FilamentReviewsKBell
Revision as of 14:28, 27 April 2014 by Dark Alchemist (talk | contribs)
Date | Material(s) | Shape/Delivered | Thickness (mm) | Measured thickness (mm) | Quantity | Delivered amount | Costs (kg) | Costs (Meter) | Destination & shipping costs | Rating 0-10 | Additional notes & Signed by |
4/27/2014 | ABS | round | 1.75mm | 1.6-1.95 | 1kg | ???kg | $24/kg | - | Free | 3/10 | At $24/kg shipped, this is a low cost filament. I had nothing but issues with the entire roll. It came vacuumed sealed with a desiccant inside the hole of the spool and it will pop (snap) and smoke (I tried temps from a jamming 190c to 230c and still a horrible smell like burning a Bic Ballpoint pen with a lot of coughing). The size has been very erratic and as a result my prints will go from blobs to fine to not enough material in one print (depends on the size of the object). Due to the smoke, pops, and coughing I have to say to stay away from this or suffer health issues. |
4/30/2013 | PLA | Slight Oval | 3mm | 2.76mm x 2.98mm | 1kg | ???kg | $28/kg | - | Free | 8/10 | At $28/kg shipped, this is a low cost filament. The only major issue is the slight oval shape, but it hasn't provided me with any trouble yet. Also, the supplier confirmed that the slight oval shape is a result of the winding process (for cost) and their focus was on the quality and density of the material itself. Overall, very friendly, knowledgeable, and so far I'm getting good prints.
-Leonexis. |
April 2013 | ABS | round | 1.75mm | 1.65mm | 1kg | 1180g including spool | $28/kg | - | included | 6/10 | Drastically, consistently undersized. Comes on a small-radius spool, which makes it a bit tricky to use (which I knew ahead of time, but tried out because of low price). Doesn't include tolerances on diameter, but it's the same spool as Octave uses and they specify +/- 0.10mm. I managed to get a couple of layers down, but it's tricky because my extruder bottoms out. I'll update once I get a full print.
-Thatch. |
July 2013 | ABS | round | 3mm | 2.7mm | 1kg | 1100g including spool | $28/kg | - | free | 2/10 | As noted above, not even close to the right diameter. Could not even get the thing to load correctly. Spool was warped beyond recognition. Seller did not care whatsoever. Avoid--too many good sellers to bother with this one. |
