Mondrian
Revision as of 10:38, 8 December 2014 by Emmanuel (talk | contribs) (R&D)
Mondrian Documentation
Mondrian
a modular cartesian RepRap
RepRap, XY-head, Other
Here is what I wanted to try among the possibilities to make a Foldable RepRap.
I didn't pursued the XY-head + telescopic Z because I couldn't get my head around how to do it properly at this moment.
But after having seen the Create it gave me some new ideas, for another concept after the FoldaRap, it then evolved toward this cartesian but modular architecture, the folding plane idea will have another name :)
<videoflash>PEaP7HCyGPY</videoflash>
<videoflash>rwdRH7mGj-M</videoflash>
Specifications
  • Printed Parts: 30
  • Non-Printed Parts: +/-400 (counting every washer/bolt/etc)
  • Material Cost: 100€
  • Cost: 600€
  • Printing Size: length of choosen extrusion minus 100mm (=100^3 for 200mm ; 200^3 for 300mm ; 350^3 for 400mm ; etc.)
  • Resolution : XY = 0.0125 mm ; Z = 0,00025 mm with m5 rods
  • Accuracy : 0.1 mm
  • Speed: 50 - 500 mm/s (print-travel, max speed tested yet)
Special features
  • Modular/scalable design (with the same printed part you can build a small cube or a big plotter frame, just choose accordingly your length of extrusions/belt)
  • Based on standard/cheap 20x20mm aluminium extrusion (with 6mm slot)
  • The frame is the linear guide for X, Y, Z axis
  • Easy to build, with few tools
  • 1.75mm Direct Driven Bowden Extruders (dual-head)
  • small footprint : lenght of extrusion plus 40mm (240x240 for 200mm ; 340x340 for 300mm ; etc.)
  • Big Blue Power Switch
Naming Convention
  • Mx_xxx : Mondrian (non-foldable verion), version, size in X, Y, Z (in dm)
  • then you can build things like : M332, M333, M763, or even a huge M71010 (latest prototype of 700 x 1000 x 1000 mm)
To Do
  • dual-extrusion settings
  • x-addon for the chocolate extruder of LaurentF. from LabFab
  • mini-cnc addon [66]
  • foldable Z axis, for a "flat" printer that expand as it print
  • bio-printing
R&D
Exemples of size scaling
Small
Medium
From left to right (3310, 332, 333)
XL
A huge Mondrian, using 70cm and 100cm profiles
External links, media/press, etc.
  1. Github mentioning an "awesome" project among others ^^
More inspiration
<videoflash>qpffEF9Jew0|320|240</videoflash>
  • H-XY
<videoflash>Hc0ADpQ6FBg|320|240</videoflash> <videoflash>FP2ciUBT6nY|320|240</videoflash> <videoflash>uqW3t7c3u4M|320|240</videoflash> <videoflash>_EWfmcWAz-M|320|240</videoflash>
  • Direct sliding on the aluminium frame
<videoflash>5UYMnzXQEtw|320|240</videoflash>
