NEMA 17 Stepper motor
A NEMA 17 stepper motor is a stepper motor with a 1.7 x 1.7 inch (43.2 x 43.2 mm) faceplate. The NEMA 17 is larger and generally heavier than for example a NEMA 14, but this also means it has more room to put a higher torque. However, its size is not an indication of its power.
Dimensions
Common Stepper Motor Models
the most commonly used stepper motors in Reprap based 3d printers are the kysan 1124090/42BYGH4803 or the rattm 17HS8401 or Wantai 42BYGHW609
however motors close to NEMA17 size, rated 1.5A to 1.8A or less, 1-4 volts, 3 to 8 mH, 62oz.in (0.44Nm, 4.5kg.cm) or more of torque, 1.8 or 0.9 degrees per step (200/400 steps/rev respectively) can also work.
References
You are welcome to add information on a stepper motor you encounter, but please add only steppers not other motors which were tested to actually work on some or all printer.
The most commonly used stepper motors in Reprap based 3d printers are the kysan 1124090/42BYGH4803 or the rattm 17HS8401 or Wantai 42BYGHW609
Model | Holding Torque | Rated voltage | Shaft | Step angle | Motor length |
42HT47 | 44 N·cm | 2.8 V | Ø 5 mm Dual | 1.8° | 47 mm |
42SHD0404-22 | 52 N·cm | 3.84 V | Ø 5 mm Single | 1.8° | 48 mm |
42BYGH4803(SKU 1124030) | 54.0 N·cm | 4.2 V | Ø 5 mm single | 1.8° | 48 mm |
42BYGH4803-DC (SKU 1124090) | 54.0 N·cm | 4.2 V | Ø 5 mm single | 1.8° | 48 mm |
1040222 | 88 N·cm | 2.6 V | Ø 5 mm single | 1.8° | 48 mm |
LDO-42STH47-1684A | 50 N·cm | 2.8 V | Ø 5 mm single or dula | 1.8° | 47 mm |
4118S-62-07 | 31 N·cm | Ø 5 mm | 1.8° | 34 mm | |
17HS4417 | 40.0 N·cm | 2.6 V | Ø 5 mm single | 1.8° | 40 mm |
SM-42BYG011-25 | 23.0 N·cm | 12 V | Ø 5 mm single | 1.8° | 34 mm |
17HS1011-20B | 28.0 N·cm | 4.8 V | Ø 5 mm single | 1.8° | 34 mm |
17HS3001-20B | 40.0 N·cm | 2.0 V | Ø 5 mm single | 1.8° | 40 mm |
17HS5005-S24 | 44.0 N·cm | 3 V | Ø 5 mm double | 1.8° | 48 mm |
17HS6002-27B | 65.0 N·cm | 4.05 V | Ø 5 mm single flat | 1.8° | 60 mm |
17HD2038E | 45.0 N·cm | Ø 5 mm single | 1.8° | ||
17HS19-1684S | 55 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 47 mm |
KH42JM2B087C | 33 N·cm | 6.7 V | Ø 5 mm single | 1.8° | 42 mm |
SY42STH47-1206A | 31.1 N·cm | 4.0 V | Ø 5 mm single | 1.8° | 40 mm |
SY42STH47-1504A | 55.0 N·cm | 2.8 V | Ø 5 mm | 1.8° | 47 mm |
SY42STH47-1684A | 43.1 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 48 mm |
SY42STH47-1684B | 43.1 N·cm | 2.8 V | Ø 5 mm double | 1.8° | 48 mm |
TB35HT36-1004A | 35.3 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 36 mm |
TB35HT36-1004B | 35.3 N·cm | 2.8 V | Ø 5 mm double | 1.8° | 36 mm |
QSH4218-51-049 | 49 N·cm | Ø 5 mm | 1.8° | 47 mm | |
42BYGH W811 | 47.0 N·cm | 3.1 V | Ø 5 mm | 1.8° | 48 mm |
42HB34F103AB | 23.5 N·cm | Ø 5 mm single | 1.8° | 34 mm |
--- ignore everything below, this page is a work in progress to build a table without all the external linking ---
417-11-48-02 | 7.0 N·cm | Ø 5 mm | 1.8° | 28 mm | |
4018X-07-04 | 11.0 N·cm | Ø 5 mm | 1.8° | 26 mm | |
4118L-25P-07R0 | 48.5 N·cm | Ø 5 mm | 1.8° | 48 mm | |
KH4248-B95101 | 48 N·cm | Ø 5 mm single | 1.8° | 48 mm | |
PK244-01AA | 33.0 N·cm | 5.6 V | Ø 5 mm single | 1.8° | 39 mm |
PX243M-03AA | 20.0 N·cm | single | 0.9° | 42 mm | |
PX243M-01AA | 15.0 N·cm | Ø 5 mm single | 0.9° | 33 mm | |
17H185H-04A | 43.8 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 42 mm |
17H185H-04B | 43.8 N·cm | 2.8 V | Ø 5 mm double | 1.8° | 42 mm |
KH42KM2R001 | 45 N·cm | Ø 5 mm | |||
42BYGHM809 | 48 N·cm | 3 V | Ø 5 mm | 0.9° | 48 mm |
42BYGH404 | 31 N·cm | Ø 5 mm single | 1.8° | 49 mm | |
YH42BYGH47-401A | 55 N·cm | 2.8 V | Ø 5 mm single | 1.8° | 47 mm |
B6524772A | 23 N·cm | 3.9 V | Ø 5 mm single | 1.8° | 34 mm |
1704HS168A | 54 N·cm | 2.8 V | Ø 5 mm single flat | 1.8° | 48 mm |
