RAMPS LCD
Revision as of 22:18, 20 November 2014 by Avdwege2003 (talk | contribs) (Where to get it)
RAMPS with LCD
Hook up a LCD display to your RAMPS setup
GPL
This page will guide you on how to hook up a LCD display to your RAMPS. Most LCD displays have 16 pins to control the display. They are either placed on the upper side of the PCB or on the left. Make sure you have the correct type of LCD display before starting.
Requirements
  1. LCD display preferably 20x4 or 20x2 characters/lines.
  2. RAMPS with Marlin firmware
  3. Some wiring
  4. A 10K trimpot is recommended for contrast adjustment
Where to get it
How to build it
We will have to connect 8 pins on the arduino to the LCD display. After that we need to configure Marlin to use the LCD display.
The following table show the pin assignments we are going to use:
RAMPS pin LCD PIN Purpose
GND 1
5V 2
3 (10K trimpot) Contrast
D16 4 RS
GND 5 R/W
D17 6 Enable
7 Data 1
8 Data 2
9 Data 3
10 Data 4
23 11 Data 5
25 12 Data 6
27 13 Data 7
29 14 Data 8
15 Backlight +
16 Backlight -
Depending on the type of display you need to wire it differntly. Here are two pictures showing how to wire two common types:
Here are two photos: Lcd1 p.jpg Lcd2 p.jpg
Adjust Marlin configuration
Marlin has LCD support by default, you just need to enable it in the configuration.
Find the following code in configuration.h:
 //LCD and SD support
 //#define ULTRA_LCD
Uncomment it, so it states:
 #define ULTRA_LCD
Find the following lines:
 #ifdef ULTRA_LCD
   #define LCD_WIDTH 16
   #define LCD_HEIGHT 2
 #endif
Change LCD_WIDTH and LCD_HEIGHT to match your display characters/lines.
Compile and upload. Happy printing!
