Abbas
Revision as of 11:28, 14 January 2015 by Hacibot (talk | contribs) (Created page with "ABBAS is the open source 3D printer that is based on Prusa i3 . It has simplified aluminum profile frame. Taht is easy to buy and assmebly than laser cut metal frame . it has...")
ABBAS is the open source 3D printer that is based on Prusa i3 . It has simplified aluminum profile frame. Taht is easy to buy and assmebly than laser cut metal frame . it has 26x26 table area if you need a big printing surface you can build it.
ABBAS 3D Printer
Release status: Working
How to build an ABBAS 3D Printer
This page represents an example development page and showcases many features that can be used in creating new development pages.
Abbas 3D printer is build with openbuild extrusion. Based dimensions are 260x260x200 , but you can scale them as you want .
Goals
Build a fully scalable 3D printer
Big printing area
Low cost as possible
And of course Opensource
Features
Printer Size  : 500mm x 450mm x 500mm Printing area  : 260mm x 260mm x 200mm Print Material  : PLA (1.75mm Default) , Flex Extruder  : Haddeci V1 Direct-Drive Nozzle  : 0.5mm default/0.4mm/0.3mm/0.2mm
Pictures
Forum thread?
Files and Parts
Downloads
5 mm Aluminium  plate
You need  2 Maximus E3D retainer , 1 printed in PLA and 1 in aluminium , thickness of each part must be 3mm
First Print
Raspberry Pi addon.
First print for the Maximus XL 3D printer
<videoflash type="youtube">vu_Uf3a5s4g</videoflash>
