File:CPH01 000000000000010009001 00000001 Solid Nylon Transformer HV Insulator Bottom Version 10.stl
CPH01_000000000000010009001_00000001_Solid_Nylon_Transformer_HV_Insulator_Bottom_Version_10.stl (file size: 310 KB, MIME type: application/acad)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
This has been successful printed in ABS with a layer hight of 0.3mm and 100% infill at 40mm/s. If printed in ABS the safe temperature of the insulator is 81 degrees Celsius The inside height is only 110mm.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 07:17, 7 December 2016 | (310 KB) | Rapatan (talk | contribs) | This has been successful printed in ABS with a layer hight of 0.3mm and 100% infill at 40mm/s. If printed in ABS the safe temperature of the insulator is 81 degrees Celsius The inside height is only 110mm. |
- You cannot overwrite this file.
File usage
The following file is a duplicate of this file (more details):
There are no pages that link to this file.
