Builders/Replath
Revision as of 00:10, 19 January 2013 by DavidCary (talk | contribs) (Output: SNAPComms)
Replath in Linux
Introduction
  • Replath is a program that can plot various 2D file formats either directly to a RepRap or to a GCode file.
  • Replath is written completely in Python and uses the wxWidgets (wxPython) user interface in conjunction with SDL (pyGame).
Tutorial
There is a work in progress Replath PCB Making Tutorial
Supported Formats
Import
Output
  • SNAP RepRap - Direct serial SNAPComms SNAP RepRap control
  • ITL File - Replath native toolpath format
  • GCode File - Standard machine toolpath language
  • SVG File - (Work in progress)
Download & Install
Currently only available from svn. I will make a nice Windows package as soon a Windows support is completely stable.
SVN Path : https://reprap.svn.sourceforge.net/svnroot/reprap/trunk/users/stef/replath/
Linux
Install Dependencies
This is for Debian/Ubuntu, others have similar commands
sudo apt-get install python-wxgtk2.6 python-pygame
You will also need to install the pyRepRap library.
System Wide Installation
svn checkout https://reprap.svn.sourceforge.net/svnroot/reprap/trunk/users/stef/replath/
cd replath
./setup.py build
sudo ./setup.py install
Run 'Replath' in the 'Graphics' menu or run 'replath' in a terminal.
Local Installation
Use this for testing or for enhancing the application.
cd replath
./setup.py install --home=${PWD}/installation
Run 'replath' in the now new directory 'installation/bin'.
Windows
I am working on a binary package.
Screenshots
Pen fill gerber
Replath in Linux
DXF file
Replath in Windows
Isolation milling gerber
Replath Isolation Path
Future Ideas
  • Toolheads
    • Laser etching / cutting
    • Paintbrush
      • 2D (work slightly in progress)
      • 3D - Paint extruded objects
    • Syringe
      • Icing a cake
  • Interface
    • Implement in OpenGL? - Allow 3D work
