EI3
Not Open Source
As stated in the RepRap Wiki Policy, a wiki page that describes a product offered for sale must provide source files for that product. This page is missing at least these item(s)
There might be more items missing. If you want to help improve this design, please find source files for these missing items and upload them to this wiki, or link to the repository containing them. In accordance with the Deletion policy, an admin will review this page in about three weeks to determine if it should be removed or not. If source files are not uploaded by the proposed delete date, this page will be removed from the wiki. Proposed delete date: 16 April 2017 Questions about this tag can be addressed on this page's discussion page or on the Administration, Announcements, Policy forum. |
Description | Based on prusa i3.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | none
External Link |
Assembly instructions
- Assembling hotend carriage 01-A-9
- Mounting motor to hotend carriage 02-B-6-1
- Left Z-carriage 03-B-7
- Right z-carriage with motor 04-B-5
- Bottom board with Y-carriage 05-B-4
- Bottom crose frame 06-B-6-3
- Bottom frame and side frame 07-B-6-2
- Mount a wheel to front of bottom frame 08-B-2
- Mount the motor to bottom frame 09-B-3
- Horizontal frame(X Axis) 10
- Axle sleeve of z-axis 11-B-4-1
- Top frame ,lead screw of z-axis, z-motor 12-B-4-2
- Extruder motor and clip 13-B-7-1
- Mount (hotend , bottom board, x-belt, y-belt) to frame 14
- Control panel 15-A-6
- Main board heating bed , limited switch 16-A-10
Firmware
CAD File
please download CAD file from this link
Circuit diagram
- EI3 single extruder
- EI3 dual extruder
- EI3 triple extruder
Product Specifications
Parameters | Description |
Structure | Aluminum profiles(black) |
Frame | Metal |
Print Size(X Y Z) | 200×200×200mm/200*280*200mm |
Layer Resolution | 100 Microns |
Print Precision | 0.1-0.4mm |
Print Head | Single/Dual/Triple |
XY Axis Positioning Accuracy | 0.012mm |
Z Axis Positioning Accuracy | 0.004mm |
LCD Screen | YES |
Nozzle Temperature | 210℃(MAX 260℃) |
Power Supply | DC 12v/250W |
Connection | SD Card or USB |
OS | Windows XP,Windows Vista,Windows 7,MAC OX |
Software | Repetier-Host,Cura,Slic3r |
Material Type | PLA,ABS,HIPS,Wood,PVA,Nylon,Flexiable PLA,Copper fill (metal) |
Material Specifications | 1.75mm |
Exreuder | Full Metal The Newest Design |
Nozzle Size | 0.2 0.3 0.4 0.5mm |
Machine Size | 430×440×400mm |
Full Kits Packing List
A Floor | Units |
2040 Aiuminum Extrusion 420mm (2040型材 420mm) | 2 |
2040 Aiuminum Extrusion 400mm (2040型材 400mm) | 1 |
2020 Aiuminum Extrusion 400mm (2020型材 400mm) | 1 |
2020 Aiuminum Extrusion 380mm (2020型材 380mm) | 1 |
Threaded Rods 380m (丝杆 380mm) | 1 |
Aluminum Wires Holder (型材藏线管) | 3 |
2040 Aluminum Extrusion 150mm (2040型材 150mm) | 2 |
Acrylic For LCD Display (亚克力 -显示屏) | 2 |
2004 LCD Display | 1 |
screw Kits A-6 (螺丝包 -A6)EI3 -A6.jpg | 1 |
Acrylic For L Alunimun Connector (压克力 - L型) | 2 |
screw Kits A-7 (螺丝包 -A7)EI3 -A7.jpg | 1 |
Acrylic For End Stop (亚克力 -限位开关) | 2 |
screw Kits A-8 (螺丝包 -A8)EI3 -A8.jpg | 1 |
X Carriage -Holde (亚克力 -X轴马车) | 1 |
screw Kits A-9EI3 -A9.jpg | 1 |
B Floor | Units |
Step Motors (电机) | 4 |
Acrylic For Y Axis Front (亚克力 -Y轴前) | 2 |
Kits - B2 (螺丝包 -B2)EI3 -B2.jpg | 1 |
Acrylic For Y Axis Black (亚克力 -Y轴后) | 2 |
Kits - B3 (螺丝包 -B3) EI3 -B3.jpg | 1 |
Acylic For Heat bed Holder (亚克力 -热床底座) | 1 |
Kits - B4 (螺丝包 -B4)EI3 -B4.jpg | 1 |
Acrylic For copper Holder (亚克力 -铜螺母) | 1 |
Kits - B4 -1 (螺丝包 -B4-1)EI3 -B4-1.jpg | 1 |
Acrylic For Z Aixs Step Motor (亚克力 -Z轴电机座) | 3 |
Kits - B4 -2 (螺丝包 -B4-2)EI3 -B4-2.jpg | 2 |
Belt (皮带) | 2 |
Wires Protection (绕线管) | 1 |
Kits - B5 (螺丝包 -B5)EI3 -B5.jpg | 1 |
E3d & Cool Fan & Screw Kit B-6-1 EI3 -B6-1.jpg | 1 |
Gift Kits(礼物套件) & Screw Kit B-6-2 EI3 -B6-2.jpg | 1 |
L aluminum Connector(L型材连接器) & Screw Kit B-6-3EI3 -B6-3.jpg | 1 |
Tools (小工具) | 1 |
Acylic For Z Axis Left Holder (亚克力 -Z轴左) | 1 |
Kits - B7 (螺丝包 -B7)EI3 -B7.jpg | 1 |
Feeder (送丝机 -B7 -1)EI3 -B7-1.jpg | 1 |
Power Supply (电源) | 1 |
C Floor | Units |
End Stop (限位开关) | 3 |
Step Motors Wires (电机线) | 4 |
Wires of power supply (电源线) | 1 |
Plug (插头) | 1 |
USB Cable (USB线) | 1 |
USB Cable (USB线)) | 1 |
Heat Bed (Mk3热床) | 1 |
PTFE Tube (四氟管) | 1 |
Filaments (耗材) | 2 |
Where to Buy
Help and Support
- More technical support: [1]
- This printer have no any printed part, but if you want to print some parts by yourself,
- please download the stl file from here:[2] [3][4][5][6]
Photos
Videos
Unboxing Video - HE3D EI3 3D Printer: 1 - EI3 3D Printer <videoflash>Nu__clyW1vs<ideoflash>
