Decapede
Revision as of 17:01, 31 March 2013 by Armanicreations (talk | contribs)
Decapede 10 motor controller with 20A FET and RepRap expansion
Release status: unknown
Decapede 1.0
Summary
Decapede Electronics is a low-cost 10 stepper motor controller and driver. A 20 amp 24VDC driver is also added for one standard drive motor. It is fully open source, and compatible with Arduino mega 2560 boards, all revisions. We will also release an open source firmware based on sprinter than accepts Arduino version 1.01.
A reprap expansion board also allows for 8 controlled outputs like fans, and 8 thermistor reads. It was developed and funded by Armanicreations and Industries3D.
Discussion forum on Reprap.org http://forums.reprap.org/read.php?2,193415 Documentation/Updates on Armanicreations.com http://armanicreations.com/main/decapede-electronics/
Decapede Feature I - 10 Stepper output
Each board comes with up to 10 G3D stepstick boards attached to a female header socket. This way any broken boards can be replaced. The G3D drivers were chosen because of their greater copper density (2Oz) and ability to reliably control the current with two trimpots.
Decapede Feature II - 1 Massive FET output
A very large FET is provided for driving up to 20 amp and 24VDC. Technically, the load can be 60V/50A, but the wires only support this.
Decapede Feature III - Expansion pins
Two expansion pins are provided capable of feeding 24VDC / 8A into the next board. 5VDC is also fed into 3 pins. Ground connectors are provided. There are 4 free PWM pins, 8 analog pins, and 8 more digital pins on the expansion header.
Decapede Feature IV - Stepper Joiners
For users linking to join multiple stepstick outputs, a joiner is being developed that has two 4-pin female headers and yield a single 4-pin male header output. In this instant the maximum theoretical output would be 4A. This way across all 10 boards, CNC users could drive 4A over 5 axis.
Reprap Expansion Feature I - 4 PWM FETS
Four 1A outputs are provided capable of PWM because they are connected to PWM outputs on arduino
Reprap Expansion Feature II - 4 More FETS
Four more 1A FET outputs are provided but do not provide PWM.
Reprap Expansion Feature III - 8 Thermistor Header
8 Thermistor headers are provided. These headers consume all remaining analog inputs.
Reprap Expansion Feature IV - 4 pin digital IO pins
The remaining pins from arduino were routed for access. Such pins could drive external circuits like the Powerswitch tail to control 120VAC.
Examples of use
Decapede comes out of a need to have a single, simple, and easy to program system for stepper motors. Ideal applications include:
Driving complex robotics with central drive motor Assembling remote control system Low cost factory automation Multi axis CNC machines General robotics prototyping Testing 3D printers/RepRaps with multiple extruders or mixing nozzles We are open to your design suggestions for future revisions. Many have suggested the use of an ARM processor and PIC drivers to allow for greater processing power and we are looking into it.
Credits
Designer and Principal: Michael Armani (Reprap user Simba[1])
Designer: David Jones
Electronics Designer 1: Am Miram
Electronics Designer 2: Miroslav Mrdjan
Naming the device: Reprap user Ugen
