FoldaRap
Revision as of 06:24, 23 October 2017 by Emmanuel (talk | contribs) (Special Features)
FoldaRap Documentation
FoldaRap2.5
first folding reprap
In my obsession dreaming of a folding RepRap, I finally started to make one, after 5-7 months of development I'm able to travel with it around the town/country/world :) (adventures pictured on flickr / youtube). Maybe a few thousands were made, from kits or by self-sourcing : FoldaRap_Hall-of-Builds / google-maps.
Specifications
  • Printed Parts: 35
  • Non-Printed Parts: around 300 (including every bolts/nuts/washers/ferules/etc.)
  • Material Cost: around 500g
  • Cost: 300-600 €
  • Printing Size: 140x140x140 mm (or 5.5"x5.5"x5.5")
  • Resolution : XY = 0.0125 mm ; Z = 0,00025 mm
  • Accuracy : 0.05mm (50 microns is the lowest layer height tested yet)
  • Speed: 75-500 mm/s (print-travel, max speed tested yet)
Special Features
  • Foldable !
  • Based on standard parts, easy to reuse/recycle
  • 1.75mm Direct Driven Bowden Extruder ; fixed on the x-axis for less hysteresis and higher z-print
  • Low energy consumption (40-110W)
  • Footprint : 210x350 mm / Total volume : 335x350x360 mm / Folded : about 335x500x98 mm / 3-4kg
Community
Recent Discussion
R&D
FoldaRap 4.0
  • external power supply
  • (and use the room left to) embed Octoprint inside
  • rack on the Y-axis (to remove the last belt/pulley)
FoldaRap 3.X
  • replace nema14 (X,Y) by nema17 (like the nema 17 in Z)
  • stiffer Y motor/idler
FoldaRap 3
Combining old and new ideas, plus the little changes in every parts, and that is good for a new release :)
FoldaRap 2.5
FoldaRap 2.1
FoldaRap 1.0
Huxley size
Mendel size
http://forums.reprap.org/read.php?283,221591
Foldarap-Mendel 00.jpg Something between a big foldarap and a mondrian
  • 5 300mm
  • 7 400mm
From the VertX to a whole printer, it's the next big project I started to dream of, some months ago, because I want to have a folding RepRap for travels/exhibitions/conferences that only need to be plugged to print (even if the Huxley is already not bad for that).
  • Foldable (first inspiration came from a folding ladder that my father have, then the Bonsai_RepStrap, this thread where Mendel90 first appeared, and from my Pocket Engraver structure)
  • Few threaded rods (I first thought about aluminium extrusion, but finally I'll assemble printed parts to make the frame, which is also good for replication/changes/scaling)
  • Easily scalable (can be 300x300x300 or 50x50x50, as we want).
  • Sells Mendel style Z-axis (one motor as I like to be able to manually tweak the Z)
More Inspiration
Some details that I found interesting or related or want to integrate to this idea of a foldable machine...
History
  • 2011/11: started to design a folding Mendel, then a folding Huxley
  • 2012/01: starting to design the Fold-a-slot (actual FoldaRap)
  • 2012/05/24: First Print !!
  • 2012/06/23: First known user build started by Spacexula :)
  • 2012/06/28: beginning of the crowdfunding campaign
  • 2012/07: 2-3 more people are starting to build one
  • 2012/07/10: the crowdfunding campaign reached 100% ! (30 days left)
  • 2012/08/08: the campaign ended at 255% !!! FoldaRap_Batch1 in progress.
  • 2012/10 : start of the FoldaRap_Distributed_Manufacturing network
  • 2012/10 : another one is being build by Paoparts
  • 2012/10 : 1st workshop at Nybicc [43]
  • 2012/10/30 : first replication's first print ! (by Joris and his FoldaRap #003)
  • 2012/11 : 2nd workshop at Nybicc [44]
  • 2012/11 : 3rd workshop at Lille [45]
  • 2012/11 : 4th workshop at Dakar [46]
  • 2012/12 : 5th workshop at Orléans [47] and first parts produced by a user's machine for the next kits to be delivered :)
  • 2013/01 : another US build ! makehacklearn
  • 2013/02 : a Japanese Foldarap
  • 2013/04 : FoldaRap 1.1
  • 2013/04/20 : second crowdfunding campaign
  • 2013/07/09 : campaign end at 445% FoldaRap_Batch2 in progress
  • 2013/07 : [48] Alex B. is making his own FoldaRap (mendel size), first beta builder of this model :)
  • 2013/10/01 : 2nd prototype of FoldaRap 2
  • 2014-2016 : FoldaRap 2.5
  • 2017/08 : back to the drawing table (FoldaRap 3)
External links, media/press, etc.
