Clone wars: Ronquío
is under construction
Intro
- This printer is being constructed at and to University of Jaén and this is in the clone wars project
- Clon number XX
Mentions
- José Antonio Pérez Caparrós
Record
Printed Parts
Full structure
Picture | Piece (STL) | Quantity | Comments |
Bar Clamp | 8 | Original Bar Clamp | |
frame vertex with foot | 4 | original frame vertex with foot | |
Frame vertex | 2 | Original Frame vertex | |
Y motor bracket | 1 | Original Y motor bracket | |
z motor mount | 1 | Z motor mount | |
belt clamp | 2 | Belt clamp | |
Belt clamp nut holder | 2 | Belt clamp nut holder | |
Bearing guide | 3 | Bearing guide | |
LM8UU Holder | 3 | LM8UU Holder | |
jonaskuehling_x-ends_threadedrod_idler | 1 | Ends threadedrod idler | |
ends_threadedrod_motor | 1 | Ends threadedrod motor | |
x-carriage | 1 | X carrige | |
coupling | 2 | Coupling | |
endstop-holder | 3 | Endstop-holder |
Extruder: Jonaskuehling
jonaskuehling_gregs-wade-v3_jhead | 1 | Greg's Wade reloaded | |
biggearmod_fixed | 1 | Big gear | |
smallgearmod_fixed | 1 | Small gear |
Vitamins
In the area of self-replicating printers (repraps) are called vitamins to the parts that non-printable and you have buy them.
Vitamins for extruder
Picture | Piece | Quantity | Comments |
M8 bolt | 1 | 1 to extruder |
Threaded rods
In total needed 6 M8 threaded rods 1m long. It should be cut to the following sizes:
Smooth rods
We are needed 6 rods, of the following sizes:
Pictures
Videos
History
- 11/16/2012: Received printed parts set from multiXtruder
- 11/28/2012: Buyed nut, washer, bolt, grub screw, threaded rod, smooth rod, vinyl tubing, bouncy, clamps, terminals, power supply Tooq 500W, etc..
- 11/03/2012: Received RAPMS 1.4 wiht Clon Mega2560, LCD 20x4, Keypad v1.0, Thermistor 100K, 2x Axial Fan 50x50x12mm 12V, 2m PTFE tubing and Pneufit straight adaptor from Reprapworld.
- 11/05/2012: Received 4x Allegro 4982 with heatsink, Thermistor, Heat Bed MK2, 3x Endstops, 5x Nema17, Jhead Mk V-B, wires, 2x pulleys, 2m timing belts, bearing 608zz and LM8UU, hobbed bolt Hyena, 2x ABS 1kg and PLA 1kg from LEAPto3d.
- 12/07/2012: Received kapton tape from Incopia2.
- 12/08/2012: Rods cut and revise plastic pieces.
- 12/13/2012: Solder Allegro 4982 and embedded nuts.
- 12/18/2012: Assembly basic structure, it absence axis X
Links
Proyecto Clone Wars |
