BIQ Opto Endstop
Revision as of 22:40, 8 December 2011 by Bodgeit (talk | contribs)
BIQ Opto Endstop
Revision 0.1
CC BY-NC-SA 3.0
Eagle
Introduction
RepRap compatible Opto Endstop using an Opto End stop with a 0.5mm beam slightly smaller than the HB102 beam wdith of 0.8mm.
The opening of the interrupter is 5mm allowing for a 3mm black perspex interrupter tag designed for use on Huxley Seedling but can be used on All RepRaps.
The output of all three versions is an Open collector active High signal.
Active high means a 1 is made when the end-stop is triggered.
Project goal was to Design:
A small low cost PCB < £1.00 for 3 bare PCBS.
Low cost of components.
With a smaller beam to break.
Wider opening for a 3mm interrupter and little more clearance.
Three circuit build configurations. ECO, standard, and Illuminated.
Reprap Standard mounting centres. (holes)
Get It!
Full Kits
Master Schematic of board
Master CCT of the PCB.
Files
Schematics
ECO Schematic
(easy to build Discreet components)
The Led is on all the time for setting up your end-stops.
Once the RepRap is set-up the link can be removed as you do not need to see the led going off/on.
In the same way your scanner or paper printer has not got a Led on its end stops.
An open collector drive gives better noise immunity.
(however adding a 10K surface mount pull up resistor is an option.)
Standard Schematic
(more difficult to build Discreet components with one Surface mount resistor)
The Led is off all the time and is only activated when the end stop is triggered.
This gives the same function as most of the other RepRap end stops.
Illuminated Schematic
(difficult to build Discreet components with two Surface mount resistors)
The Led is slightly on all the time and brightens when the end stop is triggered.
Its function can also be enabled and disabled by the link.
Components
Components ECO
Components STD
Components Iliminated
Soldering Instructions
Building 3 ECO PCBs
Building 3 STD PCBs
Building 3 Iluminated PCBs
To be updated with files and build pictures.
