I3 power switch and end stops assembly
Bill of materials | The main panel frame assembly | Y-axis assembly | X-axis assembly | Z-axis assembly
Connecting X-axiz and Z-axiz | Power and LCD assembly | Extruder assembly | Heating bed assembly
power switch and end stops assembly | Control Board assembly and wiring | Circuit Diagram
Y Axis
Need parts:
  • 1×endstop switch
  • 1×endstop switch plastic parts
  • 2×M3*16 screw
  • 1×M3*20 screw
  • 3×M3 lock nut
  • 4×M3 flat gasket
Repair Parts
Step 1
Repair the endstop switch with 3.2mm drill.
Step 2
Welding endstop switch and the power switch.
Step 3
Insert heat shrink tube and weld.
Step 4
Heat up the heat shrink tube
Power supply switch assembly
Step 1
First put the power supply cable into the acrylic sheet bottom and take out from Y axis acrylic square hole, and then weld.
Step 2
Power supply plug weld “o” end, Twisted Pair cable weld “-” end, positive is on one side, negetive Is on other side.
Step 3
Insert Twisted Pair cable and connect power supply.
Endstop switch assembly
Y-axis endstop switch
Need parts:
  • 1×Y-axis endstop switch
  • 1×Plastic parts
  • 2×M3*16 screw
  • 1×M3*20scew
  • 3×M3 lock nut
  • 4×M3 flat gasket
Step 1
Insert 2 pcs M3*16 scew and tighten.
Step 2
The end of Y axis back motor M8 rod insert M3*20 scew and then tighten.
X-axis endstop switch
Step 1
If them can not close together, please repair with knife.
Step 2
M3*20scew tighten.
Z-axis endstop switch
Step 1
Limit shrapnel can be removed.
