Coupling
Revision as of 08:05, 7 November 2014 by Traumflug (talk | contribs)
Coupling
Vitamin
Wikipedia none
CNC Couplings
High quality couplings are often made from Aluminium. Different types exist.
(please insert examples with pictures)
Polymer Couplings
In several cases a sort of plastic tube have been used as a coupling between the motor shaft and the threaded rod.
Reprappro-mendel-z-axis-motor-tube.jpg from RepRapPro_Mendel_z_axis_assembly
  • aquarium tubing
    • silicone tubing 4mm inner diam. - 6mm outer diam.
    • polyurethane tubing
    • pvc
  • heatshrink tubing 3:1 ratio (12mm to 4mm) with adhesive
  • vinyl end cap from hobby rc cars 4mm inner diam. - 10mm outer diam. - 22mm long
<videoflash>QVA5KSnD7tw</videoflash>
As mentioned in this thread : http://forums.reprap.org/read.php?283,151801,151801
