G-code
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications, too.
There are a few different ways to prepare GCode for a printer. One is to use a slicer like Slic3r, Skeinforge or Cura. These programs take a CAD model, slice it into layers, and output the GCode required for each layer. Slicers are the easiest way to go from a 3D model to a printed part, but the user sacrifices some flexibility when using them. Another option for GCode generation is to use a lower level library like mecode. Libraries like mecode give you precise control over the tool path, and thus are useful if you have a complex print that is not suitable for naive slicing. The final option is to just write the GCode yourself. This may be the best choice if you just need to run a few test lines while calibrating your printer.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years. But this is the master page for RepRap. Nowhere in here should the same code be used for two different things. The rule is: add your new code here, then implement it.
But human nature being what it is, things aren't always done that way, so some multiple uses of the same code exist. The rule is that later appearances by them on this page than the original use of a code are deprecated and should be changed, unless there is a good technical reason (like the general G-Code standard) why a later instance should be prefered. Note that the key date is appearance here, not date of implementation.
- 1 Introduction
- 2 Fields
- 3 Comments
- 4 Special fields
- 5 Checking
- 6 Buffering
- 7 G-commands
- 7.1 G0 & G1: Move
- 7.2 G2 & G3: Controlled Arc Move
- 7.3 G4: Dwell
- 7.4 G10: Tool Offset
- 7.5 G10: Retract **DEPRICATED**
- 7.6 G11: Unretract
- 7.7 G17..19: Plane Selection (CNC specific)
- 7.8 G20: Set Units to Inches
- 7.9 G21: Set Units to Millimeters
- 7.10 G22 & G23: Firmware controlled Retract/Precharge
- 7.11 G28: Move to Origin (Home)
- 7.12 G29: Detailed Z-Probe
- 7.13 G29.1: Set Z probe head offset
- 7.14 G29.2: Set Z probe head offset calculated from toolhead position
- 7.15 G30: Single Z-Probe
- 7.16 G31: Report Current Probe status
- 7.17 G32: Probe Z and calculate Z plane
- 7.18 G31: Dock Z Probe sled
- 7.19 G32: Undock Z Probe sled
- 7.20 G38.x Straight Probe (CNC specific)
- 7.21 G40: Compensation Off (CNC specific)
- 7.22 G54..59: Coordinate System Select (CNC specific)
- 7.23 G80: Cancel Canned Cycle (CNC specific)
- 7.24 G90: Set to Absolute Positioning
- 7.25 G91: Set to Relative Positioning
- 7.26 G92: Set Position
- 7.27 G93: Feed Rate Mode (Inverse Time Mode) (CNC specific)
- 7.28 G94: Feed Rate Mode (Units per Minute) (CNC specific)
- 7.29 G100: Calibrate floor or rod radius
- 7.30 G130: Set digital potentiometer value
- 7.31 G131: Remove offset
- 7.32 G132: Calibrate endstop offsets
- 7.33 G133: Measure steps to top
- 7.34 G161: Home axes to minimum
- 7.35 G162: Home axes to maximum
- 8 M-commands
- 8.1 M0: Stop or Unconditional stop
- 8.2 M1: Sleep or Conditional stop
- 8.3 M2: Program End
- 8.4 M3: Spindle On, Clockwise (CNC specific)
- 8.5 M4: Spindle On, Counter-Clockwise (CNC specific)
- 8.6 M5: Spindle Off (CNC specific)
- 8.7 M6: Tool change
- 8.8 M7: Mist Coolant On (CNC specific)
- 8.9 M8: Flood Coolant On (CNC specific)
- 8.10 M9: Coolant Off (CNC specific)
- 8.11 M10: Vacuum On (CNC specific)
- 8.12 M11: Vacuum Off (CNC specific)
- 8.13 M17: Enable/Power all stepper motors
- 8.14 M18: Disable all stepper motors
- 8.15 M20: List SD card
- 8.16 M21: Initialize SD card
- 8.17 M22: Release SD card
- 8.18 M23: Select SD file
- 8.19 M24: Start/resume SD print
- 8.20 M25: Pause SD print
- 8.21 M26: Set SD position
- 8.22 M27: Report SD print status
- 8.23 M28: Begin write to SD card
- 8.24 M29: Stop writing to SD card
- 8.25 M30: Delete a file on the SD card
- 8.26 M31: Output time since last M109 or SD card start to serial
- 8.27 M32: Select file and start SD print
- 8.28 M33: Get the long name for an SD card file or folder
- 8.29 M34: Set SD file sorting options
- 8.30 M36: Return file information
- 8.31 M37: Simulation mode
- 8.32 M40: Eject
- 8.33 M41: Loop
- 8.34 M42: Switch I/O pin
- 8.35 M43: Stand by on material exhausted
- 8.36 M48: Measure Z-Probe repeatability
- 8.37 M70: Display message
- 8.38 M72: Play a tone or song
- 8.39 M73: Set build percentage
- 8.40 M80: ATX Power On
- 8.41 M81: ATX Power Off
- 8.42 M82: Set extruder to absolute mode
- 8.43 M83: Set extruder to relative mode
- 8.44 M84: Stop idle hold
- 8.45 M85: Set inactivity shutdown timer
- 8.46 M92: Set axis_steps_per_unit
- 8.47 M93: Send axis_steps_per_unit
- 8.48 M98: Call Macro/Subprogram
- 8.49 M99: Return from Macro/Subprogram
- 8.50 M98: Get axis_hysteresis_mm
- 8.51 M99: Set axis_hysteresis_mm
- 8.52 M101: Turn extruder 1 on (Forward), Undo Retraction
- 8.53 M102: Turn extruder 1 on (Reverse)
- 8.54 M103: Turn all extruders off, Extruder Retraction
- 8.55 M104: Set Extruder Temperature
- 8.56 M105: Get Extruder Temperature
- 8.57 M106: Fan On
- 8.58 M107: Fan Off
- 8.59 M108: Set Extruder Speed
- 8.60 M109: Set Extruder Temperature and Wait
- 8.61 M110: Set Current Line Number
- 8.62 M111: Set Debug Level
- 8.63 M112: Emergency Stop
- 8.64 M113: Set Extruder PWM
- 8.65 M114: Get Current Position
- 8.66 M115: Get Firmware Version and Capabilities
- 8.67 M116: Wait
- 8.68 M117: Get Zero Position
- 8.69 M117: Display Message
- 8.70 M118: Negotiate Features
- 8.71 M119: Get Endstop Status
- 8.72 M120: Push
- 8.73 M121: Pop
- 8.74 M120: Enable endstop detection
- 8.75 M121: Disable endstop detection
- 8.76 M122: Diagnose
- 8.77 M123: Tachometer value
- 8.78 M124: Immediate motor stop
- 8.79 M126: Open Valve
- 8.80 M127: Close Valve
- 8.81 M128: Extruder Pressure PWM
- 8.82 M129: Extruder pressure off
- 8.83 M130: Set PID P value
- 8.84 M131: Set PID I value
- 8.85 M132: Set PID D value
- 8.86 M133: Set PID I limit value
- 8.87 M134: Write PID values to EEPROM
- 8.88 M135: Set PID sample interval
- 8.89 M136: Print PID settings to host
- 8.90 M140: Set Bed Temperature (Fast)
- 8.91 M141: Set Chamber Temperature (Fast)
- 8.92 M142: Holding Pressure
- 8.93 M143: Maximum hot-end temperature
- 8.94 M144: Stand By Your Bed
- 8.95 M146: Set Chamber Humidity
- 8.96 M149: Set temperature units
- 8.97 M150: Set display color
- 8.98 M160: Number of mixed materials
- 8.99 M163: Set weight of mixed material
- 8.100 M164: Store weights
- 8.101 M190: Wait for bed temperature to reach target temp
- 8.102 M191: Wait for chamber temperature to reach target temp
- 8.103 M200: Set filament diameter
- 8.104 M201: Set max printing acceleration
- 8.105 M202: Set max travel acceleration
- 8.106 M203: Set maximum feedrate
- 8.107 M204: Set default acceleration
- 8.108 M205: Advanced settings
- 8.109 M206:
- 8.110 M207: Calibrate z axis by detecting z max length
- 8.111 M207: Set retract length
- 8.112 M208: Set axis max travel
- 8.113 M208: Set unretract length
- 8.114 M209: Enable automatic retract
- 8.115 M210: Set homing feedrates
- 8.116 M211: Disable/Enable software endstops
- 8.117 M212: Set Bed Level Sensor Offset
- 8.118 M218: Set Hotend Offset
- 8.119 M220: Set speed factor override percentage
- 8.120 M221: Set extrude factor override percentage
- 8.121 M220: Turn off AUX V1.0.5
- 8.122 M221: Turn on AUX V1.0.5
- 8.123 M222: Set speed of fast XY moves
- 8.124 M223: Set speed of fast Z moves
- 8.125 M224: Enable extruder during fast moves
- 8.126 M225: Disable on extruder during fast moves
- 8.127 M226: Gcode Initiated Pause
- 8.128 M226: Wait for pin state
- 8.129 M227: Enable Automatic Reverse and Prime
- 8.130 M228: Disable Automatic Reverse and Prime
- 8.131 M229: Enable Automatic Reverse and Prime
- 8.132 M230: Disable / Enable Wait for Temperature Change
- 8.133 M231: Set OPS parameter
- 8.134 M232: Read and reset max. advance values
- 8.135 M240: Trigger camera
- 8.136 M240: Start conveyor belt motor / Echo off
- 8.137 M241: Stop conveyor belt motor / echo on
- 8.138 M245: Start cooler
- 8.139 M246: Stop cooler
- 8.140 M250: Set LCD contrast
- 8.141 M251: Measure Z steps from homing stop (Delta printers)
- 8.142 M280: Set servo position
- 8.143 M300: Play beep sound
- 8.144 M301: Set PID parameters
- 8.145 M302: Allow cold extrudes
- 8.146 M303: Run PID tuning
- 8.147 M304: Set PID parameters - Bed
- 8.148 M305: Set thermistor and ADC parameters
- 8.149 M306: set home offset calculated from toolhead position
- 8.150 M320: Activate autolevel(Repetier)
- 8.151 M321: Deactivate autolevel(Repetier)
- 8.152 M322: Reset autolevel matrix
- 8.153 M340: Control the servos
- 8.154 M350: Set microstepping mode
- 8.155 M351: Toggle MS1 MS2 pins directly
- 8.156 M355: Turn case lights on/off
- 8.157 M360: Report firmware configuration
- 8.158 SCARA calibration codes (Morgan)
- 8.159 M360: Move to Theta 0 degree position
- 8.160 M361: Move to Theta 90 degree position
- 8.161 M362: Move to Psi 0 degree position
- 8.162 M363: Move to Psi 90 degree position
- 8.163 M364: Move to Psi + Theta 90 degree position
- 8.164 M365: SCARA scaling factor
- 8.165 M370: Morgan manual bed level - clear map
- 8.166 M371: Move to next calibration position
- 8.167 M372: Record calibration value, and move to next position
- 8.168 M373: End bed level calibration mode
- 8.169 M374: Save calibration grid
- 8.170 M375: Display matrix / Load Matrix
- 8.171 M380: Activate solenoid
- 8.172 M381: Disable all solenoids
- 8.173 M400: Wait for current moves to finish
- 8.174 M401: Lower z-probe
- 8.175 M402: Raise z-probe
- 8.176 M404: Filament width and nozzle diameter
- 8.177 M405: Filament Sensor on
- 8.178 M406: Filament Sensor off
- 8.179 M407: Display filament diameter
- 8.180 M408: Report JSON-style response
- 8.181 M420: Set RGB Colors as PWM
- 8.182 M500: Store parameters in EEPROM
- 8.183 M501: Read parameters from EEPROM
- 8.184 M502: Revert to the default "factory settings."
