Chimera/ru
Chimera Steel
Release status: Working
Description | 3D printer with two extruder and 200*200*300mm build area.
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Chimera Steel
Introducing the Chimera Steel. The portable dual extruder 3D Printer.
Status
The Chimera Steel is currently ready to be built by anyone wanting one. I am currently working on a build guide, but all the files to laser cut and print the parts required, as well as the BOM and a complete CAD model are available on the github repository.
Specifications
Outer dimensions:
Laser cut version
- Only 400mm x 350mm x 450mm
Build Area:
- 200mm x 200mm x 300mm (If using provided firmware)
Features
- It can be 3d printed, or Laser cut (Check other GitHub Branches)
- It can print all of its own parts.
- Designed to use the e3d chimera or cyclops hotend
- Internal power supply
- Internally mounted extruders bowden setup
- Has optional CNC and Laser cutter/engraver attachments (Currently not released)
