Brainwave
Revision as of 21:19, 26 May 2014 by Geeetech (talk | contribs) (How to get it)
Brainwave is a low cost controller for Reprap 3D printers derived from the well known Sanguinololu. The primary design goal was lower cost, achieved by providing only the minimum required components for a single extruder printer. It can be used to drive a cartesian or delta style printer.
Features:
  • Small footprint: only 60mm x 79mm!
  • 12V power input
  • Micro USB connector
  • All connectors at edge of board, vertical or right-angle connectors will fit.
  • Atmel AT90USB646 microcontroller w/ USB bootloader
  • 1, 2, 16 or 32x microstepping @ up to 800mA
  • Dual Z-axis connectors
  • Optional per channel current attenuation
  • Heated bed support with separate power input (up to 24V @ 15A)
  • Integrated heater/thermistor/stepper connector for E channel
  • Fan control
Instructions
  1. Build, buy or borrow a Brainwave
  2. Install Arduino 1.0.2
  3. install the brainwave arduino hardware bundle from github.com/unrepentantgeek/brainwave-arduino into the Arduino hardware directory.
  4. Get Marlin. I am maintaining a branch of Marlin that will compile for brainwave at github.com/unrepentantgeek/Marlin Marlin HEAD has support, but it doesn't always compile cleanly for this board.
Hardware configuration
  1. Set micro-stepping selector jumpers (D1, D2) per channel as follows. Short both for 32x microstepping. Default: single-step.
  2. Set stepper current reference voltages. I = V / 2.55. Default: 1V == 400mA.
Step Mode
D1 D2 Mode
0 0 Full
1 0 Half
0 1 16x
1 1 32x
Software configuration
  1. Open Arduino, find the Marlin directory and open Marlin.ino.
  2. Select 'Brainwave' from the Board menu. Find the Configuration.h file and change DEFAULT_AXIS_STEPS_PER_UNIT to suit your printer (remember, 32x microsteps!)
  3. Power on the Brainwave and connect the USB cable (note: the brainwave will not power up off USB, you need the 12V supply.)
  4. Hold down the PROGRAM button and press RESET, the STATUS led should pulse.
  5. Press the Upload button in Arduino.
  6. After a reset the brainwave will show up as a CDC ACM serial device (/dev/ttyACM[0..9] on Linux) and be ready to accept commands.
Brandon Bowman wrote up an excellent guide for getting the board working under Windows and MacOS: fabbersuw.blogspot.com/2012/12/if-your-brainwaves-got-no-brains-or.html
Known issues
  • It may take a couple of presses of the RESET button to get the firmware to come up after flashing.
  • You may need a thermistor or similar 100k resistance present across the bed and extruder thermistor inputs. Otherwise Marlin may go into a deathloop and you'll never even see a serial device. Even if it doesn't fall on its face it will only sit and complain about too high temp.
how to get it
The Metrix Open Hardware Lab has the Brainwave in stock and available for purchase for $100.
Special thanks
  • Julie Atwood
  • Matt Westervelt
  • Frederik Hubinette
  • Silas Snider
  • Johann Rocholl
  • JP Sugarbroad
  • Austin Appleby
  • Richard DeLeon
  • Plamena Milusheva
  • Mark Ganter
  • Brandon Bowman
How to get it
geeetech.com - provide Brainwave.