- 8.185 M503: Print settings
- 8.186 M540: Enable/Disable "Stop SD Print on Endstop Hit"
- 8.187 M540: Set MAC address
- 8.188 M550: Set Name
- 8.189 M551: Set Password
- 8.190 M552: Set IP address
- 8.191 M553: Set Netmask
- 8.192 M554: Set Gateway
- 8.193 M555: Set compatibility
- 8.194 M556: Axis compensation
- 8.195 M557: Set Z probe point
- 8.196 M558: Set Z probe type
- 8.197 M559: Upload configuration file
- 8.198 M560: Upload web page file
- 8.199 M561: Set Identity Transform
- 8.200 M562: Reset temperature fault
- 8.201 M563: Define or remove a tool
- 8.202 M564: Limit axes
- 8.203 M565: Set Z probe offset
- 8.204 M566: Set allowable instantaneous speed change
- 8.205 M567: Set tool mix ratios
- 8.206 M568: Turn off/on tool mix ratios
- 8.207 M569: Set axis direction values
- 8.208 M570: Set heater timeout
- 8.209 M571: Set output on extrude
- 8.210 M572: Set or report extruder elasticity compensation
- 8.211 M573: Report heater PWM
- 8.212 M574: Set endstop configuration
- 8.213 M575: Set serial comms parameters
- 8.214 M576: Set axis/extruder drive mapping
- 8.215 M577: Wait until endstop is triggered
- 8.216 M578: Fire inkjet bits
- 8.217 M600: Set line cross section
- 8.218 M600: Filament change pause
- 8.219 M605: Set dual x-carriage movement mode
- 8.220 M665: Set delta configuration
- 8.221 M666: Set delta endstop adjustment
- 8.222 M667: Select CoreXY mode
- 8.223 M700: Level plate
- 8.224 M701: Load filament
- 8.225 M702: Unload filament
- 8.226 M906: Set motor currents
- 8.227 M907: Set digital trimpot motor
- 8.228 M908: Control digital trimpot directly
- 8.229 M909: Set microstepping
- 8.230 M928: Start SD logging
- 8.231 M998: Request resend of line
- 8.232 M999: Restart after being stopped by error
- 9 Other commands
- 10 Proposed EEPROM configuration codes
- 11 Replies from the RepRap machine to the host computer
- 12 Proposal for sending multiple lines of G-code
- 13 Alternatives to G-code
Introduction
N3 T0*57 N4 G92 E0*67 N5 G28*22 N6 G1 F1500.0*82 N7 G1 X2.0 Y2.0 F3000.0*85 N8 G1 X3.0 Y3.0*33
Gcode can also be stored in files on SD cards. A file containing RepRap Gcode usually has the extension .g, .gco or .gcode. Files for BFB/RapMan have the extension .bfb. Gcode stored in file or produced by a slicer might look like this:
G92 E0 G28 G1 F1500 G1 X2.0 Y2.0 F3000 G1 X3.0 Y3.0
Support | Marlin | RepRapFirmware | Repetier | Smoothie | Klipper | Prusa | MK4duo | MakerBot |
Partial | ??? | Experimental | depreciated | ??? | ??? | ??? | ??? | |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | |
??? | No | ??? | Yes | ??? | ??? | automatic | ??? |
Here means:
- {{yes}}
- The Gcode is fully supported by the firmware.
- {{partial}} or {{experimental}}
- There is some support for the Gcode. Often it is required to check out the source code branch for the firmware (usually stored in a different branch) or to flip configuration switches on the mainboard.
- automatic
- The firmware handles this Gcode automatically, so there's no need to send the command. An example is power supply on/off Gcode (M80/M81) in the Teacup firmware.
- It is unknown if the firmware supports this Gcode. You may want to test this yourself before using it in production.
- {{no}}
- The firmware does not support this Gcode.
- depreciated
- The firmware depreciated this Gcode. The firmware author(s) should amend the depreciated Gcode on this page with workarounds (if needed) and the last supported firmware version that will accept this Gcode.
Fields
A RepRap Gcode is a list of fields that are separated by white spaces or line breaks. A field can be interpreted as a command, parameter, or for any other special purpose. It consists of one letter directly followed by a number, or can be only a stand-alone letter (Flag). The letter gives information about the meaning of the field (see the list below in this section). Numbers can be integers (128) or fractional numbers (12.42), depending on context. For example, an X coordinate can take integers (X175) or fractionals (X17.62), but selecting extruder number 2.76 would make no sense. In this description, the numbers in the fields are represented by nnn as a placeholder.
Letter | Meaning |
Gnnn | Standard GCode command, such as move to a point |
Mnnn | RepRap-defined command, such as turn on a cooling fan |
Tnnn | Select tool nnn. In RepRap, tools are extruders |
Snnn | Command parameter, such as time in seconds; temperatures; voltage to send to a motor |
Pnnn | Command parameter, such as time in milliseconds; proportional (Kp) in PID Tuning |
Xnnn | A X coordinate, usually to move to. This can be an Integer or Fractional number. |
Ynnn | A Y coordinate, usually to move to. This can be an Integer or Fractional number. |
Znnn | A Z coordinate, usually to move to. This can be an Integer or Fractional number. |
Innn | Parameter - X-offset in arc move; integral (Ki) in PID Tuning |
Jnnn | Parameter - Y-offset in arc move |
Dnnn | Parameter - used for diameter; derivative (Kd) in PID Tuning |
Hnnn | Parameter - used for heater number in PID Tuning |
Fnnn | Feedrate in mm per minute. (Speed of print head movement) |
Rnnn | Parameter - used for temperatures |
Qnnn | Parameter - not currently used |
Ennn | Length of extrudate. This is exactly like X, Y and Z, but for the length of filament to extrude. |
Nnnn | Line number. Used to request repeat transmission in the case of communications errors. |
*nnn | Checksum. Used to check for communications errors. |
Comments
Gcode comments begin at a semicolon, and end at the end of the line:
N3 T0*57 ; This is a comment N4 G92 E0*67 ; So is this N5 G28*22
Special fields
N: Line number
Yes | ??? | Yes | ??? | ??? | ??? | ??? | ??? | |
? | Yes | ??? | Yes | Yes | ??? | Yes | ??? |
Example: N123
If checking is supported, the RepRap firmware expects line numbers to increase by 1 each line, and if that doesn't happen it is flagged as an error. But you can reset the count using M110 (see below).
*: Checksum
? | Yes | ??? | Yes | ??? | ??? | Yes | ??? |
Example: *71
If checking is supported, the RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
Checking
The RepRap firmware checks the line number and the checksum. You can leave both of these out - RepRap will still work, but it won't do checking. You have to have both or neither though. If only one appears, it produces an error.
int cs = 0; for(i = 0; cmd[i] != '*' && cmd[i] != NULL; i++) cs = cs ^ cmd[i]; cs &= 0xff; // Defensive programming...
Buffering
??? | ??? | ??? | Yes | ??? | ??? | Yes | ??? |
G-commands
G0 & G1: Move
Yes | Yes | Yes | Yes | ??? | ??? | ??? | Yes | |
Yes | Yes | Yes | Yes | Yes | ??? | Yes | ??? |
- G0 : Rapid linear Move
- G1 : Linear Move
- Usage
- G0 Xnnn Ynnn Znnn Ennn Fnnn Snnn
- G1 Xnnn Ynnn Znnn Ennn Fnnn Snnn
- Parameters
- Not all parameters need to be used, but at least one has to be used
- Xnnn The position to move to on the X axis
- Ynnn The position to move to on the Y axis
- Znnn The position to move to on the Z axis
- Ennn The amount to extrude between the starting point and ending point
- Fnnn The feedrate per minute of the move between the starting point and ending point (if supplied)
- Snnn Flag to check if an endstop was hit (S1 to check, S0 to ignore, S2 see note, default is S0)1
- Examples
- G0 X12 (move to 12mm on the X axis)
- G0 F1500 (Set the feedrate to 1500mm/minute)
- G1 X90.6 Y13.8 E22.4 (Move to 90.6mm on the X axis and 13.8mm on the Y axis while extruding 22.4mm of material)
1. G1 F1500 2. G1 X50 Y25.3 E22.4
In the above example, we set the feedrate to 1500mm/minute on line 1, then move to 50mm on the X axis and 25.3mm on the Y axis while extruding 22.4mm of filament between the two points.
1. G1 F1500 2. G1 X50 Y25.3 E22.4 F3000
However, in the above example, we set a feedrate of 1500 mm/minute on line 1, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X and Y movement, so everything stays synchronized.
The RepRap spec treats the feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over the acceleration and deceleration of the printer head in such a way that ensures that everything moves smoothly together, and the right volume of material is extruded at all points.3
Notes
1Some firmwares allow for the RepRap to enable or disable the "sensing" of endstops during a move. Please check with whatever firmware you are using to see if they support the S parameter in this way, as damage may occur if you assume incorrectly. In the dc42 fork of RepRapFirmware, using the S1 or S2 parameter on a delta printer causes the XYZ parameters to refer to the individual tower motor positions instead of the head position, and to enable endstop detection as well if the parameter is S1.
