FSR
Description | Force Sensing Resistors
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | autolevel
CAD Models | |
External Link |
Instead of the retractable Z probe, now using Force Sensing Resistors (FSR) sandwiched between the glass print surface and the triangle frame. We use three FSR wired in parallel, connected to the Z_MIN endstop pin. This allows calibrating the print surface with 0.02 mm repeatability, which is good enough for printing PLA on cold naked glass.
When the hotend pushes down on the print surface, the FSR changes quickly from 5MΩ to <50Ω, depending on the force. A few Newton is sufficient to trigger the Z_MIN endstop digital input pin, because it's using a 20kΩ internal pull-up resistor inside the Arduino or similar microcontroller.
Johann's first prototype used the heated bed thermistor (analog) input pin, but the endstop (digital) input pin works just fine, without any additional parts.
Because Force Sensing Resistors are normally open (NO) make sure that you have the following in Configuration.h:
const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
FSR product details: http://www.phidgets.com/products.php?product_id=3104
Source code: https://github.com/jcrocholl/Marlin/tree/fsr
Project history: http://deltabot.tumblr.com
<videoflash>HcnhCNh2Ln4</videoflash>
