G-code
Revision as of 16:53, 17 November 2013 by Adrianbowyer (talk | contribs) (M999: Restart after being stopped by error)
This page tries to describe the flavour of G-codes that the RepRap firmwares use and how they work. The main target is additive fabrication using FFF/FDM processes. Codes for print head movements follow the NIST RS274NGC G-code standard, so RepRap firmwares are quite usable for CNC milling and similar applications, too.
As many different firmwares exist and their developers tend to implement new features without discussing strategies or looking what others did before them, a lot of different sub-flavours for the 3D-Printer specific codes developed over the years.
Introduction
A typical piece of GCode as sent to a RepRap machine might look like this:
N3 T0*57
N4 G92 E0*67
N5 G28*22
N6 G1 F1500.0*82
N7 G1 X2.0 Y2.0 F3000.0*85
N8 G1 X3.0 Y3.0*33
To find out which specific gcode/s are implemented in any given firmware, there are little tables attached to the command descriptions, like this one:
Support FiveD Teacup Sprinter Marlin Repetier
yes automatic yes yes experimental
Here means:
yes
Fully supported.
experimental
There is some support. Often it's required to check out a source code branch other than the default or to flip certain configuration switches.
automatic
The firmware handles this feature automatically, so there's no need to send the command; you get the feature regardless. An example is power supply on/off (M80/M81) in Teacup firmware.
no
The firmware doesn't support this feature.
For the technically minded, the end of line is marked by a <nl> and optionally a <cr>. So, Unix line endings work as well as Windows ones.
RepRap G Code Fields
This section explains the letter-preceded fields. The numbers in the fields are represented by nnn. Numbers can be integers, or can contain a decimal point, depending on context. For example an X coordinate can be integer (X175) or fractional (X17.62), whereas trying to select extruder number 2.76 would make no sense.
Letter Meaning
Tnnn Select tool nnn. In RepRap, tools are extruders
Snnn Command parameter, such as the voltage to send to a motor
Pnnn Command parameter, such as a time in milliseconds
Xnnn An X coordinate, usually to move to
Ynnn A Y coordinate, usually to move to
Znnn A Z coordinate, usually to move to
Innn Parameter - not currently used
Jnnn Parameter - not currently used
Ennn Length of extrudate in mm. This is exactly like X, Y and Z, but for the length of filament to extrude. It is common for newer stepper based systems to interpret ... Better: Skeinforge 40 and up interprets this as the absolute length of input filament to consume, rather than the length of the extruded output.
Comments
G Code comments:
N3 T0*57 ;This is a comment
N4 G92 E0*67
; So is this
N5 G28*22
Will be ignored by RepRap, as will blank lines. But it's better to strip these out in the host computer before the lines are sent. This saves bandwidth.
Individual commands
Checking
N and *
These are the line number and the checksum. The RepRap firmware checks the checksum against a locally-computed value and, if they differ, requests a repeat transmission of the line of the given number.
int cs = 0;
   cs = cs ^ cmd[i];
Buffered G Commands
The RepRap firmware stores these commands in a ring buffer internally for execution. This means that there is no (appreciable) delay while a command is acknowledged and the next transmitted. In turn, this means that sequences of line segments can be plotted without a dwell between one and the next. As soon as one of these buffered commands is received it is acknowledged and stored locally. If the local buffer is full, then the acknowledgment is delayed until space for storage in the buffer is available. This is how flow control is achieved.
G0: Rapid move
 ??? yes yes yes yes
Example: G0 X12
In this case move rapidly to X = 12 mm. In fact, the RepRap firmware uses exactly the same code for rapid as it uses for controlled moves (see G1 below), as - for the RepRap machine - this is just as efficient as not doing so. (The distinction comes from some old machine tools that used to move faster if the axes were not driven in a straight line. For them G0 allowed any movement in space to get to the destination as fast as possible.)
G1: Controlled move
yes yes yes yes yes
Example: G1 X90.6 Y13.8 E22.4
Go in a straight line from the current (X, Y) point to the point (90.6, 13.8), extruding material as the move happens from the current extruded length to a length of 22.4 mm.
RepRap does subtle things with feedrates. Thus:
G1 F1500
Will set a feedrate of 1500 mm/minute, then do the move described above at that feedrate. But
G1 F1500
G1 X90.6 Y13.8 E22.4 F3000
Will set a feedrate of 1500 mm/minute, then do the move described above accelerating to a feedrate of 3000 mm/minute as it does so. The extrusion will accelerate along with the X, Y movement so everything stays synchronized.
