File:PLA SpecificHeat.zip
Revision as of 20:39, 4 February 2011 by Jbayless (talk | contribs)
PLA_SpecificHeat.zip(file size: 49 KB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
Specific heat data of PLA.
Source: Pyda, M., Bopp, R., Wunderlich, B. 2004. Heat capacity of poly(lactic acid), J. Chem.
Compiled and edited by user: Jbayless for use in extruder design calculations.
Note: Zip file contains a variety of common data formats:
  • xlsx (original file)
  • xls
  • ods
  • txt (tab-delimited values)
  • csv (comma-separated values)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current20:37, 4 February 2011 (49 KB)Jbayless (talk | contribs)Specific heat data of PLA. Source: Pyda, M., Bopp, R., Wunderlich, B. 2004. Heat capacity of poly(lactic acid), J. Chem. Compiled and edited by [[user: Jbayless] for use in extruder design calculations. Note: Zip file contains a variety of common data
  • You cannot overwrite this file.
The following 3 pages link to this file:
