probe Z and calculate Z plane
- 7.18 G31: Dock Z Probe sled
- 7.19 G32: Undock Z Probe sled
- 7.20 G38.x Straight Probe (CNC specific)
- 7.21 G40: Compensation Off (CNC specific)
- 7.22 G54..59: Coordinate System Select (CNC specific)
- 7.23 G80: Cancel Canned Cycle (CNC specific)
- 7.24 G90: Set to Absolute Positioning
- 7.25 G91: Set to Relative Positioning
- 7.26 G92: Set Position
- 7.27 G93: Feed Rate Mode (Inverse Time Mode) (CNC specific)
- 7.28 G94: Feed Rate Mode (Units per Minute) (CNC specific)
- 7.29 G100: Calibrate floor or rod radius
- 7.30 G130: Set digital potentiometer value
- 7.31 G131: Remove offset
- 7.32 G132: Calibrate endstop offsets
- 7.33 G133: Measure steps to top
- 7.34 G161: Home axes to minimum
- 7.35 G162: Home axes to maximum
- 8 M-commands
- 8.1 M0: Stop or Unconditional stop
- 8.2 M1: Sleep or Conditional stop
- 8.3 M2: Program End
- 8.4 M3: Spindle On, Clockwise (CNC specific)
- 8.5 M4: Spindle On, Counter-Clockwise (CNC specific)
- 8.6 M5: Spindle Off (CNC specific)
- 8.7 M6: Tool change
- 8.8 M7: Mist Coolant On (CNC specific)
- 8.9 M8: Flood Coolant On (CNC specific)
- 8.10 M9: Coolant Off (CNC specific)
- 8.11 M10: Vacuum On (CNC specific)
- 8.12 M11: Vacuum Off (CNC specific)
- 8.13 M17: Enable/Power all stepper motors
- 8.14 M18: Disable all stepper motors
- 8.15 M20: List SD card
- 8.16 M21: Initialize SD card
- 8.17 M22: Release SD card
- 8.18 M23: Select SD file
- 8.19 M24: Start/resume SD print
- 8.20 M25: Pause SD print
- 8.21 M26: Set SD position
- 8.22 M27: Report SD print status
- 8.23 M28: Begin write to SD card
- 8.24 M29: Stop writing to SD card
- 8.25 M30: Delete a file on the SD card
- 8.26 M31: Output time since last M109 or SD card start to serial
- 8.27 M32: Select file and start SD print
- 8.28 M33: Get the long name for an SD card file or folder
- 8.29 M34: Set SD file sorting options
- 8.30 M36: Return file information
- 8.31 M37: Simulation mode
- 8.32 M38 Compute SHA1 hash of target file
- 8.33 M40: Eject
- 8.34 M41: Loop
- 8.35 M42: Switch I/O pin
- 8.36 M43: Stand by on material exhausted
- 8.37 M48: Measure Z-Probe repeatability
- 8.38 M70: Display message
- 8.39 M72: Play a tone or song
- 8.40 M73: Set build percentage
- 8.41 M80: ATX Power On
- 8.42 M81: ATX Power Off
- 8.43 M82: Set extruder to absolute mode
- 8.44 M83: Set extruder to relative mode
- 8.45 M84: Stop idle hold
- 8.46 M85: Set inactivity shutdown timer
- 8.47 M92: Set axis_steps_per_unit
- 8.48 M93: Send axis_steps_per_unit
- 8.49 M98: Call Macro/Subprogram
- 8.50 M99: Return from Macro/Subprogram
- 8.51 M98: Get axis_hysteresis_mm
- 8.52 M99: Set axis_hysteresis_mm
- 8.53 M101: Turn extruder 1 on (Forward), Undo Retraction
- 8.54 M102: Turn extruder 1 on (Reverse)
- 8.55 M103: Turn all extruders off, Extruder Retraction
- 8.56 M104: Set Extruder Temperature
- 8.57 M105: Get Extruder Temperature
- 8.58 M106: Fan On
- 8.59 M107: Fan Off
- 8.60 M108: Set Extruder Speed
- 8.61 M109: Set Extruder Temperature and Wait
- 8.62 M110: Set Current Line Number
- 8.63 M111: Set Debug Level
- 8.64 M112: Emergency Stop
- 8.65 M113: Set Extruder PWM
- 8.66 M114: Get Current Position
- 8.67 M115: Get Firmware Version and Capabilities
- 8.68 M116: Wait
- 8.69 M117: Get Zero Position
- 8.70 M117: Display Message
- 8.71 M118: Negotiate Features
- 8.72 M119: Get Endstop Status
- 8.73 M120: Push
- 8.74 M121: Pop
- 8.75 M120: Enable endstop detection
- 8.76 M121: Disable endstop detection
- 8.77 M122: Diagnose
- 8.78 M123: Tachometer value
- 8.79 M124: Immediate motor stop
- 8.80 M126: Open Valve
- 8.81 M127: Close Valve
- 8.82 M128: Extruder Pressure PWM
- 8.83 M129: Extruder pressure off
- 8.84 M130: Set PID P value
- 8.85 M131: Set PID I value
- 8.86 M132: Set PID D value
- 8.87 M133: Set PID I limit value
- 8.88 M134: Write PID values to EEPROM
- 8.89 M135: Set PID sample interval
- 8.90 M136: Print PID settings to host
- 8.91 M140: Set Bed Temperature (Fast)
- 8.92 M141: Set Chamber Temperature (Fast)
- 8.93 M142: Holding Pressure
- 8.94 M143: Maximum hot-end temperature
- 8.95 M144: Stand By Your Bed
- 8.96 M146: Set Chamber Humidity
- 8.97 M149: Set temperature units
- 8.98 M150: Set display color
- 8.99 M160: Number of mixed materials
- 8.100 M163: Set weight of mixed material
- 8.101 M164: Store weights
- 8.102 M190: Wait for bed temperature to reach target temp
- 8.103 M191: Wait for chamber temperature to reach target temp
- 8.104 M200: Set filament diameter
- 8.105 M201: Set max printing acceleration
- 8.106 M202: Set max travel acceleration
- 8.107 M203: Set maximum feedrate
- 8.108 M204: Set default acceleration
- 8.109 M205: Advanced settings
- 8.110 M206:
- 8.111 M207: Calibrate z axis by detecting z max length
- 8.112 M207: Set retract length
- 8.113 M208: Set axis max travel
- 8.114 M208: Set unretract length
- 8.115 M209: Enable automatic retract
- 8.116 M210: Set homing feedrates
- 8.117 M211: Disable/Enable software endstops
- 8.118 M212: Set Bed Level Sensor Offset
- 8.119 M218: Set Hotend Offset
- 8.120 M220: Set speed factor override percentage
- 8.121 M221: Set extrude factor override percentage
- 8.122 M220: Turn off AUX V1.0.5
- 8.123 M221: Turn on AUX V1.0.5
- 8.124 M222: Set speed of fast XY moves
- 8.125 M223: Set speed of fast Z moves
- 8.126 M224: Enable extruder during fast moves
- 8.127 M225: Disable on extruder during fast moves
- 8.128 M226: Gcode Initiated Pause
- 8.129 M226: Wait for pin state
- 8.130 M227: Enable Automatic Reverse and Prime
- 8.131 M228: Disable Automatic Reverse and Prime
- 8.132 M229: Enable Automatic Reverse and Prime
- 8.133 M230: Disable / Enable Wait for Temperature Change
- 8.134 M231: Set OPS parameter
- 8.135 M232: Read and reset max. advance values
- 8.136 M240: Trigger camera
- 8.137 M240: Start conveyor belt motor / Echo off
- 8.138 M241: Stop conveyor belt motor / echo on
- 8.139 M245: Start cooler
- 8.140 M246: Stop cooler
- 8.141 M250: Set LCD contrast
- 8.142 M251: Measure Z steps from homing stop (Delta printers)
- 8.143 M280: Set servo position
- 8.144 M300: Play beep sound
- 8.145 M301: Set PID parameters
- 8.146 M302: Allow cold extrudes
- 8.147 M303: Run PID tuning
- 8.148 M304: Set PID parameters - Bed
- 8.149 M305: Set thermistor and ADC parameters
- 8.150 M306: set home offset calculated from toolhead position
- 8.151 M320: Activate autolevel(Repetier)
- 8.152 M321: Deactivate autolevel(Repetier)
- 8.153 M322: Reset autolevel matrix
- 8.154 M340: Control the servos
- 8.155 M350: Set microstepping mode
- 8.156 M351: Toggle MS1 MS2 pins directly
- 8.157 M355: Turn case lights on/off
- 8.158 M360: Report firmware configuration
- 8.159 SCARA calibration codes (Morgan)
- 8.160 M360: Move to Theta 0 degree position
- 8.161 M361: Move to Theta 90 degree position
- 8.162 M362: Move to Psi 0 degree position
- 8.163 M363: Move to Psi 90 degree position
- 8.164 M364: Move to Psi + Theta 90 degree position
- 8.165 M365: SCARA scaling factor
- 8.166 M366: SCARA convert trim
- 8.167 M370: Morgan manual bed level - clear map
- 8.168 M371: Move to next calibration position
- 8.169 M372: Record calibration value, and move to next position
- 8.170 M373: End bed level calibration mode
- 8.171 M374: Save calibration grid
- 8.172 M375: Display matrix / Load Matrix
- 8.173 M380: Activate solenoid
- 8.174 M381: Disable all solenoids
- 8.175 M400: Wait for current moves to finish
- 8.176 M401: Lower z-probe
- 8.177 M402: Raise z-probe
- 8.178 M404: Filament width and nozzle diameter
- 8.179 M405: Filament Sensor on
- 8.180 M406: Filament Sensor off
- 8.181 M407: Display filament diameter
- 8.182 M408: Report JSON-style response
- 8.183 M420: Set RGB Colors as PWM and is also Enable/Disable Mesh Bed Leveling
- 8.184 M421: Set a Mesh Bed Leveling Z coordinate
- 8.185 M450: Report Printer Mode
- 8.186 M451: Select FFF Printer Mode
- 8.187 M452: Select Laser Printer Mode
- 8.188 M453: Select CNC Printer Mode
- 8.189 M460: Define temperature range for thermistor controlled fan
- 8.190 M500: Store parameters in EEPROM
- 8.191 M501: Read parameters from EEPROM
- 8.192 M502: Revert to the default "factory settings."
- 8.193 M503: Print settings
- 8.194 M540: Enable/Disable "Stop SD Print on Endstop Hit"
- 8.195 M540: Set MAC address
- 8.196 M550: Set Name
- 8.197 M551: Set Password
- 8.198 M552: Set IP address
- 8.199 M553: Set Netmask
- 8.200 M554: Set Gateway
- 8.201 M555: Set compatibility
- 8.202 M556: Axis compensation
- 8.203 M557: Set Z probe point
- 8.204 M558: Set Z probe type
- 8.205 M559: Upload configuration file
- 8.206 M560: Upload web page file
- 8.207 M561: Set Identity Transform
- 8.208 M562: Reset temperature fault
- 8.209 M563: Define or remove a tool
- 8.210 M564: Limit axes
- 8.211 M565: Set Z probe offset
- 8.212 M566: Set allowable instantaneous speed change
- 8.213 M567: Set tool mix ratios
- 8.214 M568: Turn off/on tool mix ratios
- 8.215 M569: Set axis direction and enable values
- 8.216 M570: Set heater timeout
- 8.217 M571: Set output on extrude
- 8.218 M572: Set or report extruder pressure advance
- 8.219 M573: Report heater PWM
- 8.220 M574: Set endstop configuration
- 8.221 M575: Set serial comms parameters
- 8.222 M577: Wait until endstop is triggered
- 8.223 M578: Fire inkjet bits
- 8.224 M579: Scale Cartesian axes
- 8.225 M580: Select Roland
- 8.226 M581: Configure external trigger
- 8.227 M582: Check external trigger
- 8.228 M583: Wait for pin
- 8.229 M600: Set line cross section
- 8.230 M600: Filament change pause
- 8.231 M605: Set dual x-carriage movement mode
- 8.232 M665: Set delta configuration
- 8.233 M666: Set delta endstop adjustment
- 8.234 M667: Select CoreXY mode
- 8.235 M668: Set Z-offset compensations polynomial
- 8.236 M700: Level plate
- 8.237 M701: Load filament
- 8.238 M702: Unload filament
- 8.239 M851: Set Z-Probe Offset
- 8.240 M906: Set motor currents
- 8.241 M907: Set digital trimpot motor
- 8.242 M908: Control digital trimpot directly
- 8.243 M909: Set microstepping
- 8.244 M910: Set decay mode
- 8.245 M928: Start SD logging
- 8.246 M997: Perform in-application firmware update
- 8.247 M998: Request resend of line
- 8.248 M999: Restart after being stopped by error
- 9 Other commands
- 10 Proposed EEPROM configuration codes
- 11 Replies from the RepRap machine to the host computer
- 12 Proposal for sending multiple lines of G-code
- 13 Alternatives to G-code
Introduction
N3 T0*57 N4 G92 E0*67 N5 G28*22 N6 G1 F1500.0*82 N7 G1 X2.0 Y2.0 F3000.0*85 N8 G1 X3.0 Y3.0*33
Gcode can also be stored in files on SD cards. A file containing RepRap Gcode usually has the extension .g, .gco or .gcode. Files for BFB/RapMan have the extension .bfb. Gcode stored in file or produced by a slicer might look like this:
G92 E0 G28 G1 F1500 G1 X2.0 Y2.0 F3000 G1 X3.0 Y3.0
Slicers will (optionally?) add GCode scripts to the beginning and end of their output file to perform specified actions before and/or after a print such as z-probing the build-area, heating/cooling the bed and hotend, performing ooze free "nozzle wipe" startup routine, switching system power on/off, and even "ejecting" parts. More info on the Start GCode routines and End GCode routines pages.
