Arduino Mega
Revision as of 22:39, 10 November 2014 by Geeetech (talk | contribs) (where to get)
Quoting verbatim from the Arduino website[[1]]
"The Arduino Mega is a microcontroller board based on the ATmega1280 (datasheet). It has 54 digital input/output pins (of which 14 can be used as PWM outputs), 16 analog inputs, 4 UARTs (hardware serial ports), a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started. The Mega is compatible with most shields designed for the Arduino Duemilanove or Diecimila."
Specifications
This is 400 pixels wide, and on the left.
Summary
  • Microcontroller: ATmega1280
  • Operating Voltage: 5V
  • Input Voltage (recommended): 7-12V
  • Input Voltage (limits): 6-20V
  • Digital I/O Pins: 54 (of which 14 provide PWM output)
  • Analog Input Pins: 16
  • DC Current per I/O Pin: 40 mA
  • DC Current for 3.3V Pin: 50 mA
  • Flash Memory: 128 KB of which 4 KB used by bootloader
  • SRAM :8 KB
  • EEPROM :4 KB
  • Clock Speed: 16 MHz
More details on the Arduino official page[[2]] including the schematic[[3]] and Eagle files[[4]]
NOTE: There is now a newer Arduino Mega: the Mega2560. See the official Arduino page
Resources
  • The offical Arduino Page[[5]]
  • Arduino Software [[6]]
  • Arduino Mega getting started guide [[7]]
  • Slightly more indepth general Arduino guide [[8]]
  • Information on another choice the MegaNano2560
Related Projects
The Arduino Mega is being used in a number of experimental projects as an alternative to the current generation of Mendel electronics, see Circuit board construction. A few examples at the time of writing include:
This area is being developed on an almost daily basis so please conduction a search[[9]] to find the latest information.
where to get
Arduino Mega2560
Arduino Mega ADK