RepRap thus treats feedrate as simply another variable (like X, Y, Z, and E) to be linearly interpolated. This gives complete control over accelerations and decelerations in a way that ensures that everything moves together and the right volume of material is extruded at all points.
Note: not every firmware implements this, e.g. the current Marlin will use the new feedrate from the beginning of the move and not change it.
The first example shows how to get a constant-speed movement. The second how to accelerate or decelerate. Thus
G1 F1500
G1 X80 Y20 E36 F1500
Will do the first movement accelerating as before, and the second decelerating from 3000 mm/minute back to 1500 mm/minute.
To reverse the extruder by a given amount (for example to reduce its internal pressure while it does an in-air movement so that it doesn't dribble) simply use G1 to send an E value that is less than the currently extruded length.
G28: Move to Origin
yes yes yes yes yes
Example: G28
This causes the RepRap machine to move back to its X, Y and Z zero endstops, a process known as "homing". It does so accelerating, so as to get there fast. But when it arrives it backs off by 1 mm in each direction slowly, then moves back slowly to the stop. This ensures more accurate positioning.
If you add coordinates, then just the axes with coordinates specified will be zeroed. Thus
G28 X0 Y72.3
will zero the X and Y axes, but not Z. The actual coordinate values are ignored.
G29-G32: Bed probing
G29 Detailed Z-Probe
probes the bed at 3 points.
G30 Single Z Probe
probes bed at current XY location.
G31 Report Current Probe status
G32 Probe Z and calibrate with FPU
probes the bed at 3 points and updates transformation matrix for bed leveling compensation.
Unbuffered G commands
The following commands are not buffered. When one is received it is stored, but it is not acknowledged to the host until the buffer is exhausted and then the command has been executed. Thus the host will pause at one of these commands until it has been done. Short pauses between these commands and any that might follow them do not affect the performance of the machine.
Teacup Firmware buffers G20, G21, G90 and G91.
G4: Dwell
Example: G4 P200
G10: Head Offset
Example: G10 P3 X17.8 Y-19.3 Z0.0 R140 S205
This sets the offset for extrude head 3 (from the P3) to the X and Y values specified. You can put a non-zero Z value in as well, but this is usually a bad idea unless the heads are loaded and unloaded by some sort of head changer. When all the heads are in the machine at once they should all be set to the same Z height.
Remember that any parameter that you don't specify will automatically be set to the last value for that parameter. That usually means that you want explicitly to set Z0.0.
The R value is the standby temperature in oC that will be used for the tool, and the S value is its operating temperature. If you don't want the head to be at a different temperature when not in use, set both values the same. See the T code (select tool) below.
The NIST G-code standard mentions an additional L parameter, which is ignored.
This command is subject to discussion.
G20: Set Units to Inches
Example: G20
G21: Set Units to Millimeters
Example: G21
Example: G90
Example: G91
G92: Set Position
Example: G92 X10 E90
Unbuffered M and T commands
M0: Stop
Example: M0
The RepRap machine finishes any moves left in its buffer, then shuts down. All motors and heaters are turned off. It can be started again by pressing the reset button on the master microcontroller. See also M1, M112.
M1: Sleep
Example: M1
Example: M3 S4000
Example: M4 S4000
Example: M5
The spindle is turned off.
Example: M7
Example: M8
Example: M9
M10: Vacuum On (CNC specific)
Example: M10
Example: M11
Example: M17
Example: M18
M20: List SD card
Example: M20
ok Files: {SQUARE.G,SQCOM.G,}
M21: Initialize SD card
Example: M21
The SD card is initialized. If an SD card is loaded when the machine is switched on, this will happen by default. SD card must be initialized for the other SD functions to work.
M22: Release SD card
Example: M22
M23: Select SD file
Example: M23 filename.gco
M24: Start/resume SD print
Example: M24
M25: Pause SD print
Example: M25
M26: Set SD position
Example: M26
M27: Report SD print status
Example: M27
Report SD print status.
M28: Begin write to SD card
Example: M28 filename.gco
M29: Stop writing to SD card
Example: M29 filename.gco
Example: M30 filename.gco
filename.gco is deleted.
M40: Eject
See also M240 and M241 below.
M41: Loop
Example: M41
M42: Stop on material exhausted / Switch I/O pin
M42 in ???