Support | Marlin | RepRapFirmware | Repetier | Smoothie | Klipper | Prusa | MK4duo | MakerBot |
Partial | ??? | Experimental | depreciated | ??? | ??? | ??? | ??? | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | |
??? | No | ??? | Yes | ??? | ??? | automatic | ??? |
Here means:
- {{yes}}
- The Gcode is fully supported by the firmware.
- {{partial}} or {{experimental}}
- There is some support for the Gcode. Often it is required to check out the source code branch for the firmware (usually stored in a different branch) or to flip configuration switches on the mainboard.
- automatic
- The firmware handles this Gcode automatically, so there's no need to send the command. An example is power supply on/off Gcode (M80/M81) in the Teacup firmware.
- It is unknown if the firmware supports this Gcode. You may want to test this yourself before using it in production.
- {{no}}
- The firmware does not support this Gcode.
- depreciated
- The firmware depreciated this Gcode. The firmware author(s) should amend the depreciated Gcode on this page with workarounds (if needed) and the last supported firmware version that will accept this Gcode.
Fields
A RepRap Gcode is a list of fields that are separated by white spaces or line breaks. A field can be interpreted as a command, parameter, or for any other special purpose. It consists of one letter directly followed by a number, or can be only a stand-alone letter (Flag). The letter gives information about the meaning of the field (see the list below in this section). Numbers can be integers (128) or fractional numbers (12.42), depending on context. For example, an X coordinate can take integers (X175) or fractionals (X17.62), but selecting extruder number 2.76 would make no sense. In this description, the numbers in the fields are represented by nnn as a placeholder.
In RepRapFirmware, some parameters can be followed by more than one number, with colon used to separate them. Typically this is used to specify extruder parameters, with one value provided per extruder. If only one value is provided where a value is needed for each extruder, then that value is applied to all extruders.
Letter | Meaning |
Gnnn | Standard GCode command, such as move to a point |
Mnnn | RepRap-defined command, such as turn on a cooling fan |
Tnnn | Select tool nnn. In RepRap, a tool is typically associated with a nozzle, which may be fed by one or more extruders. |
Snnn | Command parameter, such as time in seconds; temperatures; voltage to send to a motor |
Pnnn | Command parameter, such as time in milliseconds; proportional (Kp) in PID Tuning |
Xnnn | A X coordinate, usually to move to. This can be an Integer or Fractional number. |
Ynnn | A Y coordinate, usually to move to. This can be an Integer or Fractional number. |
Znnn | A Z coordinate, usually to move to. This can be an Integer or Fractional number. |
Innn | Parameter - X-offset in arc move; integral (Ki) in PID Tuning |
Jnnn | Parameter - Y-offset in arc move |
Dnnn | Parameter - used for diameter; derivative (Kd) in PID Tuning |
Hnnn | Parameter - used for heater number in PID Tuning |
Fnnn | Feedrate in mm per minute. (Speed of print head movement) |
Rnnn | Parameter - used for temperatures |
Qnnn | Parameter - not currently used |
Ennn | Length of extrudate. This is exactly like X, Y and Z, but for the length of filament to consume. |
Nnnn | Line number. Used to request repeat transmission in the case of communications errors. |
*nnn | Checksum. Used to check for communications errors. |
Comments
Gcode comments begin at a semicolon, and end at the end of the line:
N3 T0*57 ; This is a comment N4 G92 E0*67 ; So is this N5 G28*22
Special fields
N: Line number
Yes | Yes | Yes | ??? | ??? | ??? | ??? | ??? | |
? | Yes | ??? | Yes | Yes | Yes | Yes | ??? |
Example: N123
If checking is supported, the RepRap firmware expects line numbers to increase by 1 each line, and if that doesn't happen it is flagged as an error. But you can reset the count using M110 (see below).
*: Checksum
? | Yes | ??? | Yes | ??? | ??? | Yes | ??? |
Example: *71
If checking is supported, the RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
Checking
The RepRap firmware checks the line number and the checksum. You can leave both of these out - RepRap will still work, but it won't do checking. You have to have both or neither though. If only one appears, it produces an error.
int cs = 0; for(i = 0; cmd[i] != '*' && cmd[i] != NULL; i++) cs = cs ^ cmd[i]; cs &= 0xff; // Defensive programming...
Buffering
Yes | Yes | ??? | ??? | ??? | ??? | ??? | ??? | |
Yes | ??? | ??? | Yes | ??? | ??? | Yes | ??? |
RepRapFirmware also implements an internal queue to ensure that certain codes (like M106) are executed in the right order and not when the last move has been added to the look-ahead queue. This feature is not available in RepRapFirmware-dc42.
G-commands
G0 & G1: Move
Yes | Yes | Yes | Yes | ??? | ??? | ??? | Yes | |
Yes | Yes | Yes | Yes | Yes | Yes | Yes | ??? |
- G0 : Rapid linear Move
- G1 : Linear Move
- Usage
- G0 Xnnn Ynnn Znnn Ennn Fnnn Snnn
- G1 Xnnn Ynnn Znnn Ennn Fnnn Snnn
- Parameters
- Not all parameters need to be used, but at least one has to be used
- Xnnn The position to move to on the X axis
- Ynnn The position to move to on the Y axis
- Znnn The position to move to on the Z axis
- Ennn The amount to extrude between the starting point and ending point
- Fnnn The feedrate per minute of the move between the starting point and ending point (if supplied)
- Snnn Flag to check if an endstop was hit (S1 to check, S0 to ignore, S2 see note, default is S0)1
- Examples
- G0 X12 (move to 12mm on the X axis)
- G0 F1500 (Set the feedrate to 1500mm/minute)
- G1 X90.6 Y13.8 E22.4 (Move to 90.6mm on the X axis and 13.8mm on the Y axis while extruding 22.4mm of material)
1. G1 F1500 2. G1 X50 Y25.3 E22.4
In the above example, we set the feedrate to 1500mm/minute on line 1, then move to 50mm on the X axis and 25.3mm on the Y axis while extruding 22.4mm of filament between the two points.
1. G1 F1500 2. G1 X50 Y25.3 E22.4 F3000
However, in the above example, we set a feedrate of 1500 mm/minute on line 1, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X and Y movement, so everything stays synchronized.
The RepRap spec treats the feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over the acceleration and deceleration of the printer head in such a way that ensures that everything moves smoothly together, and the right volume of material is extruded at all points.3
- Notes
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the S parameter in this way, as damage may occur if you assume incorrectly. In RepRapFirmware, using the S1 or S2 parameter on a delta printer causes the XYZ parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1.
4RepRapFirmware provides an additional 'R1' parameter to tell the machine to go back to the coordinates a print was previously paused at. If this parameter is used and the code contains axis letters, an offset will be added to the pause coordinates (e.g. G1 R1 Z5).
Yes1 | No | Yes | Yes | ??? | ??? | ??? | ??? | |
Yes | Yes | No | No | Yes | Experimental | No | ??? |
- Usage
- G2 Xnnn Ynnn Innn Jnnn Ennn Fnnn (Clockwise Arc)
- G3 Xnnn Ynnn Innn Jnnn Ennn Fnnn (Counter-Clockwise Arc)
- Parameters
- Innn The point in X space from the current X position to maintain a constant distance from
- Jnnn The point in Y space from the current Y position to maintain a constant distance from
- Examples
- G2 X90.6 Y13.8 I5 J10 E22.4 (Move in a Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
- G3 X90.6 Y13.8 I5 J10 E22.4 (Move in a Counter-Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
- Notes
1In Marlin Firmware not implemented for DELTA and SCARA printers.
G4: Dwell
- Parameters
- Pnnn Time to wait, in milliseconds
- Snnn Time to wait, in seconds (Only on Marlin and Smoothie)
- Example
- G4 P200
On Marlin and Smoothie, the "S" parameter will wait for seconds, while the "P" parameter will wait for milliseconds. "G4 S2" and "G4 P2000" are equivalent.
G10: Tool Offset
No | Yes | No | No | ??? | ??? | ??? | ??? | |
??? | No | No | No | Yes | ??? | No | ??? |
- Usage
- G10 Pnnn Xnnn Ynnn Znnn Rnnn Snnn1
- Parameters
- Pnnn Tool number
- Xnnn X offset
- Ynnn Y offset
- Znnn Z offset2
- Rnnn Standby temperature(s)
- Snnn Active temperature(s)
- Examples
- G10 P2 X17.8 Y-19.3 Z0.0 (sets the offset for tool (or in older implementations extrude head) 2 to the X, Y, and Z values specified)
- G10 P1 R140 S205 (set standby and active temperatures3 for tool 1)
- Notes
1Marlin uses G10/G11 for executing a retraction/unretraction move. The RepRapPro version of Marlin supports G10 for tool offset. Smoothie uses G10 for retract and G10 Ln for setting workspace coordinates.
2It's usually a bad idea to put a non-zero Z value in as well unless the tools are loaded and unloaded by some sort of tool changer. When all the tools are in the machine at once they should all be set to the same Z height.
4The NIST G-code standard mentions an additional L parameter, which is ignored (except in smoothie). This command is subject to discussion.
G10: Retract
Yes | dc42,ch | Yes: 0.92 | Yes | ??? | ??? | ??? | ??? | |
??? | No | No | No | No | ??? | No | ??? |
- Parameters
- Snnn retract length (S1 = long retract, S0 = short retract = default) (Repetier only)
- Example
- G10
Retracts filament according to settings of M207 (Marlin, RepRapFirmware) or according to the S value (Repetier).
RepRapFirmware recognizes G10 as a command to set tool offsets and/or temperatures if the P parameter is present, and as a retraction command if it is absent.
G11: Unretract
- Parameters
- Example
- G11
Unretracts/recovers filament according to settings of M208 (Marlin, RepRapFirmware) or according to the S value (Repetier).
??? | No | ??? | ??? | ??? | ??? | ??? | ??? | |
Yes | ??? | ??? | ??? | Yes | ??? | ??? | ??? |
- G17 : XY (default)
- G18 : ZX
- G19 : YZ
No | Yes | Yes | Yes | ??? | ??? | ??? | ??? | |
Yes | Yes | No | Yes | Yes | ??? | Yes | ??? |
- Example
- G20
- Example
- G21
No | No | No | No | ??? | ??? | ??? | ??? | |
- Usage
- G22 ; Retract
- G23 ; Unretract/Precharge
Relying on machine's firmware to execute extrusion retract/precharge move, instead of having slicer generating to E axis G1 movement. The retract/precharge length, velocity is handled by the machine firmware.
- Parameters
- This command can be used without any additional parameters.
- X Flag to go back to the X axis origin
- Y Flag to go back to the Y axis origin
- Z Flag to go back to the Z axis origin
- Examples
- G28 (Go to origin on all axes)
- G28 X Z (Go to origin only on the X and Z axis)
When the RepRap firmware receives this command, it moves all (or the supplied) axis's back to the zero endstops as quickly as it can, then backs off by a millimeter and slowly moves back to the zero endstop activation points to increase position accuracy. This process is also known as "Homing".