I like feedback from the community, but a little attention from a blog or other people is always good :)
  1. hackaday mention a neat folding reprap, in their article about the many choices of repraps to build
  2. twittpic of Korben at the NuitDuHack2012
  3. Paradoxe temporel [49] and [50] also during the NDH2012
  4. From a little post in the GOALL, to Lorraine numérique / e-alsace
  5. Dans-ce-pot
  6. Retour sur la nuit du hack 2012
  7. B3dge
  8. 3ders.org
  9. Demonter.net
  10. Mobile Solar Powered 3D Printer Project on Appropedia (a solar powered foldarap ? :))
  11. Faveoly
  12. 3druck
  13. Bundlr
  14. Personnal Factory and several other tumblrs
  15. Fabbaloo
  16. 3dprinter
  17. Imastresd
  18. Nirvasite
  19. Ponoko
  20. Makezine
  21. Genomicon
  22. Dailygeekshow
  23. Semageek
  24. Core77
  25. Notcot
  26. Premiere
  27. Wired
  28. Nada nos libra de escorpio
  29. DfRobot
  30. Usinette&co au Summerlab Nantes
  31. Atelier-outdoor
  32. 2013 whishes by OVA design
  33. Sextoy hacking, from a workshop at the FacLab
  34. Be-3D, une imprimante 3D portable française
  35. Disrupt3d
  36. Reddit
  37. Sarfata's first steps in 3D Printing with a FoldaRap
  38. Ping
  39. Atelier.net
  40. The RepRap project: an open source/open hardware movement for 3D-printing
  41. paperblog
  42. MakerFaire Rome Tour
  43. Good Morning Crowdfunding
  44. France Inter, Bienvenue dans la 3ème dimension
  45. Good Morning Crowdfunding - PDJ
  46. Cerfav
  47. MakeHackFab
  48. Kreizenn-dafar
  49. Formalab
  50. Planète-PME
  51. ITespresso
  52. FrenchWeb
  53. La tête dans le flux : les makers
  54. el diario : Cultura libre y peer production: La era maker
  55. in the Summer edition of Focus, an Italian magazin about science
  56. Il Sole 24 Ore
  57. Maker Faire Rome
  58. Rue 89
  59. Futura-Science maker-faire
  60. REWU 07
  61. Convention APM 2013
  62. Anis asso
  63. birth of the #069 ;-)
  64. Bubu
  65. Xevel
  66. Xevel
  67. F4GRX
  68. marie lombard
  69. 3D Print Show full report
  70. éveillons-nous
  71. RepRap Floss Manual
  72. Poirpom
  73. France 3 Région Lorraine
  74. France 3 édition des régions du Journal National
  75. Management magazine
  76. La Semaine de Metz : Les pionniers d'un monde libre
  77. Mosaik.tv
  78. L'Express
  79. Une Semaine en Lorraine n°54
  80. Management Magazine 217
  81. FabLab Champagneulle
  82. FabLab Lannion
  83. Workshop Chemillé
  84. Workshop Dijon
  85. Sketchup Scribbles
  86. OpenAtelier
  87. HackLab.fr
  88. Républicain Lorrain
  89. Milan Design Week
  90. Stampa3D
  91. Lorraine Numérique
  92. TV8
  93. MJC Apt
  94. Dydlo OHW
  95. Feria matematica (1mn05)
  96. in cover of Comment fabriquer tout et n'importe quoi (translation of "How To Make Almost Anything from Neil Gershenfeld)
  97. Ceci n'est pas une illusion
  98. Yes We Are Open!
  99. Le Parisien Magazine 11.jul.2014
And as is it getting longer and longer, you can follow the tag foldarap on delicious
