FilamentReviewsRepRapWorld
Revision as of 12:19, 1 August 2012 by Danielpublic (talk | contribs) (Initial creation with [User:Emmanuel|Emmanuel]]'s review''s'' (props!))
Reviews for: Company_Name (Template)
Back to Filament Suppliers.
(Answer Template)
Date Material(s) Shape/Delivered Thickness (mm) Measured thickness (mm) Quantity Delivered amount Costs (kg) Costs (Meter) Destination & shipping costs Rating 0-10 Additional notes & Signed by
08:55, 1 September 2011 PLA Round/Round 1.75mm & 3mm 1.58-1.99mm & 2.79-3.11mm 5x500gr (green/yellow/red/blue/black) ???kg €20/kg range - shipping - One of the few in the €20/kg range (maybe imported from other china suppliers ?), I gave it a try. Ordered 26aug / Received 31aug. Shipped with TNT, in the delays announced of 4days
They have some bending (one in the blue, 4-5 for the black), a bubble sometimes (mostly for the green translucent), and little bit dirt (mostly visible on the black, and few black dusts on the others) probably need to clean it before extruding.
The black roll of 1,75mm have also some interruptions (it's not a continuous roll).
Beside that it seems correct. -Emmanuel. Each 3mm filament is fine, they required some tweaking (average diameter) but printed good.
However I wouldn't recommend the 1,75mm-black, I don't know why but the print quality is far from the other filament and the uneven diameter has finally led to a nozzle jam (fortunately the bowden tube broke before a critical failure). --Emmanuel 17:58, 28 September 2011 (UTC) I tried again to use the 1,75 black but failed again (and the min-max diameter is worse than previously measured)
--Emmanuel 10:34, 16 November 2011 (UTC)
