FoldaRap2.1 Build Manual
Revision as of 11:12, 20 July 2015 by Emmanuel (talk | contribs) (archiving FR2.1)
2.1
Actual Version
The build manual for the most recent version of the FoldaRap is here
Tools required
  • 1,5 mm hexagonal wrench (for the pulleys grub screw)
  • 2 mm hexagonal wrench (for M3 counterksunk bolts and pneumatic fittings "MA-12-03-M5")
  • 2,5 mm hexagonal wrench (for normal M3 cap-head bolts and the rounded M4 bolts used for the frame)
  • a flat screwdriver (for the psu's screw terminals)
  • s small screwdriver (to set the drivers current)
You may need also :
  • a 5,5mm flat spanner or a small pliers (for m3 nuts)
  • something to cut wires, and strip them (knife, automatic striper, etc.)
  • a lighter for the heat-shrink sleeves
  • soldering iron (to eventually solder the endstops)
  • small files (round, flat) to eventually ream the printed parts
BOM
Hardware
Electronic
Lasercut parts
Printed parts (total : xx)
Other
General tips
  • Read the whole manual once or twice before starting, to get an overview of the build
    • Basically we have a main frame and several sub-assemblies, some can be done in parallel : gather your friends and establish a record for minimum building time ! (Actual best record : 4 hours)
  • Work on a cutting mat if you have one, it will protect your table plus they often show a millimetre grid that will be useful to check the bolts length (with some experience you will recognize them just by looking or holding one).
  • Place you mouse over a picture in a list if you wonder what part it is
  • In case of doubt, don't hesitate to have a look at the 3d model in Sketchup (before/during the build), even if about a next version of the machine it will show you the folded/unfolded state of the machine and you can play around with it :)
Ok let's start
It should take approximately 12 hours to put everything together.
From step 1 to 4 : 2-4 hours
Know the parts
Firstly, have a look at all the part and learn what everything is.
How to insert a T-nut
T-nut insertion.jpg Tightening torque : 2.5 Nm (+/- 5%)
<videoflash>9CAiVmfO2mk|320|240</videoflash>
Base Frame
Rear Base
Foldarap2 foot-rear-left.jpg x1 foot-rear-left Foldarap2 foot-rear-right.jpg x1 foot-rear-right 20x20 200mm.jpg x2 200mm profile M4x8 round-head.jpg x4 m4x8 T-nut.jpg x4 t-nut
Front Base
Foldarap2 foot-front-left.jpg x1 foot-front-left Foldarap2 foot-front-right.jpg x1 foot-front-right 20x20 200mm.jpg x1 200mm profile M4x8 round-head.jpg x2 m4x8 T-nut.jpg x2 t-nut
Base Frame
Foldarap frame rear assembled.jpg x1 rear assembly Foldarap2 frame front assembled.jpg x1 front assembly Foldarap2 hinge-inner-left.jpg x1 hinge-inner-left Foldarap2 hinge-inner-right.jpg x1 hinge-inner-right
20x20 300mm.jpg x4 300mm profile M4x8 round-head.jpg x10 m4x8 T-nut.jpg x10 t-nut
Y-idler
FoldaRap y-idler 603zz.jpg y-idler M3x20.jpg x1 m3x20 623zz.jpg x2 603zz bearing M4x8 round-head.jpg x2 m4x8 T-nut.jpg x2 t-nut
Y-motor
Plug
Foldarap y-motor.jpg x1 y-motor C14 CEI male-plug.jpg x1 plug M3 nut.jpg x2 m3 nut M3x8.jpg x2 m3x8
Motor
M3x8.jpg x2 m3x8 Nema14.jpg x1 nema 14 stepper motor Pulley-T2.5 paopart.jpg x1 pulley
Wiring
6,35mm-faston-ferule.jpg x7 ferules 6432-heatshrink-sleeve.jpg heat-shrink sleeve Big-blue-power-switch RS-5287858.jpg x1 switch M4x8 round-head.jpg x3 m4x8 T-nut.jpg x3 t-nut
A part of the wiring depend of the combination of electronic board and power supply, for other version : FoldaRap_power-supplies
Z-axis
Z-Left / Z-Right
Foldarap2 hinge-outer-left.jpg x1 hinge-outer-left Foldarap2 hinge-outer-right.jpg x1 hinge-outer-right Foldarap2 z-motor-bracket-left.jpg x1 z-motor-left Foldarap2 z-motor-bracket-right.jpg x1 z-motor-right
20x20 300mm.jpg x2 300mm profile M4x8 round-head.jpg x4 m4x8 T-nut.jpg x4 t-nut
