Jello Solution
Jello as a bed adherence method
This solution consists of 10 parts water to 1 part unflavored cooking jello.
How to make
  • Measure 1 part jello to 10 parts of cold water ( purified water works best ) Eg: 10gr of jello to 100ml of water.
  • Mix both thoroughly until no floating particles are apparent.
  • You can store the solution and use a few drops of propolis to stop growth of bacteria.
  • Do not heat or cook the jello
How to use it
Swab some of the solution on the heated bed surface and heat it at least until 60C, print the part, it will pop itself up when the bed cools down.