If you add coordinates, these coordinates are ignored. For example, G28 Z0.00
results in the same behaviour as G28 Z
RepRapFirmware runs macro files to home either all axes or an individual one. If all axes are homed, the file homeall.g will be processed, and homex.g, homey.g, or homez.g if individual axes are homed. On a Delta printer, any G28 command will home all three towers by processing the homedelta.g file, regardless of any XYZ letters.
Yes | No, see G32 | Yes | No, see G32 | ??? | ??? | ??? | ??? | |
??? | No | No | No | Yes | Yes | No | ??? |
Example: G29
Probes the bed at 3 or more points. The printer must be homed with G28 before G29.
Example: G29.1 X30 Y20 Z0.5
Example: G29.2 Z0.0
The user would typically place the toolhead at the zero point of the axis and issue the G29.2 command.
G30: Single Z-Probe
Yes | Yes | Yes | Yes | ??? | ??? | ??? | ??? | |
- Usage
- G30 Pnnn Xnnn Ynnn Znnn Hnnn Snnn
- Parameters
- Pnnn Probe point number
- Xnnn X coordinate
- Ynnn Y coordinate
- Znnn Z coordinate
- Hnnn Height correction1
- Snnn Set parameter
- Examples
- G30
- G30 P1 X20 Y50 Z0.3
- G30 P3 X180 Y180 Z-99999 S1
In its simplest form probes bed at current XY location. If G30 without parameters is called in RepRapFirmware, the bed is not probed, but the current Z value will be used as trigger height and the 'H' value (if specified) will be omitted.
Some implementations allow more general behaviour: if a Pn field is specified the probed X, Y, and Z values are saved as point n on the bed for calculating the offset plane. Generally n is 0, 1, or 2. If X, or Y, or Z values are specified (e.g. G30 P1 X20 Y50 Z0.3) then those values are used instead of the machine's current coordinates. A silly Z value (less than -9999.0) causes the machine to probe at the current point to get Z, rather than using the given value. If an S field is specified (e.g. G30 P1 Z0.3 S) the bed plane is computed for compensation and stored. The combination of these options allows for the machine to be moved to points using G1 commands, and then probe the bed, or for the user to position the nozzle interactively and use those coordinates. The user can also record those values and place them in a setup GCode file for automatic execution.
RepRapFirmware uses the value of the S parameter to specify what computation to perform. If the value is -1 then the Z offsets of all the points probed are printed, but no calibration is done. If the value is zero or not present, then this specified that the number of factors to be calibrated is the same as the number of points probed. Otherwise, the value indicates the number of factors to be calibrated, which must be no greater than the number of points probed. Currently (as of version 1.09), the number of factors may be 3, 4 or 5 when doing auto bed compensation on a Cartesian or CoreXY printer, and 3, 4, 6 or 7 when doing auto calibration of a Delta printer.
- Notes
1Recent RepRapFirmware versions support an optional H parameter, which is a height correction to be added to the trigger height set by the G31 Z parameter. It allows for the Z probe having a trigger height that varies with XY position.
No | Yes | ??? | Yes | ??? | ??? | ??? | ??? | |
- Usage
- G31 Pnnn Xnnn Ynnn Znnn Cnnn Snnn
- Parameters
- Pnnn Trigger value
- Xnnn Probe X offset1
- Ynnn Probe Y offset1
- Znnn Trigger Z height
- Cnnn Temperature coefficient2
- Snnn Calibration temperature2
- Examples
- G31 P500 Z2.6
- G31 X16.0 Y1.5
In RepRapFirmware, separate G31 parameters may be defined for different probe types (i.e. 0+4 for switches, 1+2 for IR probes and 3 for alternative sensors). To specify which probe you are setting parameters for, send a M558 command to select the probe type before sending the G31 command.
- Notes
1X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) can be specified in RepRapFirmware. This allows you to calculate your M557 probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset. It also provides more accurate bed compensation.
2In RepRapFirmware, additional parameters 'S' (bed temperature in oC at which the specified Z parameter is correct, default is current bed temperature) and 'C' (temperature coefficient of Z parameter in mm/oC, default zero) can be set for the alternative (ultrasonic) sensor. This is useful for probes that are affected by temperature.
No: See G29 | Yes | ??? | Yes | ??? | ??? | ??? | ??? | |
- Usage
- G32
Probes the bed at 3 or more pre-defined points (see M557) and updates transformation matrix for bed leveling compensation.
RepRapFirmware executes macro file bed.g if present instead of using the M557 coordinates.
Yes | No | ??? | No | ??? | ??? | ??? | ??? | |
??? | No | ??? | Yes | ??? | ??? | ??? | ??? | |
Yes | ??? | ??? | ??? | ??? | ??? | ??? | ??? |
G40 turn cutter compensation off. If tool compensation was on the next move must be a linear move and longer than the tool diameter. It is OK to turn compensation off when it is already off.
Example: G90
Yes | Yes | No | Yes | Yes | Yes | Yes | ??? |
Example: G91
G92: Set Position
- Parameters
- Xnnn new X axis position
- Ynnn new Y axis position
- Znnn new Z axis position
- Ennn new extruder position
- Example
- G92 X10 E90
G92.x: Reset Coordinate System Offsets (CNC specific)
- G92.1 - reset axis offsets to zero and set parameters 5211 - 5219 to zero. (X Y Z A B C U V W)
- G92.2 - reset axis offsets to zero.
G93 is Inverse Time Mode. In inverse time feed rate mode, an F word means the move should be completed in (one divided by the F number) minutes. For example, if the F number is 2.0, the move should be completed in half a minute.
When the inverse time feed rate mode is active, an F word must appear on every line which has a G1, G2, or G3 motion, and an F word on a line that does not have G1, G2, or G3 is ignored. Being in inverse time feed rate mode does not affect G0 (rapid move) motions.
No | No | Yes: 0.92 | No | ??? | ??? | ??? | ??? | |
- Parameters
- X Flag to set floor for X axis
- Y Flag to set floor for Y axis
- Z Flag to set floor for Z axis
- Rnnn Radius to add
- Examples
- G100 X Y Z (set floor for argument passed in. Number ignored and may be absent.)
- G100 R5 (Add 5 to radius. Adjust to be above floor if necessary)
- G100 R0 (Set radius based on current z measurement. Moves all axes to zero)
No | No | No | No | ??? | ??? | ??? | Yes | |
Example: G130 X10 Y18 Z15 A20 B12
G131: Remove offset
No | No | Yes: 0.91 | No | ??? | ??? | ??? | ??? | |
??? | No | No | No | No | ??? | Yes | ??? |
- Parameters
- X Flag to home the X axis to its minimum position
- Y Flag to home the Y axis to its minimum position
- Z Flag to home the Z axis to its minimum position
- Fnnn Desired feedrate for this command
- Example
- G161 X Y Z F1800
Instruct the machine to home the specified axes to their minimum position. Similar to G28, which decides on its own in which direction to search endstops.
- Parameters
- X Flag to home the X axis to its maximum position
- Y Flag to home the Y axis to its maximum position
- Z Flag to home the Z axis to its maximum position
- Example
- G162 X Y Z F1800
M-commands
Yes | Yes | No | No | ??? | ??? | ??? | ??? | |
Yes | No | No | Yes | Yes | ??? | Yes | ??? |
- Parameters
- Pnnn Time to wait, in milliseconds1
- Snnn Time to wait, in seconds2
- Example
- M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller, although this step is not mandatory on RepRapFirmware. See also M1, M112.
RepRapFirmware executes macro file stop.g before everything is turned off. Apart from that, RepRapFirmware (v1.09n-ch) accepts an extra 'H' parameter, whose value must be non-zero, to keep all heaters active. This is what Duet Web Control v1.07 sends to cancel a paused print.
- Notes
1Not available in RepRapFirmware, but as a work-around G4 can be run before M0.
2Only available on Marlin.
Yes | No | No | No | No | ??? | ??? | ??? |
- Example
- M1
If Marlin is emulated in RepRapFirmware, this does the same as M25 if the code was read from a serial or Telnet connection, else the macro file sleep.g is run before all heaters and drives are turned off.
M2: Program End
No | No | No | ??? | ??? | ??? | ??? | Yes | |
Yes | No | No | No | No | ??? | Yes | ??? |
Example: M2
- Parameters
- Snnn Spindle RPM
- Example
- M3 S4000
RepRapFirmware interprets this code only if a Roland mill has been configured.
In Repetier-Firmware in laser mode you need S0..255 to set laser intensity. Normally you use S255 to turn it on full power for moves. Laser will only fire during G1/2/3 moves and in laser mode (M452).
No | No | Yes | No | ??? | ??? | ??? | ??? | |
Yes | No | No | No | No | ??? | No | ??? |
Example: M4 S4000
No | No | Yes | Yes | ??? | ??? | ??? | ??? | |
Example: M5
The spindle is turned off.
M6: Tool change
No | No | No | ??? | ??? | ??? | ??? | ??? | |
Example: M6
Yes | No | No | No | No | ??? | use M106 | ??? |
Example: M7
Example: M8
Example: M9
??? | No | No | No | No | ??? | use M106 | ??? |
Example: M10
Example: M11
Yes | No | No | Yes | ??? | ??? | ??? | ??? | |
??? | No | No | No | No | Yes | (automatic) | ??? |
Example: M17
call M84 | Yes | No | Yes | ??? | ??? | ??? | Yes | |
??? | No | No | No | No | Yes | use M2 | ??? |
- Parameters
- This command can be used without any additional parameters.1
- X X axis
- Y Y axis
- Z Z axis
- E Extruder drive(s)2
- Examples
- M18
- M18 X E0
- Notes
2RepRapFirmware allows stepper motors to be disabled selectively. For example, M18 X E0:2 will disable the X, extruder 0 and extruder 2 motors.
M20: List SD card
??? | Yes | No | No | No | ??? | Yes | ??? |
- Parameters
- Snnn Output style1
- Pnnn Directory to list2
- Examples
- M20
- M20 P/gcodes/subdir S2
ok SQUARE.G SQCOM.G ZCARRI~2.GCO CARRIA~1.GCO
On Marlin, a file list response is usually encapsulated. Standard configurations of RepRapFirmware mimic this style in emulation mode:
Begin file list: SQUARE.G ZCARRI~2.GCO End file list ok
GCode files: "Traffic cone.g","frog.gcode","calibration piece.g"
Note that some firmwares list file names in upper case, but - when sent to the M23 command (below) they must be in lower case. Teacup and RepRapFirmware have no such trouble and accept both. Besides, RepRapFirmware always returns long filenames in the case in which they are stored.
- Notes
1This parameter is only supported by RepRapFirmware and defaults to the /gcodes directory, which would be whatever directory printable gcode files are normally stored in on other firmware.
2If the S2 parameter is used on RepRapFirmware, then the file list is returned in JSON format as a single array called "files" with each name that corresponds to a subdirectory preceded by an asterisk, and the directory is returned in variable "dir".
Yes | No | Yes | Yes | ??? | ??? | ??? | ??? | |
??? | Yes | No | No | No | No | Yes | ??? |
Example: M21
The SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
Yes | No | Yes | No | ??? | ??? | ??? | ??? | |
Example: M22
SD card is released, so further (accidental) attempts to read from it are guaranteed to fail. Helpful, but not mandatory before removing the card physically.
M23: Select SD file
- Example
- M23 filename.gco
- Example
- M24
The machine prints from the file selected with the M23 command. If the print was previously paused with M25, printing is resumed from that point. To restart a file from the beginning, use M23 to reset it, then M24.
When this command is used to resume a print that was paused, RepRapFirmware runs macro file resume.g prior to resuming the print.
M25: Pause SD print
- Example
- M25
The machine pauses printing at the current position within the file. To resume printing, use M24. Do not use this code to pause the print in a G-code file, use M226 instead.
Prior to pausing, RepRapFirmware runs macro file pause.g. This allows the head to be moved away from the print, filament to be retracted, etc.
Yes | Yes | Yes | aborts | ??? | ??? | ??? | ??? | |
??? | Yes | No | No | No | ??? | No | ??? |
- Parameters
- Snnn File position in bytes
- Example
- M26
- Example
- M27
Report SD print status.
Marlin and recent forks of RepRapFirmware report the number of bytes processed in this format, which can be processed by Pronterface:
SD printing byte 2134/235422
Not SD printing.
- Example
- M28 filename.gco
Yes | Yes | Yes | No | ??? | ??? | ??? | ??? | |
- Example
- M29 filename.gco
Yes | Yes | No | No | No | ??? | No | ??? |
Example: M30 filename.gco
filename.gco is deleted.