Example: M42
If your RepRap can detect when its material runs out, this decides the behaviour when that happens. The X and Y axes are zeroed (but not Z), and then the machine shuts all motors and heaters off. You have to press reset to reactivate the machine. In other words, it parks itself and then executes an M0 command (q.v.).
M42 in Marlin/Sprinter
Example: M42 P7 S255
M42 switches a general purpose I/O pin.
M42 in Teacup
Not needed. General purpose devices are handled like a heater, see M104.
Example: M43
M80: ATX Power On
Example: M80
Note: some firmwares, like Teacup, handle power on/off automatically, so this is redundant there. Also, see RAMPS wiring for ATX on/off
M81: ATX Power Off
Example: M81
M82: set extruder to absolute mode
Example: M82
makes the extruder interpret extrusion as absolute positions.
M83: set extruder to relative mode
Example: M83
makes the extruder interpret extrusion values as relative positions.
M84: Stop idle hold
Example: M84
M92: Set axis_steps_per_unit
Example: M92 X<newsteps> Sprinter and Marlin
M98: Get axis_hysteresis_mm
Example: M98
Proposed for Marlin
M99: Set axis_hysteresis_mm
Example: M99 X<mm> Y<mm> Z<mm> E<mm>
Proposed for Marlin
M101 Turn extruder 1 on Forward / Undo Extruder Retraction
M101 in Teacup firmware
If a DC extruder is present, turn that on. Else, undo filament retraction, which means, make the extruder ready for extrusion. Complement to M103.
M101 in other firmwares
Deprecated. Regarding filament retraction, see M227, M228, M229.
M102 Turn extruder 1 on Reverse
Deprecated.
M103 Turn all extruders off / Extruder Retraction
M103 in Teacup firmware
If a DC extruder is present, turn that off. Else, retract the filament in the hope to prevent nozzle drooling. Complement to M101.
M103 in other firmwares
Deprecated. Regarding extruder retraction, see M227, M228, M229.
yes yes yes yes yes
Example: M104 S190
Set the temperature of the current extruder to 190oC and return control to the host immediately (i.e. before that temperature has been reached by the extruder). See also M109.
M104 in Teacup Firmware
Example: M104 P1 S100
Set the temperature of the device attached to the second temperature sensor to 100 °C.
Example: M105
Request the temperature of the current extruder and the build base in degrees Celsius. The temperatures are returned to the host computer. For example, the line sent to the host in response to this command looks like: ok T:201 B:117
Expansion/generalization of M105 to be considered as noted in Pronterface I/O Monitor
M106: Fan On
yes yes yes
Example: M106 S127
Turn on the cooling fan at half speed.
Mandatory parameter 'S' declares the PWM value (0-255). M106 S0 turns the fan off. In some implementations the pwm is specified by a real fraction: M106 S0.7.
M106 in Teacup Firmware
Example: M106 P2 S255
M107: Fan Off
Deprecated. Use M106 S0 instead.
M108: Set Extruder Speed
Sets speed of extruder motor. (Deprecated in current firmware, see M113)
 ??? not needed see text yes  ???
M109 in Teacup
M109 in Marlin, Sprinter (ATmega port)
Example: M109 S185
M109 in Sprinter (4pi port)
Example: M109 S185 R240 //sets extruder temperature to 185 and waits for the temperature to be between 185 - 240.
M110: Set Current Line Number
 ??? not needed  ???  ???  ???
Example: M110 N123
M111: Set Debug Level
Example: M111 S6
#define DEBUG_ECHO (1<<0)
#define DEBUG_INFO (1<<1)
#define DEBUG_ERRORS (1<<2)
Example: M253
Debug
M112: Emergency Stop
Example: M112
M113: Set Extruder PWM
Example: M113
M113 S0.7
M114: Get Current Position
Example: M114
Example: M115
sample data from firmware:
M116: Wait
Example: M116
M117: Get Zero Position
Example: M117
M117 in Marlin: Display Message
Example: M117 Hello World
This causes the given message to be shown in the status line on an attached LCD. The above command will display Hello World.