Z-Motors
Nema14.jpg x2 nema14 M3x8.jpg x4 m3x8
Hinges
FoldaRap2 base-frame assembled.jpg FoldaRap2 Z-axis 08.jpg M3x20.jpg x2 m3x20 M3 nut.jpg x2 m3 nut
Underplate
Power Supply
Different kind of power supply have been used in FoldaRap builds, if you don't recognize yours look at this page : FoldaRap power-supplies
Anyway, the principle is always 1) bolt the power supply on the plate, 2) then the plate on the base of the frame
Flat-120w-psu.jpg x1 power supply M3x8.jpg x2 m3x8 M3 nut.jpg x2 m3 nut
Foldarap2 underplate.jpg x1 lasercut underplate M4x8 round-head.jpg x3 m4x8 T-nut.jpg x3 t-nut
Z-axis position
Z-sliders
Foldarap2 Z-slider-left.jpg z-slider-left Foldarap2 Z-slider-right.jpg z-slider-right
X-axis
X-slider
Foldarap2 X-slider.jpg x-slider Nema14.jpg x1 nema14 stepper motor Timing pulley.jpg x1 pulley
M3x30.jpg x4 M3x30 countersunk head 623zz.jpg x2 603zz bearing
Fan-holder
FoldaRap2 X-slider fan-holder.jpg fan-holder M3x30.jpg x1 m3x25
X-belt
20x20 200mm.jpg x1 200mm profile T2.5belt.jpg x1 250mm belt M4x8 round-head.jpg x2 m4x8 T-nut.jpg x2 t-nut
XZ-axis
Z-rods
M5 nut.jpg x4 M5 nylon nut 230-235mm threaded-rod.jpg x2 M5 threaded rod 230mm Flexible-coupling.jpg x2 flexible coupling
<videoflash>iZKFV5miQEk|320|240</videoflash>
Extruder(s)
Foldarap2 extruder-left nema14.jpg extruder-left Pneumatic-fitting MA1203M5.jpg x1 pneumatic-fitting M3x16.jpg x1 m3x16 623zz.jpg x1 603zz bearing
(and/or extruder-right Foldarap2 extruder-right nema14.jpg)
Nema14.jpg x1 nema14 stepper motor Maritime-models drive-gear.jpg x1 knurled insert (juste one) M3x8.jpg x2 m3x10 M3x20.jpg x1 m3x20
M3x35.jpg x2 M3x35 Foldarap extruder-spring RS751483.jpg x2 spring M3 nut.jpg x2 M3 nut
Top-frame (need update)
Foldarap2 z-top-left.jpg x1 Foldarap2 z-top-right.jpg x1 20x20 200mm.jpg x1 M4x8 round-head.jpg x4 T-nut.jpg x4
FoldaRap-handle.jpg x1 M4x8 round-head.jpg x2 T-nut.jpg x2
Reprap-org plate 160mm.jpg x1 M4x8 round-head.jpg x2 T-nut.jpg x2
Great ! You are almost done !
Have a pause, you need to be relaxed for the next step, or you can also just head to the end :)
Hotend
Heater
FoldaRap-hotend Heater-block.jpg x1 heater block FoldaRap-hotend nozzle.jpg x1 nozzle FoldaRap-hotend Barrel 00.jpg x1 barrel Thermistor 100k.jpg x1 thermistor
Heatsink
FoldaRap-hotend Heatsink-v3.jpg x1 hotend heatsink (+ tube holder) Tubing.jpg x1 PTFE tube
FoldaRap2 X-slider hotend-holder.jpg x1 hotend holder M3x8.jpg x4 m3x8
Fan
Fan404010.png x1 fan Fan-railings.png x1 fan railings M3x16.jpg x4 m3x16 M3 washer.jpg x4 m3 washer
Cartridge heater
Cartridge-heater.jpg x1 cartridge heater
Wires
Ferule.JPG x2 1mm ferrule 6432-heatshrink-sleeve.jpg x2 heatshrink sleeve
Male-casing.jpg x1 male casing Female-ferrule.jpg x6 female ferrule
Cable harness
2pin-wire connector.JPG x2 2 pin-wire with connector Cartridge-wires-70cm-1.jpg x2 cartridge wire (70cm)
Female-casing.jpg x1 female casing Male-ferrule.jpg x6 male ferrule End-piece.jpg x2 end piece
Bed-Plate
Heater
Foldarap1.1 bed-plate.jpg x1 bed plate Foldarap2 kapton-heater.jpg x1 film-heater
M3x30 countersunk-head.jpg x3 m3x30 countersunk M3 nut.jpg x3 m3 nut Bed springs RS751455.jpg x3 springs
Y-carriage
Foldarap y-carriage lasercut.jpg x1 y-carriage LM6UU.jpg x3 linear bearing Zipties.jpg x4 zip-tie
Foldarap belt-clamp.jpg x1 belt-clamp T2.5belt.jpg x1 belt (600mm) M3x12.jpg x2 m3x10 M3 nut.jpgx2 m3 nut M3 washer.jpg x2 m3 washer M3 nut nylock.jpgx3 m3 nylock
Wires
Housing flat 2pin.jpg x1 2pin housing Female-crimp-terminal.jpg x2 female crimp terminal
Electronic Board
Previous instructions for the AzteegX1 / Melzi
Minitronicsv1.jpg x1 Foldarap board-mount.jpg x1 board-mount M3x8.jpg x2 m3x8 M4x8 round-head.jpg x2 m4x8 T-nut.jpg x2 t-nut
Wiring
Setting the drivers current
Now lets plug everything to the board !
