File:CPH01 000000000000010009001 00000001 Solid Transformer HV Insulator Bottom Version 10.stl
Revision as of 07:35, 7 December 2016 by Rapatan (talk | contribs) (This has been successful printed in ABS with a layer hight of 0.3mm and 100% infill at 40mm/s. If printed in ABS the safe temperature of the insulator is 81 degrees Celsius The inside height is only 110mm.)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current07:35, 7 December 2016 (310 KB)Rapatan (talk | contribs)This has been successful printed in ABS with a layer hight of 0.3mm and 100% infill at 40mm/s. If printed in ABS the safe temperature of the insulator is 81 degrees Celsius The inside height is only 110mm.
  • You cannot overwrite this file.
The following page links to this file:
