Chimera
Revision as of 09:45, 23 January 2019 by Edlab (talk | contribs)
Chimera Steel
Release status: Working
3D printer with two extruder and 200*200*300mm build area.
unknown
Chimera Steel
Introducing the Chimera Steel. The portable dual extruder 3D Printer.
Status
The Chimera Steel is currently ready to be built by anyone wanting one. I am currently working on a build guide, but all the files to laser cut and print the parts required, as well as the BOM and a complete CAD model are available on the github repository.
Specifications
Outer dimensions:
Laser cut version
  • Only 400mm x 350mm x 450mm
Build Area:
  • 200mm x 200mm x 300mm (If using provided firmware)
Features
  • It can be 3d printed, or Laser cut (Check other GitHub Branches)
  • It can print all of its own parts.
  • Designed to use the e3d chimera or cyclops hotend
  • Internal power supply
  • Internally mounted extruders bowden setup
  • Has optional CNC and Laser cutter/engraver attachments (Currently not released)