M118: Negotiate Features
Example: M118 P42
M119: Get Endstop Status
yes yes yes
Example: M119
M120: Push
  1. Current feedrate, and
M121: Pop
M122: Diagnose
M126: Open Valve
Example: M126 P500
M127: Close Valve
Example: M127 P400
M128: Extruder Pressure PWM
Example: M128 S255
M129: Extruder pressure off
Example: M129 P100
M130: Set PID P value
yes
Example: M130 P 0 S 8.0 # Sets heater 0 P factor to 8.0
M131: Set PID I value
yes
Example: M130 P 1 S 0.5 # Sets heater 1 I factor to 0.5
M132: Set PID D value
yes
Example: M130 P 0 S 24 # Sets heater 0 D factor to 24.0
M133: Set PID I limit value
yes
Example: M130 P 1 S 264 # Sets heater 0 I limit value to 264
yes
Example: M134
M135: Set PID sample interval
Example: M135 S300
Debug
Example: M136 P1 # print heater 0 PID parameters to host
M140: Bed Temperature (Fast)
yes yes yes yes
Example: M140 S55
Set the temperature of the build bed to 55oC and return control to the host immediately (i.e. before that temperature has been reached by the bed).
M141: Chamber Temperature (Fast)
Example: M141 S30
M142: Holding Pressure
Example: M142 S1
M143: Maximum hot-end temperature
Example: M143 S275
Example: M160 S4
When N >= 2, then the E field that controls extrusion requires N+1 values separated by spaces after it like this:
M160 S4
G1 X90.6 Y13.8 E22.4 0.1 0.1 0.1 0.7
G1 X70.6 E42.4 0.0 0.0 0.0 1.0
G1 E42.4 1.0 0.0 0.0 0.0
The second line moves straight to the point (90.6, 13.8) extruding 22.4mm of filament. The mix ratio at the end of the move is 0.1:0.1:0.1:0.7.
The third line moves back 20mm in X extruding 20mm of filament. The mix varies linearly from 0.1:0.1:0.1:0.7 to 0:0:0:1 as the move is made.
The fourth line has no physical effect, but sets the mix proportions for the start of the next move to 1:0:0:0.
obsolete, see M116 yes yes
Example: M190 S60
M200 - Set filament diameter / Get Endstop Status
yes
M200 sets the filament diameter.
Question: what does a firmware do with filament diameter? Has this an effect on how much an E command moves the extruder motor? --Traumflug 11:34, 14 October 2012 (UTC)
M201 - Set max printing acceleration
in units/s^2 for print moves (M201 X1000 Y1000)
M202 - Set max travel acceleration
M203 - Set maximum feedrate
that your machine can sustain (M203 X200 Y200 Z300 E10000) in mm/sec
Note: this should be in units/minute, just like the F code.
M204 - Set default acceleration
M205 - advanced settings
M206: set home offset
Example: M206 X10.0 Y10.0 Z-0.4
M207: calibrate z axis by detecting z max length
Example: M207
M208: set axis max travel
Example: M208 X250 Y210 Z180
M209: enable automatic retract
Example: M209 S1
M210: Set homing feedrates
Example: M210 X1000 Y1500
M220:set speed factor override percentage
Example: M220 S80
S<factor in percent>- set speed factor override percentage
M221: set extrude factor override percentage
Example: M221 S70
S<factor in percent>- set extrude factor override percentage
M226: Gcode Initiated Pause
Example: M226
Example: M227 P1600 S1600
P and S are steps.
Example: M228
See also M227.
Example: M229 P1.0 S1.0
Example: M230 S1
Debug: Echo off
Example: M240
Debug: Echo on
Example: M241
M245: Start cooler
Example: M245
M246: Stop cooler
Example: M246
M300: Play beep sound
Usage: M300 S<frequency Hz> P<duration ms>
Example: M300 S300 P1000
M301: Set PID parameters - Hot End
PID
Example: M301 P1 I2 D3 C5
Sets Proportional, Integral and Derivative values for hot end, the value C refers to an extrusion rate.
Alternate implementation
Example: M301 W125
M302: Allow cold extrudes
This tells the printer to allow movement of the extruder motor, when the hotend is not at printing temperature
Example: M302
M303: Run PID tuning
PID PID
Hotend Usage: M303 S<temperature> C<cycles> Bed Usage: M303 E-1 C<cycles> S<temperature> Example: M303 C8 S175
Generate Proportional, Integral and Derivative values for the hotend or bed (E-1). Send the appropriate code and wait for the output to update the firmware.
PID
Example: M304 P1 I2 D3
Sets Proportional, Integral and Derivative values for bed
Example: M400
M420: Set RGB Colors as PWM
Example: M420 R255 E255 B255
M500: Set Password
Example: M500 Pmy-very-secret-word
On machines that need a password to activate them, set that password. The code 'P' is not part of the password. Note that as this is sent in clear it does not (nor is it intended to) offer a very high level of security. But on machines that are (say) on a network, it prevents idle messing about by the unauthorised. The password can contain any printable charcters except ';', which still means start comment.
