CAM Toolchains
Revision as of 22:37, 22 September 2013 by Pknoe3lh (talk | contribs) (falsee to false)
Java development
THIS page is an extremely rough draft. You can help us improve it. (Someday this page will document many of the known-working systems. A few known-working systems are already documented at RepRap Options).
Alternative Build Documentation Build Documentation
You might also want to look at Builders/Alternative host software. Perhaps some or all of that page should be merged into this page. (Discuss)
You might also want to look at Host software Variations . Perhaps some or all of that page should be merged into this page. (Discuss)
Overview
A RepRap CAM toolchain consists of all the software elements needed to create printed 3d models from CAD models to firmware. To help visualize this for new users, consider the flow chart below:
CAM toolchain
A hypothetical software/CAM process for a new design would be:
  1. Design a new 3D model in a CAD package (ex: openscad, FreeCAD, ProEngineer, SolidWorks)
  2. Export the design's geometry to a .stl file
  3. Generate motion paths & extruder commands in GCODE format by means of a "slicing" program (ex: skeinforge, repsnapper, SFACT)
  4. Use a host software package to communicate the GCODE to the printer (ex: printrun, repsnapper, replicatorG, Repetier-Host)
  5. Determine how your printer reacts to the GCODE by configuring the firmware for your printer controller (ex. FiveD, Sprinter, Teacup, Marlin, or your very own!)
The lists below contain various toolchain components available and provides a comparison of their features, compatible components and how to get them.
It should be noted that a comparison of CAD modeling programs is outside of the scope of this article. CAM toolchains are generally CAD program agnostic because they can accept standard STL models as input which almost all CAD programs can export directly or through plugins. See Useful Software Packages for a list of various CAD related software
Working Configurations
There are a number of working configurations for RepRap. Please do yours up in a new wiki page, and then add the text
[[Category:Working Configuration]]
to that page to add it to the existing list.
Firmware
Here is a brief list of active firmware for repraps:
For more details, see List of Firmware
RepRap Drivers
Driver Author(s) Compatible firmware(s) Manual movement? Manual extruder control? Manual stepper disable? Manual heated build platform control? Live GCode terminal? SD card upload? GCode input? Step-NC input? Integrated GCode compiler? Documentation Download
EMCRepRap EMC and RepRap.org Linux PC true false false wiki page wiki page
RepRap Host Software RepRap.org 5D GCode Interpreter, FiveD on Arduino, more? true true false true false true false true install guide, user manual dev
RepSnapper Kulitorum et al. 5D GCode Interpreter, 3D GCode Interpreter true true true
use a Custom Button
true
use a Custom Button
true true false true manual windows, src
ReplicatorG RRRF Makerbot, 5D true true true true false true true false true install guide, user manual stable
send.py (bundled with SkeinForge) Brendan Erwin and John Gilmore 5D GCode Interpreter, 3D GCode Interpreter false false false false false false true false false user manual builds
Printrun AKA Pronterface Kliment Sprinter, ... true true true true true true true false Github
GCode-utils Ralith 5D GCode Interpreter?, 3D GCode Interpreter? true true true false false Website src, linux binaries
Repetier-Host repetier Repetier-Firmware, Sprinter, Teacup, Marlin, ... true true true true true true true false true User manual Windows Linux Mac OS X
RebRep RebRep Sprinter, ... true true false false true false true false false Docs Windows Linux
OctoPrint foosel Marlin, Repetier, ... true true true true true false true false Website Github
GCode Simulator & Printer mdietz Sprinter, Marlin, ... true (Android Version) true (Android Version) true (Android Version) true (Android Version) true false false false false Website PC Version Android Github
CNC GCODE Controller pknoe3lh Marlin, .... true
for complex Milling
but Gcode used for Milling, PCB, ..
true true
(Postprocessor)
false link link
for complex Milling
Template:Falsee false false true false
true true
(Postprocessor)
false link link
for complex Milling
true true
(Postprocessor)
false link link
CNCGcodeController pknoe3lh Marlin, .... true
for complex Milling
true true
(Postprocessor)
false link link
Note: some drivers such as the RepRap Host Software are listed here and under GCode compilers as they serve both functions however for comparison purposes their features have been split into the relevant tables.
GCode, Etc. Compilers
Compiler Author(s) Compatible firmware features STL input? Multiple STL input? Step-NC input? RFO input? GCode output? Step-NC output? RFO output? Compilation Speed Documentation Download
Reprap host software RepRap.org 5D true true false true true false true average install guide, user manual dev
RepSnapper Kulitorum et al. 5D, 3D true true false true false fast see table above see table above
SkeinForge Enrique 5D, 3D true false false true false false average manual latest builds
Netfabb Engine Netfabb true very fast latest release
SuperSkein MaskedRetriever true true fast src, downloads
Slic3r alexj 5D, 3D true false false false true false false fast manual latest builds
Related
  • Template:My_Toolchain
  • x2sw is a host software toolchain bundle -- including Slic3r, Skeinforge, and Printrun -- packaged together in a Windows installer.