4zpl and dc42 forks of RepRapFirmware implement an additional 'R1' parameter to tell the machine to go back to the coordinates a print was originally paused at.
Yes1 | No | Yes | Yes | ??? | ??? | ??? | ??? | |
Yes | Yes | No | No | Yes | ??? | No | ??? |
- Usage
- G2 Xnnn Ynnn Innn Jnnn Ennn Fnnn (Clockwise Arc)
- G3 Xnnn Ynnn Innn Jnnn Ennn Fnnn (Counter-Clockwise Arc)
- Parameters
- Innn The point in X space from the current X position to maintain a constant distance from
- Jnnn The point in Y space from the current Y position to maintain a constant distance from
- Examples
- G2 X90.6 Y13.8 I5 J10 E22.4 (Move in a Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
- G3 X90.6 Y13.8 I5 J10 E22.4 (Move in a Counter-Clockwise arc from the current point to point (X=90.6,Y=13.8), with a center point at (X=current_X+5, Y=current_Y+10), extruding 22.4mm of material between starting and stopping)
Notes
1In Marlin Firmware not implemented for DELTA and SCARA printers.
G4: Dwell
??? | Yes | Yes | Yes | Yes | ??? | Yes | ??? |
- Parameters
- Pnnn Time to wait, in milliseconds
- Snnn Time to wait, in seconds (Only on Marlin and Smoothie)
- Example
- G4 P200
On Marlin and Smoothie, the "S" parameter will wait for seconds, while the "P" parameter will wait for milliseconds. "G4 S2" and "G4 P2000" are equivalent.
G10: Tool Offset
No | Yes | No | No | ??? | ??? | ??? | ??? | |
??? | No | No | No | Yes | ??? | No | ??? |
Example: G10 P3 X17.8 Y-19.3 Z0.0 R140 S205
This sets the offset for tool (or in older implementations extrude head) 3 (from the P3) to the X and Y values specified. You can put a non-zero Z value in as well, but this is usually a bad idea unless the tools are loaded and unloaded by some sort of tool changer. When all the tools are in the machine at once they should all be set to the same Z height.
Remember that any parameter that you don't specify will automatically be set to the last value for that parameter. That usually means that you want explicitly to set Z0.0.
The NIST G-code standard mentions an additional L parameter, which is ignored.
This command is subject to discussion.
Note that Marlin and Smoothie use G10/G11 for executing a retraction/unretraction move. The RepRapPro version of Marlin supports G10 for tool offset.
Duet-zpl allows tool heaters to be switched off if the absolute negative temperature (-273.15) is passed as active and standby temperature. In this case the current active and standby temperatures are not affected.
G10 P1 R-273.15 S-273.15
Yes | No | Yes: 0.92 | Yes | ??? | ??? | ??? | ??? | |
??? | No | No | No | No | ??? | No | ??? |
- Parameters
- Snnn retract length (S1 = long retract, S0 = short retract = default) (Repetier only)
- Example
- G10
Retracts filament according to settings of M207 (Marlin) or accoridng to the S value (Repetier).
G11: Unretract
- Parameters
- Example
- G11
Unretracts/recovers filament according to settings of M208 (Marlin) or accoridng to the S value (Repetier).
Yes | ??? | ??? | ??? | Yes | ??? | ??? | ??? |
- G17 : XY (default)
- G18 : ZX
- G19 : YZ
No | Yes | Yes | Yes | ??? | ??? | ??? | ??? | |
Yes | Yes | No | Yes | Yes | ??? | Yes | ??? |
Example: G20
Example: G21
No | ??? | No | No | ??? | ??? | ??? | ??? | |
- Usage
- G22 ; Retract
- G23 ; Unretract/Precharge
Relying on machine's firmware to execute extrusion retract/precharge move, instead of having slicer generating to E axis G1 movement. The retract/precharge length, velocity is handled by the machine firmware.
- Parameters
- This command can be used without any additional parameters.
- X Flag to go back to the X axis origin
- Y Flag to go back to the Y axis origin
- Z Flag to go back to the Z axis origin
- Examples
- G28 (Go to origin on all axes)
- G28 X Z (Go to origin only on the X and Z axis)
When the RepRap firmware receives this command, it moves all (or the supplied) axis's back to the zero endstops as quickly as it can, then backs off by a millimeter and slowly moves back to the zero endstop activation points to increase position accuracy. This process is also known as "Homing".
If you add coordinates, these coordinates are ignored. For example, G28 Z0.00
results in the same behaviour as G28 Z
When Duet-dc42 firmware is used to control a delta printer, any G28 command will home all three towers, regardless of any XYZ letters.
Yes | No | Yes | No | ??? | ??? | ??? | ??? | |
Example: G29
Probes the bed at 3 or more points. The printer must be homed with G28 before G29.
No | No | No | No | ??? | ??? | ??? | ??? | |
Example: G29.1 X30 Y20 Z0.5
Example: G29.2 Z0.0
The user would typically place the toolhead at the zero point of the axis and issue the G29.2 command.
G30: Single Z-Probe
Yes | Yes | Yes | Yes | ??? | ??? | ??? | ??? | |
Some implementations allow more general behaviour: if a Pn field is specified the probed X, Y, and Z values are saved as point n on the bed for calculating the offset plane. Generally n is 0, 1, or 2. If X, or Y, or Z values are specified (e.g. G30 P1 X20 Y50 Z0.3) then those values are used instead of the machine's current coordinates. A silly Z value (less than -9999.0) causes the machine to probe at the current point to get Z, rather than using the given value. If an S field is specified (e.g. G30 P1 Z0.3 S) the bed plane is computed for compensation and stored. The combination of these options allows for the machine to be moved to points using G1 commands, and then probe the bed, or for the user to position the nozzle interactively and use those coordinates. The user can also record those values and place them in a setup GCode file for automatic execution.
The dc42 variant of RepRapFirmware uses the value of the S parameter to specify what computation to perform. If the value is -1 then the Z offsets of all the points probed are printed, but no calibration is done. If the value is zero or not present, then this specified that the number of factors to be calibrated is the same as the number of points probed. Otherwise, the value indicates the number of factors to be calibrated, which must be no greater than the number of points probed. Currently (as of version 1.04d), the number of factors may be 3, 4 or 5 when doing auto bed compensation on a Cartesian or CoreXY printer, and 3, 4, 6 or 7 when doing auto calibration of a Delta printer.
No | Yes | ??? | Yes | ??? | ??? | ??? | ??? | |
In Duet-dc42 firmware, separate G31 parameters may be defined for probe types 0, 1/2, and 3 (probe types 1 and 2 share the same set of parameters). To specify which probe you are setting parameters for, send a M558 command to select the probe type before sending the G31 command.
Duet-dc42 firmware supports additional parameters S (bed temperature in degC at which the specified Z parameter is correct, default is current bed temperature) and C (temperature coefficient of Z parameter in mm/degC, default zero). This is useful for ultrasonic and other probes that are affected by temperature.
Duet-dc42 firmware versions 1.00b onwards also allow the X and Y offsets of the Z probe relative to the print head (i.e. the position when the empty tool is selected) to be specified, by adding parameters X and Y. This allows you to calculate your M557 probe coordinates based on the geometry of the bed, without having to correct them for Z probe X and Y offset. It also provides more accurate bed compensation.
No: See G29 | Yes | ??? | Yes | ??? | ??? | ??? | ??? | |
Probes the bed at 3 or more pre-defined points (see M557) and updates transformation matrix for bed leveling compensation. Later versions of RepRapFirmware execute macro file bed.g if present instead of using the M557 coordinates.
Yes | No | ??? | No | ??? | ??? | ??? | ??? | |
Yes | ??? | ??? | ??? | ??? | ??? | ??? | ??? |
G40 turn cutter compensation off. If tool compensation was on the next move must be a linear move and longer than the tool diameter. It is OK to turn compensation off when it is already off.
Example: G90
Example: G91
G91.x: Reset Coordinate System Offsets (CNC specific)
- G91.1 - reset axis offsets to zero and set parameters 5211 - 5219 to zero. (X Y Z A B C U V W)
- G91.2 - reset axis offsets to zero.
G92: Set Position
- Parameters
- Xnnn new X axis position
- Ynnn new Y axis position
- Znnn new Z axis position
- Ennn new extruder position
- Example
- G92 X10 E90
G93 is Inverse Time Mode. In inverse time feed rate mode, an F word means the move should be completed in (one divided by the F number) minutes. For example, if the F number is 2.0, the move should be completed in half a minute.
When the inverse time feed rate mode is active, an F word must appear on every line which has a G1, G2, or G3 motion, and an F word on a line that does not have G1, G2, or G3 is ignored. Being in inverse time feed rate mode does not affect G0 (rapid move) motions.
No | No | Yes: 0.92 | No | ??? | ??? | ??? | ??? | |
- Parameters
- X Flag to set floor for X axis
- Y Flag to set floor for Y axis
- Z Flag to set floor for Z axis
- Rnnn Radius to add
- Examles
- G100 X Y Z (set floor for argument passed in. Number ignored and may be absent.)
- G100 R5 (Add 5 to radius. Adjust to be above floor if necessary)
- G100 R0 (Set radius based on current z measurement. Moves all axes to zero)
No | ??? | No | No | ??? | ??? | ??? | Yes | |
Example: G130 X10 Y18 Z15 A20 B12
G131: Remove offset
No | No | Yes: 0.91 | No | ??? | ??? | ??? | ??? | |
??? | No | No | No | No | ??? | Yes | ??? |
- Parameters
- X Flag to home the X axis to its minimum position
- Y Flag to home the Y axis to its minimum position
- Z Flag to home the Z axis to its minimum position
- Fnnn Desired feedrate for this command
- Example
- G161 X Y Z F1800
Instruct the machine to home the specified axes to their minimum position. Similar to G28, which decides on its own in which direction to search endstops.
- Parameters
- X Flag to home the X axis to its maximum position
- Y Flag to home the Y axis to its maximum position
- Z Flag to home the Z axis to its maximum position
- Example
- G162 X Y Z F1800
M-commands
Yes | Yes | No | No | ??? | ??? | ??? | ??? | |
Yes | No | No | Yes | Yes | ??? | Yes | ??? |
- Parameters
- Snnn Time to wait, in seconds (Only on Marlin)
- Example
- M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M1, M112.
