Extruder Expansion Board
Revision as of 20:44, 6 January 2014 by Bobc (talk | contribs) (Extruder Expansion Boards)
EXT6
Release status: Experimental
GPL
KiCAD
An expansion board to allow additional extruders to be operated.
There are now two variants :
  • EXT4 supports up to 4 extruders with a direct GPIO interface, does not require firmware change apart from config
  • EXT6 supports up to 6 extruders with I2C/SPI interfaces, to make better use of limited IO but requires firmware support
EXT4
Prototype
Features:
  • slots for 4 stepper driver modules
  • 4 thermistor inputs
  • 4 MOSFET outputs
  • compatible with 3.3V or 5V electronics
  • independent stepper drivers, heater control and thermistor inputs
EXT6
Bill of Materials
To be documented..
Prototype
Features:
  • slots for 6 stepper driver modules
  • 6 thermistor inputs
  • 6 MOSFET outputs with PWM control
  • fast low latency SPI compatible interface
  • interface requires minimum number of pins
