X axis assembly
X axis assembly
Take care as plexyglass is very brittle.
Oil liner bearings or you may encounter missed step problem on Z axis.
z-Axis nut:
An important thing to do here is to ensure that the nut fits into the nut cut-out on the x-axis-plate. This requires a lot of delicate filing before assembly.
General hints:
A problem was experienced where the x-axis-plate and the z-runner-mount are attached to one another. There are laser cut features in two parts, and two mounting holes to allow the bearing fit as shown here Z-runner-mount-fitted 1.jpg
In the recevied hardware, the hole in the x-rib needed to be expanded to repair a collision