Look at the Minitronics_10 page, it is well documented and the wiring should be quite easy with the male/female connectors.
Endstops
  1. cut wires
  2. solder wires
  3. insulate
  4. crimp
  5. casing
  6. in place
  7. wiring
X
Micro-switch with-lever.jpg x1
glued on the side
Y
Micro-switch with-lever.jpg x1 Zipties.jpg x1 zip-tie
Z
Micro-switch with-lever.jpg x1 M4x8 round-head.jpg x1 m4x8 T-nut.jpg x1 t-nut Zipties.jpg x1 zip-tie (or 2 m2x10 bolt)
Motors
  • Y-motor
  • Z-motors
  • X-motor
  • Extruder-motor
Hotend(s)
  • thermistor (blue 75cm)
  • heater (red 75cm)
  • fan : on a 12v pin (must be always on)
Fans
  • printed-part cooling fan: if the hotend's fan is alway on, this one is controlled by the electronic board via the "cooling fan" screw terminal (turned on by sending Mcode "M106 Sxxx" (xxx being between 0 and 255), turned off by "M107" but Slic3r automate this)
  • Cooling the Minitronics_10's PCB is mandatory according to RichRap in RepRap Magazine 2:
The PCB is used as a heatsink and must be cooled from the underside with a 40mm fan or bigger, this is important to do with such a compact board.
Bed-Plate
Finish by this one, as it is moving, the wires need to be above all the other wires.
  • thermistor
  • heater element (the two thicker wires)
Tidying
  • spiral wrapping band : for the wires that came out of the base.
(image)
Y-axis
Smooth-rod-300mm.jpg x2 Micro-switch with-lever.jpg x1 (with 32cm green wires for y-endstop) Zipties.jpg x6
Tape (5-10 min)
  • Kapton (polyimide) or blue tape (= outside masking tape, uv resistant usually with acrylic adhesive, PLA stick well to acrylic)
<videoflash>MdCMMt7siy4|640|480</videoflash>
Making the bed parallel and zeroing
The Z-zero is made when making the bed parallel to the nozzle.
  1. Start by roughly makin it parallel
  2. then move the nozzle to the lowest point
  3. and adjust the 3 screws to move it regarding that height (by turning them until the homing move stop lowering the bed)
  4. repeat on each corners so the zero is exactly when the nozzle stop touching the bed (true for the four corners+center)
  • I like to start with the Y direction with the two bolts, then with the remaining one
<videoflash>35Xv_R8U_hU|320|240</videoflash> Here is a video to show what I mean by "the homing move stop lowering the bed"
<videoflash>rjIMmzltyLQ|320|240</videoflash> "Bad" (the bolts need to be tightened)
  • Once the plan is set from left to right you can check front/end
  • after that it's supposed to be parallel but may need few more tweaks that will be revealed by observing the first layer of a print
Software side
  • Skeinforge : you will only have to add a little offset (altitude), to have the desired height for the first layer, usually the same as your layer height.
  • Slic3r : leave z-offset at 0, it will add one layer height automatically (you still may have to adjust it slightly to fine tune the Z-zero, depending on where your endstop have been glued).
Another advantage of that : by moving to the center of the bed from the zero height, the nozzle is also wiped by the side of the bed from any purged plastic ;-)
Go go go first print !!!
This article will probably help you along your first print :)
http://www.sarfata.org/3d-printing/2013/04/First-Steps-In-3D-Printing-With-Foldarap/
Also have a look at the User Manual