The Marlin Firmware does wait for user to press a button on the LCD, or a specific time. "M0 P2000" waits 2000 milliseconds "M0 S2" waits 2 seconds
Yes | No | No | No | No | ??? | ??? | ??? |
- Example
- M1
M2: Program End
No | ??? | No | ??? | ??? | ??? | ??? | ??? | |
Yes | No | No | No | No | ??? | Yes | ??? |
Example: M2
No | No | No | Yes | ??? | ??? | ??? | ??? | |
Example: M3 S4000
Yes | No | No | No | No | ??? | No | ??? |
Example: M4 S4000
No | ??? | No | Yes | ??? | ??? | ??? | ??? | |
Example: M5
The spindle is turned off.
M6: Tool change
Example: M6
Yes | No | No | No | No | ??? | use M106 | ??? |
Example: M7
Example: M8
Example: M9
??? | No | No | No | No | ??? | use M106 | ??? |
Example: M10
Example: M11
Yes | ??? | No | Yes | ??? | ??? | ??? | ??? | |
??? | No | No | No | No | ??? | (automatic) | ??? |
Example: M17
call M84 | Yes | No | Yes | ??? | ??? | ??? | Yes | |
??? | No | No | No | No | ??? | use M2 | ??? |
Example: M18
RepRapFirmware allows stepper motors to be disabled selectively. For example, M18 X E0:2 will disable the X, extruder 0 and extruder 2 motors.
M20: List SD card
??? | Yes | No | No | No | ??? | Yes | ??? |
Example: M20
All files in the root folder of the SD card are listed to the serial port. One name per line, like:
ok SQUARE.G SQCOM.G ZCARRI~1.GCO ZCARRI~2.GCO ZADJUS~1.GCO CARRIA~1.GCO
Note that some firmwares list file names in upper case, but - when sent to the M23 command (below) they must be in lower case. Teacup has no such trouble and accepts both.
Duet-dc42 firmware returns the (long) filenames in the correct case. If the S2 parameter is present, the file list is returned in JSON format as a single array called "files", and the directory is returned in variable "dir". The optional P parameter specifies the directory to list, defaulting to the /gcodes directory in RepRapFirmware - for other firmware, this is whatever directory printable gcode files are normally stored in.
Yes | No | Yes | Yes | ??? | ??? | ??? | ??? | |
Example: M21
The SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
Example: M22
SD card is released, so further (accidental) attempts to read from it are guaranteed to fail. Helpful, but not mandatory before removing the card physically.
M23: Select SD file
Example: M23 filename.gco
Duet-dc42 firmware supports long filenames as well as 8.3 format.
Example: M24
The machine prints from the file selected with the M23 command. If the print was previously paused with M25, printing is resumed from that point. To restart a file from the beginning, use M23 to reset it, then M24.
When this command is used to resume a print that was paused, the dc42 and zpl forks of RepRapFirmware run macro file resume.g if it exists prior to resuming the print.
M25: Pause SD print
Example: M25
The machine pauses printing at the current position within the file. To resume printing, use M24.
Prior to pausing, the dc42 and zpl forks of RepRapFirmware run macro file pause.g if it exists. This allows the head to be moved away from the print, filament to be retracted, etc.
Yes | ??? | Yes | aborts | ??? | ??? | ??? | ??? | |
??? | Yes | No | No | No | ??? | No | ??? |
Example: M26
Yes | ??? | Yes | Yes | ??? | ??? | ??? | ??? | |
Example: M27
Report SD print status.
Example: M28 filename.gco
Yes | ??? | Yes | No | ??? | ??? | ??? | ??? | |
Example: M29 filename.gco
Yes | Yes | No | No | No | ??? | No | ??? |
Example: M30 filename.gco
filename.gco is deleted.
M30 in grbl
M30 exchange pallet shuttles and end the program. Pressing cycle start will start the program at the beginning of the file.
Yes | ??? | No | No | ??? | ??? | ??? | ??? | |
Example: M31
The response looks like:
echo:54 min, 38 sec
Yes | Yes | No | Yes | ??? | ??? | ??? | ??? | |
(Can be used when printing from SD card)
Example: M32 filename.gco
Yes | No | No | No | ??? | ??? | ??? | ??? | |
Get a long filename on the SD card from a short filename. Proposed by Marlin firmware, May 2015.
No | dc42 | No | No | ??? | ??? | ??? | ??? | |
Example: M36 filename.gco
If the file name parameter is not supplied and a file on the SD card is currently being printed, then information for that file is returned including additional field "fileName". This feature is used by the web interface any by PanelDue, so that if a connection is made when a file is already being printed, the name and other information about that file can be shown.
M37 S1 enters simulation mode. All G and M codes will not be acted on, but the time they take to execute will be calculated.
M37 S0 leaves simulation mode.
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
- When you press the reset button,
- When the build material runs out (if your RepRap is set up to detect this), and
- When there's an error (such as a heater failure).
M42: Switch I/O pin
Yes | Yes | Yes | No | ??? | ??? | ??? | ??? | |
Example: M42 P7 S255
In RepRapFirmware only 1 and 0 are supported for the S field. If the S field is omitted then the state of the pin is read and reported.
Example: M43
- Parameters
- Pnnn number of points
- Xnnn position on the X axis
- Ynnn position on the Y axis
- Vnnn verbosity
- E engage
- Lnnn legs of travel
As with G29, the E flag causes the probe to stow after each probe.
No: See M117 | ??? | No | ??? | ??? | ??? | ??? | Yes | |
Example: M70 P200 Message
Instruct the machine to display a message on it's interface LCD. P is the time to display message for.
No: See M300 | ??? | No | No | ??? | ??? | ??? | Yes | |
Example: M72 P2
Example: M73 P50
Instruct the machine that the build has progressed to the specified percentage. The machine is expected to display this on it's interface board. If the percentage is exactly 0, then a Build Start Notification is sent. If the percentage is exactly 100, then a Build End notification is sent.
M80: ATX Power On
Yes | dc42 | Yes | No | ??? | ??? | ??? | ??? | |
??? | Yes | No | No | No | ??? | automatic | ??? |
Example: M80
Note: some firmwares, like Teacup, handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off
M81: ATX Power Off
Example: M81
Example: M82
makes the extruder interpret extrusion as absolute positions.
Example: M83
makes the extruder interpret extrusion values as relative positions.
M84: Stop idle hold
Example: M84
On Marlin, Repetier and Duet-zpl, M84 can also be used to configure or disable the idle timeout. For example, "M84 S10" will idle the stepper motors after 10 seconds of inactivity. "M84 S0" will disable idle timeout; steppers will remain powered up regardless of activity.
Example: M85 S30
Example: M92 X<newsteps> Sprinter and Marlin
No | ??? | ??? | No | ??? | ??? | ??? | ??? | |
Example: M98 Pmymacro.g
Runs the macro in the file mymacro.g. In conventional G Codes for CNC machines the P parameter normally refers to a line number in the program itself (P2000 would run the Macro starting at line O2000, say). For RepRap, which almost always has some sort of mass storage device inbuilt, it simply refers to the name of a GCode file that is executed by the G98 call. That GCode file does not need to end with an M99 (return) as the end-of-file automatically causes a return. Macro calls cannot usually be nested or be recursive; i.e. you can't call a macro from a macro (though some implementations may allow this).
RepRapFirmware-dc42 and RepRapFirmware-zpl support nested macros and allow the filename to include a path. The default folder is /sys.
Example: M99
Returns from an M98 call.
Example: M98
Proposed for Marlin
Example: M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
??? | No | Yes | No | No | ??? | Yes | ??? |
in Teacup firmware: If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103.
in BFB/RapMan firmware: Turn extruder on (forward/filament in).
in other firmwares: Deprecated. Regarding filament retraction, see M227, M228, M229.
??? | No | Yes | No | No | ??? | No | ??? |
In other firmwares: Deprecated.
In Teacup firmware: If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101.
In other firmwares: Deprecated. Regarding extruder retraction, see M227, M228, M229.
- Parameters
- Snnn Target temperature
- Example
- M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). Duet-dc42 and other firmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command applies to. See also M109.
M104 in Teacup Firmware
Example: M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100 °C.
??? | Yes | No | Yes | No | ??? | Yes | ??? |
Example: M105
ok T:201 B:117
M105 X0 ==> 11:05:48.910 : T:23.61 /0 @:0 T0:23.61 /0 @0:0 RAW0:3922 T1:23.89 /0 @1:0 RAW1:3920
Duet-dc42 extension
Duet-dc42 firmware returns a JSON-formatted response if parameter S2 or S3 is included. This is used by the touch-screen control panel. Additionally, parameter Rnn may be provided, where nn is the sequence number of the most recent G-code response that the client has already received.
The response comprises a single JSON object, with no nesting of objects or arrays, followed by newline. It is similar to the object returned by the web interface status request, but some fields are omitted. Here is a sample response when S2 is used:
{"status":"I","heaters":[25.0,29.0,28.3],"active":[-273.1,0.0,0.0],"standby":[-273.1,0.0,0.0],"hstat":[0,2,1],"pos":[-11.00,0.00,0.00],"extr":[0.0,0.0],"sfactor":100.00, "efactor":[100.00,100.00],"tool":1,"probe":"535","fanRPM":0,"homed":[0,0,0],"fraction_printed":0.572}
The meaning of these fields is:
status: I=idle, P=printing from SD card, S=stopped (i.e. needs a reset), C=running config file, A=paused, D=pausing, R=resuming, B=busy (running a macro) heaters: current heater temperatures, numbered as per the machine (typically, heater 0 is the bed) active: active temperatures of the heaters standby: standby temperatures of the heaters hstat: status of the heaters, 0=off, 1=standby, 2=active, 3=fault pos: the X, Y and Z positions of the print head extr: the positions of the extruders sfactor: the current speed factor (see M220 command) efactor: the current extrusion factors (see M221 command) tool: the selected tool number. Zero typically means no tool selected. probe: the Z-probe reading fanRPM: the cooling fan RPM homed: the homed status of the X, Y and Z axes (or towers on a delta). 0=axis has not been homed so position is not reliable, 1=axis has been homed so position is reliable. fraction_printed: the fraction of the file currently being printed that has been read and at least partially processed. message: the message to be displayed on the screen (only present if there is a message to display) timesLeft: an array of the estimated remaining print times (in seconds) calculated by different methods. These are currently based on the proportion of the file read, the proportion of the total filament consumed, and the proportion of the total layers already printed. Only present if a print from SD card is in progress. seq: the sequence number of the most recent G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater. resp: the most recent G-code response or error message. Only present if the R parameter was provided and the current sequence number is greater.
