FoldaRapX
Revision as of 03:55, 30 May 2019 by Emmanuel (talk | contribs)
Back to the concept of a foldable reprap using a scissor-like mechanism for the Z axis :)
FoldaRapX 0.1
Release status: in progress
another folding reprap
Notes :
  • tensioning the z-belt should be done in the upward direction, in order to tension against gravity
To-Do
Version 0.2
  • change the aluminium flight case (not cheap) for a regular wooden flight case (easier to use and customize)
  • move the linear rail 5mm closer to the pivot, in order for the end rail (printed part) to play its role of mechanical stop
Version 0.1
  • fine tune E step value (837 for start)
  • test print
  • tweaking RepRap Firmware for the scissor Z... (will need help here)
R&D