M30 in grbl
M30 exchange pallet shuttles and end the program. Pressing cycle start will start the program at the beginning of the file.
Yes | No | No | No | ??? | ??? | ??? | ??? | |
- Example
- M31
The response looks like:
echo:54 min, 38 sec
Yes | Yes | No | Yes | ??? | ??? | ??? | ??? | |
- Example
- M32 filename.gco
It can be used when printing from SD card and does the same as M23 and M24.
No | Yes | No | No | ??? | ??? | ??? | No | |
??? | No | No | No | No | No | No | ??? |
- Example
- M36 filename.gco
If the file name parameter is not supplied and a file on the SD card is currently being printed, then information for that file is returned including additional field "fileName". This feature is used by the web interface and by PanelDue, so that if a connection is made when a file is already being printed, the name and other information about that file can be shown.
No | dc42 | No | No | ??? | ??? | ??? | ??? | |
M37 S1 enters simulation mode. All G and M codes will not be acted on, but the time they take to execute will be calculated.
M37 S0 leaves simulation mode.
No | ch fork | No | No | ??? | ??? | ??? | ??? | |
Used to compute a hash of a file on the SD card. Examples:
M37 gcodes/myfile.g
Cannot find file
M37 www/reprap.htm
91199139dbfadac15a18cfb962dfd4853db83999
Returns a hexadecimal string which is the SHA1 of the file. If the file cannot be found, then the string "Cannot find file" is returned instead.
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
- When you press the reset button,
- When the build material runs out (if your RepRap is set up to detect this), and
- When there's an error (such as a heater failure).
M42: Switch I/O pin
Yes | Yes | Yes | No | ??? | ??? | ??? | No | |
??? | Yes | No | No | No | No | No | ??? |
- Parameters
- Pnnn Pin number
- Snnn Pin value
- Example
- M42 P7 S255
In RepRapFirmware, only 1 and 0 are supported for the S field. On Duet hardware, the supported pin numbers and their names on the expansion connector are:
16 TXD1, 17 RXD1, 18 TXD0, 19 RXD0, 20 TWD1, 21 TWCK1, 23 RTS1, 36 PC4_PWML1, 52 AD14, 66 AD13, 67 PB16.
See also M583.
Example: M43
- Parameters
- Pnnn number of points
- Xnnn position on the X axis
- Ynnn position on the Y axis
- Vnnn verbosity
- E engage
- Lnnn legs of travel
As with G29, the E flag causes the probe to stow after each probe.
see M117 | see M117 | No | ??? | ??? | ??? | ??? | Yes | |
Example: M70 P200 Message
Instruct the machine to display a message on it's interface LCD. P is the time to display message for.
see M300 | see M300 | No | No | ??? | ??? | ??? | Yes | |
Example: M72 P2
Example: M73 P50
Instruct the machine that the build has progressed to the specified percentage. The machine is expected to display this on it's interface board. If the percentage is exactly 0, then a Build Start Notification is sent. If the percentage is exactly 100, then a Build End notification is sent.
M80: ATX Power On
??? | Yes | No | No | No | ??? | automatic | ??? |
- Example
- M80
Note: some firmwares, like Teacup, handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off
M81: ATX Power Off
??? | Yes | No | No | No | Yes | automatic | ??? |
- Example
- M81
For redeem, adding 'P' will quit the daemon (redeem). Adding parameter 'R' will restart the daemon.
- Example
- M82
- Example
- M83
M84: Stop idle hold
- Parameters
- Innn Reset flags1
- Example
- M84
On Marlin, Repetier and RepRapFirmware, M84 can also be used to configure or disable the idle timeout. For example, "M84 S10" will idle the stepper motors after 10 seconds of inactivity. "M84 S0" will disable idle timeout; steppers will remain powered up regardless of activity.
- Notes
1RepRapFirmware-dc42 and other firmware may not support this parameter.
Example: M85 S30
- Parameters
- Xnnn Steps per unit for the X drive
- Ynnn Steps per unit for the Y drive
- Znnn Steps per unit for the Z drive
- Ennn Steps per unit for the extruder drive(s)
- Examples
- M92 X87.489 Y87.489 Z87.489
- M92 E420:420
Allows programming of steps per unit (usually mm) for motor drives. These values are reset to firmware defaults on power on, unless saved to EEPROM if available (M500 in Marlin) or in the configuration file (config.g in RepRapFirmware). Very useful for calibration.
No | No | ??? | No | ??? | ??? | ??? | ??? | |
- Parameters
- Pnnn Macro filename
- Example
- M98 Pmymacro.g
Runs the macro in the file mymacro.g. In conventional G Codes for CNC machines the P parameter normally refers to a line number in the program itself (P2000 would run the Macro starting at line O2000, say). For RepRap, which almost always has some sort of mass storage device inbuilt, it simply refers to the name of a GCode file that is executed by the G98 call. That GCode file does not need to end with an M99 (return) as the end-of-file automatically causes a return. Macro calls cannot usually be nested or be recursive; i.e. you can't call a macro from a macro, although RepRapFirmware explicitly supports this.
RepRapFirmware also allows the filename to include a path to a subdirectory. For relative paths, the default folder is /sys, but some implementations may check the /macros directory too. Absolute file paths are supported on RepRapFirmware as well.
- Example
- M99
Returns from an M98 call.
Example: M98
Proposed for Marlin
Example: M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
??? | No | Yes | No | No | ??? | Yes | ??? |
in Teacup firmware: If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103.
in BFB/RapMan firmware: Turn extruder on (forward/filament in).
in other firmwares: Deprecated. Regarding filament retraction, see M227, M228, M229.
??? | No | Yes | No | No | ??? | No | ??? |
In other firmwares: Deprecated.
In Teacup firmware: If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101.
In other firmwares: Deprecated. Regarding extruder retraction, see M227, M228, M229.
??? | Yes | Yes | Yes | Yes | Yes | Yes | ??? |
- Parameters
- Snnn Target temperature
- Example
- M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). Duet-dc42 and other firmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command applies to. See also M109.
M104 in Teacup Firmware
Example: M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100 °C.
??? | Yes | No | Yes | No | Yes | Yes | ??? |
- Parameters
- Rnnn Response sequence number1
- Snnn Response type1
- Examples
- M105
- M105 S2
ok T:201 B:117
M105 X0 ==> 11:05:48.910 : T:23.61 /0 @:0 T0:23.61 /0 @0:0 RAW0:3922 T1:23.89 /0 @1:0 RAW1:3920
- Notes
1These parameters are only supported by RepRapFirmware, which returns a JSON-formatted response if parameter S2 or S3 is specified. Additionally, parameter Rnn may be provided, where nn is the sequence number of the most recent G-code response that the client has already received. M105 S2 is equivalent to M408 S0, and M105 S3 is equivalent to M408 S2. Usage of these forms of M105 is deprecated, please use M408 instead.
M106: Fan On
??? | Yes | Yes | Yes | Yes | ??? | Yes | ??? |
- Parameters
- Pnnn Fan number (optional, defaults to 0)2
- Snnn Fan speed (0 to 255)
- Innn Invert signal1
- Fnnn Set fan PWM frequency, in Hz1
- Hnn:nn:nn... Select heaters monitored when in thermostatic mode1
- Rnnn Restore fan speed to the value it has when the print was paused1
- Tnnn Set thermostatic mode trigger temperature1
- Examples
- M106 S127
- M106 P1 I1 S871
- M106 P1 T45 H1:21
The first example turns on the default cooling fan at half speed. The second one inverts the cooling fan signal of the second fan and sets its value to 1/3 of its maximum. The third one sets the second fan to a thermostatic fan for heaters 1 and 2 (e.g. the extruder heaters in a dual-nozzle machine) such that the fan will be on when either hot end is at or above 45C.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0 turns the fan off. In some implementations like RepRapFirmware the PWM value may alternatively be specified as a real fraction: M106 S0.7.
- Notes
2Marlin only supports fan 0, all values above 0 will be interpreted as 0
M106 in RepRapFirmware
RepRapFirmware supports an optional 'I' parameter, whose value must be greater than zero to invert the cooling fan output signal. This makes the cooling fan output suitable for feeding the PWM input of a 4-wire fan via a diode. If the parameter is present and zero or negative, the output is not inverted. If the parameter is not present, the inverted/non-inverted state remains unchanged. The default at power up is not inverted.
If the optional 'R' parameter is specified, the fan value when the print was last paused will be set. If the 'S' parameter is passed along with 'R', the firmware will not reset the last-known fan value. This may be useful for tool change macro files.
The T and H parameters allow a fan to be configured to operate in thermostatic mode, for example to use one of the fan channels to control the hot end fan. In this mode the fan will be fully on when the temperature of any of the heaters listed in the H parameter is at or above the trigger temperature set by the T parameter, and off otherwise. Thermostatic mode can be disabled using parameter H-1.
M106 in Teacup Firmware
Example: M106 P2 S255
Note well: The ambiguous text in the note above needs to be reworded by someone who knows the actual functioning. Below is my interpretation based on language use, not practical experience or code inspection.
Note: If M104 is (or becomes) active on a heater (or other device) with a feedback sensor it will correct any M106 initiated control output value change in the time it takes for the PID (of other feedback) loop to adjust it back to minimum error. It may not be easy to observe a change in the temperature (process value) due to this brief change in the control value
M107: Fan Off
??? | Yes | Yes | Yes | Yes | ??? | No | ??? |
Deprecated in Teacup firmware and in RepRapFirmware. Use M106 S0 instead.
Sets speed of extruder motor. (Deprecated in FiveD firmware, see M113)
??? | Yes | No | Yes | Yes | Yes | not needed | ??? |
- Parameters
- Snnn minimum target temperature, waits until heating
- Rnnn maximum target temperature, waits until cooling (Sprinter)
- Rnnn accurate target temperature, waits until heating and cooling (Marlin)
- Example
- M109 S215
M109 in Teacup
M109 in Marlin, Sprinter (ATmega port), RepRapFirmware
Example: M109 S185
RepRapFirmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command refers to (see below).
M109 in Sprinter (4pi port)
Example: M109 S185 R240 //sets extruder temperature to 185 and waits for the temperature to be between 185 - 240.
M109 in MakerBot
Example: M109 S70 T0
??? | No | No | Yes | No | ??? | not needed | ??? |
- Parameters
- Nnnn Line number
- Example
- M110 N123
??? | No | No | Yes | No | ??? | Debug | ??? |
- Parameters
- Pnnn Debug module1
- Snnn Debug on/off
- Examples
- M111 S6
- M111 P1 S1
- Notes
M111 in RepRapFirmware
RepRapFirmware allows debugging to be set for each module. If the optional 'P' parameter is not specified, debugging will be enabled for all modules. For a complete list of all modules, refer to the Module enumeration in RepRapFirmware.h of the fork you are using.
M111 in Repetier
#define DEBUG_ECHO (1<<0) #define DEBUG_INFO (1<<1) #define DEBUG_ERRORS (1<<2) #define DEBUG_DRYRUN (1<<3) // repetier-firmware #define DEBUG_COMMUNICATION (1<<4) // repetier-firmware
M112: Emergency Stop
??? | No | No | Yes | No | ??? | Yes | ??? |
- Example
- M112
M113: Set Extruder PWM
??? | No | No | Yes | No | ??? | No | ??? |
Example: M113
M113 S0.7
M114: Get Current Position
??? | Yes | No | Yes | No | ??? | Yes | ??? |
- Example
- M114
- Parameters
- Pnnn Electronics type1
- Examples
- M115
- M115 P2
sample data from firmware:
- Notes
1This parameter is supported only in RepRapFirmware and can be used tell the firmware about the hardware on which it is running. If the P parameter is present then the integer argument specifies the hardware being used. The following are currently supported:
M115 P0 Automatic board type selection if supported, or default if not M115 P1 Duet 0.6 M115 P2 Duet 0.7 M115 P3 Duet 0.85
M116: Wait
No | Yes | Yes | No | ??? | ??? | ??? | Yes | |
??? | No | No | Yes | No | Yes | Yes | ??? |
- Parameters
- Pnnn Tool number
- Hnnn Heater number
- Cnnn Chamber number
- Examples
- M116
- M116 P1
Wait for all temperatures and other slowly-changing variables to arrive at their set values if no parameters are specified. See also M109.