The response when S3 is used comprises these fields plus some additional ones that do not generally change and therefore do not need to be fetched as often. The extra fields include:
myName: the name of the printer geometry: one of "cartesian", "delta", "corexy, "corexz" etc.
M106: Fan On
- Parameters
- Snnn speed
- Example
- M106 S127
Turn on the cooling fan at half speed.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0 turns the fan off. In some implementations the pwm is specified by a real fraction: M106 S0.7.
M106 in Duet Firmware
Duet-dc42 firmware also supports an optional I parameter. If this parameter is present and greater than zero, the cooling fan output is inverted. This makes the cooling fan output suitable for feeding the PWM input of a 4-wire fan via a diode. If the parameter is present and zero or negative, the output is not inverted. If the parameter is not present, the inverted/non-inverted state remains unchanged. The default at power up is not inverted.
If the 'R' parameter is passed when using Duet-zpl firmware (0.96g+), the last-known fan value will be set. If the 'S' parameter is passed along with 'R', the firmware will not reset the last-known fan value. This may be useful for tool change macro files.
M106 in Teacup Firmware
Example: M106 P2 S255
M107: Fan Off
??? | Yes | Yes | Yes | Yes | ??? | No | ??? |
Deprecated in Teacup firmware. Use M106 S0 instead.
Sets speed of extruder motor. (Deprecated in FiveD firmware, see M113)
??? | Yes | No | Yes | Yes | ??? | not needed | ??? |
- Parameters
- Snnn minimum target temperature, waits until heating
- Rnnn maximum target temperature, waits until cooling (Sprinter)
- Rnnn accurate target temperature, waits until heating and cooling (Marlin)
- Example
- M109 S215
M109 in Teacup
M109 in Marlin, Sprinter (ATmega port), Duet
Example: M109 S185
Duet-dc42 firmware also supports the optional T parameter (as generated by slic3r) to specify which tool the command refers to (see below).
M109 in Sprinter (4pi port)
Example: M109 S185 R240 //sets extruder temperature to 185 and waits for the temperature to be between 185 - 240.
M109 in MakerBot
Example: M109 S70 T0
No | ??? | Yes | Yes | ??? | ??? | ??? | ??? | |
??? | No | No | Yes | No | ??? | not needed | ??? |
Example: M110 N123
No | Yes | Yes | No | ??? | ??? | ??? | ??? | |
??? | No | No | Yes | No | ??? | Debug | ??? |
Example: M111 S6
#define DEBUG_ECHO (1<<0) #define DEBUG_INFO (1<<1) #define DEBUG_ERRORS (1<<2) #define DEBUG_DRYRUN (1<<3) // repetier-firmware #define DEBUG_COMMUNICATION (1<<4) // repetier-firmware
??? | No | No | Yes | No | ??? | Yes | ??? |
Example: M112
??? | No | No | Yes | No | ??? | No | ??? |
Example: M113
M113 S0.7
Example: M114
Example: M115
sample data from firmware:
M116: Wait
Example: M116
Duet-dc42 firmware version 0.78c and later supports an optional P parameter, used to specify a tool number. If this parameter is present, then the system only waits for temperatures associated with that tool to arrive at their set values. This is useful during tool changes, to wait for the new tool to heat up without necessarily waiting for the old one to cool down fully.
Users of Duet-zpl may specify a list of the heaters to be waited for by specifying an 'H' parameter. Duet-zpl v1.08d+ further supports an additional 'C' parameter to wait for the chamber temperature to be reached.
Example: M117
Yes | dc42 | Yes | Yes | ??? | ??? | ??? | ??? | |
Example: M117 Hello World
This causes the given message to be shown in the status line on an attached LCD. The above command will display Hello World.
Example: M118 P42
Example: M119
M120: Push
No | Yes | No | Yes | ??? | ??? | ??? | ??? | |
- Current feedrate, and
- Whether moves (and separately extrusion) are relative or absolute
M121: Pop
M122: Diagnose
Immediately stops all motors.
M126: Open Valve
Yes | ??? | No | No | ??? | ??? | ??? | Yes | |
Example: M126 P500
M126 in MakerBot
Example: M126 T0
M127: Close Valve
Example: M127 P400
M127 in MakerBot
Example: M127 T0
??? | ??? | No | No | ??? | ??? | ??? | ??? | |
Example: M128 S255
Example: M129 P100
No: See M301 | No | No | No: See M301 | ??? | ??? | ??? | ??? | |
- Parameters
- Pnnn heater number
- Snnn proportional (Kp)
- Example
- M130 P0 S8.0 ; Sets heater 0 P factor to 8.0
- Parameters
- Snnn integral (Ki)
- Example
- M131 P1 S0.5 ; Sets heater 1 I factor to 0.5
No: See M301 | ??? | No | No: See M301 | ??? | ??? | ??? | Yes | |
- Parameters
- Snnn derivative (Kd)
- Example
- M132 P0 S24 ; Sets heater 0 D factor to 24.0
M132 in MakerBot
Example: M132 X Y Z A B
No | No | No | No | ??? | ??? | ??? | Yes | |
- Parameters
- Snnn integral limit (Ki)
- Example
- M133 P1 S264 ; Sets heater 1 I limit value to 264
M133 in MakerBot
Example: M133 T0 P500
Instruct the machine to wait for the toolhead to reach its target temperature. T is the extruder to wait for. P if present, sets the time limit.
No | No | No | No: See M504 | ??? | ??? | ??? | Yes | |
Example: M134
M134 in MakerBot
Example: M134 T0 P500
Example: M135 S300
M135 in MakerBot
Example: M135 T0
??? | No | No | No | No | ??? | Debug | ??? |
Example: M136 P1 # print heater 0 PID parameters to host
??? | Yes | No | Yes | Yes | ??? | Yes | ??? |
- Parameters
- Example
- M140 S55
Duet-zpl allows the bed heater to be switched off if the absolute negative temperature (-273.15) is passed as active temperature. In this case the current active temperature is not affected:
M140 S-273.15
No | zpl | No | No | ??? | ??? | ??? | ??? | |
??? | No | No | No | Yes | ??? | uses M104 | ??? |
Example: M141 S30
Duet-zpl 1.08d+ implements M141 and accepts an additional 'H' parameter to set the chamber heater number.
M142: Holding Pressure
Example: M142 S1
M143: Maximum hot-end temperature
Example: M143 S275
M144: Stand By Your Bed
Example: M144
M146: Set Chamber Humidity
- Parameters
- Rnnn Relative humidity in percent
- Example
- M146 R60
M149: Set temperature units
- Parameters
- C Flag to treat temperature as degrees Celsius
- K Flag to treat temperature as Kelvin
- Example
- M149 K
M150: Set display color
- Parameters
- Rnnn red
- Unnn green
- Bnnn blue
- Example
- M150 R255 U128 B192
Set BlinkM Color via I2C. Range for values: 0-255
Example: M160 S4
M160 S4 G1 X90.6 Y13.8 E2.24:2.24:2.24:15.89 G1 X70.6 E0:0:0:42.4 G1 E42.4:0:0:0
- Parameters
- Snnn extruder number
- Pnnn weight
M164: Store weights
- Parameters
- Snnn virtual extruder number
- Pnnn store to eeprom (P0 = no, P1 = yes)
??? | Yes | No | No | Yes | ??? | No: See M116 | ??? |
- Parameters
- Example
- M190 S60
Example: M191 P60
M200: Set filament diameter
M200 D0 or M200 D1.128 ; reset E multiplier to 1, since sqrt(1/pi)*2=1.128
Example: M201 X1000 Y1000 Z100 E2000
??? | ??? | No | No | No | ??? | No | ??? |
M203: Set maximum feedrate
Example: M203 X6000 Y6000 Z300 E10000
Sets the maximum feedrates that your machine can do in mm/min.
M203 Repetier
Set temperture monitor to Sx.
P = Printing moves
The command "M204 P800 T3000 R9000" set the acceleration for printing movements to 800mm/s^2, for travels to 3000mm/s^2 and for retracts to 9000mm/s^2.
M204 Repetier
M204 X[Kp] Y[Ki] Z[Kd] -
M205: Advanced settings
Support | Marlin | RepRapFirmware | Repetier | Smoothie | Klipper | Prusa | MK4duo | MakerBot |
grbl | Sprinter | BFB | FiveD | Machinekit | Redeem | Teacup | Yaskawa | |
M205 Repetier
Output EEPROM settings.
M206:
M206 Marlin, Sprinter, Smoothie - Set home offset
Example: M206 X10.0 Y10.0 Z-0.4
M206 Repetier - Set eeprom value
Example: M206 T3 P39 X19.9
Set Jerk to 19.9
Example: M207
M207: Set retract length
- Parameters
- Snnn positive length to retract, in mm
- Fnnn feedrate, in mm/min
- Znnn additional zlift/hop
- Example
- M207 S4.0 F2400 Z0.075
Sets retract length, stays in mm regardless of M200 setting
M208: Set axis max travel
Example: M208 X250 Y210 Z180
With Duet-dc42 firmware, on a Cartesian printer you can also use this command to specify software limits for axis travel in the negative direction, by adding parameter S1. The axis limits you set are also the positions assumed when an endstop is triggered.
M208: Set unretract length
Yes | No | No | Yes | ??? | ??? | ??? | ??? | |
- Parameters
- Snnn positive length surplus to the M207 Snnn, in mm
- Fnnn feedrate, in mm/sec
Example: M209 S1
M210: Set homing feedrates
Example: M210 X1000 Y1500
Example: M211 X1 Y1 Z1 S0
Disables X,Y,Z max endstops
Example: M211 X0 S1
Enables X min endstop
Example: M211
Yes* | ??? | No | No | ??? | ??? | ??? | ??? | |
Example: M212 Z-0.2
M218: Set Hotend Offset
Example: M218 T1 X50 Y0.5
Example: M220 S80
S<factor in percent>- set speed factor override percentage
Example: M221 S70
S<factor in percent>- set extrude factor override percentage
M220: Turn off AUX V1.0.5
M221: Turn on AUX V1.0.5
M226: Gcode Initiated Pause
??? | No | Yes | No | Yes | ??? | No | ??? |
Example: M226
M226: Wait for pin state
- Parameters
- Pnnn pin number
- Snnn pin state
- Example
- M226 P2 S1
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
M231: Set OPS parameter
No | ??? | Yes | No | ??? | ??? | ??? | ??? | |
M231 S[OPS_MODE] X[Min_Distance] Y[Retract] Z[Backslash] F[ReatrctMove]
M240: Trigger camera
Example: M240
Triggers a camera to take a photograph. (Add to your per-layer GCode.)
