File:Spindle-hub 1off.scad
Revision as of 00:00, 2 August 2010 by Tbuser (talk | contribs) (uploaded a new version of "File:Spindle-hub 1off.scad": moved bearing inset deeper to make new spool design level easier with the other bearings)
Spindle-hub_1off.scad (file size: 3 KB, MIME type: unknown/unknown)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 00:00, 2 August 2010 | (3 KB) | Tbuser (talk | contribs) | moved bearing inset deeper to make new spool design level easier with the other bearings |
01:46, 30 July 2010 | (3 KB) | Tbuser (talk | contribs) | ||
01:35, 28 July 2010 | (2 KB) | Tbuser (talk | contribs) | ||
01:47, 27 July 2010 | (2 KB) | Tbuser (talk | contribs) | removing unnecessary code | |
01:35, 27 July 2010 | (4 KB) | Tbuser (talk | contribs) | fixed bearing diameter | |
01:00, 27 July 2010 | (4 KB) | Tbuser (talk | contribs) |
- You cannot overwrite this file.
File usage
The following page links to this file:
