Chimera/ua
Revision as of 08:49, 23 January 2019 by Edlab (talk | contribs)
Chimera Steel
Стан випуску: Дiючий
Опис 3D printer with two extruder and 200*200*300mm build area.
Ліцензія GPL 2.0
Автор Cifero
Співавтори
На основі H-bot
Категорії RepRap machines
CAD моделі ні
Посилання на зовнішній ресурс Build instruction
Chimera Steel
Introducing the Chimera Steel. The portable dual extruder 3D Printer.
Status
The Chimera Steel is currently ready to be built by anyone wanting one. I am currently working on a build guide, but all the files to laser cut and print the parts required, as well as the BOM and a complete CAD model are available on the github repository.
Specifications
Outer dimensions:
Laser cut version
  • Only 400mm x 350mm x 450mm
Build Area:
  • 200mm x 200mm x 300mm (If using provided firmware)
Features
  • It can be 3d printed, or Laser cut (Check other GitHub Branches)
  • It can print all of its own parts.
  • Designed to use the e3d chimera or cyclops hotend
  • Internal power supply
  • Internally mounted extruders bowden setup
  • Has optional CNC and Laser cutter/engraver attachments (Currently not released)