??? | No | No | No | No | ??? | Debug: Echo off | ??? |
Example: M240
??? | No | No | No | No | ??? | Debug: Echo on | ??? |
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
M250: Set LCD contrast
Example: M250 C20
M251 S0 - Reset, S1 - Print, S2 - Store to Z length (also EEPROM if enabled)
(This is a Repetier-Firmware only feature)
M280: Set servo position
Yes | ??? | ??? | No | ??? | ??? | ??? | ??? | |
(Marlin, Repetier M340)
Set servo position absolute. P: servo index, S: angle or microseconds (Marlin)
M300: Play beep sound
- Parameters
- Snnn frequency in Hz
- Pnnn duration in milliseconds
- Example
- M300 S300 P1000
Play beep sound, use to notify important events like the end of printing. See working example on R2C2 electronics. Also supported by duet-dc42 firmware via the sounder on the add-on touch screen control panel.
M301: Set PID parameters
??? | Yes | No | No | No | ??? | No: See M13[0-3]) | ??? |
- Parameters
- Hnnn heater number (Smoothie uses 'S')
- Pnnn proportional (Kp)
- Innn integral (Ki)
- Dnnn derivative (Kd)
- Examples
- M301 H1 P1 I2 D3 ; Marlin
- M301 H1 P1 I2 D3 T0.2 B20 W127 S0.8 ; RepRapFirmware (v1.09 onwards), Duet-dc42
- M301 S0 P30 I10 D10 ; Smoothie
Marlin
Hot end only; see M304 for bed PID. H is the heater number, default 1 (i.e. first extruder heater).
Duet-dc42 and RepRapFirmware (v1.09 onwards)
H: Is the heater number, and is compulsory. H0 is the bed, H1 is the first hot end, H2 the second etc.
P: Interprets a negative P term as indicating that bang-bag control should be used instead of PID (not recommended for the hot end, but OK for the bed heater).
I: Integral value
D: Derivative value
T: Is the approximate additional PWM (on a scale of 0 to 255) needed to maintain temperature, per degree C above room temperature. Used to preset the I-accumulator when switching from heater fully on/off to PID.
S: PWM scaling factor, to allow for variation in heater power and supply voltage. Is designed to allow a correction to be made for a change in heater power and/or power supply voltage without having to change all the other parameters. For example, an S factor of 0.8 means that the final output of the PID controller should be scaled to 0.8 times the standard value, which would compensate for a heater that is 25% more powerful than the standard one or a supply voltage that is 12.5% higher than standard.
W: Wind-up. Sets the maximum value of I-term, must be high enough to reach 245C for ABS printing.
B: PID Band. Errors larger than this cause heater to be on or off.
An example using all of these would be:
- M301 H1 P20 I0.5 D100 T0.4 S1 W180 B30
Smoothie
S0 is 0 for the hotend, and 1 for the bed, other numbers may apply to your configuration, depending on the order in which you declare temperature control modules.
W: Wind-up. Sets the maximum value of I-term, so it does not overwhelm other PID values, and the heater stays on. (Check firmware support - Sprinter, Marlin?) Example:
- M301 W125
Teacup
M302: Allow cold extrudes
Yes | Yes | Yes: 0.92 | No | ??? | ??? | ??? | ??? | |
This tells the printer to allow movement of the extruder motor, when the hotend is not at printing temperature
Example: M302
When using RepRapFirmware, running M302 will only report the current cold extrusion state. To allow or deny cold extrudes/retracts, run either "M302 P1" or "M302 P0".
M303: Run PID tuning
Hot end usage:
M303 S<temperature> C<cycles>
Bed usage:
Example:
M303 C8 S175
M303 E0 S190
Yes | dc42 | ??? | No: See M301 | ??? | ??? | ??? | ??? | |
- Parameters
- Examples
- M304 P1 I2 D3 ; set kP=3, kI=2, kD=3
- M301 P1 I2 D3 T0.7 H0 B20 W127 ; Duet-dc42 firmware
- M304 ; Report parameters
Sets Proportional, Integral and Derivative values for bed. Duet-dc42 firmware interprets a negative P term as indicating that bang-bag control should be used instead of PID. In Duet-dc42 firmware, this command is identical to M301 except that the H parameter (heater number) defaults to zero.
Example: M304 H1 B4200 R4800 T100000
Sets the parameters for temperature measurement. Supported by RepRapFirmware from 0.78c, and Duet-dc42 firmware.
Example: M305 P1 T100000 R1000 B4200
This tells the firmware that for heater 1 (P parameter: 0 = heated bed, 1 = first extruder) the thermistor 25C resistance (T parameter) is 100Kohms, the thermistor series resistance (R parameter) is 1Kohms, the thermistor beta (B parameter) is 4200. All parameters other than P are optional. If only the P parameter is given, the existing values are displayed.
Additionally, Duet-dc42 firmware supports an ADC correction functionality and a thermistor selection facility.
Example: M305 P1 T100000 R1000 B4200 H14 L-11 X2
Here the ADC high end correction (H parameter) is 14, the ADC low end correction (L parameter) is -11, and thermistor input #2 is used to measure the temperature of heater #1.
M306: set home offset calculated from toolhead position
No | ??? | ??? | Yes | ??? | ??? | ??? | ??? | |
Example: M306 Z0
Implemented in Smoothieware
M320: Activate autolevel(Repetier)
(Repetier only)
M321: Deactivate autolevel(Repetier)
??? | No | No | No | No | ??? | No | ??? |
(Repetier only)
M322: Reset autolevel matrix
Example: M322 S1
Parameter S1 is mandatory
(Repetier only)
M340: Control the servos
M350: Set microstepping mode
Sets microstepping mode.
Warning: Steps per unit remains unchanged.
- Usage
- M350 Snn Xnn Ynn Znn Enn Bnn
- Parameters
- Not all parameters need to be used, but at least one should be used
- Snn Set stepping mode for all drivers
- Xnn Set stepping mode for the X axis
- Ynn Set stepping mode for the Y axis
- Znn Set stepping mode for the Z axis
- Enn Set stepping mode for Extruder 0
- Bnn Set stepping mode for Extruder 1
- Modes (nn)
- 1 = full step
- 2 = half step
- 4 = quarter step
- 8 = 1/8 step
- 16 = 1/16 step
- Examples
- M350 S16 (reset all drivers to the default 1/16 micro-stepping)
- M350 Z1 (set the Z-axis' driver to use full steps)
- M350 E4 B4 (set both extruders to use quarter steps)
Example: M351
M355: Turn case lights on/off
No | No | Yes: 0.92.2 | No | ??? | ??? | ??? | ??? | |
- Examples
- M355 S1 ; Enable lights
- M355 S0 ; Disable lights
- M355 ; Report status
Every call or change over LCD menu sends a state change for connected hosting software like
Case lights on Case lights off No case lights
No | ??? | Yes: 0.92.2 | No | ??? | ??? | ??? | ??? | |
- Target
- Example
- M360
- Response
Config:Baudrate:250000 Config:InputBuffer:127 Config:NumExtruder:2 Config:MixingExtruder:0 Config:HeatedBed:0 Config:SDCard:1 Config:Fan:1 Config:LCD:1 Config:SoftwarePowerSwitch:1 Config:XHomeDir:-1 Config:YHomeDir:-1 Config:ZHomeDir:-1 Config:SupportG10G11:1 Config:SupportLocalFilamentchange:1 Config:CaseLights:0 Config:ZProbe:1 Config:Autolevel:0 Config:EEPROM:1 Config:PrintlineCache:24 Config:JerkXY:30.00 Config:JerkZ:0.30 Config:RetractionLength:3.00 Config:RetractionLongLength:13.00 Config:RetractionSpeed:40.00 Config:RetractionZLift:0.00 Config:RetractionUndoExtraLength:0.00 Config:RetractionUndoExtraLongLength:0.00 Config:RetractionUndoSpeed:0.00 Config:XMin:0.00 Config:YMin:0.00 Config:ZMin:0.00 Config:XMax:250.00 Config:YMax:150.00 Config:ZMax:90.00 Config:XSize:250.00 Config:YSize:150.00 Config:ZSize:90.00 Config:XPrintAccel:250.00 Config:YPrintAccel:250.00 Config:ZPrintAccel:100.00 Config:XTravelAccel:250.00 Config:YTravelAccel:250.00 Config:ZTravelAccel:100.00 Config:PrinterType:Cartesian Config:MaxBedTemp:120 Config:Extr.1:Jerk:50.00 Config:Extr.1:MaxSpeed:100.00 Config:Extr.1:Acceleration:10000.00 Config:Extr.1:Diameter:0.00 Config:Extr.1:MaxTemp:220 Config:Extr.2:Jerk:50.00 Config:Extr.2:MaxSpeed:100.00 Config:Extr.2:Acceleration:10000.00 Config:Extr.2:Diameter:0.00 Config:Extr.2:MaxTemp:220
Partial | No | No | Yes | ??? | ??? | ??? | ??? | |
Experimental | No | No | Yes | ??? | ??? | ??? | ??? | |
Smoothieware: M364 P0 will accept the current position as 90deg between arms. The offset is stored as a trim offset (M666) and no further user interaction is required except to save all changes via M500
M365: SCARA scaling factor
- Usage
- M370
- M370 X<divisions> Y<divisions>
M374: Save calibration grid
Saves the calibration grid. (Smoothieware)
- Usage
- M374
- M374 <file extension> Z
Without parameters safes the grid into the default grid file that gets loaded at boot Parameter specifies the extension of the grid file - useful for special grid files such as for a special print surface like a removable print plate. Addition of Z will additionally save the M206 Z homing offset into the grid file
Display the bed level calibration matrix (Marlin) Load Grid matrix file (Smoothieware)
- Usage
- M375
- M375 <file extension>
M380: Activate solenoid
Example: M380
M381: Disable all solenoids
Example: M381
??? | Yes | No | No | Yes | ??? | No | ??? |
Finishes all current moves and and thus clears the buffer. That's identical to G4 P0
Example: M400
M401: Lower z-probe
Example: M401
Lower z-probe if present.
M402: Raise z-probe
Example: M402
Raise z-probe if present.
Yes | Partial | No | No | ??? | ??? | ??? | ??? | |
Example: M404 N1.75
N<dia in mm> Enter the nominal filament width (3mm, 1.75mm) or will display nominal filament width without parameters.
