Template:Firmware Support Cell
Revision as of 14:47, 26 January 2018 by S2KTS (talk | contribs)
??? Yes Partial Experimental No
Usage
If you put:
{| class="wikitable"
| {{Firmware Support Cell | Yes}}
Then you will get:
Yes
As you can clearly see from the usage above, this template will return the table cell with corresponding 'style' attribute. So you cannot use this template without table tag.
Parameters
1
Put the firmware's availability here. The default value is ???. If you put "Yes", "Partial", "Experimental" or "No", the background color will be set for corresponding color. It's case-insensitive.
align
You can override the cell's "text-align" attribute with this parameter. The default is center.
style
You can add or override the cell's "style" attributes with this parameter.
