Extruderinsulator
Revision as of 10:37, 29 January 2011 by Bodgeit (talk | contribs) (Materials)
Materials
Peek or PTFE
Benifit of Peek
no dangerous fumes if over heated.
I have 16mm diameter PEEK rod.
Disadvantages of PTFE
I dont have any PTFE.
The Original Reprap Mendel design:-
New Idea for a PEEK version of the insulator.
Diffrence from original.
1/ The top of the insulator is D shaped.
2/ The insulator mounts through a 6mm thick D Shape hole to stop twisting.
3/ The insulator is held in place with an E clip
4/ The filament clearance hole is bigger at 4.2mm
5/ The heated barel threaded length is much shorter.
6/ The heated batrrel is 25mm long
Calculations for the thermal insulation of these insulators calculated here.