- Notes
M117: Get Zero Position
No | No | No | No | ??? | ??? | ??? | see M70 | |
Example: M117
M117: Display Message
Yes | Yes | Yes | Yes | ??? | ??? | ??? | No | |
??? | No | No | No | No | Yes | No | ??? |
- Example
- M117 Hello World
M118: Negotiate Features
Example: M118 P42
M119: Get Endstop Status
??? | Yes | No | No | No | Yes | Yes | ??? |
- Example
- M119
In redeem, M119 can also be used to invert end stops.
- Example
- M119 X1 1
This will invert end stop X1 (Inverted means switch is connected in Normally Open state (NO))
M120: Push
No | Yes | No | Yes | ??? | ??? | ??? | ??? | |
- Example
- M120
- Current feedrate, and
- Whether moves (and separately extrusion) are relative or absolute
- Current feedrate
- Extruder positions
M121: Pop
- Example
- M121
M122: Diagnose
- Example
- M122
M123: Tachometer value
M124: Immediate motor stop
Immediately stops all motors.
M126: Open Valve
Yes | No | No | No | ??? | ??? | ??? | Yes | |
Example: M126 P500
M126 in MakerBot
Example: M126 T0
M127: Close Valve
Example: M127 P400
M127 in MakerBot
Example: M127 T0
M128: Extruder Pressure PWM
??? | No | No | No | ??? | ??? | ??? | ??? | |
Example: M128 S255
M129: Extruder pressure off
Example: M129 P100
M130: Set PID P value
see M301 | No | No | No: See M301 | ??? | ??? | ??? | ??? | |
- Parameters
- Pnnn heater number
- Snnn proportional (Kp)
- Example
- M130 P0 S8.0 ; Sets heater 0 P factor to 8.0
M131: Set PID I value
Support | Marlin | RepRapFirmware | Repetier | Smoothie | Klipper | Prusa | MK4duo | MakerBot |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | |
- Parameters
- Snnn integral (Ki)
- Example
- M131 P1 S0.5 ; Sets heater 1 I factor to 0.5
M132: Set PID D value
see M301 | see M301 | No | No: See M301 | ??? | ??? | ??? | Yes | |
- Parameters
- Snnn derivative (Kd)
- Example
- M132 P0 S24 ; Sets heater 0 D factor to 24.0
M132 in MakerBot
Example: M132 X Y Z A B
M133: Set PID I limit value
see M301 | No | No | No | ??? | ??? | ??? | Yes | |
- Parameters
- Snnn integral limit (Ki)
- Example
- M133 P1 S264 ; Sets heater 1 I limit value to 264
M133 in MakerBot
Example: M133 T0 P500
Instruct the machine to wait for the toolhead to reach its target temperature. T is the extruder to wait for. P if present, sets the time limit.
No | see M500 | No | No: See M504 | ??? | ??? | ??? | Yes | |
Example: M134
M134 in MakerBot
Example: M134 T0 P500
M135: Set PID sample interval
No | Yes | No | No | ??? | ??? | ??? | Yes | |
- Parameters
- Snnn Heat sample time in seconds
- Example
- M135 S300
M135 in MakerBot
Example: M135 T0
No | see M301 | No | No | ??? | ??? | ??? | ??? | |
??? | No | No | No | No | ??? | Debug | ??? |
Example: M136 P1 # print heater 0 PID parameters to host
??? | Yes | No | Yes | Yes | ??? | Yes | ??? |
- Parameters
- Hnnn Heater number1
- Example
- M140 S55
RepRapFirmware allows the bed heater to be switched off if the absolute negative temperature (-273.15) is passed as target temperature. In this case the current bed temperature is not affected1:
M140 S-273.15
- Notes
1This parameter is not supported by RepRapFirmware-dc42 and other firmware.
??? | No | No | No | Yes | ??? | uses M104 | ??? |
- Parameters
- Examples
- M141 S30
- M141 H0
- Notes
M142: Holding Pressure
Example: M142 S1
M143: Maximum hot-end temperature
No | ch,dc42 | No | No | ??? | ??? | ??? | ??? | |
Example: M143 S275
Set the maximum temperature of the hot-end to 275°C.
Default value is 300°C.
M144: Stand By Your Bed
- Example
- M144
M146: Set Chamber Humidity
- Parameters
- Rnnn Relative humidity in percent
- Example
- M146 R60
M149: Set temperature units
- Parameters
- C Flag to treat temperature as degrees Celsius
- K Flag to treat temperature as Kelvin
- Example
- M149 K
M150: Set display color
- Parameters
- Rnnn red
- Unnn green
- Bnnn blue
- Example
- M150 R255 U128 B192
Set BlinkM Color via I2C. Range for values: 0-255
Example: M160 S4
M160 S4 G1 X90.6 Y13.8 E2.24:2.24:2.24:15.89 G1 X70.6 E0:0:0:42.4 G1 E42.4:0:0:0
- Parameters
- Snnn extruder number
- Pnnn weight
M164: Store weights
- Parameters
- Snnn virtual extruder number
- Pnnn store to eeprom (P0 = no, P1 = yes)
??? | Yes | No | No | Yes | ??? | No: See M116 | ??? |
- Parameters
- Example
- M190 S60
No | see M301 C1 | No | No | ??? | ??? | ??? | ??? | |
Example: M191 P60
M200: Set filament diameter
Yes | see M404 | Yes | Yes | ??? | ??? | ??? | ??? | |
M200 D0 or M200 D1.128 ; reset E multiplier to 1, since sqrt(1/pi)*2=1.128
- Parameters
- Xnnn Acceleration for X axis
- Ynnn Acceleration for Y axis
- Znnn Acceleration for Z axis
- Ennn Acceleration for extruder drives
- Example
- M201 X1000 Y1000 Z100 E2000
RepRapFirmware expects these values to be in mm/s².
??? | ??? | No | No | No | ??? | No | ??? |
M203: Set maximum feedrate
- Parameters
- Xnnn Maximum feedrate for X axis
- Ynnn Maximum feedrate for Y axis
- Znnn Maximum feedrate for Z axis
- Ennn Maximum feedrate for extruder drives
- Example
- M203 X6000 Y6000 Z300 E10000
Sets the maximum feedrates that your machine can do in mm/min (Marlin uses mm/sec).
M203 Repetier
Set temperture monitor to Sx.
P = Printing moves
The command "M204 P800 T3000 R9000" set the acceleration for printing movements to 800mm/s^2, for travels to 3000mm/s^2 and for retracts to 9000mm/s^2.
M204 Repetier
M204 X[Kp] Y[Ki] Z[Kd] -
M205: Advanced settings
Yes | see M566 | Yes | Yes | ??? | ??? | ??? | ??? | |
Sprinter and Marlin:
- minimum travel speed S=while printing T=travel only, B=minimum segment time X= maximum xy jerk, Z=maximum Z jerk, E=maximum E jerk
Sprinter / Marlin Example:
- M205 X30 Z5 ; Set X/Y Jerk to 30mms, Z jerk to 5mms
Smoothieware uses a different algorithm: [1]
- X<xy junction deviation> Z<z junction deviation> S<minimum planner speed>, Z junction deviation only applies to z only moves, 0 disables junction deviation for Z, -1 uses global junction deviation
Smoothie example:
- M205 X0.05 ; set X/Y Junction Deviation
M205 Repetier
Output EEPROM settings.
M206:
M206 Marlin, Sprinter, Smoothie, RepRapFirmware - Set home offset
- Parameters
- Xnnn X axis offset
- Ynnn Y axis offset
- Znnn Z axis offset
- Example
- M206 X10.0 Y10.0 Z-0.4
M206 Repetier - Set eeprom value
Example: M206 T3 P39 X19.9
Set Jerk to 19.9
Example: M207
M207: Set retract length
Yes | dc42,ch | No | Yes | ??? | ??? | ??? | ??? | |
- Parameters
- Snnn positive length to retract, in mm
- Rnnn positive additional length to un-retract, in mm (RepRapFirmware only)
- Fnnn feedrate, in mm/min
- Znnn additional zlift/hop
- Example
- M207 S4.0 F2400 Z0.075
Sets retract length, stays in mm regardless of M200 setting
M208: Set axis max travel
No | Yes | No | No | ??? | ??? | ??? | ??? | |
- Parameters
- Snnn Whether to set the axis minimum1
- Xnnn X axis limit
- Ynnn Y axis limit
- Znnn Z axis limit
- Example
- M208 X250 Y210 Z180
RepRapPro's version of Marlin uses M208 this way. Send M503 to see the current values. On Marlin, the value can be saved to EEPROM using the M500 command.
- Notes
1With RepRapFirmware on a Cartesian printer, you can also use this command to specify software limits for axis travel in the negative direction, by adding parameter S1. The axis limits you set are also the positions assumed when an endstop is triggered.
M208 X200 Y200 Z90; set axis maxima M208 X-5 Y0 Z0 S1 ; set axis minimum
M208: Set unretract length
Yes | See M207 | No | Yes | ??? | ??? | ??? | ??? | |
- Parameters
- Snnn positive length surplus to the M207 Snnn, in mm
- Fnnn feedrate, in mm/sec
Yes | No | Yes | No | ??? | ??? | ??? | No | |
Example: M209 S1
M210: Set homing feedrates
Example: M210 X1000 Y1500
Example: M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
Example: M211 X0 S1
Enables X min endstop
Example: M211
Yes* | No | No | No | ??? | ??? | ??? | ??? | |
Example: M212 Z-0.2
M218: Set Hotend Offset
??? | No | No | No | No | ??? | No | ??? |
Example: M218 T1 X50 Y0.5
- Parameters
- Snnn Speed factor override percentage (0..100 or higher)
- Example
- M220 S80
- Parameters
- Snnn Extrude factor override percentage (0..100 or higher)
- Example
- M221 S70
Sets extrude factor override percentage.
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
No | No | No | No | ??? | ??? | ??? | ??? | |
M226: Gcode Initiated Pause
??? | No | Yes | No | Yes | ??? | No | ??? |
- Example
- M226
M226: Wait for pin state
Yes | see M577 | Yes | No | ??? | ??? | ??? | ??? | |
- Parameters
- Pnnn pin number
- Snnn pin state
- Example
- M226 P2 S1
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
M231: Set OPS parameter
M231 S[OPS_MODE] X[Min_Distance] Y[Retract] Z[Backslash] F[ReatrctMove]
M240: Trigger camera
Example: M240
Triggers a camera to take a photograph. (Add to your per-layer GCode.)
??? | No | No | No | No | ??? | Debug: Echo off | ??? |
Example: M240
??? | No | No | No | No | ??? | Debug: Echo on | ??? |
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
M250: Set LCD contrast
Yes | No | No | No | ??? | ??? | ??? | No | |
Example: M250 C20
M251 S0 - Reset, S1 - Print, S2 - Store to Z length (also EEPROM if enabled)
(This is a Repetier-Firmware only feature)
M280: Set servo position
??? | No | No | No | Yes | ??? | No | ??? |
(Marlin, Repetier M340)
Set servo position absolute. P: servo index, S: angle or microseconds (Marlin)
M300: Play beep sound
Yes | Yes | Yes | No | ??? | ??? | ??? | Yes | |
- Parameters
- Snnn frequency in Hz
- Pnnn duration in milliseconds
- Example
- M300 S300 P1000
If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound.
M301: Set PID parameters
Yes | Yes | Yes | Yes | ??? | ??? | ??? | ??? | |
??? | Yes | No | No | No | ??? | No: See M13[0-3]) | ??? |
- Parameters
- Hnnn heater number (Smoothie uses 'S')
- Pnnn proportional (Kp)
- Innn integral (Ki)
- Dnnn derivative (Kd)
- Examples
- M301 H1 P1 I2 D3 ; Marlin
- M301 H1 P1 I2 D3 T0.2 B20 W127 S0.8 ; RepRapFirmware (v1.09 onwards), Duet-dc42
- M301 S0 P30 I10 D10 ; Smoothie
Marlin
Hot end only; see M304 for bed PID. H is the heater number, default 1 (i.e. first extruder heater).
H: Is the heater number, and is compulsory. H0 is the bed, H1 is the first hot end, H2 the second etc.
P: Interprets a negative P term as indicating that bang-bang control should be used instead of PID (not recommended for the hot end, but OK for the bed heater).
I: Integral value
D: Derivative value
T: Is the approximate additional PWM (on a scale of 0 to 255) needed to maintain temperature, per degree C above room temperature. Used to preset the I-accumulator when switching from heater fully on/off to PID.
S: PWM scaling factor, to allow for variation in heater power and supply voltage. Is designed to allow a correction to be made for a change in heater power and/or power supply voltage without having to change all the other parameters. For example, an S factor of 0.8 means that the final output of the PID controller should be scaled to 0.8 times the standard value, which would compensate for a heater that is 25% more powerful than the standard one or a supply voltage that is 12.5% higher than standard.
