CygwinBuild
Revision as of 19:54, 26 November 2011 by Glenn (talk | contribs) (catchg)
Building Firmware under Cygwin
Prerequisites
Cygwin should be installed with at least the following packages:
  • wget
  • gcc
  • g++
  • make
  • subversion
  • unzip
Build Process
These are temporary instructions for building the reprap firmware under cygwgin.
  • Run cygwin
  • Choose a location to build the source. For now it should be somewhere without spaces in the path. /usr/src is a reasonable place to do this for now. From the windows filesystem point of view, this will typically be C:\cygwin\usr\src
  • Issue the following commands
  • The output .hex files will be stored in subdirectories of C:\cygwin\usr\src\reprap\firmware\build\16f628
After changes to source code, subsequent builds can be executed by just re-running the make command.
If re-entering cygwin, to re-build you will first need to issue the following commands:
  • cd /usr/src/reprap/firmware
  • PATH=${PATH}:`pwd`/sdcc/bin
Then the make command can be executed as necessary.
Updating code to get the latest version
  • svn update devices
-- Main.SimonMcAuliffe - 19 May 2006
