File:Mendel-m4-assembly-data-sheet.ods
Revision as of 00:52, 15 November 2010 by Taniwha (talk | contribs) (uploaded a new version of "File:Mendel-m4-assembly-data-sheet.ods": Changed studding assignment to represent parts that come more than once from the same length)
Mendel-m4-assembly-data-sheet.ods(file size: 325 KB, MIME type: application/vnd.oasis.opendocument.spreadshe)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
Critical dimensions and BOM needed to assemble Mendel.
File history
Click on a date/time to view the file as it appeared at that time.
(newest | oldest) View (newer 10 | ) (10 | 20 | 50 | 100 | 250 | 500)
Date/TimeDimensionsUserComment
current00:52, 15 November 2010 (325 KB)Taniwha (talk | contribs)Changed studding assignment to represent parts that come more than once from the same length
23:57, 31 October 2010 (317 KB)Bandit (talk | contribs)update BOM which calls for 9 rods to say 8 and update the 1m stud refferences as per http://reprap.org/wiki/Mendel_materials_procurement
11:58, 1 April 2010 (315 KB)Johnnyr (talk | contribs)Changed BY from split BX to split BZ, allowing more efficient belt splitting.
18:19, 4 March 2010 (318 KB)Renoir (talk | contribs)Added UK alternative suppliers and part IDs for Farnell and RS (uk) for the stepper driver 2.3 boards. Some substitute parts listed: please check and confirm before using.
18:19, 2 March 2010 (317 KB)Adrianbowyer (talk | contribs)
17:17, 1 March 2010 (317 KB)Adrianbowyer (talk | contribs)
14:30, 28 February 2010 (316 KB)Adrianbowyer (talk | contribs)Added details of the RFO files for mass production of Mendels in Mendels.
21:11, 24 February 2010 (314 KB)Cakeller98 (talk | contribs)Added the stepper driver IC from digikey. they have single part pricing now - and around 2000+ pcs on hand.
20:26, 14 February 2010 (311 KB)Adrianbowyer (talk | contribs)
08:35, 16 December 2009 (310 KB)Adrianbowyer (talk | contribs)Improved extruder design. This needs 4x 25mm M3 caps and one 20mm M4 cap...
  • You cannot overwrite this file.