W: Wind-up. Sets the maximum value of I-term, must be high enough to reach 245C for ABS printing.
B: PID Band. Errors larger than this cause heater to be on or off.
An example using all of these would be:
- M301 H1 P20 I0.5 D100 T0.4 S1 W180 B30
Smoothie
S0 is 0 for the hotend, and 1 for the bed, other numbers may apply to your configuration, depending on the order in which you declare temperature control modules.
Other implementations
W: Wind-up. Sets the maximum value of I-term, so it does not overwhelm other PID values, and the heater stays on. (Check firmware support - Sprinter, Marlin?) Example:
- M301 W125
Teacup
M302: Allow cold extrudes
Yes | Yes | Yes: 0.92 | No | ??? | ??? | ??? | ??? | |
- Parameters
- Pnnn Cold extrude state1
- Examples
- M302
- M302 P1
This tells the printer to allow movement of the extruder motor, when the hotend is not at printing temperature
- Notes
1When using RepRapFirmware, running M302 will only report the current cold extrusion state. To allow or deny cold extrudes/retracts, run either "M302 P1" or "M302 P0".
M303: Run PID tuning
Hot end usage:
M303 S<temperature> C<cycles>
Bed usage (repetier, not sure whether cycles work here):
M303 P1 S<temperature>
Bed usage (others):
Example:
M303 C8 S175
M303 E0 S190
Yes | Yes | ??? | see M301 | ??? | ??? | ??? | ??? | |
- Parameters
- Examples
- M304 P1 I2 D3 ; set kP=3, kI=2, kD=3
- M301 P1 I2 D3 T0.7 H0 B20 W127 ; RepRapFirmware
- M304 ; Report parameters
Sets Proportional, Integral and Derivative values for bed. RepRapFirmware interprets a negative P term as indicating that bang-bag control should be used instead of PID. In RepRapFirmware, this command is identical to M301 except that the H parameter (heater number) defaults to zero.
Example: M304 H1 B4200 R4800 T100000
No | Yes | ??? | Yes | ??? | ??? | ??? | ??? | |
- Parameters
- Pnnn Heater number
- Tnnn Thermistor resistance at 25oC
- Bnnn Beta value
- Rnnn Series resistor value
- Lnnn ADC low offset
- Hnnn ADC high offset
- Xnnn Heater ADC channel
- Example
- M305 P1 T100000 R1000 B4200
Sets the parameters for temperature measurement. Supported by RepRapFirmware from 0.78c, and Duet-dc42 firmware.
The example above tells the firmware that for heater 1 (P parameter: 0 = heated bed, 1 = first extruder) the thermistor 25C resistance (T parameter) is 100Kohms, the thermistor series resistance (R parameter) is 1Kohms, the thermistor beta (B parameter) is 4200. All parameters other than P are optional. If only the P parameter is given, the existing values are displayed.
RepRapFirmware also supports an ADC correction functionality and a thermistor selection facility. Example:
M305 P1 T100000 R1000 B4200 H14 L-11 X2
New versions of RepRapFirmware also allow an external SPI thermocouple (such as the MAX31855) to be configured. The first MAX31855 ADC channel is currently set to 100, the second one to 101 etc.
Here the ADC high end correction (H parameter) is 14, the ADC low end correction (L parameter) is -11, and thermistor input #2 is used to measure the temperature of heater #1.
M306: set home offset calculated from toolhead position
No | No | ??? | Yes | ??? | ??? | ??? | ??? | |
Example: M306 Z0
Implemented in Smoothieware
M320: Activate autolevel(Repetier)
(Repetier only)
M321: Deactivate autolevel(Repetier)
(Repetier only)
M322: Reset autolevel matrix
Example: M322 S1
Parameter S1 is mandatory
(Repetier only)
M340: Control the servos
M350: Set microstepping mode
Sets microstepping mode.
Warning: Steps per unit remains unchanged.
- Usage
- M350 Snn Xnn Ynn Znn Enn Bnn
- Parameters
- Not all parameters need to be used, but at least one should be used. As with other commands, RepRapFirmware reports the current settings if no parameters are used.
- Snn Set stepping mode for all drivers (not supported by RepRapFirmware)
- Xnn Set stepping mode for the X axis
- Ynn Set stepping mode for the Y axis
- Znn Set stepping mode for the Z axis
- Enn Set stepping mode for Extruder 0 (for RepRapFirmware use Enn:nn:nn etc. for multiple extruders)
- Bnn Set stepping mode for Extruder 1 (not supported by RepRapFirmware, see above)
- Inn Enable (nn=1) or disable (nn=0) microstep interpolation mode for the specified drivers, if they support it (RepRapFirmware only)
- Modes (nn)
- 1 = full step
- 2 = half step
- 4 = quarter step
- 8 = 1/8 step
- 16 = 1/16 step
- 64 = 1/64 step
- 128 = 1/128 step
- 256 = 1/256 step
- Examples
- M350 S16 (reset all drivers to the default 1/16 micro-stepping - not supported by RepRapFirmware)
- M350 Z1 (set the Z-axis' driver to use full steps)
- M350 E4 B4 (set both extruders to use quarter steps - Marlin/Repetier)
- M350 E4:4:4 (set extruders 0-2 to use quarter steps - RepRapFirmware)
Example: M351
M355: Turn case lights on/off
No | No | Yes: 0.92.2 | No | ??? | ??? | ??? | ??? | |
- Examples
- M355 S1 ; Enable lights
- M355 S0 ; Disable lights
- M355 ; Report status
Every call or change over LCD menu sends a state change for connected hosting software like
Case lights on Case lights off No case lights
- Target
- Example
- M360
- Response
Config:Baudrate:250000 Config:InputBuffer:127 Config:NumExtruder:2 Config:MixingExtruder:0 Config:HeatedBed:0 Config:SDCard:1 Config:Fan:1 Config:LCD:1 Config:SoftwarePowerSwitch:1 Config:XHomeDir:-1 Config:YHomeDir:-1 Config:ZHomeDir:-1 Config:SupportG10G11:1 Config:SupportLocalFilamentchange:1 Config:CaseLights:0 Config:ZProbe:1 Config:Autolevel:0 Config:EEPROM:1 Config:PrintlineCache:24 Config:JerkXY:30.00 Config:JerkZ:0.30 Config:RetractionLength:3.00 Config:RetractionLongLength:13.00 Config:RetractionSpeed:40.00 Config:RetractionZLift:0.00 Config:RetractionUndoExtraLength:0.00 Config:RetractionUndoExtraLongLength:0.00 Config:RetractionUndoSpeed:0.00 Config:XMin:0.00 Config:YMin:0.00 Config:ZMin:0.00 Config:XMax:250.00 Config:YMax:150.00 Config:ZMax:90.00 Config:XSize:250.00 Config:YSize:150.00 Config:ZSize:90.00 Config:XPrintAccel:250.00 Config:YPrintAccel:250.00 Config:ZPrintAccel:100.00 Config:XTravelAccel:250.00 Config:YTravelAccel:250.00 Config:ZTravelAccel:100.00 Config:PrinterType:Cartesian Config:MaxBedTemp:120 Config:Extr.1:Jerk:50.00 Config:Extr.1:MaxSpeed:100.00 Config:Extr.1:Acceleration:10000.00 Config:Extr.1:Diameter:0.00 Config:Extr.1:MaxTemp:220 Config:Extr.2:Jerk:50.00 Config:Extr.2:MaxSpeed:100.00 Config:Extr.2:Acceleration:10000.00 Config:Extr.2:Diameter:0.00 Config:Extr.2:MaxTemp:220
Partial | No | No | Yes | ??? | ??? | ??? | ??? | |
Experimental | No | No | Yes | ??? | ??? | ??? | ??? | |
Smoothieware: M364 P0 will accept the current position as 90deg between arms. The offset is stored as a trim offset (M666) and no further user interaction is required except to save all changes via M500
M365: SCARA scaling factor
M366: SCARA convert trim
No | No | No | Yes | ??? | ??? | ??? | ??? | |
- Usage
- M370
- M370 X<divisions> Y<divisions>
M374: Save calibration grid
Saves the calibration grid. (Smoothieware)
- Usage
- M374
- M374 <file extension> Z
Without parameters safes the grid into the default grid file that gets loaded at boot Parameter specifies the extension of the grid file - useful for special grid files such as for a special print surface like a removable print plate. Addition of Z will additionally save the M206 Z homing offset into the grid file
Display the bed level calibration matrix (Marlin) Load Grid matrix file (Smoothieware)
- Usage
- M375
- M375 <file extension>
M380: Activate solenoid
Yes | No | ??? | No | ??? | ??? | ??? | ??? | |
Example: M380
M381: Disable all solenoids
Example: M381
??? | Yes | No | No | Yes | ??? | No | ??? |
- Example
- M400
Finishes all current moves and and thus clears the buffer. That's identical to G4 P0
M401: Lower z-probe
Example: M401
Lower z-probe if present.
M402: Raise z-probe
Example: M402
Raise z-probe if present.
Yes | Yes | No | No | ??? | ??? | ??? | ??? | |
- Parameters
- Nnnn Filament width (in mm)
- Dnnn Nozzle diameter (in mm)1
- Examples
- M404 N1.75
- M404 N3.0 D1.0
Enter the nominal filament width (3mm, 1.75mm) or will display nominal filament width without parameters.
- Notes
1While Marlin only accepts the 'N' parameter, RepRapFirmware further allows to specify the nozzle diameter (in mm) via the 'D 'parameter. This value is used to properly detect the first layer height when files are parsed or a new print is being started.
M405: Filament Sensor on
Example: M405
M406: Filament Sensor off
Yes | No | No | No | ??? | ??? | ??? | ??? | |
Example: M406
- Example
- M407
Displays measured filament diameter. In RepRapFirmware, M407 does the same as M404.
- Parameters
- Example
- M408 S0
Report a JSON-style response by specifying the desired type using the 'S' parameter.
The following response types are supported:
- Type 0 is a short-form response, similar to the response used by older versions of the web interface.
- Type 1 is like type 0 except that static values are also included.
- Type 2 is similar to the response provided by the web server for Duet Web Control.
- Type 3 is an extended version of type 2 which includes some additional parameters that aren't expected to change very frequently.
- Type 4 is an extended version of type 2 which may be used to poll for current printer statistics.
- Type 5 reports the current machine configuration.
Here is an example of a typical type 0 response:
{"status":"I","heaters":[25.0,29.0,28.3],"active":[-273.1,0.0,0.0],"standby":[-273.1,0.0,0.0],"hstat":[0,2,1],"pos":[-11.00,0.00,0.00],"extr":[0.0,0.0], "sfactor":100.00, "efactor":[100.00,100.00],"tool":1,"probe":"535","fanPercent":[75.0,0.0],"fanRPM":0,"homed":[0,0,0],"fraction_printed":0.572}
The response is set as a single line with a newline character at the end. The meaning of the fields is:
status: I=idle, P=printing from SD card, S=stopped (i.e. needs a reset), C=running config file, A=paused, D=pausing, R=resuming, B=busy (running a macro) heaters: current heater temperatures, numbered as per the machine (typically, heater 0 is the bed) active: active temperatures of the heaters standby: standby temperatures of the heaters hstat: status of the heaters, 0=off, 1=standby, 2=active, 3=fault pos: the X, Y and Z positions of the current tool (if a tool is selected), or the print head reference point if no tool is selected extr: the positions of the extruders sfactor: the current speed factor (see M220 command) efactor: the current extrusion factors (see M221 command) tool: the selected tool number. A negative number typically means no tool selected. probe: the Z-probe reading fanPercent: the speeds of the controllable fans, in percent of maximum fanRPM: the cooling fan RPM homed: the homed status of the X, Y and Z axes (or towers on a delta). 0=axis has not been homed so position is not reliable, 1=axis has been homed so position is reliable. fraction_printed: the fraction of the file currently being printed that has been read and at least partially processed. message: the message to be displayed on the screen (only present if there is a message to display) timesLeft: an array of the estimated remaining print times (in seconds) calculated by different methods. These are currently based on the proportion of the file read, the proportion of the total filament consumed, and the proportion of the total layers already printed. Only present if a print from SD card is in progress. seq: the sequence number of the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater than that. resp: the most recent non-trivial G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater.
The type 1 response comprises these fields plus some additional ones that do not generally change and therefore do not need to be fetched as often. The extra fields include:
myName: the name of the printer geometry: one of "cartesian", "delta", "corexy, "corexz" etc.
For a more detailed comparison of type 2 - 5, see Proposed_RepRap_Duet_Status_Responses.
PanelDue currently uses only M408 S0 and M408 S1.
M420: Set RGB Colors as PWM and is also Enable/Disable Mesh Bed Leveling
Example: M420 R255 E255 B255
In marlin, is also: M420 - Enable/Disable Mesh Leveling (with current values) S1=enable S0=disable
M421: Set a Mesh Bed Leveling Z coordinate
M421 - Set a single Z coordinate in the Mesh Leveling grid. X<index> Y<index> Z<offset in mm>
M450: Report Printer Mode
No | No | Yes | No | ??? | ??? | ??? | ??? | |
Usage: M450
Example: M450 Output: PrinterMode:FFF
Printers can be used for different task by exchanging the toolhead. Depending on the tool, a different behavior of some commands can be expected. This command reports the current working mode. Possible answers are:
- PrinterMode:FFF
- PrinterMode:Laser
- PrinterMode:CNC
M451: Select FFF Printer Mode
- Usage
- M451
- Example
- M451
- Output
- PrinterMode:FFF
Switches to FFF mode for filament printing.
M452: Select Laser Printer Mode
- Usage
- M452
- Example
- M452
- Output
- PrinterMode:Laser
Switches to laser mode. This mode enables handling of a laser pin and makes sure that the laser is only activated during G1 moves if laser was enabled or E is increasing. G0 moves should never enable the laser. M3/M5 can be used to enable/disable the laser for moves.
M453: Select CNC Printer Mode
- Usage
- M453
- Example
- M453
- Output
- PrinterMode:CNC
Switches to CNC mode. In this mode M3/M4/M5 control the pins defined for the milling device.
M460: Define temperature range for thermistor controlled fan
- Usage
- M460 X<minTemp> Y<maxTemp>
- Example
- M460 X50 Y60
If the firmware has a thermistor controlled fan defined, you can set at which temperature the fan starts and from which temperature on it should run with maximum speed.
M500: Store parameters in EEPROM
Yes | Yes | Yes | ??? | ??? | ??? | ??? | ??? | |
??? | Yes | No | No | No | ??? | No | ??? |
- Parameters
- Snnn Enable auto-save (only RepRapFirmware)
- Example
- M500
Save current parameters to EEPROM. RepRapFirmware allows "S1" to be passed, which forces parameters to be automatically saved to EEPROM when they are changed.
M501: Read parameters from EEPROM
- Example
- M501
Set the active parameters to those stored in the EEPROM. This is useful to revert parameters after experimenting with them.
M502: Revert to the default "factory settings."
- Example
- M502
This command resets all tunable parameters to their default values, as set in the firmware. This doesn't reset any parameters stored in the EEPROM, so it must be followed with M500 if you want to do that.
M503: Print settings
Yes | Yes | ??? | ??? | ??? | ??? | ??? | ??? | |
- Example
- M503
This command asks the firmware to reply with the current print settings stored in EEPROM. The reply output includes the G-Code commands to produce each setting. For example, the Steps Per Unit values are displayed as an M92 command.
RepRapFirmware outputs the content of the configuration file, but note that it may be truncated if it is too long.
M540: Enable/Disable "Stop SD Print on Endstop Hit"
- Parameters
- Snnn state, S1=enable, S0=disable
- Example
- M540 S1
M540: Set MAC address
- Parameters
- Pnnn The MAC address
- Examples
- M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED
- M540 PDE:AD:BE:EF:CA:FE
M550: Set Name
- Parameters
- Pnnn Machine name
- Example
- M550 PGodzilla
M551: Set Password
- Parameters
- Pnnn Password
- Example
- M551 Pmy-very-secret-word
Note for RepRapFirmware: If the specified password differs from the default one (i.e. reprap), the user will be asked to enter it when a connection is established via HTTP or Telnet. For FTP, the password must always be passed explicitly.
M552: Set IP address
- Parameters
- Pnnn IP address
- Snnn Enable networking (optional)
- Example
- M552 P192.168.1.14
Sets the IP address of the RepRap machine to (in this case) 192.168.1.14. A restart may be required before the new IP address is used. If no 'P' field is specified, this echoes the existing IP address configured. If S0 is added thus: M552 S0 P192.168.1.14 networking is disabled. If you set the address M552 P0.0.0.0 the RepRap machine will obtain its IP address from the network's server, whereupon it will appear on the network with an address something like http://godzilla.home, where godzilla is the name set by the M550 command (see above). The precise URL incorporating that name will depend on the conventions of your network.
Recent RepRapFirmware versions allow the IP configuration to be changed without a restart.
M553: Set Netmask
- Parameters
- Pnnn Net mask
- Example
- M553 P255.255.255.0
Sets the network mask of the RepRap machine to (in this case) 255.255.255.0. A restart may be required before the new network mask is used. If no 'P' field is specified, this echoes the existing network mask configured.
M554: Set Gateway
- Parameters
- Pnnn Gateway
- Example
- M554 P192.168.1.1
Sets the Gateway IP address of the RepRap machine to (in this case) 192.168.1.1. A restart may be required before the new gateway IP address is used. If no 'P' field is specified, this echoes the existing Gateway IP address configured.
M555: Set compatibility
- Parameters
- Pnnn Emulation type
- Example
- M555 P1
For firmware that can do it, the firmware is set to a mode where its input and (especially) output behaves exactly like other established firmware. The value of the 'P' argument is:
P value | Firmware |
0 | Native (i.e. whatever the firmware actually is) |
1 | RepRap_Firmware |
2 | Marlin |
3 | Teacup |
4 | Sprinter |
5 | Repetier |
M556: Axis compensation
- Parameters
- Snnn Height of the measured distances
- Xnnn Deviation in X direction
- Ynnn Deviation in Y direction
- Znnn Deviation in Z direction
- Example
- M556 S100 X0.7 Y-0.2 Z0.6
M557: Set Z probe point
- Parameters
- Pnnn Probe point number
- Xnnn X coordinate
- Ynnn Y coordinate
- Example
- M557 P1 X30 Y40.5
M558: Set Z probe type
- Parameters
- Pnnn Z probe type
- Xnnn Use probe for X axis
- Ynnn Use probe for Y axis
- Znnn Use probe for Z axis
- Hnnn Dive height1
- Fnnn Feed rate (i.e. probing speed)1
- Tnnn Travel speed to probe points1
- Snnn Extra parameter for experimentation (1)
- Rnnn Extra parameter for experimentation (2)2
- Example
- M558 P0 X1 Y0 Z1
A Z probe may be a switch, an IR proximity sensor, or some other device. This selects which to use. P0 indicates that no Z probe is present. P1 gives an unmodulated IR probe, or any other probe type that emulates an unmodulated IR probe (probe output is an analog signal that rises with decreasing nozzle height above the bed). If there is a control signal to the probe, it is driven high when the probe type is P1. P2 specifies a modulated IR probe, where the modulation is commanded directly by the main board firmware using the control signal to the probe. P3 selects an alternative Z probe by driving the control signal to the probe low. P4 selects a switch for bed probing (on the Duet, this must be connected to the E0 endstop pins).
The X, Y and Z parameters specify whether each axis uses the Z probe for homing or not. If the parameter is nonzero, the Z probe is used for homing that axis. if the parameter is zero, the endstop switch for that axis is used for homing instead. See also G31 and G32.
Recent versions of RepRapFirmware support an additional parameter H. This specifies the dive height (default 3mm) from which probing is done in response to a G30 command when the P parameter is present, or a G32 command.
- Notes
1These parameters are only supported by recent RepRapFirmware versions.
2This parameter used to specify the Z probe channel in RepRapFirmware, but it has been superceded by the functionality of "M115 Px". With older firmware versions and a Duet 0.7/0.85, this parameter should be 1.
- Example
- M559
M560: Upload web page file
- Example
- M560
<!-- **EoF** -->. Clearly that string cannot exist in the body of the file, but can be put on the end to facilitate this process. This should not be too serious a restriction...
M561: Set Identity Transform
- Example
- M561
M562: Reset temperature fault
- Parameters
- Example
- M562 P2
M563: Define or remove a tool
- Parameters
- Pnnn Tool number
- Dnnn Extruder drive(s)
- Hnnn Heater(s)
- Example
- M563 P0 D0:5:6 H1:3
Tools are usually (though not necessarily) extruders. The 'P' field specifies the tool number. Tool numbers can have any positive integer value and 0. The 'D' field specifies the drive(s) used by the tool - in this case drives 0, 5 and 6. Drive 0 is the first drive in the machine after the movement drives (usually X, Y and Z). If there is no 'D' field the tool has no drives. The 'H' field specifies the tool's heaters - in this case heaters 1 and 3. Heater 0 is usually the hot bed (if any) so the first extruder heater is usually 1. If there is no H field the tool has no heaters.
Tools are driven using multiple values in the 'E' field of G1 commands, each controlling the corresponding drive in the 'D' field above, as follows:
G1 X90.6 Y13.8 E2.24:2.24:15.89 G1 X70.6 E0:0:42.4
The first line moves straight to the point (90.6, 13.8) extruding a total of 2.24mm of filament from both drives 0 and 5 and 15.98mm of filament from drive 6.
The second line moves back 20mm in X extruding 42.4mm of filament from drive 6.
RepRapFirmware supports an additional form of the M563 command. The command:
M563 S1
Recent versions of RepRapFirmware allow the deletion of existing tools if M563 is called in this way:
M563 P1 D-1 H-1
M564: Limit axes
- Parameters
- Snnn Limit movement within axis boundaries
- Example
- M564 S0
Allow moves outside the print volume, or not. If the S parameter is 0, then you can send G codes to drive the RepRap outside its normal working volume, and it will attempt to do so. User beware... If you set the S parameter to 1 then the RepRap will not think outside the box. The default behaviour is S = 1.
M565: Set Z probe offset
No | see G31 | No | Yes | ??? | ??? | ??? | ??? | |
Example: M565 X3 Y4.5 Z-2.37
Set the offset from the extruder tip to the probe position. The X, Y and Z values are the delta between the extruder and the actual trigger position of the probe. If the probe trigger point is below the extruder (typical) the Z offset will be negative. This just records the point offset; it does not actually do the probing. See G32.
- Parameters
- Xnnn Maximum instantaneous speed change of the X axis
- Ynnn Maximum instantaneous speed change of the Y axis
- Znnn Maximum instantaneous speed change of the Z axis
- Ennn Maximum instantaneous speed change of the extruder drives
- Example
- M566 X20 Y20 Z2 E10
Work around an algorithm limitation of some firmwares, which can't calculate step timings for a standing start. Teacup Firmware and Smoothieware don't have this limitation, so M566 is obsolete there.
M566 sets the speeds in mm/minute that axes can do from a standing start. If an accelerating algorithm starts a move with a zero velocity on other firmwares and then accelerates from that, it can give problems when the zero initial velocity is used to calculate a timestep between stepper pulses at the beginning: the timestep ends up being infinite... So these systems have initial small velocities to start at. This sets them.
Recent versions of RepRapFirmware don't have the limitation, but instead they use this parameter to determine the maximum allowable speed change of each motor when cornering.
M567: Set tool mix ratios
- Parameters
- Pnnn Tool number
- Ennn Mix ratios
- Example
- M567 P2 E0.1:0.2:0.1:0.6
This example sets the mix ratio for tool 2 (the P value). When mixing is then turned on (see M568), only single E values need to be sent on a G1 command (any extra E values will be ignored, but are not illegal):
G1 X20 E1.3
See also M568.
- Parameters
- Pnnn Tool number
- Snnn Whether mix ratios should be activated
- Example
- M568 P2 S0
G1 X20 E0.2:0.4:0.166:0.3
The off state is the default.
M569: Set axis direction and enable values
- Parameters
- Pnnn Drive number
- Snnn Whether the drive should move forwards
- Rnnn Enable drive1
- Xnnn Map drive to X axis2
- Ynnn Map drive to Y axis2
- Znnn Map drive to Z axis2
- Ennn Map drive to extruder drive2
- Example
- M569 P0 S1
Set the control value for the drive specified by P that sends it forwards to the given value in the S field. After sending the example, sending a 1 to X (drive 0) will make it go forwards, sending a 0 will make it go backwards. Obviously to be used with extreme caution...