While Marlin only accepts the N parameter, Duet-zpl further allows to specify the nozzle diameter (in mm) via the D-parameter. It is used to properly detect the first layer height when a new print is being started.
Example: M404 N3.0 D1.0
M405: Filament Sensor on
Example: M405
M406: Filament Sensor off
Example: M406
Example: M407
Displays measured filament diameter. In RepRapFirmware M407 does the same as M404.
No | Partial | No | No | ??? | ??? | ??? | ??? | |
Report a JSON-style response by specifying the desired type using the 'S' parameter. For some purposes it is necessary to pass the sequence number, which is why Duet-zpl and Duet-dc42 accept an additional 'P' parameter to specify it.
Example: M408 S0
The following response types are supported:
- Type 0 is the M105 S2 response, which is like the new-style status response (for the old web interface) but some fields are omitted.
- Type 1 is the M105 S3 response, which is like the M105 S2 response except that static values are also included.
- Type 2 is the new-style standard JSON response, which is also reported to the new web interface (see Duet Web Control)
- Type 3 is an extended version of type 2 which includes some additional parameters that aren't expected to change very frequently
- Type 4 is an extended version of type 2 which may be used to poll for current printer stats
- Type 5 reports the current machine configuration
For a more detailed comparison of type 2 - 5, see Proposed_RepRap_Duet_Status_Responses
Currently M408 is only supported by Duet-dc42 and Duet-zpl.
M420: Set RGB Colors as PWM
No | ??? | No | No | ??? | ??? | ??? | ??? | |
??? | No | No | No | Yes | ??? | No | ??? |
Example: M420 R255 E255 B255
M500: Store parameters in EEPROM
Yes | dc42, zpl | Yes | ??? | ??? | ??? | ??? | ??? | |
Example: M500
Save current parameters to EEPROM. dc42 and zpl forks of RepRapFirmware allow "S1" to be passed, which forces parameters to be automatically saved to EEPROM when they are changed.
M501: Read parameters from EEPROM
Example: M501
Set the active parameters to those stored in the EEPROM. This is useful to revert parameters after experimenting with them.
M502: Revert to the default "factory settings."
Yes | ??? | Yes | ??? | ??? | ??? | ??? | ??? | |
Example: M502
This command resets all tunable parameters to their default values, as set in the firmware. This doesn't reset any parameters stored in the EEPROM, so it must be followed with M501 if you want to do that.
M503: Print settings
Yes | ??? | ??? | ??? | ??? | ??? | ??? | ??? | |
Example: M503
This command asks the firmware to reply with the current print settings stored in EEPROM. The reply output includes the G-Code commands to produce each setting. For example, the Steps Per Unit values are displayed as an M92 command.
M540: Enable/Disable "Stop SD Print on Endstop Hit"
- Parameters
- Snnn state, S1=enable, S0=disable
- Example
- M540 S1
M540: Set MAC address
No | Yes | No | No | ??? | ??? | ??? | ??? | |
Example: M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED
M550: Set Name
Example: M550 PGodzilla
M551: Set Password
Example: M551 Pmy-very-secret-word
M552: Set IP address
Example: M552 P192.168.1.14
Sets the IP address of the RepRap machine to (in this case) 192.168.1.14. A restart may be required before the new IP address is used. If no P field is specified, this echoes the existing IP address configured. If S0 is added thus: M552 S0 P192.168.1.14 networking is disabled.
M553: Set Netmask
Example: M553 P255.255.255.0
Sets the network mask of the RepRap machine to (in this case) 255.255.255.0. A restart may be required before the new network mask is used. If no P field is specified, this echoes the existing network mask configured.
M554: Set Gateway
Example: M554 P192.168.1.1
Sets the Gateway IP address of the RepRap machine to (in this case) 192.168.1.1. A restart may be required before the new gateway IP address is used. If no P field is specified, this echoes the existing Gateway IP address configured.
M555: Set compatibility
Example: M555 P1
For firmware that can do it, sets the firmware to a mode where its input and (especially) output behaves exactly like other established firmware. The value of the P argument is:
P value | Firmware |
0 | Native (i.e. whatever the firmware actually is) |
1 | RepRap_Firmware |
2 | Marlin |
3 | Teacup |
4 | Sprinter |
5 | Repetier |
M556: Axis compensation
Example: M556 S100 X0.7 Y-0.2 Z0.6
M557: Set Z probe point
Example: M557 P1 X30 Y40.5
M558: Set Z probe type
Example: M558 P0 X1 Y0 Z1
A Z probe may be a switch, an IR proximity sensor, or some other device. This selects which to use. P0 indicates that no Z probe is present. P1 gives an unmodulated IR probe, or any other probe type that emulates an unmodulated IR probe (probe output is an analog signal that rises with decreasing nozzle height above the bed). If there is a control signal to the probe, it is driven high when the probe type is P1. P2 specifies a modulated IR probe, where the modulation is commanded directly by the main board firmware using the control signal to the probe. P3 selects an alternative Z probe by driving the control signal to the probe low. P4 selects a switch (on the Duet, this must be connected to the E0 endstop pins).
The X, Y and Z parameters specify whether each axis uses the Z probe for homing or not. If the parameter is nonzero, the Z probe is used for homing that axis. if the parameter is zero, the endstop switch for that axis is used for homing instead. See also G31 and G32.
Duet-dc42 and zpl-dc42 firmware support an additional R parameter, which specifies the modulation channel. Channel 0 (the default) uses the standard Z probe modulation pin on the Duet 0.6. Channel 1 selects the alternative Z probe modulation pin on the Duet 0.7.
Duet-dc42 firmware versions 1.00e onwards supports additional parameter H. This specifies the dive height from which probing is done in response to a G30 command when the P parameter is present, or a G32 command.
Example: M559
M560: Upload web page file
Example: M560
For RepRaps that have web support and that can be driven by a web browser, this uploads the file that is the control page for the RepRap. After sending M560 the file (usually an HTML file) should be sent, terminated by the string<!-- **EoF** -->. Clearly that string cannot exist in the body of the file, but can be put on the end to facilitate this process. This should not be too serious a restriction...
M561: Set Identity Transform
Example: M561
M562: Reset temperature fault
Example: M562 P2
M563: Define or remove a tool
Example: M563 P3 D0:5:6 H1:3
Tools are usually (though not necessarily) extruders. The P field specifies the tool number. Tool numbers can have any positive integer value and 0. The D field specifies the drive(s) used by the tool - in this case drives 0, 5 and 6. Drive 0 is the first drive in the machine after the movement drives (usually X, Y and Z). If there is no D field the tool has no drives. The H field specifies the tool's heaters - in this case heaters 1 and 3. Heater 0 is usually the hot bed (if any) so the first extruder heater is usually 1. If there is no H field the tool has no heaters.
Tools are driven using multiple values in the E field of G1 commands, each controlling the corresponding drive in the D field above, as follows:
G1 X90.6 Y13.8 E2.24:2.24:15.89 G1 X70.6 E0:0:42.4
The first line moves straight to the point (90.6, 13.8) extruding a total of 2.24mm of filament from both drives 0 and 5 and 15.98mm of filament from drive 6.
The second line moves back 20mm in X extruding 42.4mm of filament from drive 6.
Duet-dc42 firmware supports an additional form of the M563 command. The command:
M563 S1
Duet-zpl firmware allows the deletion of existing tools if M563 is called in this way:
M563 P1 D-1 H-1
M564: Limit axes
Example: M564 S0
Allow moves outside the print volume, or not. If the S parameter is 0, then you can send G codes to drive the RepRap outside its normal working volume, and it will attempt to do so. User beware... If you set the S parameter to 1 then the RepRap will not think outside the box. The default behaviour is S = 1.
M565: Set Z probe offset
No | No: See G31 | No | Yes | ??? | ??? | ??? | ??? | |
Example: M565 X3 Y4.5 Z-2.37
Set the offset from the extruder tip to the probe position. The X, Y and Z values are the delta between the extruder and the actual trigger position of the probe. If the probe trigger point is below the extruder (typical) the Z offset will be negative. This just records the point offset; it does not actually do the probing. See G32.
Example: M566 X20 Y20 Z2 E10
Work around an algorithm limitation of some firmwares, which can't calculate step timings for a standing start. Teacup Firmware and Smoothieware don't have this limitation, so M566 is obsolete there.
M566 sets the speeds in mm/minute that axes can do from a standing start. If an accelerating algorithm starts a move with a zero velocity on other firmwares and then accelerates from that, it can give problems when the zero initial velocity is used to calculate a timestep between stepper pulses at the beginning: the timestep ends up being infinite... So these systems have initial small velocities to start at. This sets them.
The dc42 variant of RepRapFirmware doesn't have the limitation, but instead it uses this parameter to determine the maximum allowable speed change of each motor when cornering.
M567: Set tool mix ratios
Example: M567 P2 E0.1:0.2:0.1:0.6
The example sets the mix ratio for tool 2 (the P value). When mixing is then turned on (see M568), only single E values need to be sent on a G1 command (any extra E values will be ignored, but are not illegal):
G1 X20 E1.3
See also M568.
Example: M568 P2 S0
G1 X20 E0.2:0.4:0.166:0.3
The off state is the default.
M569: Set axis direction values
Example: M569 P0 S1
Set the control value for the drive specified by P that sends it forwards to the given value in the S field. After sending the example, sending a 1 to X (drive 0) will make it go forwards, sending a 0 will make it go backwards. Obviously to be used with extreme caution...
M570: Set heater timeout
Example: M570 S120
After a heater has been switched on, wait 120 seconds for it to get close to the set temperature. If it takes longer than this, flag a heater fault.
M571: Set output on extrude
Example: M571 S0.5
This turns an output on whenever extrusion is being done, and turns it off when the extrusion is finished. The output could control a fan or a stirrer or anything else that needs to work just when extrusion is happening. The S parameter sets the value of the PWM to the output. 0.0 is off; 1.0 is fully on.
M572: Set or report extruder elasticity compensation
No | dc42 | No | No | ??? | ??? | ??? | ??? | |
Example: M572 P3 S0.06
This sets the compensation time in seconds (S parameter) for Bowden extruder elasticity for the specified drive (P parameter). Supported by Duet-dc42 firmware. It has an effect similar to the EXTRUDER_ADVANCE_K factor in Marlin firmware. Normally, compensation should be applied to extruder drives only (drives 3 and higher).
M573: Report heater PWM
Example: M573 P1
This gives a running average (usually taken over about five seconds) of the PWM to the heater specified by the P field. If you know the voltage of the supply and the resistance of the heater this allows you to work out the power going to the heater.
