Builders/McMaster-Carr Part Numbers
This is a preliminary list of McMaster part numbers. There may be misbuys or cheaper options. This list may not be complete if you're using NEMA 17 motors and/or are using bolts instead of studding in the Y-Axis Assembly.
Screws
8 M3 12mm screw 92005A122 29 M3 16mm screw 92005A126 22 M3 20mm screw 92005A128 109 M3 25mm screw 92005A130 16 M3 25mm screw NEMA17 92005A130 13 M3 30mm screw 92005A132 20 M3 40mm screw 92005A135 3 M3 50mm screw 92005A137 10 M5 25mm screw 92005A330 13 M5 30mm screw 92005A332 4 M5 50mm screw 92005A342 3 M8 25mm screw 92005A530
19 M5 8mm grub screw 91390A119 10 M5 grub screw 91390A119 --------? (assuming this is also 8mm)
1 40mm long piece of M6 brass bolt with a 3mm hole drilled right down the middle 93270A455 (extruder heater barrel)
Nuts
197 M3 nut 90695A033 50 M5 nut 90695A037 4 M5 nut NEMA23 90695A037 91 M8 nut 90591A161 2 M8 nut ifstudding 90591A161
2 M6 dome nut 91982A250 2 M6 half- or press-nut 90695A038 2 M8 half-nut 90591A161
2 M5 Nyloc nut 90576A114 1 M5 nyloc nut 90576A114 2 M8 nyloc nut 90576A117
Washers
364 M3 washer 91166A210 32 M3 washer NEMA17 91166A210 4 large M3 washer 91100A120 32 M5 washer 91166A240 8 M5 washer NEMA23 91166A240 1 M6 32mm o/d washer ----------? (Hardware Store) 2 M6 washer 91166A250 79 M8 washer 91166A270 2 M8 wide aka fender washer 91100A160
Steel Rod
16 8mm diameter 500mm long bright steel rod 5544T27 (6 6ft lengths)
Studding
4 M8 400mm studding 93000A573 (5 2m lengths) 1 M8 500mm studding 93000A573 8 M8 600mm studding 93000A573 2 M8 650mm studding 93000A573 2 M8 70mm studding ifstudding 93000A573 1 M8 80mm studding 93000A573 1 M8 studding 110mm 93000A573
Ball Chain
3 1200mm of 3.5mm ball chain (trade size 6) 3606T119 1 2200mm of 4.5mm ball chain (trade size 10) 3606T121
Springs
3 8mm i/d compression spring approximately 16mm long 9657K155 4 small, stout springs ------------?
Bearings
7 608Z skate bearing -------RRRF? *or* 2 packs of steel metric balls (aka BBs) 9292K38
1 625ZZNSK bearing --- 6153K69
Miscellaneous
1 PTFE tape 4591K11 3mm drill bit 2958A61 Cement 9372K22 1 35mm piece of 10mm diameter PTFE rod with a 3mm hole drilled down the centre 8546K42 (7/16ths inch diameter substituted)
Other Hardware
2 5mm i/d soft plastic tubing, approx 22mm long ----- Hardware store 1 thick, solid, insulated copper wire --- Hardware store/Radioshack 1 gear motor ----- RRRF 2 hole socket strip ----- Radioshack