- Notes
1The 'R' parameter is not supported by all firmware, but in the dcnewman fork of RepRapFirmware and versions 1.09i and later of the dc42 fork, this sets the enable value -- logic level -- for the drive specified by P to the given value in the R field. Allowed 'R' values are 0 or 1. With the following example, drive 2 is enabled by sending an enable value of 0. Sending an enable value of 1 will disable the drive.
M569 P2 R0
You can use any combination of S XYZE and R parameters in a single M569 command. Values not provided are left unchanged.
2Recent firmware versions allow drives to be remapped. For example:
M569 P0 X0
Assigns driver 0 to control the X0 motor. In place of X0 you can use Y0 Z0 E0 E1 E2 etc. to assign the driver to the corresponding motor. Currently, only one driver can be allocated to each axis or extruder.
M570: Set heater timeout
- Parameters
- Snnn Heater timeout (in seconds)
- Example
- M570 S120
After a heater has been switched on, wait 120 seconds for it to get close to the set temperature. If it takes longer than this, flag a heater fault.
M571: Set output on extrude
- Parameters
- Snnn Output value
- Example
- M571 S0.5
This turns an output on whenever extrusion is being done, and turns it off when the extrusion is finished. The output could control a fan or a stirrer or anything else that needs to work just when extrusion is happening. The S parameter sets the value of the PWM to the output. 0.0 is off; 1.0 is fully on.
M572: Set or report extruder pressure advance
No | dc42, ch, dn | No | No | ??? | ??? | ??? | ??? | |
- Parameters
- Dnnn Extruder number
- Snnn Pressure advance amount (in seconds)
- Example
- M572 D0 S0.1
This sets the pressure advance coefficient (S parameter) for the specified extruder (D parameter). Supported by RepRapFirmware-dc42, -ch and -dn.
Pressure advance causes the extruder drive position to be advanced or retarded during printing moves by an additional amount proportional to the rate of extrusion. At the end of a move when the extrusion rate is decreasing, this may result in the extruder drive moving backwards (i.e. retracting). Therefore, if you enable this feature, you may need to reduce the amount of retraction you use in your slicing program to avoid over-retraction.
With Bowden extruders, an S value between 0.1 and 0.2 usually gives the best print quality.
Older versions of RepRapFirmware used the P parameter to specify the drive number, instead of using D to specify the extruder number.
M573: Report heater PWM
- Parameters
- Example
- M573 P1
This gives a running average (usually taken over about five seconds) of the PWM to the heater specified by the P field. If you know the voltage of the supply and the resistance of the heater this allows you to work out the power going to the heater.
- Parameters
- Xnnn Switch type for X axis
- Ynnn Switch type for Y axis
- Znnn Switch type for Z axis
- Snnn Logic level
- Example
- M574 X1 Y2 Z0 S1
This defines the type of endstop switch or opto sensor that the printer has for each axis: 0 = none, 1 = low end, 2 = high end. The optional S parameter defines whether the endstop input is active high (S1, the default) or low (S0). Intended for use with boards that provide a single endstop input for each axis that may be used for either a high or a low end endstop, such as the Duet. Supported by RepRapFirmware. On delta printers, the XYZ parameters refer to the towers and the endstops should normally all be high end.
- Parameters
- Pnnn Serial channel number
- Bnnn Baud rate
- Snnn Whether checksums should be used
- Example
- M575 P1 B57600 S1
This sets the communications parameters of the serial comms channel specified by the P parameter. P0 specifies the main serial interface (typically a USB port, or serial-over-USB), while P1 specifies an auxiliary serial port (for example, the port used to connect a PanelDue). The B parameter is the required baud rate (this parameter is typically ignored if the port is a true USB port). The S parameter is a bitmap of features. The lowest bit, if set, specifies that only commands that include a valid checksum should be accepted from this comms channel.
M577: Wait until endstop is triggered
No | Yes | No | No | ??? | ??? | ??? | No | |
- Parameters
- Snnn Desired endstop level
- Xnnn Select X axis endstop
- Ynnn Select Y axis endstop
- Znnn Select Z axis endstop
- Ennn Select extruder drive endstop
- Example
- M577 E0 S1
Wait for an endstop switch to be pressed. The example above will wait until the first extruder endstop is triggered.
The following trigger types may be used using the 'S' parameter:
0: Endstop not hit 1: Low endstop hit 2: High endstop hit 3: Near endstop (only Z probe)
M578: Fire inkjet bits
- Parameters
- Pnnn Inkjet head number
- Snnn Bit pattern
- Example
- M578 P3 S5
This fires inkjet head 3 (the P field) using the bit pattern specified by the S field. The example shown would fire bits 101. If the P parameter is ommitted inkjet 0 is assumed.
This is a version of the M700 command used by the Inkshield, but unfortunately M700 is already taken so cannot be used for that in the standard.
M579: Scale Cartesian axes
- Parameters
- Xnnn Scale factor for X axis
- Ynnn Scale factor for Y axis
- Znnn Scale factor for Z axis
- Example
- M579 X1.0127 Y0.998
On a Cartesian RepRap you can get prints exactly the right size by tweaking the axis steps/mm using the M92 G Code above. But this does not work so easily for Delta and other RepRaps for which there is cross-talk between the axes. This command allows you to adjust the X, Y, and Z axis scales directly. So, if you print a part for which the Y length should be 100mm and measure it and find that it is 100.3mm long then you set Y0.997 (= 100/100.3).
M580: Select Roland
Support | Marlin | RepRapFirmware | Repetier | Smoothie | Klipper | Prusa | MK4duo | MakerBot |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | |
- Parameters
- Rnnn Whether Roland mode should be activated
- Pnnn Initial text to send to the Roland controller
- Example
- M580 R1 PVS4;!VZ2;!MC1;
This is not really anything to do with RepRap, but it is convenient. The little Roland mills are very widely available in hackerspaces and maker groups, but annoyingly they don't speak G Codes. As all RepRap firmware includes a G-Code interpreter, it is often easy to add functions to convert G Codes to Roland RML language. M580 selects a Roland device for output if the R field is 1, and returns to native mode if the R field is 0. The optional P string is sent to the Roland if R is 1. It is permissible to call this repeatedly with R set to 1 and different strings in the P field to communicate directly with a Roland.
M581: Configure external trigger
No | dc42 | No | No | ??? | ??? | ??? | No | |
- Parameters
- Tnn Logical trigger number to associate the endstop input(s) with.
- X, Y, Z, E Selects endstop input(s) to monitor
- P Reserved for future use, may be used to allow general I/O pins to cause triggers
- S Whether trigger occurs on a rising edge (S1, default) or falling edge (S0). Use S-1 to delete the trigger.
- Example
- M581 E1:2 S1 T2 ; invoke trigger 2 when a rising edge is detected on the E1 or E2 endstop input
When M581 is executed, if the T parameter is present but the other parameters are omitted, the trigger inputs and edge polarities for that trigger number are reported. Otherwise, if S is negative then the trigger is deleted. Otherwise, the specified inputs and their polarities are added to the conditions that cause that trigger.
In RepRapFirmware, trigger number 0 causes an emergency stop as if M999 had been received. Trigger number 1 causes the print to be paused as if M25 had been received. Any trigger number # greater then 1 causes the macro file sys/trigger#.g to be executed. Polling for further trigger conditions is suspended until the trigger macro file has been completed.
M582: Check external trigger
- Parameters
- T Trigger number to poll
- Example
- M582 T2 ; check levels of inputs that give rise to trigger #2
Triggers set up by the M581 command are normally activated only when the specified inputs change state. This command provides a way of causing the trigger to be executed if the input is at a certain level. For each of the inputs associated with the trigger, the trigger condition will be checked as if the input had just changed from the opposite state to the current state.
For example, if you use M581 to support an out-of-filament sensor, then M582 allows you to check for out-of-filament just before starting a print.
M583: Wait for pin
No | {soon} | No | No | ??? | ??? | ??? | No | |
- Parameters
- Pnnn Pin number
- Sn State to wait for (0 or 1) or analogue tolerance
- Rnnn Analogue value to wait for (between 0.0 and 1.0)
- Example
- M583 P5 S0 ; Wait for Pin 5 to become 0
This allows you, for example, to turn on a DC motor (see the M42 command) then wait until a switch connected to Pin Pnnn gives the value Sn.
If the R field is present, then the system waits until the value on analogue Pnnn is reached. In this case the S value is used as a tolerance, so M583 P8 R0.7 S0.01 would wait until the analogue value on Pin 8 was between 0.69 and 0.71.
M600: Set line cross section
No | No | ??? | ??? | ??? | ??? | ??? | ??? | |
Example: M600 P0.061
Sets the cross section for a line to extrude in velocity extrusion mode. When the extruder is enabled and movement is executed the amount of extruded filament will be calculated to match the specified line cross section.
M600: Filament change pause
Yes | Use macro files instead | ??? | ??? | ??? | ??? | ??? | ??? | |
Example: M600
Pause for filament change X[pos] Y[pos] Z[relative lift] E[initial retract] L[later retract distance for removal].
Example: M605 S1
Sets the dual x-carriage movement mode: S<mode> [ X<duplication x-offset> R<duplication temp offset> ].
M605 S0: Full control mode. The slicer has full control over x-carriage movement M605 S1: Auto-park mode. The inactive head will auto park/unpark without slicer involvement M605 S2 [Xnnn] [Rmmm]: Duplication mode. The second extruder will duplicate the first with nnn millimeters x-offset and an optional differential hotend temperature of mmm degrees. E.g., with "M605 S2 X100 R2" the second extruder will duplicate the first with a spacing of 100mm in the x direction and 2 degrees hotter.
M665: Set delta configuration
Yes | Yes | No | Yes | ??? | ??? | ??? | ??? | |
- Parameters
- Lnnn Diagonal rod length
- Rnnn Delta radius
- Snnn Segments per second1
- Bnnn Safe printing radius2
- Hnnn Nozzle height above the bed when hmed after allowing for endstop corrections2
- Xnnn X tower position correction3
- Ynnn Y tower position correction3
- Znnn Z tower position correction3
- Examples
- M665 L250 R160 S200 (Marlin)
- M665 L250 R160 B80 H240 X0 Y0 Z0 (RepRapFirmware)
Set the delta calibration variables.
- I don't think it's a good idea to have two different implementations for the same G-code, and I also question the practical value of specifying the print bed radius when defining a delta configuration, since many delta printers use a square or rectangular print bed. So perhaps we should stick to the Marlin-defined command as the definition for this command, and use a different command or set of commands to define print bed shape and size. --AndrewBCN (talk) 23:10, 31 January 2015 (PST)
- The implementations are not different, they have the same L and R parameters, but each has additional parameters that are not relevant to the other implementation. I'm not against defining a new Gcode to define bed size and shape; however, you can already define the limits of a rectangular print area using M208. Even when a delta printer has a square bed, the printable area is not square. It is usually taken to be circular, although it is in reality more complicated. My purpose in adding the B parameter was to make it easy to define a radius outside which movement will not normally be attempted. I have changed "bed radius" to "safe printing radius" in the text to help clarify this. --dc42
- Notes
1Only supported on Marlin.
2Only supported in RepRapFirmware.
3X, Y and Z tower angular offsets from the ideal (i.e. equilateral triangle) positions, in degrees, measured anti-clockwise looking down on the printer.
- Parameters
- Xnnn X axis endstop adjustment
- Ynnn Y axis endstop adjustment
- Znnn Z axis endstop adjustment
- Example
- M666 X-0.1 Y+0.2 Z0
In RepRapFirmware and Repetier, positive endstop adjustments move the head closer to the bed when it is near the corresponding tower. In Marlin and Smoothieware, negative endstop corrections move the head closer to the bed when it is near the corresponding tower.
In Marlin, only negative endstop corrections are allowed.
In Repetier the endstop corrections are expressed in motor steps. In other firmwares they are expressed in mm.
M667: Select CoreXY mode
- Parameters
- Snnn CoreXY mode
- Xnnn X axis scale factor
- Ynnn Y axis scale factor
- Znnn Z axis scale factor
- Example
- M667 S1
M667 S0 selects Cartesian mode (unless the printer is configured as a delta using the M665 command). Forward motion of the X motor moves the head in the +X direction. Similarly for the Y motor and Y axis, and the Z motor and Z axis. This is the default state of the firmware on power up.
M667 S1 selects CoreXY mode. Forward movement of the X motor moves the head in the +X and +Y directions. Forward movement of the Y motor moves the head in the -X and +Y directions.
M667 S2 selects CoreXZ mode. Forward moveme
