Belt splitter jig
Revision as of 12:29, 12 October 2009 by Skinnyed (talk | contribs) (New page: The belt splitter jig is needed to cut down wide belts. Mendel uses 5 mm wide belts, and stock belts usually come in either 10 mm or 15 mm widths. The two RP part files for the belt split...)
The two RP part files for the belt splitter can be found in the cartesian bot files.
Name Qty/assembly Total Qty Type
belt-split-jig-10mm-belt-spacer_1off 1 1 RP
belt-split-jig_2off.aoi 1 1 RP
Box cutter/Stanley blade 1 1 Blade
M4x40 cap 4 4 Fastener
M4 nut 4 4 Fastener
M4 washer 8 8 Fastener
