Belt tensioner
Revision as of 20:47, 18 September 2016 by Robotdigg (talk | contribs) (CAD Files)
Belt tensioner
Release status: unknown
unknown
Belts should be reasonably tight, to ensure minimal freedom of unwanted movement in your extruder and build platforms. If you're creative, you can make belt tensioners with pretty much anything. Belt tensioner also could be very easy as a Tensioner Spring.
CAD Files
TODO: post links to your cad files, so people can actually use your designs!
Tensioner spring available for 6mm, 9mm wide belts 6mm Tensioner Spring 9mm Tensioner Spring
