Bill of Material Tiny Cut
Revision as of 17:38, 17 November 2015 by Phd0 (talk | contribs) (Laser tube)
This is the Bill of Material Tiny Cut
Laser
Laser tube
http://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20151117133722&SearchText=40w+laser+tube
http://www.ebay.fr/itm/New-High-Quality-40W-Power-Supply-for-CO2-Laser-Engraving-Cutting-Machine-220V-/330792470660?pt=PCA_UPS&hash=item4d04c48884#ht_1759wt_1270
Water cooling pump
http://www.ebay.fr/itm/12V-DC-Liquid-Water-Cooled-Pump-Tank-f-pc-Computer-CPU-CO2-Laser-cool-system-/170929162068?pt=US_Water_Cooling&hash=item27cc2c0754#ht_3310wt_1031
Flexible water pipe
http://www.ebay.fr/itm/8mm-5-16-1-MTR-CLEAR-PVC-FLEXIBLE-AQUARIUM-AIR-WATER-HOSE-PIPE-POND-TUBING-TUBE-/380416380174?pt=UK_HomeGarden_Garden_PondsWaterFeatures_UK&hash=item5892954d0e#ht_4450wt_1031
Optical part
Laser Head
http://www.ebay.fr/itm/A-set-of-CO2-10600nm-Laser-Head-w-Mirrors-Focus-Focal-Lens-Integrative-Mounts-/180872049290?pt=LH_DefaultDomain_0&hash=item2a1cd0728a#ht_1702wt_1031
Air compresor
Air pump
http://www.ebay.fr/itm/New-Mini-Water-Priming-Pump-DC-3-12V-9V-RS-360SH-Spray-Motor-Pisciculture-/170902508850?pt=LH_DefaultDomain_0&hash=item27ca955532#ht_1846wt_1031
Accessoire
Emergency stop button
http://www.ebay.fr/itm/AC-660V-10A-40mm-Red-Sign-Emergency-Stop-Switch-Push-Button-Mushroom-PushButton-/390506980349?pt=AU_B_I_Electrical_Test_Equipment&hash=item5aec07a3fd#ht_1491wt_899
Safety glasses
http://www.ebay.fr/itm/Protection-Safety-Glasses-Goggles-for-10600nm-CO2-laser-with-CE-CERTIFICATION-/320897958721?pt=LH_DefaultDomain_0&hash=item4ab7024341#ht_1372wt_1270
Laser sight beam
http://www.ebay.fr/itm/12V-650nm-Red-beam-Linear-Laser-Light-/271147084665?pt=LH_DefaultDomain_0&hash=item3f21a02b79#ht_1157wt_1031
Interior light
http://www.ebay.fr/itm/5M-500CM-Warm-White-5050-SMD-Flexible-LED-Strip-Light-300-Leds-IP65-Waterproof-/110940638477?pt=US_Car_Lighting&hash=item19d493cd0d#ht_3637wt_1031
Filtration of fumes
Fan
http://www.ebay.fr/itm/120mm-AC-220V-Sleeve-Bearing-Cool-Case-Cooling-Fan-2PIN-/190500151886?pt=UK_Computing_Case_Fans&hash=item2c5ab1a24e
Fan grid
http://www.ebay.fr/itm/Computer-PC-120mm-Chrome-Silver-Metal-Fan-Wire-Grill-Finger-Guard-Protection-New-/271011527262?pt=AU_Components&hash=item3f198bba5e
Filtres
http://www.ebay.fr/itm/ORIGINAL-HEPA-13-FILTER-H13-EFH-13W-WASCHBAR-AEG-ELECTROLUX-PHILIPS-TORNADO-H-13-/121064026727?pt=LH_DefaultDomain_77&hash=item1c2ffa7267
Base FoldaRap2
Structure
http://www.motedis.com/shop/Nutprofil/20-B-Typ-Nut-6/Aluprofil-20x20-B-Typ-Nut-6::1.html
ALU beam
Electronique
