Endstop
Revision as of 09:57, 7 March 2013 by Danielpublic (talk | contribs) (Initial creation with overview (used the Gen3 desc.) and different types. Needs pic of optical endstop in situ.)
RepRap's Cartesian axes all need a datum (also known as home position or end-stop) to reference their movements. At the start of each build each axis needs to back up until the datum point is reached. The switches also help protect the machine from moving past its intended range and damaging itself.
Mechanical
These Mechanical Enstops are the most basic form of Endstops, think of it as a ordinary switch, two wires; when connected sends an signal to the electronics.
Parts
Assembled
Z-axis with micro adjuster
Optical
These Optical Enstops observe the lightlevel and reacts to sudden changes.
E.g: Gen7 Endstop.
Gen7 Endstop v.1.3.1
Magnetic
These endstops; Hall effect sensors is a transducer that varies its output voltage in response to a magnetic field. Hall effect sensors are used for proximity switching, positioning, speed detection, and current sensing applications.(--Wikipedia)
E. g: Hall-Θ.
Hall-Θ
Hall-Θ
