DRV8825 Chip
Revision as of 11:19, 5 November 2017 by Jobo (talk | contribs) (Chip, creation)
The DRV8825 is a 1/32 microstepping stepper motor driver developed and manufactured by Texas Instruments.
The DRV8825 provides an integrated motor driver solution for printers, scanners, and other automated equipment applications. The device has two H-bridge drivers, and can drive a bipolar stepper motor or two DC motors. The output driver block for each consists of N-channel power MOSFET’s configured as full H-bridges to drive the motor windings. The DRV8825 can supply up to 2.5-A peak or 1.75-A RMS output current (with proper heatsinking at 24 V and 25°C).
A simple step/direction interface allows easy interfacing to controller circuits. Pins allow configuration of the motor in full-step up to 1/32-step modes. Decay mode is programmable. Internal shutdown functions are provided for overcurrent protection, short circuit protection, undervoltage lockout and overtemperature. The DRV8825 is available in a 28-pin HTSSOP package with PowerPAD (Eco-friendly: RoHS & no Sb/Br).
Features
  • PWM Microstepping Motor Driver
  • Built-In Microstepping Indexer
  • Five-Bit Winding Current Control Allows
  • Up to 32 Current Levels
  • Low MOSFET On-Resistance
  • 2.5-A Maximum Drive Current at 24 V, 25°C
  • Built-In 3.3-V Reference Output
  • 8.2-V to 45-V Operating Supply Voltage Range
  • Thermally Enhanced Surface Mount Package
NOTE: When using a 24V supply to power low amperage steppers (< 1.5A), microsteps will be 'cogged over' if the DECAY pin is not set to FAST mode. See the datasheet for details on the DECAY pin.
Applications
  • Automatic Teller Machines
  • Money Handling Machines
  • Video Security Cameras
  • Printers
  • Scanners
  • Office Automation Machines
  • Gaming Machines
  • Factory Automation
  • Robotics
Datasheet
[1]
External notes/references
See also
A4988 vs DRV8825 Chinese Stepper Driver Boards
