I3 Y axis assembly
Bill of materials | The main panel frame assembly | Y-axis assembly | X-axis assembly | Z-axis assembly
Connecting X-axiz and Z-axiz | Power and LCD assembly | Extruder assembly | Heating bed assembly
power switch and end stops assembly | Control Board assembly and wiring | Circuit Diagram
Y-axis rear side parts assembly
Need parts:
  • 12,13,14 Y axis,back side thread rod fixed sheet
  • 15,16 Y axis motor sea
  • 10×M3 * 16 screw
  • 10×M3 nut
  • 10×M3 flat gasket
Step 1
Put the 4×M3 Nut into the 15,16parts(yellow mark),look at the picture.
Step 2
Please put 13,14 parts fixed to 12 parts. (M3*16 screws×2,M3 NUT×2,M3 flat gasket×2)
Step 3
Please install 15,16 parts to 12 parts.(M3*16 screws×4,M3 flat gasket×4)
Step 4
Inserted in the left side of the plate and the lower right side of the plate.( M3 * 16 screws×4, M3 flat gasket×4)
Y-axis front side parts assembly
Need parts:
  • 17,20,21,22 Y-axis front side fixed plate.
  • 1×M3*30 screw
  • 1×M3 Lock nut
  • 4×M3 flat gasket
  • 2×Unilateral bearing
Step 1
Please assemble 20,21,22 parts.
Step 2
Put the assembled parts inserted to the 17 parts.
Step 3
Fix the two parts use M4*30 screw× and Installed dish ×1.(look at the picture)
Assembly with the longitudinal parts
Need parts:
  • 2×M8*380mm threaded rods
  • 2×M8*350mm smooth rod
  • 12×M8 NUT
  • 12×M8 flat gasket
  • 6×M8 spring gasket
Step 1
Fix the threaded rods and smooth rods to the Y-axis rear side plate. (look at the picture)
Step 2
Fix the threaded rods and smooth rods to the Y-axis front side plate. (look at the picture) Screw inserted into the hole in the optical axis, fasten the fixing plate 18, 19.,, Plus flat on the mat after tighten the nut.
Y-axis Pulley &the motor assembly
Need parts:
  • 1×NEMA 17
  • 1×Pulley
  • 3×M3*10 screws
  • 3×M3 flat gasket
Step 1
Fix the motor to 15, 16 parts.Pulley wheel and motor shaft is exposed 5mm, tighten the top wire.