M501: Set Name
Example: M501 PGodzilla
M502: Set IP address
Example: M502 P192.168.1.14
Sets the IP address of the RepRap machine to (in this case) 192.168.1.14. If no P field is specified, this echos the existing IP address.
M503: Set compatibility
Example: M503 P1
For firmware that can do it, sets the firmware to a mode where its input and (especially) output behaves exactly like other established firmware. The value of the P argument is:
P value Firmware
1 RepRap_Firmware
2 Marlin
3 Teacup
4 Sprinter
5 Repetier
M504: Axis compensation
Example: M504 S100 X0.7 Y-0.2 Z0.6
M505: Set Z probe point
Example: M505 P1 X30 Y40.5
M906: Set motor currents
Example: M906 X300 Y500 Z200 E350
M998: Request resend of line
Example: M998 P34
Request a resend of line 34. In some implementations the input-handling code overwrites the incomming G Code with this when it detects, for example, a checksum error. Then it leaves it up to the GCode interpreter actually to request the resend.
Example: M999
T: Select Tool
Example: T1
Select extruder number 1 to build with.
The sequence followed is:
  1. Set the current extruder to its standby temperature specified by G10 (see above),
  2. Set the new extruder to its operating temperature specified by G10 and wait for all temperatures to stabilise,
  3. Apply any X, Y, Z offset for the new extruder specified by G10,
  4. Use the new extruder.
Selecting a non-existent tool (100, say) just does Step 1. above. That is to say it leaves all tools in their standby state. You can, of course, use the G10 command beforehand to set that standby temperature to anything you like.
If the Z value changes in the offsets and the head moves up, then the Z move is made before the X and Y moves. If Z moves down, X and Y are done first.
After a reset extruders will not start heating until they are selected. You can either put them all at their standby temperature by selecting them in turn, or leave them off so they only come on if/when you first use them. The M0, M1 and M112 commands turn them all off. You can, of course, turn them all off with the M1 command, then turn some back on again. Don't forget also to turn on the heated bed (if any) if you use that trick.
Extruder numbering starts at 0.
Proposed SCARA calibration codes (Morgan)
In order to ease calibration of Reprap Morgan, the following M-codes are used to set the machine up Implemented in qharley/Marlin armlevel branch.
M360 : Move to Theta 0 degree position
M361 : Move to Theta 90 degree position
M362 : Move to Psi 0 degree position
M363 : Move to Psi 90 degree position
M364 : Move to Psi + Theta 90 degree position
M365 : SCARA scaling factor
M370 : Morgan manual bed level - clear map
M371 : Move to next calibration position
M372 : Record calibration value, and move to next position
M373 : End bed level calibration mode
M375 : Display matrix
Display the bed level calibration matrix
Store the calibration to EEPROM using M500
Marlin uses these codes to manipulate EEPROM values.
M500: stores paramters in EEPROM
M501: reads parameters from EEPROM
If you need to reset them after you changed them temporarily
M502: reverts to the default "factory settings".
You still need to store them in EEPROM afterwards if you want to.
M503: Print settings
xx can be one of:
ok
rs
ok
start
Exceptions: Marlin 1.0.0 Gen6 Firmware does not follow the two character rule. 'rs' is actually 'Resend' and '!!' is 'Error'. Example Lines:
  • Error: Line Number is not current line + 1. Last Line: 7
  • Resend: 8
  • Writing to File: print.gco
  • Done saving file.
  • File selected
Problem to solve
Each line of G-code sent from the host to the controller is answered with an ok before the next line can be sent without locking communcations up. This makes operations very slow, as the usual USB-TTL converters and probably also the host's operating system drivers come with substantial latency, often 10 milliseconds.
For more details on this proposal, and some suggested solutions, and comments please see GCODE_buffer_multiline_proposal
Alternatives to G-code
  • Wikipedia: STEP-NC: "STEP-NC was designed to replace ... G-codes ... adding tolerance data ... [with a] XML format."
  • Elegant multispline motion controller "will not use G-code. It will use a custom language based on cubic Bezier curves. This allows for much better description of arcs and will result in much higher quality prints with a much lower data throughput requirements."
  • GCODE buffer multiline proposal This may have some relevance to developers
