User talk:DaveX
Revision as of 13:51, 25 April 2014 by DaveX (talk | contribs) (Undo revision 123840 by DaveX (talk))
Hello? Is this how you send messages? I was really amazed with your teensy breadboard. Could you make a parts list and a wiring diagram? -- Chimera15
I moved things around and fit it all on one breadboard. I should take a new picture and update Teensy Breadboard. DaveX 04:42, 30 October 2012 (UTC)
Awesome!! This is so great! I'm going to build this. Thank you so much!
I'd recommend trying the Teensy++ 2.0 with the at90usb1287 chip so you have more choices for firmware & more pins to play with. DaveX 03:18, 6 November 2012 (UTC)
Hello, are you still there? I'm trying to compile teacup and running into some problems. I believe I've set everything properly, but when I try to compile I get missing serial.h, and when I moved that file over from the master teacup...I get missing "serial_teensy.c".... Any suggestions?
Thanks....would you mind giving me your email, or facebook or something so I can bug you directly? lol I'm sure I'll have a lot more questions.... Mine is [email protected]. Thanks!
