File:Mendel-m4-assembly-data-sheet.ods
Revision as of 17:17, 1 March 2010 by Adrianbowyer (talk | contribs) (uploaded a new version of "Image:Mendel-m4-assembly-data-sheet.ods")
Mendel-m4-assembly-data-sheet.ods (file size: 325 KB, MIME type: application/vnd.oasis.opendocument.spreadshe)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
Critical dimensions and BOM needed to assemble Mendel.
File history
Click on a date/time to view the file as it appeared at that time.
(newest | oldest) View (newer 10 | older 10) (10 | 20 | 50 | 100 | 250 | 500)Date/Time | Dimensions | User | Comment | |
current | 00:52, 15 November 2010 | (325 KB) | Taniwha (talk | contribs) | Changed studding assignment to represent parts that come more than once from the same length |
23:57, 31 October 2010 | (317 KB) | Bandit (talk | contribs) | update BOM which calls for 9 rods to say 8 and update the 1m stud refferences as per http://reprap.org/wiki/Mendel_materials_procurement | |
11:58, 1 April 2010 | (315 KB) | Johnnyr (talk | contribs) | Changed BY from split BX to split BZ, allowing more efficient belt splitting. | |
18:19, 4 March 2010 | (318 KB) | Renoir (talk | contribs) | Added UK alternative suppliers and part IDs for Farnell and RS (uk) for the stepper driver 2.3 boards. Some substitute parts listed: please check and confirm before using. | |
18:19, 2 March 2010 | (317 KB) | Adrianbowyer (talk | contribs) | ||
17:17, 1 March 2010 | (317 KB) | Adrianbowyer (talk | contribs) | ||
14:30, 28 February 2010 | (316 KB) | Adrianbowyer (talk | contribs) | Added details of the RFO files for mass production of Mendels in Mendels. | |
21:11, 24 February 2010 | (314 KB) | Cakeller98 (talk | contribs) | Added the stepper driver IC from digikey. they have single part pricing now - and around 2000+ pcs on hand. | |
20:26, 14 February 2010 | (311 KB) | Adrianbowyer (talk | contribs) | ||
08:35, 16 December 2009 | (310 KB) | Adrianbowyer (talk | contribs) | Improved extruder design. This needs 4x 25mm M3 caps and one 20mm M4 cap... |
- You cannot overwrite this file.
File usage
The following 6 pages link to this file:
