FSR
Revision as of 23:24, 24 March 2014 by Johann (talk | contribs) (Testing)
FSR
Force Sensing Resistors
GPL
autolevel
Instead of the retractable Z probe, now using Force Sensing Resistors (FSR) sandwiched between the glass print surface and the triangle frame. We use three FSR wired in parallel, connected to the Z_MIN endstop pin. This allows calibrating the print surface with 0.02 mm repeatability, which is good enough for printing PLA on cold naked glass.
When the hotend pushes down on the print surface, the FSR changes quickly from 5MΩ to <50Ω, depending on the force. A few Newton is sufficient to trigger the Z_MIN endstop digital input pin, because it's using a 20kΩ internal pull-up resistor inside the Arduino or similar microcontroller.
Johann's first prototype used the heated bed thermistor (analog) input pin, but the endstop (digital) input pin works just fine, without any additional parts.
Because Force Sensing Resistors are normally open (NO) make sure that you have the following in Configuration.h:
const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
Testing
When none of your endstops are touched, the result of M119 should look like this:
SENDING:M119
PC>Reporting endstop status
PC>x_max: open
PC>y_max: open
PC>z_min: open
PC>z_max: open
When you put a weight of about 300g (e.g. a roll of blue tape) on the print surface, it should look like this:
SENDING:M119
PC>x_max: open
PC>y_max: open
PC>z_min: TRIGGERED
PC>z_max: open
Links
FSR product details: http://www.phidgets.com/products.php?product_id=3104
Source code: https://github.com/jcrocholl/Marlin/tree/fsr
Project history: http://deltabot.tumblr.com
<videoflash>HcnhCNh2Ln4</videoflash>