Example: M574 X1 Y2 Z0 S1
This defines the type of endstop switch or opto sensor that the printer has for each axis: 0 = none, 1 = low end, 2 = high end. The optional S parameter defines whether the endstop input is active high (S1, the default) or low (S0). Intended for use with boards that provide a single endstop input for each axis that may be used for either a high or a low end endstop, such as the Duet. Supported by Duet-dc42 firmware. On delta printers, the XYZ parameters refer to the towers and the endstops should normally all be high end.
Example: M575 P1 B57600 S1
This sets the communications parameters of the serial comms channel specified by the P parameter. P0 specifies the main serial interface (typically a USB port, or serial-over-USB), while P1 specifies an auxiliary serial port (for example, the port used to connect a PanelDue). The B parameter is the required baud rate (this parameter is typically ignored if the port is a true USB port). The S parameter is a bitmap of features. The lowest bit, if set, specifies that only commands that include a valid checksum should be accepted from this comms channel.
M576: Set axis/extruder drive mapping
No | not yet | No | No | ??? | ??? | ??? | No | |
Example: M576 X0 Y1 Z2:3 A4 E5:6:7
This maps each letter to the specified drive number(s). In this example the Z axis configuration consists of two motors that need to be controlled simultaneously. An extra axis 'A' is also defined for cusstom purposes (rotary nozzle, cutter tool etc.) while the remaining axes are mapped to extruder drives.
M577: Wait until endstop is triggered
No | Duet-zpl | No | No | ??? | ??? | ??? | No | |
Example: M577 E0 S1
Wait for an endstop switch to be pressed. The example above will wait until the first extruder endstop is triggered.
The following trigger types may be used using the 'S' parameter:
0: Endstop not hit 1: Low endstop hit 2: High endstop hit 3: Near endstop (only Z probe)
M578: Fire inkjet bits
No | Yes | No | No | ??? | ??? | ??? | No | |
Example: M578 P3 S5
This fires inkjet head 3 (the P field) using the bit pattern specified by the S field. The example shown would fire bits 101. If the P parameter is ommitted inkjet 0 is assumed.
This is a version of the M700 command used by the Inkshield, but unfortunately M700 is already taken so cannot be used for that in the standard.
M600: Set line cross section
No | ??? | ??? | ??? | ??? | ??? | ??? | ??? | |
Example: M600 P0.061
Sets the cross section for a line to extrude in velocity extrusion mode. When the extruder is enabled and movement is executed the amount of extruded filament will be calculated to match the specified line cross section.
M600: Filament change pause
Example: M600
Pause for filament change X[pos] Y[pos] Z[relative lift] E[initial retract] L[later retract distance for removal].
Example: M605 S1
Sets the dual x-carriage movement mode: S<mode> [ X<duplication x-offset> R<duplication temp offset> ].
M605 S0: Full control mode. The slicer has full control over x-carriage movement M605 S1: Auto-park mode. The inactive head will auto park/unpark without slicer involvement M605 S2 [Xnnn] [Rmmm]: Duplication mode. The second extruder will duplicate the first with nnn millimeters x-offset and an optional differential hotend temperature of mmm degrees. E.g., with "M605 S2 X100 R2" the second extruder will duplicate the first with a spacing of 100mm in the x direction and 2 degrees hotter.
M665: Set delta configuration
Yes | dc42 | No | Yes | ??? | ??? | ??? | ??? | |
Example: M665 L250 R160 S200 (Marlin), M665 L250 R160 B80 H200 (Duet-dc42)
Set the delta calibration variables. L = diagonal rod length, R = delta radius, S = segments per second, B = safe printing radius, H = nozzle height above bed when homed after allowing for the endstop corrections.
- I don't think it's a good idea to have two different implementations for the same G-code, and I also question the practical value of specifying the print bed radius when defining a delta configuration, since many delta printers use a square or rectangular print bed. So perhaps we should stick to the Marlin-defined command as the definition for this command, and use a different command or set of commands to define print bed shape and size. --AndrewBCN (talk) 23:10, 31 January 2015 (PST)
- The implementations are not different, they have the same L and R parameters, but each has additional parameters that are not relevant to the other implementation. I'm not against defining a new Gcode to define bed size and shape; however, you can already define the limits of a rectangular print area using M208. Even when a delta printer has a square bed, the printable area is not square. It is usually taken to be circular, although it is in reality more complicated. My purpose in adding the B parameter was to make it easy to define a radius outside which movement will not normally be attempted. I have changed "bed radius" to "safe printing radius" in the text to help clarify this. --dc42
Example M666 X-0.1 Y+0.2 Z0
M667: Select CoreXY mode
M667 S0 selects Cartesian mode (unless the printer is configured as a delta using the M665 command). Forward motion of the X motor moves the head in the +X direction. Similarly for the Y motor and Y axis, and the Z motor and Z axis. This is the default state of the firmware on power up.
M667 S1 selects CoreXY mode. Forward movement of the X motor moves the head in the +X and +Y directions. Forward movement of the Y motor moves the head in the -X and +Y directions.
M667 S2 selects CoreXZ mode. Forward movement of the X motor moves the head in the +X and +Z directions. Forward movement of the Z motor moves the head in the -X and +Z directions.
M667 S3 selects CoreYZ mode. Forward movement of the Y motor moves the head in the +Y and +Z directions. Forward movement of the Z motor moves the head in the -Y and +Z directions.
M700: Level plate
bq | ??? | No | No | ??? | ??? | ??? | ??? | |
1 only in bq-Marlin Firmware
Example: M700
M701: Load filament
Example: M701
M702: Unload filament
Example: M702
M906: Set motor currents
No | Yes | No | M907? | ??? | ??? | ??? | ??? | |
Example: M906 X300 Y500 Z200 E350
The dc42 fork of RepRapFirmware supports an additional I parameter. This is the percentage of normal that the motor currents should be reduced to when the printer becomes idle but the motors have not been switched off.
Yes | ??? | No | ??? | ??? | ??? | ??? | ??? | |
Set digital trimpot motor current using axis codes (X, Y, Z, E, B, S).
Yes | ??? | Yes: 0.92 | No | ??? | ??? | ??? | ??? | |
M908 P<pin> S<current>
M909: Set microstepping
Example: M909 X3 Y5 Z2 E3
Set the microstepping value for each of the steppers.
In Redeem this is implemented as 2^value, so
M909 X2 sets microstepping on X-axis to 2^2 = 4,
M909 Y3 sets microstepping on Y-axis to 2^3 = 8 etc.
M928: Start SD logging
Yes | ??? | No | No | ??? | ??? | ??? | ??? | |
Example: M928 filename.g
Ended by M29.
M998: Request resend of line
Example: M998 P34
Request a resend of line 34. In some implementations the input-handling code overwrites the incoming G Code with this when it detects, for example, a checksum error. Then it leaves it up to the GCode interpreter actually to request the resend.
Yes | Yes | No | Yes | ??? | ??? | ??? | ??? | |
Example: M999
The dc42 fork of RepRapFirmware not only resets the board but also puts the board into firmware upload mode if parameter PERASE is present.
Other commands
G: List all G-codes
Example: G
This lists all implemeted G-codes in the firmware with description and sends it back to the host.
M: List all M-codes
Example: M
This lists all implemeted M-codes in the firmware with description and sends it back to the host.
T: Select Tool
Yes | Yes | Yes | Yes | ??? | ??? | ??? | ??? | |
??? | No | ??? | Yes | ??? | ??? | Yes | ??? |
Example: T1
The sequence followed is:
- Set the current tool to its standby temperatures specified by G10 (see above),
- Set the new tool to its operating temperatures specified by G10 and wait for all temperatures to stabilise,
- Apply any X, Y, Z offset for the new tool specified by G10,
- Use the new tool.
Selecting a non-existent tool (100, say) just does Step 1. above. That is to say it leaves all tools in their standby state. You can, of course, use the G10 command beforehand to set that standby temperature to anything you like.
Some implementations (e.g. RepRapFirmware) allow you to specify tool-change G Code macros. There are normally three specified (any of which can contain no commands if desired) that execute in this order:
- Actions to do with the old tool before it is released - macro name: tfreeN.g where N is the tool number;
- (Old tool is released);
- Actions to do with the new tool before it is selected - macro name: tpreN.g where N is the tool number;
- (New tool is selected); and
- Actions to do with the new tool after it is selected - macro name: tpostN.g where N is the tool number.
With such implementations there is no wait for temperature stabilisation. That can be achieved by an M116 in any of the macros, of course.
After a reset tools will not start heating until they are selected. You can either put them all at their standby temperature by selecting them in turn, or leave them off so they only come on if/when you first use them. The M0, M1 and M112 commands turn them all off. You can, of course, turn them all off with the M1 command, then turn some back on again. Don't forget also to turn on the heated bed (if any) if you use that trick.
Marlin uses codes M500-M503 to manipulate EEPROM values.
xx can be one of:
ok
rs
On the latest version of Pronterface and soon Octoprint a special comment of the form:
// action:command
is allowed to be sent from the firmware, the command can currently be pause, resume or disconnect which will execute those commands on the host. As this is also a comment other hosts will just ignore these commands.
ok
start
Exceptions:
1. Marlin 1.0.0 Gen6 Firmware does not follow the two character rule. 'rs' is actually 'Resend' and '!!' is 'Error'. Example Lines:
- Error: Line Number is not current line + 1. Last Line: 7
- Resend: 8
- Writing to File: print.gco
- Done saving file.
- File opened:print.gco Size:22992
- File selected
2. The dc42 fork of RepRapFirmware responds to some commands with a reply string in JSON format, terminated by a newline. This allows later firmware revisions to include additional information without confusing clients (e.g. PanelDue) that do not expect it, and to make responses self-describing so that the client will not be confused if responses are delayed or lost. The commands affected are:
- M105 S2
- M105 S3
- M20 S2
- M36
- M408
Problem to solve
When using Marlin firmware or emulating Marlin, each line of G-code sent from the host to the controller is answered with an ok before the next line can be sent without locking communications up. This slows down communication and limits the number of commands that can be sent per second to the printer controller, as the USB stack on the host and the serial interface driver on the Arduino add their own latencies (up to 10 milliseconds). This is not a problem for other controller electronics using native USB such as the Duet, because the standard serial-over-USB drivers provide flow control, so the host software can be configured so as not to wait for the ok.
Alternatives to G-code
- Main article: Firmware/Alternative#alternatives to G-code
