Clonedel
Revision as of 21:50, 5 March 2011 by Chronomex (talk | contribs) (Created page)
What is the Clonedel?
The Clonedel is a RepStrap design which is essentially a Prusa Mendel that is modified for easy casting.
Where did these parts come from?
If you got your parts from Metrix Create:Space, they were cast out of a two-part urethane cold-casting plastic compound, called Smooth-On Smooth Cast 325.
The original (positive) masters of these parts were printed on a Zcorp Z400 powder printer at Metrix Create:Space in Seattle around the beginning of March 2011. The design is from Mark Ganter’s lab at the University of Washington, and is a modification of the Prusa Mendel for easy casting.
These parts were printed from the designs located on our GitHub page.
How do I turn this into a printer?
Tools and Supplies
  1. One set of parts
  2. Drill bits:
    1. 3mm
    2. 4mm
    3. 8mm
  3. Tap
Instructions
  1. Remove the parts from the shipping container.
  2. Locate a drill press and drill out most of the holes.
